  3. Home Assistant
  4. None nnn Node in Home Assistant
home assistantnrf5nrf52832node
10 Posts 3 Posters 663 Views 2 Watching
  • K Offline
    K Offline
    KevinT
    I ran into a problem while testing out an nRF52832 board with home assistant. Sometimes, when a new node connected, it would show in Home Assistsant as None nnn (where nnn is the node number) with only a battery sensor and no other sensors. Looking in the mysensors.json file, I found the sensors were defined but the sketch_name was "null".
        "211": {
            "sensor_id": 211,
            "children": {
                "0": {
                    "id": 0,
                    "type": 6,
                    "description": "Temperature",
                    "values": {
                        "0": "22.99"
                "1": {
                    "id": 1,
                    "type": 8,
                    "description": "Pressure",
                    "values": {
                        "43": "kPa",
                        "4": "101.86"
            "type": 17,
            "sketch_name": null,
            "sketch_version": "1.0",
            "battery_level": 0,
            "protocol_version": "2.3.2",
            "heartbeat": 0
    The sketch name is set by sendSketchInfo(), which made me think that this message was getting lost sometimes, perhaps the transport message system was still processing previous messages.
    I added a 10ms wait, and the problem was solved, the nodes now consistently register with home assistant.
    void presentation()  {
      // Send the sketch name & version information to the gateway and Controller
      wait(10);		// allow transport to setup, sometimes sketch info is being lost
      sendSketchInfo("BMP280 Sensor", "1.0");
      present(CHILD_ID_TEMP, S_TEMP, "Temperature");
      present(CHILD_ID_PRES, S_BARO, "Pressure");
    I just thought I would share this, in case others run into the same problem.
    • OldSurferDudeO Offline
      OldSurferDude
      Yeah, you need the sketch name.
      I found that wait() was required pretty much after every send. I don't why exactly, I suspect the the send commands were overrunning the previous send command.
      nagelcN 1 Reply Last reply
      • K Offline
        K Offline
        KevinT
        Good to know. I'll have to check and see if all my sensor measurements are getting through to ha. Out of curiosity, what hardware are you using for your gateway and controller?
          OldSurferDude
          Home Assistant is my controller. It runs in a virtualbox under linux on a refurbished PC. On that same computer I run an MQTT broker (not using HA's)
          My gateway, which uses MQTT for transport, runs on an RPi zero 2W running Raspberry Pi OS. It also controls my irrigation relays.
          I also have a serial gateway which has no radio network which is its own node for "pushing" the buttons on a remote control. This gateway essentially gives a PC digital IO.
            nagelcN Offline
            nagelcN Offline
            nagelc
            I second this. Waiting after send can help some odd behavior.
            I have also had nodes the performed well with debug turned on, then not work when it is off. The debug prints are slow in processor time and I think they act like a wait. If this happens, check where you have debug messages and try some waits there, especially if it is after a send.
            • K Offline
              K Offline
              KevinT
              Given that the nrf52832 is a fairly fast processor (ARM Cortex M4), I can see how that might happen, depending on the speed of the gateway and controller. That's why I asked @oldsurferdude what he's running. I'm running a Pi4 with Home Assistant OS and 2 serial gateways, 915Mhz and 2.4Ghz. My 2.4Ghz gateway consists of an ESP8266 with an nRF24L01P module. So far, I haven't had any lost messages, but it's early days for me, just testing out the hardware. I've been running with DEBUG off.
              I'm also trying to determine battery requirements. Here's what I've found for current for various peripherals.
              Bare bones mySensors sketch, with sleep, serial disabled: 2 uA
              Bare bones mySensors sketch, with sleep & serial: 7.5 uA
              sketch with I2C, sleep, serial disabled, ic2 disable/enable: 2 uA
              sketch with I2C, sleep & serial, ic2 disable/enable: 8.4 uA
              sketch with I2C, sleep & serial disable/enable, ic2 disable/enable: 2 uA
              sketch with digital interrupt, sleep, serial disabled: 7.6 uA
              sketch with digital interrupt, sleep, serial: 3.5 mA !
              sketch with digital interrupt, sleep, serial disable/enable: 7.6 uA
              sketch with spi, sleep, serial disabled: 2 uA
              sketch with spi, sleep, serial : 3.1 mA !
              sketch with spi, sleep, serial disable/enable: 2 uA
              Basically, if you are using serial output, always disable it before sleep, and re-enable upon wake.
              Current draw is normally 2 uA when sleeping. If you are using digital input interrupts, sleep current is 7.6 uA.
              • nagelcN Offline
                nagelcN Offline
                nagelc
                I have been getting about a year from a coin cell on nrf52832 and BME280 sending temperature and humidity every 3 minutes. Good enough for me : )
                • K Offline
                  K Offline
                  KevinT
                  Good stuff. Which coin cell are you using? What transmit power?
                  • nagelcN Offline
                    nagelcN Offline
                    nagelc
                    I'm using CR2032 batteries.
                    I'm just using the default transmit power . .. looking in MyConfig.h, looks like that is NRF5_PA_MAX = 4dBm. I may have to experiment with some of the lower settings for nodes that are close to my gateway.
                    My nodes are using NRF5_250KBPS. I have set up some newer ones using NRF5_1MBPS on a different gateway. It will take a while to see if that makes a difference. I'm hoping the shorter transmission time gives some additional improvement.
                    • K Offline
                      K Offline
                      KevinT
                      @nagelc Thanks for the info, it gives me a good starting point.
