  3. High power consumption NRF52832 & SI7021
24 Posts 3 Posters 4.2k Views 3 Watching
  • N ncollins
    @waspie Looks like there is a related issue with NRF51822
    #35 in https://infocenter.nordicsemi.com/pdf/nRF51822-pan_v2.0.pdf?cp=5_4_1_8
    But I don't think you'll need to do hack I listed above (not sure it'll even work for NRF51822). You can probably replace the three lines above with
    NRF_TWI0->ENABLE = 0;
    NRF_TWI1->ENABLE = 0;
    Just be sure to call Wire.begin() before each sensor read. Or if you're using a library, make sure you call the service that calls Wire.begin(), in my case that was sensor.begin().
    I'll try with one of my NRF51 modules tomorrow and report back.
    W
    W
    waspie
    @ncollins said in High power consumption NRF52832 & SI7021:
    thanks, added those lines after reading and an appropriate .begin prior and it compiled and sent and works so far.
    Won't know about consumption for a while - it doesn't act up while I'm watching it... it seems to get stuck at some point (1 week? 2 weeks? 10 days?) and then dies. And yes, it is set to reboot every 24 hours :)
    So it's something else you or I have not pinpointed yet.
    N 1 Reply Last reply
    • W waspie
      N
      N
      ncollins
      @waspie Mind sharing your sketch?
      I've run into a few issues with NRF51 modules:
      • Using attachInterrupt leads to at least 1ma power consumption. This can be worked around with the LPCOMP approach that's mentioned in several threads
      • LPCOMP stops registering interrupts after reading internal battery. Something to do with the hwCPUvoltage call taking over LPCOMP and not restoring initial values. You can just call your LPCOMP activate code after battery read
      Issues with all NRF5 modules:
      • Module completely freezes and rapidly drains battery in high traffic (or poor connectivity) scenarios. There are / were several deadlock issues with MySensors transport code. I don't believe the fix has been merged, but I've been testing with the fixes in this branch https://github.com/mysensors/MySensors/pull/1447 and it seems a lot better. I believe there is a new merge request with even more enhancements/improvements: https://github.com/mysensors/MySensors/pull/1455
      W 1 Reply Last reply
      • N ncollins
        W
        W
        waspie
        @ncollins
        Thanks, I backed off the changed when I read the one pull that got reversed. Hadn't seen there was an update.
        Im not using any interrupts on my NRF51 modules - only si7021/htu21s
        thanks for the update on the PRs. I'll give that a go after I see how long the battery lasts this go 'round.
        So far holding steady at 3+ volts with 3 minute read times but again, it does go for a while before randomly killing itself.
        • W
          W
          waspie
          @ncollins sure:
          be aware, i'm not a coder. i just hack crap together to the point that it works then move on.
          // SUMMARY: This demo sketch runs on MultiSensor Version 7 board with an I2C Si7021 module to transmit temperature, humidity, and battery voltage to a MySensors gateway using MySensors protocols.
          // Note: because this is a passive node, node ID must be set manually to a unique sensor node ID:
          #define MY_NODE_ID 150  // Passive mode requires static node ID
           * Copyright (C) 2013-2017 Sensnology AB
           * Version 1.0 - tekka
           * Passive node example: This is a passive & independent reporting node
          // This demo sketch uses the LowPowerLab SI7021 library and also some of its sample code:  https://github.com/LowPowerLab/SI7021
          // This demo sketch also draws from the MySensor's example MockMySensors sketch.
          // This demo sketch also draws from some of the code posted by smilvert here: https://forum.mysensors.org/topic/7961/why-do-passive-nodes-need-to-set-their-node-id-manually/14
          #define SHORT_WAIT 50
          #include <SparkFunHTU21D.h>
          HTU21D myHumidity;
          // Enable debug prints
          // Enable passive mode
          #define MY_PASSIVE_NODE
          #define MY_PARENT_NODE_ID 0
          #define MY_TRANSPORT_MAX_TSM_FAILURES 2
          #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 3000
          #define MY_TRANSPORT_WAIT_READY_MS 10000
          #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 5000
          //#define MY_RADIO_NRF24
          #define MY_RADIO_NRF5_ESB
          //#define MY_RADIO_RFM95
          #define CHILD_ID_TEMP 0  //definitions contributed by smilvert (see above credit)
          #define CHILD_ID_HUM 1
          // Initialize general message
          #define ID_S_MULTIMETER        28
          //float lastTemperature=0;
          float lastSentTemp=0;
          int lastSentHumd=0;
          //float lastHumidity=0;
          float lastVoltage=0;
          float batteryVoltage=0;
          float temperature=0;
          int humidity=0;
          unsigned long time;
            myHumidity.begin();
            wait(SHORT_WAIT);
          	sendSketchInfo("NRF51822 Temp & Humidity", "1.0");
            wait(SHORT_WAIT);
            present(CHILD_ID_HUM, S_HUM);
            wait(SHORT_WAIT);
            present(ID_S_MULTIMETER,S_MULTIMETER,"Electric Station");
            wait(SHORT_WAIT);
            myHumidity.begin(); //power consumption add
              // get humidity and temperature in one shot, saves power because sensor takes temperature when doing humidity anyway
              float temperature = myHumidity.readTemperature();
              temperature = (temperature*1.8)+32;
              wait(SHORT_WAIT);
              float humidity = myHumidity.readHumidity();
              //temperature = float(temperature*1.8)+32;
              batteryVoltage=((float)hwCPUVoltage())/1000.0;  //take voltage measurement after transmission to hopefully measure lowest voltage that occurs.
          	if ( (temperature > lastSentTemp + .1) || (temperature < lastSentTemp - .1) ) {
          		send(msgTemp.set(temperature,2));
          		lastSentTemp = temperature;
          	if ( (humidity > lastSentHumd + 1) || (humidity < lastSentHumd - 1) ){
          		send(msgHum.set(humidity,0));
          		lastSentHumd = humidity;
            //if ( batteryVoltage > (lastVoltage+.1) || batteryVoltage < (lastVoltage-.1) ) {
              send(msg_S_MULTIMETER_V_VOLTAGE.set(batteryVoltage,2));  //send battery voltage with 2 decimal places
              //lastVoltage = batteryVoltage;
            time = millis();
              if (time > 64800000 ) {
                reboot();
            NRF_TWI0->ENABLE = 0; //possible power consumption adds
            sleep(180000);  //sleep for three minutes
          void reboot() {
            wdt_disable();
            wdt_enable(WDTO_15MS);
            while (1) {}
          • W waspie
            @ncollins sure:
            HTU21D myHumidity;
            int lastSentHumd=0;
            int humidity=0;
            unsigned long time;
              myHumidity.begin();
              wait(SHORT_WAIT);
              wait(SHORT_WAIT);
              wait(SHORT_WAIT);
              wait(SHORT_WAIT);
                wait(SHORT_WAIT);
              time = millis();
                  reboot();
            void reboot() {
              wdt_disable();
              while (1) {}
            N
            N
            ncollins
            @waspie Thanks for sharing. First thing I notice is you can probably remove:
            from your setup(). I believe this is legacy code that is now built in to MySensors / nRF5-arduino, and managed based on the features you're utilizing.
            I just tested power consumption on NRF51822 with SI7021. Similar to your sketch but using the LowPowerLab SI7021 library.
            I didn't have to do any hack or workaround to get ~7uA power consumption.
            I'm using MySensors 2.3.2, SandeepMistry/nRF-Arduino 0.6. Just to be sure, I also reburned the bootloader.
            I will try to get your sketch running on my NRF51, see if I can rule out the specific library as a cause for your power issues.
            #define MY_NODE_ID 68
            #define MY_PARENT_NODE_ID 13
            #define MY_TRANSPORT_UPLINK_CHECK_DISABLED
            #define MY_TRANSPORT_CHKUPL_INTERVAL_MS 2000
            #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 2000
            #define SLEEP_SHORT_MS (5000)
            #define SLEEP_MS 1000 * 60 * 1
            #define REBOOT_HRS 24
            #define REBOOT_MS 1000 * 60 * 60 * REBOOT_HRS
            #define BATTERY_SEND_MS REBOOT_MS
            unsigned long sleepTime = BATTERY_SEND_MS;
            unsigned long lastReboot = 0;
            unsigned long lastBatterySent = 0;
            unsigned long lastTemperatureSent = 0;
            bool firstBoot = true;
            #include <SI7021.h>
            MyMessage     msgBattery( 1, V_VOLTAGE );
            MyMessage msgTemperature( 3, V_TEMP );
            MyMessage    msgHumidity( 4, V_HUM );
            static SI7021 sensor;
              enableReset();
              sensor.begin();
              bool sendBattery = millis() - lastBatterySent >= BATTERY_SEND_MS || firstBoot;
              bool shouldReboot = millis() - lastReboot >= REBOOT_MS;
              const float temperature = float( sensor.getFahrenheitHundredths() ) / 100.0;
              const float humidity    = float( sensor.getHumidityBasisPoints() ) / 100.0;
              sleep(SLEEP_SHORT_MS);
              send( msgTemperature.set( temperature, 2 ) );
              send( msgHumidity.set( humidity, 2) );
              if(sendBattery){
                bool sent = send(msgBattery.set(getInternalVoltage(),3));
                if(sent) lastBatterySent = millis();
              if(shouldReboot){
                lastReboot = millis();
                hwReboot();
              firstBoot = false;
              sleep(SLEEP_MS);
            void present() {}
            float getInternalVoltage(){
              return ((float)hwCPUVoltage())/1000.0;
            void enableReset(){
              NRF_POWER->RESET = 1;
              while (NRF_POWER->RESET != 1);
            • W
              W
              waspie
              @ncollins thanks bud!
              with the htu21 the sleeping consumption is sub 5ua. its been 4 days and hovering around 3 volts. i'm keeping my fingers crossed. Would love to reliably use these. Since I had so much trouble with them I designed and put into use atmega328p boards quite a while ago now so I'm happy with those but I still had a crap ton of these nrf51 and nrf52 boards made thinking i would get a lot of use out of them.
              Things are improving. With some of the more recent developments and the reboot strategy I at least have reliable motion sensors working now. They've been up for about 2 months now, huge improvement!
              • W
                W
                waspie
                it happened...i'm losing it already.
                • N
                  N
                  ncollins
                  I think it's a symptom of the "deadlock" scenario. I had a similar experience with NRF51 soil level sensors that were on the edge of their usable range. Looks like they get stuck in a loop, drain a huge amount of power (these were AA and AAA LiFePO4), trigger undervoltage/brown out, then restart, effectively clearing the deadlock.
                  I'm guessing that high interference or weak signal (too far away) increases the number of transmission attempts, compounding the likelihood of lockup.
                  • W
                    W
                    waspie
                    wrote on last edited by waspie
                    I think that's an accurate description. Range won't be a factor this time in particular as its probably 10 feet (3 meters) away from the parent. I'll grab it and reflash it in a few days with the updated code.
                    I see our graphs show identical behavior, interesting.
                    edit
                    If I want to try out the new code is this the one i'm after:
                    ? Its a little unclear to me
                    • W waspie
                      edit
                      N
                      N
                      ncollins
                      @waspie I haven't tried the code from the redesign branch, as there are a lot of additional enhancements that may not have been fully tested yet.
                      I've been testing this file on NRF52s, hal/transport/NRF5_ESB/driver/Radio_ESB.cpp, specifically from this commit https://github.com/mysensors/MySensors/pull/1448/files.
                      Given the redesign merge request was submitted a few days after this Fix ESB deadlock, the Fix ESB Deadlock might not be that effective. I haven't been testing on NRF51.
                      I'd suggest asking on github, as a comment on the NRF5 ESB redesign commit, for suggestions on the best way to test the latest improvements.
                      • W
                        W
                        waspie
                        that's the reversion isn't it? so wouldn't that be the same as no changes at all? or is this supposed to be the pre-reversion test fix? i think i'll try that code in 1455. nothing to lose but another cr2032 heh
                        good idea on asking, will do
                        • W waspie
                          N
                          N
                          ncollins
                          @waspie ...potentially. It's a little confusing, to be honest.
                          I used #1448 based on this comment in #1445 (the revision commit).
                          • N ncollins
                            W
                            W
                            waspie
                            @ncollins 1455 is the latest and greatest
                            d00616 replied to use it.
                            6 days on no dip (yet)
                            edit i guess its 3 days since the spike (plugged in) was on 12/10
                            • W waspie
                              N
                              N
                              ncollins
                              @waspie Looking a lot better. This node is in the same location that it was before the update?
                              • N ncollins
                                W
                                W
                                waspie
                                @ncollins
                                yep!
                                while its only a few days I'm not seeing those dips that you can notice prior to the big drop. might be nothing, might be something. who know!
                                • O
                                  O
                                  Omemanti
                                  @waspie said in High power consumption NRF52832 & SI7021:
                                  so would it be a good idea to flash all my nodes? got 10 laying around..:)
                                  • O Omemanti
                                    W
                                    W
                                    waspie
                                    @Omemanti
                                    If you're experiencing this issue I'd certainly try 1. I don't know that I'd got hog wild just yet unless they're easy to get to and easy to hook up.
                                    • W
                                      W
                                      waspie
                                      I don't know if any of you guys are still around and using this stuff -
                                      I moved and am reviving a few of these 51/52 boards that I had built. Prior to moving I had decent luck with all these fixes though I don't quite remember where I was with any of this stuff seeing as it was 3 years ago.
                                      I had a few motion sensors and some temp/humd based on these fixes and they were working great, no dips.
                                      Not sure any of you will ever see this but hey it all worked.
