  3. No LAN connection ESP8266 gateway
esp8266
21 Posts 4 Posters 3.9k Views 4 Watching
  • B
    B
    Bramz
    My ESP8266-NodeMCU gateway was successfully flashed using Arduino IDE 1.8.19 with MySensors library version 2.3.2
    The standard sketch was amended only with my credentials and a static IP address as follows:
    #define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "XXX"
    #define MY_WIFI_PASSWORD "YYY"
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_HOSTNAME "ESP8266_GW"
    #define MY_IP_ADDRESS 192,168,178,4
    #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    // Flash leds on rx/tx/err
    The gateway fails to show up in the LAN however and pinging it at the static IP address fails.
    In the serial monitor a push on the reset button gives:
    ets Jan  8 2013,rst cause:2, boot mode:(3,6)
    load 0x4010f000, len 3460, room 16
    tail 4
    chksum 0xcc
    load 0x3fff20b8, len 40, room 4
    tail 4
    chksum 0xc9
    csum 0xc9
    v00049310
    ~ld
    I have tried two other NodeMCU boards and also a sketch with DHCP address assignment but results remain the same.
    Where do I go wrong?
    mfalkviddM OldSurferDudeO 2 Replies Last reply
    • B Bramz
      tail 4
      chksum 0xcc
      tail 4
      chksum 0xc9
      csum 0xc9
      v00049310
      ~ld
      @Bramz is anything connected to any of the gpio pins? Some of the pins control boot behavior.
      B 1 Reply Last reply
      • B Bramz
        tail 4
        chksum 0xcc
        tail 4
        chksum 0xc9
        csum 0xc9
        v00049310
        ~ld
        OldSurferDudeO
        OldSurferDudeO
        OldSurferDude
        @Bramz @mfalkvidd I was curious about this and tried to see if it worked for me. I have the same results as @Bramz ! I can only see the output, though, when I set the monitor baud rate to 74880
        This is the same for the ESP8266Gateway and the ESP8266GatewayMQTTclient examples
        I tried it with the radio connected and without.
        On the Building a WiFi Gateway using ESP8266 one is instructed to "Install CP2102 drivers from here" but "here" is a dead link This is the driver for Windows in order for the nodeMCU to be seen as a serial port. So this is not the problem.
        I tried another example file-->examples-->ESP8266-->interactive and it worked as described. But this is not a MySensors example.
          @OldSurferDude that's strange. The driver download link works for me:
          But if you can flash the esp, you already have working drivers so there is no need to install more.
          We have a lots of users using esp8266 as gateways (I have on such gateway myself) so generally MySensors works well with esp8266. I wonder what the difference could be for your and Bramz's devices.
          The esp8266 uses 74880 baud when it boots (before it loads the sketch) so yes, to see the boot output you must use 74880 baud.
          • mfalkviddM
            Hmm, interesting. On my mobile I get redirected to https://www.silabs.com/developers/usb-to-uart-bridge-vcp-drivers?tab=downloads which works. But on my PC I get an error.
            • mfalkviddM
              btw, docs on the boot mode: https://docs.espressif.com/projects/esptool/en/latest/esp8266/advanced-topics/boot-mode-selection.html#boot-log
                B
                B
                Bramz
                @mfalkvidd In my gateway hardware setup nothing is connected to GPIO pins apart from those used for radio connection as described in https://www.mysensors.org/build/connect_radio .
                Next to that, I have uploaded the sketch to 2 different NodeMCU-boards with absolutely nothing connected.
                I have also successfully uploaded the gateway sketch from two different Linux computers with same negative result. Only the serial monitor does not work in a Linux-ESP8266 connection as Linux apparently does not support the rather uncommon 74880 Baud rate which is forced by ESP8266.
                The funny thing is that about two years ago, using exactly the same hardware, I managed to set up a fully functional gateway with a remote Arduino-Nano temperature node and a visible, static-adressed LAN-connection. As it would not connect to my Domoticz-system at the time, I left it for a while until I tried to revive it recently.
                OldSurferDudeO 1 Reply Last reply
                • B Bramz
                  OldSurferDudeO
                  OldSurferDudeO
                  OldSurferDude
                  @Bramz I am not an expert, but I can verify your findings. This looks like a serious bug in the MySensors code.
                  OSD
                    OSD
                    B
                    B
                    Bramz
                    @OldSurferDude Judging by the many different ways I tried to upload a functional gateway sketch I am beginning to suspect the same. Question is: where did things start to change from my earlier attempts two years ago?
                    OldSurferDudeO mfalkviddM 2 Replies Last reply
                    • B Bramz
                      OldSurferDudeO
                      OldSurferDudeO
                      OldSurferDude
                      @Bramz I'm fairly new to MySensors. As it is supported by volunteers, like you and me and @mfalkvidd, some code doesn't get updated when there's a version change, the code update often happens when someone notices that the code needs to be updated. I suspect that this is the case here.
                      I'd be glad to help out, but not knowing the in's and out's of things, I can pretty much only verify code for which I have hardware.
                      OSD
                      • B Bramz
                        @Bramz see section #1:1 in https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time on how to enable debug logging. After that, please post the serial output here.
                          B
                          B
                          Bramz
                          @mfalkvidd Thanks for your suggestion. I was under the impression that the com port could only be used for one thing at a time: either flashing or monitoring, but apparently this combination is possible. Anyway, I followed the instruction but unfortunately the serial monitor remains completely blank.
                          • electrikE
                            electrikE
                            electrik
                            Did you try an earlier ESP 8266 framework version? Perhaps version 3 or even lower?
                            • electrikE electrik
                              @electrik version 3 will not work. 2.6.2 is required.
                                B
                                B
                                Bramz
                                @mfalkvidd I am not entirely sure what is meant by an ESP framework, but if it refers to the URL which is given in the <Preferences> section of the Arduino IDE under <More Board manager URL's> than this might be the problem.
                                I am now using https://arduino.esp8266.com/stable/package_esp8266com_index.json which leads to a version 3.0.2.
                                What URL should I use for a version 2.6.2 ? Than I will give that a try.
                                • B Bramz
                                  @Bramz yes. Here:
                                  • B
                                    B
                                    Bramz
                                    Blush, blush. Thanks.
                                      @Bramz yes. Here:
                                      B
                                      B
                                      Bramz
                                      @mfalkvidd @electrik Yes! This did the trick for me. Thanks for your guidance.
                                      Probably the instruction to use a version not higher than 2.6.2 has been given somewhere/sometime and I have overlooked it.
                                      The serial monitor remained blank during upload, but when I select 9600 baud and press the reset-button it gives what I think is a healthy response:
                                      ⸮⸮5R⸮⸮64 MCO:BGN:INIT GW,CP=RNNGE---,FQ=80,REL=255,VER=2.3.2
                                      121 TSF:LRT:OK
                                      137 TSM:INIT
                                      151 TSF:WUR:MS=0
                                      174 TSM:INIT:TSP OK
                                      scandone
                                      state: 0 -> 2 (b0)
                                      state: 2 -> 3 (0)
                                      state: 3 -> 5 (10)
                                      add 0
                                      aid 3
                                      cnt
                                      connected with XXX, channel 6
                                      dhcp client start...
                                      ip:192.168.178.46,mask:255.255.255.0,gw:192.168.178.1
                                      403 TSM:INIT:GW MODE
                                      426 TSM:READY:ID=0,PAR=0,DIS=0
                                      458 MCO:REG:NOT NEEDED
                                      ip:192.168.178.4,mask:255.255.255.0,gw:192.168.178.1
                                      1544 GWT:TIN:CONNECTING...
                                      2573 GWT:TIN:CONNECTING...
                                      scandone
                                      3601 GWT:TIN:CONNECTING...
                                      3629 GWT:TIN:IP: 192.168.178.4
                                      3662 MCO:BGN:STP
                                      3680 MCO:BGN:INIT OK,TSP=1
                                      3708 TSM:READY:NWD REQ
                                      3735 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                      pm open,type:2 0
                                      And sure enough, the LAN has detected an ESP device at 192.168.178.4 now.
                                      Secretly, I was hoping that connection to Domoticz would now also work but unfortunately I keep on getting the persistent message:
                                      2022-11-25 11:54:58.598 Error: MySensorsGateway: Can not connect to: 192.168.178.4:5003
                                      However, that probably needs to be adressed in a different topic.
                                        OSD
                                        B
                                        B
                                        Bramz
                                        @OldSurferDude Hope this worked for you too.
                                        • OldSurferDudeO
                                          OldSurferDudeO
                                          OldSurferDude
                                          @mfalkvidd @Bramz @electrik
                                          When I saw 2.6.2 I was thinking the MySensors Library (2.3.2)! It never occurred to me it was the board manager.
                                          So, yes! it works for me. :)
                                          I just checked to see if Domoticz has an MQTT interface and it appears that it does. @Bramz, look into that. Once you have that, then it may be easy to connect other devices, like Tasmota devices, to Domoticz. MQTT requires an always-on computer connected to your network.
                                          I have a headless (needs dummy monitor plug or 3x 75Ω resistors to boot), refurbished computer on which I run Linux OS, then both MQTT and Home Assistant running in Virtual Box.
                                          Thanks everyone!
                                          OSD
