  3. Home Assistant
  4. Some questions on how gateway works
14 Posts 4 Posters 2.5k Views 4 Watching
  • HomerH
    HomerH
    Homer
    I think I'm going to move on from the Ethernet route, coz no matter what I can't get it to connect to the network. I have an ESP12F that I found in my box of stuff that I'll wire a radio to and set it up as my gateway.
    • OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      @homer You do have to put in the MQTT parameters, such as, MQTT broker IP. The logic of your sensors and how you send the data remains the same.
      In Home Assistant you have to have the MQTT integration and the MySensors integration.
      1. Set up your MQTT broker
      2. install the MQTT integration
      3. install the MySensors integration (I always forget which goes where, MySensorsIn and MySensorsOut)
      4. create and configure your MySensors MQTT gateway
      5. add the MQTT code to your sensors
      Once you turn on your sensors, they should appear in Home Assistant as devices.
      • HomerH
        HomerH
        Homer
        Thanks for your reply!
        I have had heaps of help from Chat GPT and I believe every thing is talking to each other, but I don't see any sensors in HA.
        Here is my sketch for the Gateway:
        #define MY_MQTT_KEEPALIVE 60
        // Use a lower baud rate for ESP8266 serial prints
        #define MY_BAUD_RATE 9600
        // Radio type (enable one)
        #define MY_RADIO_RF24
        // #define MY_RADIO_RFM69
        // #define MY_RADIO_RFM95
        // nRF24 radio pins
        #define MY_RF24_CE_PIN 4
        #define MY_RF24_CS_PIN 15
        // Gateway type
        #define MY_GATEWAY_ESP8266
        // MQTT topics
        // MQTT client ID
        // Support controller ID allocation
        #define MY_CONTROLLER_ID_ALLOC_SUPPORT
        // MQTT broker authentication (optional)
        #define MY_MQTT_USER "homeassistant"
        #define MY_MQTT_PASSWORD "oN3Oe0eile6iVaivaiphooChieNg5wei0kapa9rohJ8au0Teethah6thahsieP7A"
        // WiFi credentials
        #define MY_WIFI_SSID "Ext"
        #define MY_WIFI_PASSWORD "lynettekoster"
        // Hostname for DHCP (optional)
        // #define MY_HOSTNAME "mqtt-sensor-gateway"
        // Static IP configuration (optional)
        #define MY_IP_ADDRESS 192,168,0,100
        // MQTT broker IP address or URL
        #define MY_CONTROLLER_IP_ADDRESS 192,168,0,77
        // #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
        // MQTT broker port
        #define MY_PORT 1883
        // Inclusion mode (optional)
        // #define MY_INCLUSION_MODE_FEATURE
        // #define MY_INCLUSION_BUTTON_FEATURE
        // #define MY_INCLUSION_MODE_DURATION 60
        // #define MY_INCLUSION_MODE_BUTTON_PIN D1
        // LED blinking period (optional)
        // #define MY_DEFAULT_LED_BLINK_PERIOD 300
        // LED pins (optional)
        // #define MY_DEFAULT_ERR_LED_PIN 16
        // #define MY_DEFAULT_RX_LED_PIN 16
        // #define MY_DEFAULT_TX_LED_PIN 16
        #include <ESP8266WiFi.h>
          // Setup locally attached sensors here (if any)
          // Present gateway node to controller
          sendSketchInfo("MQTT Gateway", "1.0");
          // Send locally attached sensors data here (if any)
        My Sensor I made is using a RF-Nano, and this is the sketch:
        #define MY_RF24_CE_PIN 10
        #define MY_RF24_CS_PIN 9
        #include <OneWire.h>
        // MySensors definitions
        #define CHILD_ID_DS18B20_TEMP 0
        #define CHILD_ID_DHT_TEMP 1
        #define CHILD_ID_DHT_HUM 2
        #define ONE_WIRE_BUS 3        // DS18B20 data pin connected to Arduino pin 3
        #define DHTPIN 4              // DHT22 data pin connected to Arduino pin 4
        #define DHTTYPE DHT22         // DHT22 sensor type
        // Setup NRF24 radio (default CE=9, CSN=10 for RF-Nano)
        // Sleep interval in milliseconds
        #define SEND_INTERVAL 30000  // 30 seconds
        // Initialize sensors
        DallasTemperature ds18b20(&oneWire);
        DHT dht(DHTPIN, DHTTYPE);
        // Child sensor objects
        MyMessage msgDs18b20Temp(CHILD_ID_DS18B20_TEMP, V_TEMP);
        MyMessage msgDhtTemp(CHILD_ID_DHT_TEMP, V_TEMP);
        MyMessage msgDhtHum(CHILD_ID_DHT_HUM, V_HUM);
        unsigned long lastSendTime = 0;
          ds18b20.begin();
          dht.begin();
          // Present sensors to gateway
          present(CHILD_ID_DS18B20_TEMP, S_TEMP);
          present(CHILD_ID_DHT_TEMP, S_TEMP);
          present(CHILD_ID_DHT_HUM, S_HUM);
          unsigned long now = millis();
          if (now - lastSendTime > SEND_INTERVAL) {
            lastSendTime = now;
            // Read DS18B20 temperature
            ds18b20.requestTemperatures();
            float tempDS = ds18b20.getTempCByIndex(0);
            // Read DHT22 temp and humidity
            float tempDHT = dht.readTemperature();
            float humDHT = dht.readHumidity();
            // Check if reads are valid before sending
            if (tempDS != DEVICE_DISCONNECTED_C) {
              send(msgDs18b20Temp.set(tempDS, 1));
              // Optional: send some error value or skip
            if (!isnan(tempDHT)) {
              send(msgDhtTemp.set(tempDHT, 1));
            if (!isnan(humDHT)) {
              send(msgDhtHum.set(humDHT, 1));
          // Sleep to save power (optional, comment out if not needed)
          // sleep(SEND_INTERVAL / 1000);
        I downloaded and installed MQTT Explorer to see what messages are there. This is what shows in the app:
        I setup Mysensors using the GUI. I am running Mosquitto broker for MQTT. The only thing I see here is my Ring cameras as they are setup using MQTT. In the Mysensors integration all there is is the MQTT gateway that I created. I should have 3 new devices, but they aren't there. I do recall reading somewhere that there was something that needed to happen for a device to show up, but I don't recall what that way as at the time I read it, it was still very far from where I was up to at the time. I guess I will start doing some more searching.
        • HomerH
          HomerH
          Homer
          Still no topics. I only have the one sensor and I haven't actually attached any sensors to the arduino as I figured the sketch itself would send enough info to create the devices, but I am starting to wonder if the reason they aren;t there is coz of this....
          • F
            F
            fsgraz
            Maybe is a silly point, but the node presents itself to the gateway, and afterwards you should see your node in your controller. The node ( in myController V1 that is my choice) I see the node's registration status as New. I need to edit the node properties and change the node status to Registered. After that the sensors show up.
            there's also an inclusion mode in the gateway if this is not possible with Vera:
            // Enable inclusion mode
            //#define MY_INCLUSION_MODE_BUTTON_PIN D1
            https://www.mysensors.org/build/advanced_gateway
            F 1 Reply Last reply
            • F fsgraz
              F
              F
              fsgraz
              let me also add that if the serial protocol is possible with an ethernet gateway, I would prefer that, w/o messing with MQTT.
              • F fsgraz
                @fsgraz you might want to use the tcp option for the ethernet gateway then. See https://www.mysensors.org/about/overview and https://www.mysensors.org/build/select_gateway
                F 2 Replies Last reply
                • HomerH
                  HomerH
                  Homer
                  Thanks for the replies!!
                  I have some progress, but I still don't see any sensors in Home Assistant.
                  As you can see. topics are being reported, but nothing related to them show up in the HA MQTT integration or the Mysensors integration.I have no idea where to go from here.
                  • HomerH
                    HomerH
                    Homer
                    I gave up on this and instead went the TCP Gateway, and now I have sensors in HA!
                    OldSurferDudeO 1 Reply Last reply
                    • HomerH Homer
                      OldSurferDudeO
                      OldSurferDudeO
                      OldSurferDude
                      @Homer That's really good to hear!
                      • HomerH
                        HomerH
                        Homer
                        Thanks mate, I am very pleased! :-D
                          F
                          F
                          fsgraz
                          @mfalkvidd thanks.
                          I am happily running 6 esp32 WiFi gateways with nRF24L01+, but with the mysensors serial protocol, not mqtt. I don't see any value on MQTT for a local system based entirely on mysensors like mine, but I might be wrong and don't see the potential.
                          I have a couple of them working as bridges, like between BLE sensors and mysensors, or Alexa an mysensors, meteo RSS Feed etc.
                            F
                            F
                            fsgraz
                            @mfalkvidd I got what you mean.
                            Yes, I am using the tcp connection using the mySensors serial API, not the USB<>UART serial interface ;-)
                            I am running a gateway with the nRF24 at 1Mpbs for the fast & furious sensors (mainly energy meters); another at 250kbps for the battery supplied nodes (temp/hum and door sensors); another one at 1Mbps dedicated to the actuators / mission critical.
                            60 nodes running
                            Another on is a BLE<>Mysensors bridge between the Mopeka Tank Pro (2) and the TPMS (4)
                            Another one is a fauxmo<>Mysensors bridge.
                            A few esp32 based displays (round oled, 3.5", 7")
