Building a Reliable Ethernet Gateway for MySensors – PCB Layout Considerations
I've been thinking about the hardware side of MySensors gateways, particularly when moving from a breadboard prototype to a dedicated PCB.
A wired Ethernet gateway can be a good option for home automation setups where Wi-Fi connectivity isn't always reliable. But getting the Ethernet interface right on a custom PCB requires a little more attention than simply connecting a PHY and RJ45 connector.
A few design considerations worth keeping in mind:
- PHY and magnetics placement: Keep the PHY, Ethernet magnetics, and RJ45 connector close together to minimize the MDI trace length.
- Differential routing: Maintain 100 Ω differential impedance and avoid unnecessary vias or stubs in Ethernet signal pairs.
- Grounding and isolation: Keep chassis ground and circuit ground properly separated around the Ethernet magnetics.
- Power supply: Provide clean, well-decoupled power to the PHY. Switching regulator noise can affect Ethernet performance.
- ESD protection: Add suitable low-capacitance TVS protection near the Ethernet interface.
I work with technical content and PCB-related projects at PCBCool. While looking into practical PCB design challenges, Ethernet gateway layouts caught my attention because small layout decisions can make a noticeable difference in reliability.
I'm curious about the experience of other MySensors users:
Has anyone here designed a custom Ethernet gateway PCB for MySensors? Did you face any issues with Ethernet link stability, EMI, or communication between the gateway and sensor nodes?
It would be interesting to hear what worked well in your hardware designs.
