  3. Trying to build a ethernet gateway but cant set an ip address
8 Posts 3 Posters 1.7k Views 3 Watching
  • J
    J
    JCH
    I have been running a serial gateway for quite a few years now but i have just built a ethernet gateway and am trying to get it up and running.....
    Here is the output from the monitor.
    MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
    4 TSM:INIT
    5 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    13 TSM:INIT:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0
    18 MCO:REG:NOT NEEDED
    601 GWT:TIN:IP=5.0.0.0
    1603 MCO:BGN:STP
    1604 MCO:BGN:INIT OK,TSP=1
    1607 TSM:READY:NWD REQ
    1612 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    1903 TSF:MSG:READ,9-9-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
    1911 TSF:MSG:READ,0-9-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    1916 TSF:MSG:BC
    1949 TSF:MSG:READ,14-9-0,s=3,c=1,t=16,pt=2,l=2,sg=0:0
    1956 TSF:MSG:READ,11-9-0,s=255,c=3,t=21,pt=1,l=1,sg=0:9
    2395 TSF:MSG:READ,14-9-0,s=255,c=3,t=21,pt=1,l=1,sg=0:9
    2509 TSF:MSG:READ,10-9-0,s=255,c=3,t=21,pt=1,l=1,sg=0:9
    2518 TSF:MSG:READ,10-9-0,s=255,c=3,t=21,pt=1,l=1,sg=0:9
    I cant seem to set an ip address, it keeps giving a random one each time i restart it. Any ideas?
    • J JCH
      4 TSM:INIT
      5 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      13 TSM:INIT:GW MODE
      1603 MCO:BGN:STP
      1916 TSF:MSG:BC
      @JCH could you share how you try to set the ip address?
      This is how setting a static ip address is described on the build page:
      #define MY_IP_ADDRESS 192,168,178,66
      • J
        J
        JCH
        Here is my gateway code
        #define MY_RADIO_RF24
        //#define MY_RADIO_NRF5_ESB
        //#define MY_RADIO_RFM95
        #define MY_GATEWAY_W5100
        //#define MY_W5100_SPI_EN 4
        // radio on the same spi bus.
        #define MY_SOFTSPI
        #ifndef MY_RF24_CE_PIN
        #define MY_RF24_CE_PIN 5
        #ifndef MY_RF24_CS_PIN
        #define MY_RF24_CS_PIN 6
        // Enable UDP communication
        //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
        #define MY_IP_ADDRESS 192,168,1,6
        #define MY_PORT 5003
        //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 5
        //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
        // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
        #define MY_MAC_ADDRESS 0xDE,0xAD,0xBE,0xEF,0xFE,0xED
        // Enable inclusion mode
        // Set blinking period
        // Flash leds on rx/tx/err
        #if defined(MY_USE_UDP)
        #include <EthernetUdp.h>
        #include <Ethernet.h>
        • J JCH
          #define MY_SOFTSPI
          @JCH looks similar to https://forum.mysensors.org/topic/9871/ethernet-w5100-gateway-ip-problem/
          How much ram on the Arduino is available after compiling the sketch?
          • J
            J
            JCH
            How do i find that out? Is it this below?
            Sketch uses 24032 bytes (78%) of program storage space. Maximum is 30720 bytes.
            Global variables use 964 bytes (47%) of dynamic memory, leaving 1084 bytes for local variables. Maximum is 2048 bytes.
            • J JCH
              @JCH yes exactly.
              Looks there is plenty of dynamic memory left, so it might not be related to the thread I linked :(
              H 1 Reply Last reply
                @JCH yes exactly.
                H
                H
                hoggin
                @mfalkvidd any luck on figuring this out. I'm have the same issue
                • H hoggin
                  @hoggin I don't know.
