  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 66.3k Views 21 Watching
  • P pii
    @marceloaqno said in 💬 Building a Orange Pi Gateway:
    #define MY_RFM95_CS_PIN 13
    #define MY_RFM95_IRQ_PIN 10
    #define MY_RFM95_FREQUENCY RFM95_915MHZ
    Thank you sooo much. I just did this. But, Now got a new error.
     ERROR Could not open /sys/class/gpio/gpio10/direction
    and when I tried to export pin 10 it says:
    :/sys/class/gpio# echo '10' > export
    -bash: echo: write error: Device or resource busy
    Though yes still I'm able to export/unexport pin 13(just for testing)
    marceloaqno
    Code Contributor
    @pii Try to connect the IRQ pin from the radio to another GPIO on your Orange Pi, for example the GPIO2.
    #define MY_RFM95_IRQ_PIN 2
    • G
      G
      ghck
      There is an issue now with spi interfaces. With the current armbian image we are stuck at the prepare the system part, no /dev/spidev* available, the old method does not work. (There is no /boot/script.bin file, for example.) Does anyone know the solution, could this guide be updated, please?
      • G
        G
        ghck
        More info: https://docs.armbian.com/User-Guide_Allwinner_overlays/
        • R
          R
          Roman
          Hi!
          Installation instructions will be adjusted for Armbian Stretch?
          • G
            G
            giaco456
            I have Mysensors running with nrf24 , I wanted to upgrade Armbian to the latest Stretch. I configured DT overlays by adding
            verbosity=1
            console=serial
            overlay_prefix=sun8i-h3
            rootdev=UUID=bd0ded76-1188-4b52-a20a-64f326c1f193
            rootfstype=ext4
            overlays=w1-gpio uart1 i2c0 spi-spidev
            param_w1_pin=PA20
            param_w1_pin_int_pullup=1
            param_uart1_rtscts=1
            param_spidev_spi_bus=0
            to /boot/armbianEnv.txt. I had spidev working, but not the mysgw. It doidn't give me errors, but i was stuck at !TSM:INIT:TSP FAIL.
            Maybe the problem is that there is no gpio-sunxi in Stretch... I have no idea.
            By the way, i noticed that the new version of Mysensors calls nrf24 transport differently, it is now called --my-transport=rf24.
            Please update the guide for Armbian Stretch.
            • R
              R
              Roman
              Made fix for Armbian Stretch https://github.com/mysensors/MySensors/pull/1200.
              my settings: /boot/armbianEnv.txt
              overlays=w1-gpio uart1 spi-spidev spi-add-cs1
              param_spidev_spi_bus=1
              param_spidev_spi_cs=0
              git clone https://github.com/mysensors/MySensors.git --branch development
              cd MySensors
              and further on the instructions
              • pansenP
                pansenP
                pansen
                wrote on last edited by pansen
                #107
                for anyone creating a gateway on an Orange Pi PC using armbian mainline (4.x Kernel): The fex modifications are not necessary any more. As noted before by @Roman, the device tree needs to be modified.
                If you use the exact same pins as in this guide for the Orange Pi PC, SPI0 needs to be activated instead of SPI1. (Pi Zero and PC are kind of pin compatible, but Zero only has SPI1 routed to the header, whereas the same pins on the PC have SPI0. On top, the Orange Pi PC also has SPI1 but on other pins):
                verbosity=1
                logo=disabled
                console=both
                disp_mode=1920x1080p60
                rootdev=<removed>
                rootfstype=ext4
                usbstoragequirks=<removed>
                Attention: Header pin 26 is different between Pi PC and Pi Zero. On the zero it is PA10 but on the PC it is PA21. I connected the interrupt pin of the nrf24 like in the guide (header pin 26) and changed the configure command accordingly.
                So the full command to use SPI0 and the interrupt connected to header pin 26 of the Orange Pi PC is:
                ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=rf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13 --my-rf24-irq-pin=21 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mysensors
                The rest of the guide is still valid, except that the transport is now called "rf24" instead of "nrf24". @mfalkvidd can you correct this maybe? Also, the -d switch seems to be not existing any more.
                • pansenP
                  pansenP
                  pansen
                  • pansenP pansen
                    verbosity=1
                    logo=disabled
                    console=both
                    rootdev=<removed>
                    rootfstype=ext4
                    Thanks @pansen. I have replaced nrf24 with rf24 for all commands on the page and removed the -d option.
                    • OldSurferDudeO
                      OldSurferDudeO
                      OldSurferDude
                      wrote on last edited by OldSurferDude
                      #110
                      I saw this page and thought I give it a go. So I bought two OrangePi Zero 2. There's a lot of potential (WiFi) as a dedicated gateway. Currently the price is about US$20 on AliExpress (caveat emptor) There are a few flavors of Linux for it. I've dabbled with Armbian, Ubuntu and Debian
                      Another upside is that it doesn't draw a lot of current ~0.5A, though I haven't been successful in getting the radio to run (the reason for me being here) This is also a downside as I suspect the power supply needs to be very close to 5V. Thinking it was a power hog like the RPi, I used a 5V-3A supply. This supply operates on the principle that the load will pull down the voltage. There are dire warnings on the orangepi page about using cheap SD cards, but failed to mention that power supplies have to be matched, too.
                      It has a different CPU than the Orange Pi Zero non-2, the board that is used here.
                      Use the serial interface to configure the board. You're going to be doing all your configuration in a terminal, anyway, so you don't need a monitor or a keyboard. https://www.instructables.com/Setup-Orange-Pi-Using-Serial-Port/
                      The big downside is that the SPI interface is not supported. My research indicates that in order to get it to work one must jump through some serious hoops and being low on the learning curve, those hoops are probably out of my reach. https://forum.armbian.com/topic/21688-tips-on-configuring-double-spi-through-two-chipselects-on-orange-pi-zero-2/
                      The armbian OS has another big downside, WiFi is not supported. Putting a TP-Link nano router configured as a client works, but it's another $30! Why did they even release the OS?
                      So! Was anyone successful in getting the Orange Pi Zero 2 configured as a gateway?
