  3. Flame Sensor Not Triggering Setup
21 Posts 6 Posters 3.6k Views 6 Watching
  • OldSurferDudeO
    OldSurferDudeO
    OldSurferDude
    wrote on last edited by OldSurferDude
    I will consider it for future designs. For now, "if it ain't broke, don't fix it."
    (I, too, hate delays)
    TheoLT 1 Reply Last reply
      TheoLT
      TheoLT
      TheoL
      @OldSurferDude I believe we started with 4.7 Uf, then it was 10Uf and eventually it become 100uf.
      Although I still wanna try if0.1 1 and 10 uf in parallel will work better. I believe EEVLOG gave an explanation why that is the best. But I forgot
      • skywatchS
        skywatchS
        skywatch
        FWIW I am using 47uF * ceramic smd caps but always use delay to allow the data and power line to stablilse between sends.
        *I like being different!
        S 1 Reply Last reply
        • skywatchS skywatch
          sindrome73
          @skywatch If I may, how do you introduce a delay between one broadcast and another?
          skywatchS 1 Reply Last reply
          • TheoLT
            TheoLT
            TheoL
            I use a message queue, I implemented a long time ago. But all of this shouldn't be needed, as there's a retry built into the MySensors Core.
            I do it to give other Nodes the time to send as well. Because sometimes the traffic is really bursty
              sindrome73
              ok grazie
              • S sindrome73
                skywatchS
                skywatchS
                skywatch
                @sindrome73 From a recent upgraded node I do it like this....
                if (dustAverage > 20.0 && dustAverage < 500.0) {
                send(msgDust.set(dustAverage, 2));
                wait(200);
                send(msgQuality.set(dustStrings[x]));
                wait(200);
                send(msgTemp.set(temperature, 2));
                lasttemperature = temperature;
                wait(200);
                send(msgHum.set(humidity, 2));
                wait(200);
                send(msgVOC.set(VOC, 2));
                wait(200);
                send(msgNOX.set(NOX, 2));
                Hope this is clear!
                Ciao.
                TheoLT OldSurferDudeO 2 Replies Last reply
                  wait(200);
                  wait(200);
                  wait(200);
                  wait(200);
                  wait(200);
                  Hope this is clear!
                  Ciao.
                  TheoLT
                  TheoLT
                  TheoL
                  wrote on last edited by TheoL
                  @skywatch When I have time I will give you a library. I like code the best when there's no wait or delay in it.
                  Giving a library means I have to take it out of my code and make it decent xd
                  • TheoLT TheoL
                    skywatchS
                    skywatchS
                    skywatch
                    @TheoL That is kind of you, but no rush. I have not been building for a while now due to circumstances outside my control.
                    Maybe you could think of putting it on this site to help others too? Just a thought.
                    I will be interested to see what you have done and how it is working. :)
                      wait(200);
                      wait(200);
                      wait(200);
                      wait(200);
                      wait(200);
                      Hope this is clear!
                      Ciao.
                      OldSurferDudeO
                      OldSurferDudeO
                      OldSurferDude
                      @skywatch @sindrome73 This is what I do, too.
                      Note that it is wait(), which is a MySensors function and not delay(), an Arduino function. wait() checks for MySensors messages, delay() halts all process, thus a message might be missed.
