  3. Flame Sensor Not Triggering Setup
21 Posts 6 Posters 3.6k Views 6 Watching
  • TheoLT
    TheoLT
    TheoL
    You mean you have no 100uf capacitor between the ground and vcc of the nrf radio? Because you really need it.
    I still wanna experiment with replacing the 100uf with 0.1 uf 1 uf and 10 uf in parallel. They use that in analog synth PSU's to guarentee a smooth power.
    • OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      I have a 10µF capacitor soldered onto the board of the nRF24.
      TheoLT 1 Reply Last reply
        TheoLT
        TheoLT
        TheoL
        @OldSurferDude Swap them with 100uf. That improves communication a lot. You might even be able to get rid of the delays
        I just hate delays in code.
        • OldSurferDudeO
          OldSurferDudeO
          OldSurferDude
          wrote on last edited by OldSurferDude
          I will consider it for future designs. For now, "if it ain't broke, don't fix it."
          (I, too, hate delays)
            TheoLT
            TheoLT
            TheoL
            @OldSurferDude I believe we started with 4.7 Uf, then it was 10Uf and eventually it become 100uf.
            Although I still wanna try if0.1 1 and 10 uf in parallel will work better. I believe EEVLOG gave an explanation why that is the best. But I forgot
            • skywatchS
              skywatchS
              skywatch
              FWIW I am using 47uF * ceramic smd caps but always use delay to allow the data and power line to stablilse between sends.
              *I like being different!
              S 1 Reply Last reply
              • skywatchS skywatch
                sindrome73
                @skywatch If I may, how do you introduce a delay between one broadcast and another?
                skywatchS 1 Reply Last reply
                • TheoLT
                  TheoLT
                  TheoL
                  I use a message queue, I implemented a long time ago. But all of this shouldn't be needed, as there's a retry built into the MySensors Core.
                  I do it to give other Nodes the time to send as well. Because sometimes the traffic is really bursty
                    sindrome73
                    ok grazie
                    • S sindrome73
                      skywatchS
                      skywatchS
                      skywatch
                      @sindrome73 From a recent upgraded node I do it like this....
                      if (dustAverage > 20.0 && dustAverage < 500.0) {
                      send(msgDust.set(dustAverage, 2));
                      wait(200);
                      send(msgQuality.set(dustStrings[x]));
                      wait(200);
                      send(msgTemp.set(temperature, 2));
                      lasttemperature = temperature;
                      wait(200);
                      send(msgHum.set(humidity, 2));
                      wait(200);
                      send(msgVOC.set(VOC, 2));
                      wait(200);
                      send(msgNOX.set(NOX, 2));
                      Hope this is clear!
                      Ciao.
                      TheoLT OldSurferDudeO 2 Replies Last reply
                        wait(200);
                        wait(200);
                        wait(200);
                        wait(200);
                        wait(200);
                        Hope this is clear!
                        Ciao.
                        TheoLT
                        TheoLT
                        TheoL
                        wrote on last edited by TheoL
                        @skywatch When I have time I will give you a library. I like code the best when there's no wait or delay in it.
                        Giving a library means I have to take it out of my code and make it decent xd
                        • TheoLT TheoL
                          skywatchS
                          skywatchS
                          skywatch
                          @TheoL That is kind of you, but no rush. I have not been building for a while now due to circumstances outside my control.
                          Maybe you could think of putting it on this site to help others too? Just a thought.
                          I will be interested to see what you have done and how it is working. :)
                            wait(200);
                            wait(200);
                            wait(200);
                            wait(200);
                            wait(200);
                            Hope this is clear!
                            Ciao.
                            OldSurferDudeO
                            OldSurferDudeO
                            OldSurferDude
                            @skywatch @sindrome73 This is what I do, too.
                            Note that it is wait(), which is a MySensors function and not delay(), an Arduino function. wait() checks for MySensors messages, delay() halts all process, thus a message might be missed.
