  3. High power consumption NRF52832 & SI7021
24 Posts 3 Posters 4.2k Views 3 Watching
  • W
    W
    waspie
    wrote on last edited by waspie
    I think that's an accurate description. Range won't be a factor this time in particular as its probably 10 feet (3 meters) away from the parent. I'll grab it and reflash it in a few days with the updated code.
    I see our graphs show identical behavior, interesting.
    edit
    If I want to try out the new code is this the one i'm after:
    https://github.com/mysensors/MySensors/pull/1455
    ? Its a little unclear to me
    N 1 Reply Last reply
    • W waspie
      edit
      N
      N
      ncollins
      @waspie I haven't tried the code from the redesign branch, as there are a lot of additional enhancements that may not have been fully tested yet.
      I've been testing this file on NRF52s, hal/transport/NRF5_ESB/driver/Radio_ESB.cpp, specifically from this commit https://github.com/mysensors/MySensors/pull/1448/files.
      Given the redesign merge request was submitted a few days after this Fix ESB deadlock, the Fix ESB Deadlock might not be that effective. I haven't been testing on NRF51.
      I'd suggest asking on github, as a comment on the NRF5 ESB redesign commit, for suggestions on the best way to test the latest improvements.
      • W
        W
        waspie
        that's the reversion isn't it? so wouldn't that be the same as no changes at all? or is this supposed to be the pre-reversion test fix? i think i'll try that code in 1455. nothing to lose but another cr2032 heh
        good idea on asking, will do
        • W waspie
          N
          N
          ncollins
          @waspie ...potentially. It's a little confusing, to be honest.
          I used #1448 based on this comment in #1445 (the revision commit).
          W 1 Reply Last reply
          • N ncollins
            W
            W
            waspie
            @ncollins 1455 is the latest and greatest
            d00616 replied to use it.
            6 days on no dip (yet)
            edit i guess its 3 days since the spike (plugged in) was on 12/10
            • W waspie
              N
              N
              ncollins
              @waspie Looking a lot better. This node is in the same location that it was before the update?
              • N ncollins
                W
                W
                waspie
                @ncollins
                yep!
                while its only a few days I'm not seeing those dips that you can notice prior to the big drop. might be nothing, might be something. who know!
                • O
                  O
                  Omemanti
                  @waspie said in High power consumption NRF52832 & SI7021:
                  so would it be a good idea to flash all my nodes? got 10 laying around..:)
                  • O Omemanti
                    W
                    W
                    waspie
                    @Omemanti
                    If you're experiencing this issue I'd certainly try 1. I don't know that I'd got hog wild just yet unless they're easy to get to and easy to hook up.
                    • W
                      W
                      waspie
                      I don't know if any of you guys are still around and using this stuff -
                      I moved and am reviving a few of these 51/52 boards that I had built. Prior to moving I had decent luck with all these fixes though I don't quite remember where I was with any of this stuff seeing as it was 3 years ago.
                      I had a few motion sensors and some temp/humd based on these fixes and they were working great, no dips.
                      Not sure any of you will ever see this but hey it all worked.
