  3. Human presence sensors....
13 Posts 4 Posters 2.7k Views 4 Watching
  • B
    B
    britishbook
    • TheoLT
      TheoLT
      TheoL
      https://esphome.io/components/sensor/ld2420.html I believe the radar model they use is in that artical. It's pretty simple to use. If you preset the zones you get a trigger and read the zone. Not sure if an atmel is fast enough to keep up with the readings of the sensor. But they aren't expensive, they are actual very affordable and fun to play with
      • C
        C
        CodeGarage
        I use similar LD2410 with atmel for 4 years now without any problems. Just configure boudrate little bit lower (via PC connection) then use interrupt pin as triger and uart only for changes in config.
        TheoLT 1 Reply Last reply
        • C CodeGarage
          TheoLT
          TheoLT
          TheoL
          @CodeGarage does it give many false positive or false negatives? I want to mount one under the porch at the frontside. Also did you post this project somewhere?
          C 1 Reply Last reply
          • TheoLT TheoL
            C
            C
            CodeGarage
            @TheoL I have cat and no false at all. But it is not simple to proper design of radon for this kind of sensors. I not posted it anywhere, but from firmware side it is straight forward - I use this one https://github.com/ncmreynolds/ld2410 + simple sketch for mysensors.
            • C CodeGarage
              TheoLT
              TheoLT
              TheoL
              @CodeGarage Bot sure what you mean with a proper design of Radon and Google translator didn't help much. I have a big renovation ahead. But after that I should have a 32 square meter hobby space. That one is the first project I'll be doing over there
              • TheoLT TheoL
                C
                C
                CodeGarage
                @TheoL "A radome (a portmanteau of "radar" and "dome") is a structural, weatherproof enclosure that protects a radar antenna."
                In other words, it is special designed enclosure. If you want 100% predictable results, it must be good design.
                • C CodeGarage
                  TheoLT
                  TheoLT
                  TheoL
                  @CodeGarage I guess I have a lot of research ahead )
                  • TheoLT TheoL
                    C
                    C
                    CodeGarage
                    @TheoL It's not that hard ;) For me, most challenging part of design was to determine material properties (I was using 3d printing technology).
                    • C CodeGarage
                      TheoLT
                      TheoLT
                      TheoL
                      @CodeGarage What I want is a lion powered Sensor if possible. And that in a case I can stick to the door frame. As I cannot screw or drill into the doorframe. But I have no idea how much current that draws.
