  3. Multisensor Multiactuator Sketch / Testboard - tested with FHEM Controller
6 Posts 5 Posters 14.7k Views 7 Watching
    Meister_Petz
    because I needed a test board with lots of sensors and getting used to do MySensor Sketches as well as FHEM Controller configuration. This is what I came up with:
    My Testboard includes:
    Sensors:
    • Temperature - Thermoresistor - PIN A3
    • Temperature - Dallas DS1820 - PIN 6
    • Lightlevel - Photoresistor - PIN A0
    Switches:
    • 2x Pushbuttons - PIN 5 and A4
    • Magnet Switch - PIN 7
    Actuators:
    The Actuators can be switched on normally (by sending 0 or 1) or can do something predifined (by sending 2 or 3).
    • 2x LEDs - PIN 3 and PIN 4
    • Piezo Buzzer - PIN A5
    This is how it looks:
    Alt text
    Alt text
    The MySensors Code:
    The code is very simple, to make it easy for beginners like me, making adjustments and understanding what happens.
        // Child ID s - Triggers - Buttons, Motion Sensors...
        #define TRIGGER1_ID 1 // Trigger 1
        #define TRIGGER2_ID 2 // Trigger 2
        #define TRIGGER3_ID 3 // Trigger 3
        #define TRIGGER4_ID 4 // Trigger 4
        #define TRIGGER5_ID 5 // Trigger 5
        #define TRIGGER6_ID 6 // Trigger 6
        #define TRIGGER7_ID 7 // Trigger 7
        #define TRIGGER8_ID 8 // Trigger 8
        #define TRIGGER9_ID 9 // Trigger 9
        // Child ID s - Actuators - Relays, LEDs,...
        #define ACTUATOR1_ID 11 // Actuator 1 - LED Orange
        #define ACTUATOR2_ID 12 // Actuator 2 - LED Red
        #define ACTUATOR3_ID 13 // Actuator 3 - PIEZO
        #define ACTUATOR4_ID 14 // Actuator 4
        #define ACTUATOR5_ID 15 // Actuator 5
        #define ACTUATOR6_ID 16 // Actuator 6
        #define ACTUATOR7_ID 17 // Actuator 7
        #define ACTUATOR8_ID 18 // Actuator 8
        #define ACTUATOR9_ID 19 // Actuator 9
        // Child ID s - Continuous Sensors - Temperature Sensors, Lightlevel Sensors,...
        #define SENSOR1_ID 21 // Sensor 1
        #define SENSOR2_ID 22 // Sensor 2
        #define SENSOR3_ID 23 // Sensor 3
        #define SENSOR4_ID 24 // Sensor 4
        #define SENSOR5_ID 25 // Sensor 5
        #define SENSOR6_ID 26 // Sensor 6
        #define SENSOR7_ID 27 // Sensor 7
        #define SENSOR8_ID 28 // Sensor 8
        #define SENSOR9_ID 29 // Sensor 9
        // DEFINITIONS
          // Triggers - Triggers - Triggers - Triggers - Triggers - Triggers
          // DEFINITIONS - Push Buttons, Door Sensors,...
          // Trigger PINS - Digital PIN -> Button -> GND
            #define TRIGGER1_PIN  5
            #define TRIGGER2_PIN  18 // A4
            #define TRIGGER3_PIN  7
            #define TRIGGER4_PIN  7
            #define TRIGGER5_PIN  7
            #define TRIGGER6_PIN  7
            #define TRIGGER7_PIN  7
            #define TRIGGER8_PIN  7
            #define TRIGGER9_PIN  7
          // Bounce
            Bounce debouncer1 = Bounce();
            Bounce debouncer2 = Bounce();
            Bounce debouncer3 = Bounce();
            Bounce debouncer4 = Bounce();
            Bounce debouncer5 = Bounce();
            Bounce debouncer6 = Bounce();
            Bounce debouncer7 = Bounce();
            Bounce debouncer8 = Bounce();
            Bounce debouncer9 = Bounce();
          // MyMessage
            MyMessage msg01(TRIGGER1_ID,V_TRIPPED);
            MyMessage msg02(TRIGGER2_ID,V_TRIPPED);
            MyMessage msg03(TRIGGER3_ID,V_TRIPPED);
            MyMessage msg04(TRIGGER4_ID,V_TRIPPED);
            MyMessage msg05(TRIGGER5_ID,V_TRIPPED);
            MyMessage msg06(TRIGGER6_ID,V_TRIPPED);
            MyMessage msg07(TRIGGER7_ID,V_TRIPPED);
            MyMessage msg08(TRIGGER8_ID,V_TRIPPED);
            MyMessage msg09(TRIGGER9_ID,V_TRIPPED);
          // Some Variables
            int oldTrigValue1=-1;
            int oldTrigValue2=-1;
            int oldTrigValue3=-1;
            int oldTrigValue4=-1;
            int oldTrigValue5=-1;
            int oldTrigValue6=-1;
            int oldTrigValue7=-1;
            int oldTrigValue8=-1;
            int oldTrigValue9=-1;
          // Actuators - Actuators - Actuators - Actuators - Actuators - Actuators
          // DEFINITIONS - LEDs, Relays, ...
          // Actuators PINS - DIGITAL PIN to Actuator
            #define ACTUATOR1_PIN  3
            #define ACTUATOR2_PIN  4
            #define ACTUATOR3_PIN  19
            #define ACTUATOR1_PIN  7
            #define ACTUATOR2_PIN  7
            #define ACTUATOR3_PIN  7
            #define ACTUATOR_ON 1
            #define ACTUATOR_OFF 0
            bool state;
          // Sensors - Sensors - Sensors - Sensors - Sensors - Sensors - Sensors
          // DEFINITIONS - Temperatur, Humidity, Lightlevel,...
          // Sensor PINS
            #define SENSOR1_PIN  A3 // AnalogTemp on A3
            #define SENSOR2_PIN  6 // Digi
            #define SENSOR3_PIN  A0 // LightLevel Sensor
            #define SENSOR4_PIN  3
            #define SENSOR5_PIN  3
            #define SENSOR6_PIN  3
            #define SENSOR7_PIN  3
            #define SENSOR8_PIN  3
            #define SENSOR9_PIN  3
          // MyMessage V_TEMP, V_LIGHT_LEVEL, ... depending on Sensor Type
            MyMessage msg11(SENSOR1_ID,V_TEMP);
            MyMessage msg12(SENSOR2_ID,V_TEMP);
            MyMessage msg13(SENSOR3_ID,V_LIGHT_LEVEL);
            MyMessage msg14(SENSOR4_ID,V_TEMP);
            MyMessage msg15(SENSOR5_ID,V_TEMP);
            MyMessage msg16(SENSOR6_ID,V_TEMP);
            MyMessage msg17(SENSOR7_ID,V_TEMP);
            MyMessage msg18(SENSOR8_ID,V_TEMP);
            MyMessage msg19(SENSOR9_ID,V_TEMP);
            // Interval for each Sensor Read (number of loops) 1000000 = ca. 60 Sec - Adruino Nano ATmega 328
              long int sensorInterval1 = 100000;
              long int sensorInterval2 = 100000;
              long int sensorInterval3 = 100000;
              long int sensorInterval4 = 1000000;
              long int sensorInterval5 = 1000000;
              long int sensorInterval6 = 1000000;
              long int sensorInterval7 = 1000000;
              long int sensorInterval8 = 1000000;
              long int sensorInterval9 = 1000000;
            // Special Config for each Sensor
              // SENSOR 1
              // SENSOR 2
                // Dallas Temp Sensor
                #include <OneWire.h>
                OneWire oneWire(SENSOR2_PIN);
                boolean receivedConfig = false;
                boolean metric = true;
              // SENSOR 3
              // SENSOR 4
              // SENSOR 5
              // SENSOR 6
              // SENSOR 7
              // SENSOR 8
              // SENSOR 9
            //for sending only if value changed
            float lastRead1;
            float lastRead2;
            float lastRead3;
            float lastRead4;
            float lastRead5;
            float lastRead6;
            float lastRead7;
            float lastRead8;
            float lastRead9;
            //for loops
            long int sI1 = sensorInterval1;
            long int sI2 = sensorInterval2;
            long int sI3 = sensorInterval3;
            long int sI4 = sensorInterval4;
            long int sI5 = sensorInterval5;
            long int sI6 = sensorInterval6;
            long int sI7 = sensorInterval7;
            long int sI8 = sensorInterval8;
            long int sI9 = sensorInterval9;
        // VOID SETUP - VOID SETUP - VOID SETUP - VOID SETUP - VOID SETUP
          gw.sendSketchInfo("3But.2Led.1DigTemp.1LightSens", "1.4.1");
          // VOID SETUP
              pinMode(TRIGGER1_PIN,INPUT);
              pinMode(TRIGGER2_PIN,INPUT);
              pinMode(TRIGGER3_PIN,INPUT);
              pinMode(TRIGGER4_PIN,INPUT);
              pinMode(TRIGGER5_PIN,INPUT);
              pinMode(TRIGGER6_PIN,INPUT);
              pinMode(TRIGGER7_PIN,INPUT);
              pinMode(TRIGGER8_PIN,INPUT);
              pinMode(TRIGGER9_PIN,INPUT);
            // Activate internal pull-up
              digitalWrite(TRIGGER1_PIN,HIGH);
              digitalWrite(TRIGGER2_PIN,HIGH);
              digitalWrite(TRIGGER3_PIN,HIGH);
              digitalWrite(TRIGGER4_PIN,HIGH);
              digitalWrite(TRIGGER5_PIN,HIGH);
              digitalWrite(TRIGGER6_PIN,HIGH);
              digitalWrite(TRIGGER7_PIN,HIGH);
              digitalWrite(TRIGGER8_PIN,HIGH);
              digitalWrite(TRIGGER9_PIN,HIGH);
              debouncer1.attach(TRIGGER1_PIN);
              debouncer2.attach(TRIGGER2_PIN);
              debouncer3.attach(TRIGGER3_PIN);
              debouncer4.attach(TRIGGER4_PIN);
              debouncer5.attach(TRIGGER5_PIN);
              debouncer6.attach(TRIGGER6_PIN);
              debouncer7.attach(TRIGGER7_PIN);
              debouncer8.attach(TRIGGER8_PIN);
              debouncer9.attach(TRIGGER9_PIN);
              debouncer1.interval(5);
              debouncer2.interval(5);
              debouncer3.interval(5);
              debouncer4.interval(5);
              debouncer5.interval(5);
              debouncer6.interval(5);
              debouncer7.interval(5);
              debouncer8.interval(5);
              debouncer9.interval(5);
            // present all Triggers to Gateway
              gw.present(TRIGGER1_ID, S_DOOR);
              gw.present(TRIGGER2_ID, S_DOOR);
              gw.present(TRIGGER3_ID, S_DOOR);
              gw.present(TRIGGER4_ID, S_DOOR);
              gw.present(TRIGGER5_ID, S_DOOR);
              gw.present(TRIGGER6_ID, S_DOOR);
              gw.present(TRIGGER7_ID, S_DOOR);
              gw.present(TRIGGER8_ID, S_DOOR);
              gw.present(TRIGGER9_ID, S_DOOR);
          // VOID SETUP
              pinMode(ACTUATOR1_PIN, OUTPUT);
              pinMode(ACTUATOR2_PIN, OUTPUT);
              pinMode(ACTUATOR3_PIN, OUTPUT);
              pinMode(ACTUATOR4_PIN, OUTPUT);
              pinMode(ACTUATOR5_PIN, OUTPUT);
              pinMode(ACTUATOR6_PIN, OUTPUT);
              pinMode(ACTUATOR7_PIN, OUTPUT);
              pinMode(ACTUATOR8_PIN, OUTPUT);
              pinMode(ACTUATOR9_PIN, OUTPUT);
            // present all Actuators to Gateway
              gw.present(ACTUATOR1_ID, S_LIGHT);
              gw.present(ACTUATOR2_ID, S_LIGHT);
              gw.present(ACTUATOR3_ID, S_LIGHT);
              gw.present(ACTUATOR4_ID, S_LIGHT);
              gw.present(ACTUATOR5_ID, S_LIGHT);
              gw.present(ACTUATOR6_ID, S_LIGHT);
              gw.present(ACTUATOR7_ID, S_LIGHT);
              gw.present(ACTUATOR8_ID, S_LIGHT);
              gw.present(ACTUATOR9_ID, S_LIGHT);
            // FETCH old State and SET old state
              bool state1 = gw.loadState(ACTUATOR1_ID); digitalWrite(ACTUATOR1_ID, state1?ACTUATOR_ON:ACTUATOR_OFF);
              bool state2 = gw.loadState(ACTUATOR2_ID); digitalWrite(ACTUATOR2_ID, state2?ACTUATOR_ON:ACTUATOR_OFF);
              bool state3 = gw.loadState(ACTUATOR3_ID); digitalWrite(ACTUATOR3_ID, state3?ACTUATOR_ON:ACTUATOR_OFF);
              bool state4 = gw.loadState(ACTUATOR4_ID); digitalWrite(ACTUATOR4_ID, state4?ACTUATOR_ON:ACTUATOR_OFF);
              bool state5 = gw.loadState(ACTUATOR5_ID); digitalWrite(ACTUATOR5_ID, state5?ACTUATOR_ON:ACTUATOR_OFF);
              bool state6 = gw.loadState(ACTUATOR6_ID); digitalWrite(ACTUATOR6_ID, state6?ACTUATOR_ON:ACTUATOR_OFF);
              bool state7 = gw.loadState(ACTUATOR7_ID); digitalWrite(ACTUATOR7_ID, state7?ACTUATOR_ON:ACTUATOR_OFF);
              bool state8 = gw.loadState(ACTUATOR8_ID); digitalWrite(ACTUATOR8_ID, state8?ACTUATOR_ON:ACTUATOR_OFF);
              bool state9 = gw.loadState(ACTUATOR9_ID); digitalWrite(ACTUATOR9_ID, state9?ACTUATOR_ON:ACTUATOR_OFF);
          // VOID SETUP
            // present all Sensors to Gateway - S_TEMP, S_LIGHT_LEVEL,... depending an SENSOR type
              gw.present(SENSOR1_ID, S_TEMP);
              gw.present(SENSOR2_ID, S_TEMP);
              gw.present(SENSOR3_ID, S_LIGHT_LEVEL);
              gw.present(SENSOR4_ID, S_TEMP);
              gw.present(SENSOR5_ID, S_TEMP);
              gw.present(SENSOR6_ID, S_TEMP);
              gw.present(SENSOR7_ID, S_TEMP);
              gw.present(SENSOR8_ID, S_TEMP);
              gw.present(SENSOR9_ID, S_TEMP);
            // Special SETUP for each Sensor
              // SENSOR 1
              // SENSOR 2 - Dallas Temp Sensor
                sensors.begin();
              // SENSOR 3
              // SENSOR 4
              // SENSOR 5
              // SENSOR 6
              // SENSOR 7
              // SENSOR 8
              // SENSOR 9
        // VOID LOOP - VOID LOOP - VOID LOOP - VOID LOOP - VOID LOOP - VOID LOOP
          // LOOP
              debouncer1.update();
              debouncer2.update();
              debouncer3.update();
              debouncer4.update();
              debouncer5.update();
              debouncer6.update();
              debouncer7.update();
              debouncer8.update();
              debouncer9.update();
            // Get the update value
              int value1 = debouncer1.read();
              int value3 = debouncer3.read();
              int value4 = debouncer4.read();
              int value5 = debouncer5.read();
              int value6 = debouncer6.read();
              int value7 = debouncer7.read();
              int value8 = debouncer8.read();
              int value9 = debouncer9.read();
            // Send in the new value - if value changed
              if (value1 != oldTrigValue1) { gw.send(msg01.set(value1==LOW ? 1 : 0)); oldTrigValue1 = value1; }
              if (value2 != oldTrigValue2) { gw.send(msg02.set(value2==LOW ? 1 : 0)); oldTrigValue2 = value2; }
              if (value3 != oldTrigValue3) { gw.send(msg03.set(value3==LOW ? 1 : 0)); oldTrigValue3 = value3; }
              if (value4 != oldTrigValue4) { gw.send(msg04.set(value4==LOW ? 1 : 0)); oldTrigValue4 = value4; }
              if (value5 != oldTrigValue5) { gw.send(msg05.set(value5==LOW ? 1 : 0)); oldTrigValue5 = value5; }
              if (value6 != oldTrigValue6) { gw.send(msg06.set(value6==LOW ? 1 : 0)); oldTrigValue6 = value6; }
              if (value7 != oldTrigValue7) { gw.send(msg07.set(value7==LOW ? 1 : 0)); oldTrigValue7 = value7; }
              if (value8 != oldTrigValue8) { gw.send(msg08.set(value8==LOW ? 1 : 0)); oldTrigValue8 = value8; }
              if (value9 != oldTrigValue9) { gw.send(msg09.set(value9==LOW ? 1 : 0)); oldTrigValue9 = value9; }
          // LOOP
             // Sensor1 - Analog Temp
             if (sI1 == sensorInterval1){
               sI1 = 0;
               int sensorRead1 = analogRead(SENSOR1_PIN);
               if (lastRead1 != sensorRead1){
                 float sensorCalc = (sensorRead1 / 10) - 45.5;
                 gw.send(msg11.set(sensorCalc,1));
                 lastRead1 = sensorRead1;
             // Sensor2 - Digital Temp Dallas
             if (sI2 == sensorInterval2){
               sI2 = 0;
               float sensorRead2 = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(0):sensors.getTempFByIndex(0)) * 10.)) / 10.;
               if (lastRead2 != sensorRead2){
                 gw.send(msg12.set(sensorRead2,1));
                 lastRead2 = sensorRead2;
             // Sensor3 - Light Level
             if (sI3 == sensorInterval3){
               sI3 = 0;
               int sensorRead3 = analogRead(SENSOR3_PIN);
               if (lastRead3 != sensorRead3){
                 gw.send(msg13.set(sensorRead3,1));
                 lastRead3 = sensorRead3;
             // Sensor4
             if (sI4 == sensorInterval4){
               sI4 = 0;
               // put here the read sensor function like:
               // float sensorRead4 = analogRead(SENSOR4_PIN);
               if (lastRead4 != sensorRead4){
                 gw.send(msg14.set(sensorRead4));
                 lastRead4 = sensorRead4;
             // Sensor5
             // Sensor6
             // Sensor7
             // Sensor8
             // Sensor9
            sI1++;
            sI2++;
            sI3++;
            sI4++;
            sI5++;
            sI6++;
            sI7++;
            sI8++;
            sI9++;
        // VOID INCOMING MESSAGE - VOID INCOMING MESSAGE - VOID INCOMING MESSAGE
          if (message.isAck()) {
            if (message.type==V_LIGHT) {
              int actPin;
              if (message.sensor == 11){ actPin = ACTUATOR1_PIN; }
              if (message.sensor == 12){ actPin = ACTUATOR2_PIN; }
              if (message.sensor == 13){ actPin = ACTUATOR3_PIN; }
              if (message.sensor == 14){ actPin = ACTUATOR4_PIN; }
              if (message.sensor == 15){ actPin = ACTUATOR5_PIN; }
              if (message.sensor == 16){ actPin = ACTUATOR6_PIN; }
              if (message.sensor == 17){ actPin = ACTUATOR7_PIN; }
              if (message.sensor == 18){ actPin = ACTUATOR8_PIN; }
              if (message.sensor == 19){ actPin = ACTUATOR9_PIN; }
                // switch Actuator normally
                  if (message.getInt() < 2) {
                    state = message.getBool();
                    digitalWrite(actPin, state?ACTUATOR_ON:ACTUATOR_OFF);
                    gw.saveState(message.sensor, state);
                    //Serial.print("normal Change for Actor:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(message.getBool());
                // switch Actuator predifined
                  if (message.getInt() == 2){
                    // BLINK 1x
                    digitalWrite(actPin, LOW);
                    delay(2000);
                    digitalWrite(actPin, HIGH);
                    delay(500);
                    delay(2000);
                    // set state back to old state
                    gw.loadState(message.sensor);
                    MyMessage msgTmp(message.sensor,V_LIGHT);
                    gw.send(msgTmp.set(state));
                  if (message.getInt() == 3){
                    // BLINK 2x
                    delay(2000);
                    delay(500);
                    delay(500);
                    delay(500);
                    delay(2000);
    Within FHEM Controller:
    Alt text
    The FHEM.cfg Code:
    And some example of my FHEM.cfg, how to use it:
    # Testboard #
    define Testboard MYSENSORS_DEVICE 100
    attr Testboard IODev gateway
    attr Testboard mapReading_brightness23 23 brightness
    attr Testboard mapReading_switch11 11 switch
    attr Testboard mapReading_switch12 12 switch
    attr Testboard mapReading_switch13 13 switch
    attr Testboard mapReading_temperature21 21 temperature
    attr Testboard mapReading_temperature22 22 temperature
    attr Testboard mapReading_tripped1 1 tripped
    attr Testboard mapReading_tripped2 2 tripped
    attr Testboard mapReading_tripped3 3 tripped
    attr Testboard mode repeater
    attr Testboard room MySensorsTB
    attr Testboard setCommands on1:switch11:on off1:switch11:off on2:switch12:on off2:switch12:off on3:switch13:on off3:switch13:off ack11:switch11:2 ack12:switch11:3 ack21:switch12:2 ack22:switch12:3 ack31:switch13:2 ack32:switch13:3
    attr Testboard setReading_switch11 on,off
    attr Testboard setReading_switch12 on,off
    attr Testboard setReading_switch13 on,off
    attr Testboard version 1.4.1
        # Actuators                                            #
         # Orange LED
         define OrangeLED dummy
          attr OrangeLED group Schalter
          attr OrangeLED room MySensorsTB
          attr OrangeLED setList on off 2 3
          attr OrangeLED webCmd on:off:2:3
          # normal Switch on
          define OrangeLED1 notify OrangeLED:on set Testboard on1
          define OrangeLED0 notify OrangeLED:off set Testboard off1
          # predefined Switching
          define OrangeLEDack1 notify OrangeLED:2 set Testboard ack11
          define OrangeLEDack2 notify OrangeLED:3 set Testboard ack12
         # Red LED
         define RedLED dummy
          attr RedLED group Schalter
          attr RedLED room MySensorsTB
          attr RedLED setList on off 2 3
          attr RedLED webCmd on:off:2:3
          # normal Switch on
          define RedLED1 notify RedLED:on set Testboard on2
          define RedLED2 notify RedLED:off set Testboard off2
          define RedLEDack1 notify RedLED:2 set Testboard ack21
          define RedLEDack2 notify RedLED:3 set Testboard ack22
         # PIEZO
         define PIEZO dummy
          attr PIEZO group Schalter
          attr PIEZO room MySensorsTB
          attr PIEZO setList on off 2 3
          attr PIEZO webCmd on:off:2:3
          # normal Switch on
          define PIEZO1 notify PIEZO:on set Testboard on3
          define PIEZO2 notify PIEZO:off set Testboard off3
          define PIEZOack1 notify PIEZO:2 set Testboard ack31
          define PIEZOack2 notify PIEZO:3 set Testboard ack32
        # Sensordata                                           #
        # Analog Temperature Sensor
        define AnalogTemp dummy
          attr AnalogTemp event-on-change-reading state
          attr AnalogTemp room MySensorsTB
          attr AnalogTemp group Sensors
          # get all 30 Sec. Temp from Testboard
          define AnalogTempCopy at +*00:00:30 { my $d= ReadingsVal("Testboard","temperature21",0);; fhem("set AnalogTemp $d");;}
          # in eigene Log Datei schreiben
          define AnalogTempLog FileLog ./log/Log_AnalogTemp-%Y-%m-%d.log AnalogTemp
            attr AnalogTempLog group SensorLogs
            attr AnalogTempLog logtype text
            attr AnalogTempLog room MySensorsTB
        define DigiTemp dummy
          attr DigiTemp event-on-change-reading state
          attr DigiTemp room MySensorsTB
          attr DigiTemp group Sensors
          define DigiTempCopy at +*00:00:30 { my $d= ReadingsVal("Testboard","temperature22",0);; fhem("set DigiTemp $d");;}
          define DigiTempLog FileLog ./log/Log_DigiTemp-%Y-%m-%d.log DigiTemp
            attr DigiTempLog group SensorLogs
            attr DigiTempLog logtype text
            attr DigiTempLog room MySensorsTB
        define LightLevel dummy
          attr LightLevel event-on-change-reading state
          attr LightLevel room MySensorsTB
          attr LightLevel group Sensors
          define LightLevelCopy at +*00:00:30 { my $d= ReadingsVal("Testboard","brightness23",0);; fhem("set LightLevel $d");;}
          define LightLevelLog FileLog ./log/Log_LightLevel-%Y-%m-%d.log LightLevel
            attr LightLevelLog group SensorLogs
            attr LightLevelLog logtype text
            attr LightLevelLog room MySensorsTB
    • D
      Dirk_H
      Thanks for sharing your project, very nicely documented. I don't have a real use for it at the moment but enjoyed very much to read a complete solution beginning with hardware and ending with FHEM.cfg code. Good Work! :+1:
      Best regards
      Dirk H
      • raditvR
        raditvR
        raditv
        Dummy device status doesnt change when I press the button, how to set the dummy state on reading change? I don't know so much about fhem config file
        • oscarcO
          oscarcO
          oscarc
          Question :
          For the dallas sensor , if I add more sensors can I add them to the same pin (D6) or it needs a different pin ?
          • marekdM
            marekdM
            marekd
            wrote on last edited by marekd
            @oscarc
            hope this will answer your question:
            or this:
            oscarcO 1 Reply Last reply
            • marekdM marekd
              @oscarc
              or this:
              oscarcO
              oscarcO
              oscarc
              @marekd Thank you, it does help : :+1:
