  3. Node-RED
  4. Node-Red as Controller
Scheduled Pinned Locked Moved Node-RED
node-red
54 Posts 17 Posters 58.6k Views 19 Watching
  • HeinzH
    HeinzH
    Heinz
    @vikasjee
    Everything is straight forward:
    • install FHEM on a rapsberry
    • add the MYSENSORS gateway to fhem.cfg
    define MYSENSOR_Gateway MYSENSORS 192.168.178.20:5003
    attr MYSENSOR_Gateway autocreate 1
    attr MYSENSOR_Gateway requestAck 1
    attr MYSENSOR_Gateway stateFormat connection
    • install mosquitto on the raspberry
    • add the MQTT device to fhem.cfg (point to local MQTT broker)
    define mqtt MQTT 127.0.0.1:1883
    • publish sensor data (e.g. MQTT_CO2) from FHEM to MQTT
    define MQTT_CO2 MQTT_BRIDGE MYSENSOR_MQ135_CO2
    attr MQTT_CO2 IODev mqtt
    attr MQTT_CO2 publishState fhem/CO2
    attr MQTT_CO2 stateFormat transmission-state
    Whenever the CO2 value changes it is forwarded to the local mosquitto broker via topic fehm/CO2
    Now you any client in the world that has access to the raspberry my subscribe this topic. You simply have to
    know the IP address of the MQTT broker.
    • install Node-Red on the raspberry
    • open the Node-Red window of the raspberry <IP>:1883
    • drag the MQTT input node to the sheet
    • configure the MQTT input node so that it uses the local broker and the topic from above
    • drag a debug output node to the sheet
    • connect both
    • Deploy
    --> The CO2 values are printed in the debug window.
    The same can be done from within bluemix with the difference that node-red runs in the cloud accessing your local broker in the raspberry.
    V 1 Reply Last reply
    • HeinzH Heinz
      @vikasjee
      • connect both
      • Deploy
      V
      V
      vikasjee
      @Heinz Thanks a lot for the details. Actually i am looking out for a confirmation and method/way of using the nodejs controller code in NodeRED somehow (looking out for direct porting or with minimal effort) so that all the functions of a MySensor controller may be made available under NodeRED and hence a NodeRED Controller for MySensor...
      This way we may port many other functionalities available as nodejs scripts into NodeRED controller...
      Any way forward or a nudge into that direction will also help...
        Mike Cayouette
        wrote on last edited by Mike Cayouette
        I also use node-red with a serial gateway attached. I created a flow that converts the serial payload to a mqtt type payload and it is picked up by openHAB. This also works the other way around. openHAB sents everything out via mqtt and node-red picks it up and parses it back into a serial formated payload which is picked up by the serial gateway. I also use node-red's Owntracks node to monitor my proximity and send updates to openHAB as an mqtt message and I also have a flow that monitors my phone and my wifes phone, if we are both home the outside lights get turned off at 22:00. node-red also sends twitter messages to me when my doors and windows are opened and no one is home.
        I only use mqtt with with a combiniation if nfr radios via the serial gateway, like I mentioned above, and I also use ESP8266 modules running lua. So as not to send the wrong payload to the serial gateway, all topics that come from openHAB that are destined for the serial gateway start with RF24SN/out/... and on node-red I subscribe the RF24SN/out/#. This will capture all those message and they will get parsed to the serial format (Nodeid;clientid;message;...etc).
        Everything that happens in node-red is passed to openHAB. I have a couple of relays and leds I control from openHAB. The leds use the MySensor LEDDimmer. Basically node-red acts as the middle man between the serial gateway and openHAB/mqtt.
        Mike
        • F Fredrik Carlsson
          Hello
          I have been tinkering a little with this and it does actually work.
          The only thing is that you must point the topic of the mqtt node directly to a child. Its not possible to just subscribe to topics higher in the hierarchy.
          For example in MyMQTT app on Android i can just subscribe to topic MyMQTT and then i get messages from all nodes connected to the Gateway. This is not possible with the mqtt node in NodeRED. You must specifically point it.
          below is and example of an mqtt node outputting to a debug node. My Gateway is at 192.168.1.201.
          [{"id":"d0ff7866.2f0088","type":"mqtt-broker","broker":"192.168.1.201","port":"1883","clientid":"MQTT"},{"id":"14e0544d.eb1fac","type":"debug","name":"","active":true,"console":"false","complete":"false","x":304,"y":827,"z":"cda8f31c.32571","wires":[]},{"id":"8792e08c.786d2","type":"mqtt in","name":"Temperatur","topic":"MyMQTT/21/1/V_TEMP","broker":"d0ff7866.2f0088","x":67.5,"y":791,"z":"cda8f31c.32571","wires":[["14e0544d.eb1fac"]]}]
          I am working on some code to push temperatures as an object trough a websocket for live viewing on a simple webpage.
          It maybe sounds advanced, but it is actually very easy. In my opinion Node-RED is just as powerfull as OpenHAB and not particulary more advanced either. Will post a full working example when i have everything ready.
          Mike Cayouette
          You can capture all higher level topics by using the # symbal. As I mention above, my openHAB sents RF24SN/out/.... and on node-red I have an mqtt node that listens for RF24SN/out/#.
          Mike
          F 1 Reply Last reply
          • M Mike Cayouette
            Mike
            F
            F
            Fredrik Carlsson
            @Mike-Cayouette thanks, I will try that tomorrow!
            • FotoFieberF
              FotoFieberF
              FotoFieber
              Here is my setup:
              • MyMQTT Client Gateway, OpenHAB, HomeMatic and node-red all connected to mosquitto
              • OpenHab configured to expose the internal bus to mosquitto
              • All glued together with node-red: the OpenHab Items have no mqtt binding, all messages are exchanged via the OpenHab internal bus.
              • Messages from any sensors are transformed in node-red to the destination (topic and payload)
              The advantage of this setup is:
              • OpenHab is only the GUI and doesn't need to know anything about the sensors
              • I can exchange any sensor/actuator without any change in OpenHab. I can even change from a netatmo device to a mysensor device or vice versa.
              I was thinking about replacing the MyMQTT Client Gateway with a Serial Gateway and node-red, but the gateway is stable since weeks.... never touch a running system. This would solve my biggest concern with the MyMQTT Client Gateway: it doesn't support encryption....
              • HeinzH
                HeinzH
                Heinz
                The following node-red sample illustrates how the data sent by the serial gateway can be analysed.
                The upper lane receives the data from COM-Port, splits the incomming message into single tokens and feeds the result into
                a switch block.
                The lower lane implements a http request which displays data for message type "set".
                The result of this simple sniffer looks like:
                On the top right I added a debug node to visualize the incomming data:
                This should be a minimalistic sample to get a feeling for how much work it would take to implement a fully functional controller.
                If the "presentation" messages would be fed into some no-sql database like mongoose, answering nodeid-requests shouldn't be a challenging task. In the end I think this could be done in 1-2 days.
                • HeinzH
                  HeinzH
                  Heinz
                  if anybody wants to try it on his own here is the source which can be imported into node-red.
                  [{"id":"e2627000.52f61","type":"serial-port","serialport":"COM13","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"10","bin":"false","out":"time","addchar":true},{"id":"ae116278.ceadf","type":"serial in","name":"SerialGateway","serial":"e2627000.52f61","x":75.5,"y":170.3333511352539,"z":"6e87bdcb.1ab8d4","wires":[["421469f9.a974f8"]]},{"id":"421469f9.a974f8","type":"function","name":"split message","func":"var message = msg.payload;\nsplitMessage = message.split(\" \");\nif(splitMessage[0] == \"0;0;3;0;9;read:\")\n{\n    msg.route = splitMessage[1].split(\"-\");\n    \n    var splitData = splitMessage[2].split(\"\\n\");\n    var tokens = splitData[1].split(\";\")\n    \n    msg.rawData = tokens;\n    if(tokens.length == 6)\n    {\n        msg.nodeId = tokens[0];\n        msg.childSensorId = tokens[1];\n        msg.messageType = tokens[2];\n        msg.ack = tokens[3];\n        msg.subType = tokens[4];\n        msg.payload = tokens[5];\n    }\n}\nelse\n{\n    \n}\nreturn msg;","outputs":1,"valid":true,"x":260.5,"y":170.3333511352539,"z":"6e87bdcb.1ab8d4","wires":[["ea996599.33b75"]]},{"id":"ea996599.33b75","type":"switch","name":"switch message type","property":"messageType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"true","outputs":5,"x":461.49998474121094,"y":170.3333511352539,"z":"6e87bdcb.1ab8d4","wires":[["4bca8505.d463e4"],["cfb87963.3e2a8"],["7cd01fb.f71436"],["e722ad62.22ebd"],["9f4ff922.f54838"]]},{"id":"4bca8505.d463e4","type":"function","name":"presentation","func":"msg.topic = \"presentation\";\nreturn msg;","outputs":1,"valid":true,"x":681.5,"y":37.333335876464844,"z":"6e87bdcb.1ab8d4","wires":[[]]},{"id":"7cd01fb.f71436","type":"function","name":"req","func":"msg.topic = \"req\";\nreturn msg;","outputs":1,"valid":true,"x":698.3333129882812,"y":152.33334350585938,"z":"6e87bdcb.1ab8d4","wires":[[]]},{"id":"e722ad62.22ebd","type":"function","name":"internal","func":"msg.topic = \"internal\";\nreturn msg;","outputs":1,"valid":true,"x":693.3333129882812,"y":203.33334350585938,"z":"6e87bdcb.1ab8d4","wires":[[]]},{"id":"9f4ff922.f54838","type":"function","name":"stream","func":"msg.topic = \"stream\";\nreturn msg;","outputs":1,"valid":true,"x":692.3333129882812,"y":261.3333435058594,"z":"6e87bdcb.1ab8d4","wires":[[]]},{"id":"137f8a82.b7ce45","type":"debug","name":"debug","active":true,"console":"false","complete":"true","x":897.3333129882812,"y":101.33333587646484,"z":"6e87bdcb.1ab8d4","wires":[]},{"id":"ff056cd7.417e98","type":"http response","name":"http out","x":744,"y":444.3333740234375,"z":"6e87bdcb.1ab8d4","wires":[]},{"id":"74b70760.4f808","type":"http in","name":"","url":"/mysensorsdata","method":"get","x":151.00001525878906,"y":444.3333740234375,"z":"6e87bdcb.1ab8d4","wires":[["68713a54.5c30ec"]]},{"id":"e26e1fbf.606c8","type":"template","name":"html template","field":"","format":"html","template":"\nGateway <br />\nreceived at:    {{data.timestamp}}<br />\nnode-id:        {{data.nodeId}}<br />\nchild-SensorId: {{data.childSensorId}}<br />\nmessageType:    {{data.messageType}}<br />\nsubType:        {{data.subType}}<br />\npayload:        {{data.payload}}\n","x":560.0000152587891,"y":445.33336663246155,"z":"6e87bdcb.1ab8d4","wires":[["ff056cd7.417e98"]]},{"id":"68713a54.5c30ec","type":"function","name":"message buffer","func":"context.data = context.data || new Object();\n\nswitch (msg.topic) {\n    case \"set\":\n        context.data.timestamp = new Date().toLocaleString();\n        context.data.nodeId = msg.nodeId;\n        context.data.childSensorId = msg.childSensorId;\n        context.data.messageType = msg.messageType;\n        context.data.subType = msg.subType;\n        context.data.payload = msg.payload;\n        msg = null;\n        break;\n    default:\n    \tmsg.data = context.data;\n}\n\nreturn msg;","outputs":1,"valid":true,"x":393.00001525878906,"y":445.3333435058594,"z":"6e87bdcb.1ab8d4","wires":[["e26e1fbf.606c8"]]},{"id":"8f3083f8.2dc96","type":"http in","name":"","url":"/mysensors","method":"get","x":135.00001525878906,"y":507.3333740234375,"z":"6e87bdcb.1ab8d4","wires":[["92f9be8f.e42c68"]]},{"id":"92f9be8f.e42c68","type":"template","name":"Auto Update Script","field":"","template":"<script>\n    setInterval(function(){\t\n\t    var theUrl = \"http://localhost:1880/mysensorsdata\";\n\t    var xmlHttp = new XMLHttpRequest();\n\t    xmlHttp.open( \"GET\", theUrl, false );\n\t    xmlHttp.send( null );\n\t    document. getElementById('mysensorsdata')\n\t    \t.innerHTML = xmlHttp.responseText;\n    },1000);\n</script>\n<div id = 'mysensorsdata'>\n ... Loading ...\n</div>\n","x":410,"y":507.3333740234375,"z":"6e87bdcb.1ab8d4","wires":[["ff056cd7.417e98"]]},{"id":"cfb87963.3e2a8","type":"function","name":"set","func":"msg.topic = \"set\";\nreturn msg;","outputs":1,"valid":true,"x":696.5,"y":101.33333587646484,"z":"6e87bdcb.1ab8d4","wires":[["137f8a82.b7ce45","68713a54.5c30ec"]]}]
                  D V 2 Replies Last reply
                  • HeinzH Heinz
                    Dheeraj
                    @Heinz
                    where are you storing the sensor data for presentation , stream. let me know which database you are using here? you can have another flows for sending the the request to sensor node via serial port. I tried it same some time back . may be i can share it here. :smiley:
                    • HeinzH Heinz
                      V
                      V
                      vikasjee
                      wrote on last edited by vikasjee
                      @Heinz ,
                      Thanks for the flow. kindly post how you have referenced mysensors library for the flow? Split function is spitting out an error as is.
                      OR Is it required at all?
                      Function Error: TypeError: Cannot call method 'split' of undefined (line 8, col 31)
                      Alco van NeckA 1 Reply Last reply
                      • HeinzH
                        HeinzH
                        Heinz
                        @Dheeraj right now I do not have a database attached as the flow is not finished. I plan to use redis or mongodb.
                        @vikasjee Indid not reference any mysensors lib in the flow. Split is standard javascript. I wonder why this should not work on your system.
                        • D Dheeraj
                          @Heinz
                          V
                          V
                          vikasjee
                          @Dheeraj said:
                          @Heinz
                          @Dheeraj, Will you like to share your way out here?
                          • HeinzH
                            HeinzH
                            Heinz
                            I paused the project as I am working on my low power sensors. As soon as I continue I will post it here.
                            • V vikasjee
                              @Heinz ,
                              Alco van NeckA
                              Alco van NeckA
                              Alco van Neck
                              You need to add an commit to the line 8 like var tokens = splitData[1].split(";");
                              I'm getting data at : http://192.168.1.115:1880/mysensorsdata, but the http://192.168.1.115:1880/mysensors don't update.. there is an autoupdate in the flow but it don't work..
                              • HeinzH
                                HeinzH
                                Heinz
                                which browser did you take? Probably you should try another one.
                                • H
                                  H
                                  humblehacker
                                  I've used NodeRED for various tasks over the years and it still remains my favorite IOT interface. All the while I've tried at least 5 of the officially supported MS controllers out there and nothing has come close! At present I'm trying Home Assistant but am almost ready to give up and set up my own workflow with NodeRED. There's a blog post at https://crankylinuxuser.net/2015/10/01/idiot-crazy-ways-to-make-iot-simple-and-cheap/ that includes a great example of a MySensors+NodeRED flow along with a spot-on critique of mainstream automation services being marketed at present.
                                  The only reason I havent just used NodeRED in the past is it would still require other components to truly make a unified home automation service. An ideal scenario IMHO would be something that uses NodeRED as a front-end with something more unified running it.
                                  crankyC 1 Reply Last reply
                                  • FotoFieberF
                                    FotoFieberF
                                    FotoFieber
                                    Here my approach:
                                    [{"id":"ba386057.845d3","type":"mqtt-broker","broker":"192.168.92.4","port":"1883","clientid":"NodeRed"},{"id":"b5e4f17d.4a1b1","type":"function","name":"hanlde internal messages","func":"//msg.subTypeString = \"\";\n//msg.topic = \"internal respones\";\n\nif (msg.subTypeString == 'I_TIME')\n{\n    var payload = parseInt(new Date().getTime()/1000);\n\tvar command = context.global.MYS.T_INTERNAL; \n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_TIME; // I_TIME\n\tmsg.payload = encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg;\n    \n}\nelse if  (msg.subTypeString == 'I_ID_REQUEST')\n{\n    msg.topic = \"I_ID_RESPONSE\";\n    msg.subTypeString = \"I_ID_RESPONSE\";\n    // 255;255;3;0;4;8 for ID 8\n    var command = context.global.MYS.T_INTERNAL;\n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_ID_RESPONSE; // I_ID_RESPONSE\n\n\tif (context.global.mysnextid[msg.controller] === undefined) {\n\t    payload = context.global.MYS.MIN_NODEID;\n\t}    \n\telse\n\t{\n\t    payload = context.global.mysnextid[msg.controller];\n\t}\n\t\n    msg.payload = encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg; \n} \nelse if  (msg.subTypeString == 'I_INCLUSION_MODE')\n{\n    // not yet implemented\n}\n\nreturn;\n\nfunction encode(destination, sensor, command, acknowledge, type, payload) {\n\tvar msg = destination.toString(10) + \";\" + sensor.toString(10) + \";\" + command.toString(10) + \";\" + acknowledge.toString(10) + \";\" + type.toString(10) + \";\";\n\tif (command == 4) {\n\t\tfor (var i = 0; i < payload.length; i++) {\n\t\t\tif (payload[i] < 16)\n\t\t\t\tmsg += \"0\";\n\t\t\tmsg += payload[i].toString(16);\n\t\t}\n\t} else {\n\t\tmsg += payload;\n\t}\n\tmsg += '\\n';\n\treturn msg.toString();\n}\n","outputs":1,"noerr":0,"x":1655.916648864746,"y":536.4166927337646,"z":"9592163f.6a6de8","wires":[["4d15a037.b2ea6","266b87b3.d99478"]]},{"id":"e6ce260d.1931d8","type":"switch","name":"switch message type","property":"messageType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"true","outputs":5,"x":1220.166648864746,"y":175.5000171661377,"z":"9592163f.6a6de8","wires":[["8c663d73.7399c"],["4a1e5f84.b5e1a"],["7753f9a2.88ac08"],["1e4aa61b.e1b55a"],["60a0dde4.9f5f24"]]},{"id":"8c663d73.7399c","type":"function","name":"presentation","func":"msg.subTypeString = context.global.MYS.SString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1449.916648864746,"y":38.2499885559082,"z":"9592163f.6a6de8","wires":[["df9e131d.2061f","4d15a037.b2ea6"]]},{"id":"7753f9a2.88ac08","type":"function","name":"req","func":"msg.topic = \"req\";\nreturn msg;","outputs":1,"noerr":0,"x":1445.5000228881836,"y":175.7500057220459,"z":"9592163f.6a6de8","wires":[["4d15a037.b2ea6"]]},{"id":"1e4aa61b.e1b55a","type":"function","name":"internal","func":"msg.subTypeString = context.global.MYS.IString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1449.5000228881836,"y":226.0000057220459,"z":"9592163f.6a6de8","wires":[["df9e131d.2061f","4d15a037.b2ea6","b5e4f17d.4a1b1"]]},{"id":"60a0dde4.9f5f24","type":"function","name":"stream","func":"msg.topic = \"stream\";\nreturn msg;","outputs":1,"x":1457.5000228881836,"y":321.0000057220459,"z":"9592163f.6a6de8","wires":[[]]},{"id":"4d15a037.b2ea6","type":"debug","name":"debug","active":true,"console":"false","complete":"true","x":1806.7500267028809,"y":235.00000667572021,"z":"9592163f.6a6de8","wires":[]},{"id":"4a1e5f84.b5e1a","type":"function","name":"set","func":"msg.subTypeString = context.global.MYS.VString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\n\nreturn msg;","outputs":1,"noerr":0,"x":1453.166648864746,"y":100.50000381469727,"z":"9592163f.6a6de8","wires":[["4d15a037.b2ea6","df9e131d.2061f"]]},{"id":"fc54bb91.03ab48","type":"debug","name":"","active":false,"console":"false","complete":"true","x":1179.9166259765625,"y":34.66668891906738,"z":"9592163f.6a6de8","wires":[]},{"id":"6aa2d9f6.955d28","type":"function","name":"Split GW Message","func":"\n    var tokens = msg.payload.split(\";\")\n    \n    msg.rawData = tokens;\n    if(tokens.length >= 6)\n    {\n        msg.nodeId = tokens[0];\n        msg.childSensorId = tokens[1];\n        msg.messageType = tokens[2];\n        msg.ack = tokens[3];\n        msg.subType = tokens[4];\n        msg.payload = tokens[5];\n        for (j=6; j<tokens.length; j++) \n            msg.payload = msg.payload + ';' + tokens[j];\n    }\n\nreturn msg;","outputs":1,"noerr":0,"x":984.6666488647461,"y":173.66664505004883,"z":"9592163f.6a6de8","wires":[["e6ce260d.1931d8","fc54bb91.03ab48","e0e76d62.1f189"]]},{"id":"df9e131d.2061f","type":"mqtt out","name":"Publish to MQTT","topic":"","qos":"","retain":"","broker":"ba386057.845d3","x":1819.9166526794434,"y":174.1666603088379,"z":"9592163f.6a6de8","wires":[]},{"id":"5f03c10e.a0fc4","type":"tcp request","server":"192.168.92.13","port":"5003","out":"char","splitc":"\\n","name":"MySWifi ESP8266 GW AES 13","x":376.6666946411133,"y":140.1666316986084,"z":"9592163f.6a6de8","wires":[["df1e322.f20e1d"]]},{"id":"e6d67f33.19298","type":"inject","name":"Startup","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":true,"x":106.25,"y":74.41665744781494,"z":"9592163f.6a6de8","wires":[["5f03c10e.a0fc4","64617800.9b9e88","c7d0d88b.382f28","56b9f6ab.a94608"]]},{"id":"ebcef3df.14311","type":"function","name":"ToString","func":"msg.payload = msg.payload.toString().replace(/[\\n\\r]/g, '');\n\nreturn msg;","outputs":1,"noerr":0,"x":790.1666946411133,"y":174.91669178009033,"z":"9592163f.6a6de8","wires":[["6aa2d9f6.955d28"]]},{"id":"31047fa6.cefb8","type":"catch","name":"","x":71,"y":642,"z":"9592163f.6a6de8","wires":[["3622f9b9.c9dd06"]]},{"id":"3622f9b9.c9dd06","type":"debug","name":"","active":false,"console":"false","complete":"true","x":216,"y":642,"z":"9592163f.6a6de8","wires":[]},{"id":"64617800.9b9e88","type":"function","name":"MYS Initialize","func":"function MySHelper() { \n\nMySHelper.prototype.TOPIC_PREFIX = \"MYS-NODERED\";\n\nMySHelper.prototype.MIN_NODEID = 10;\n\n\n// don't touch below :)\n    \nMySHelper.prototype.T_PRESENTATION                = 0;\nMySHelper.prototype.T_SET                         = 1;\nMySHelper.prototype.T_REQ                         = 2;\nMySHelper.prototype.T_INTERNAL                    = 3;\nMySHelper.prototype.T_STREAM                      = 4;\n\nMySHelper.prototype.I_BATTERY_LEVEL               = 0;\nMySHelper.prototype.I_TIME                        = 1;\nMySHelper.prototype.I_VERSION                     = 2;\nMySHelper.prototype.I_ID_REQUEST                  = 3;\nMySHelper.prototype.I_ID_RESPONSE                 = 4;\nMySHelper.prototype.I_INCLUSION_MODE              = 5;\nMySHelper.prototype.I_CONFIG                      = 6;\nMySHelper.prototype.I_PING                        = 7;\nMySHelper.prototype.I_PING_ACK                    = 8;\nMySHelper.prototype.I_LOG_MESSAGE                 = 9;\nMySHelper.prototype.I_CHILDREN                    = 10;\nMySHelper.prototype.I_SKETCH_NAME                 = 11;\nMySHelper.prototype.I_SKETCH_VERSION              = 12;\nMySHelper.prototype.I_REBOOT                      = 13;\nMySHelper.prototype.I_GATEWAY_READY               = 14;\nMySHelper.prototype.I_REQUEST_SIGNING             = 15;\nMySHelper.prototype.I_GET_NONCE                   = 16;\nMySHelper.prototype.I_GET_NONCE_RESPONSE          = 17;\nMySHelper.prototype.I_HEARTBEAT                   = 18;\nMySHelper.prototype.I_PRESENTATION                = 19;\n \nvar itype = {\nI_BATTERY_LEVEL:                    MySHelper.prototype.I_BATTERY_LEVEL,\nI_TIME:                             MySHelper.prototype.I_TIME,\nI_VERSION:                          MySHelper.prototype.I_VERSION,\nI_ID_REQUEST:                       MySHelper.prototype.I_ID_REQUEST,\nI_ID_RESPONSE:                      MySHelper.prototype.I_ID_RESPONSE,\nI_INCLUSION_MODE:                   MySHelper.prototype.I_INCLUSION_MODE,\nI_CONFIG:                           MySHelper.prototype.I_CONFIG,\nI_PING:                             MySHelper.prototype.I_PING,\nI_PING_ACK:                         MySHelper.prototype.I_PING_ACK,\nI_LOG_MESSAGE:                      MySHelper.prototype.I_LOG_MESSAGE,\nI_CHILDREN:                         MySHelper.prototype.I_CHILDREN,\nI_SKETCH_NAME:                      MySHelper.prototype.I_SKETCH_NAME,\nI_SKETCH_VERSION:                   MySHelper.prototype.I_SKETCH_VERSION,\nI_REBOOT:                           MySHelper.prototype.I_REBOOT,\nI_GATEWAY_READY:                    MySHelper.prototype.I_GATEWAY_READY,\nI_REQUEST_SIGNING:                  MySHelper.prototype.I_REQUEST_SIGNING,\nI_GET_NONCE:                        MySHelper.prototype.I_GET_NONCE,\nI_GET_NONCE_RESPONSE:               MySHelper.prototype.I_GET_NONCE_RESPONSE,\nI_HEARTBEAT:                        MySHelper.prototype.I_HEARTBEAT,\nI_PRESENTATION:                     MySHelper.prototype.I_PRESENTATION\n};\n\nMySHelper.prototype.IString = function(I_SUBTYPE) {\n    for (var prop in itype ) \n    if( itype[ prop ] === parseInt(I_SUBTYPE) )\n        return prop;\n};\n\nMySHelper.prototype.V_TEMP                = 0;\nMySHelper.prototype.V_HUM                 = 1;\nMySHelper.prototype.V_LIGHT               = 2;\nMySHelper.prototype.V_DIMMER              = 3;\nMySHelper.prototype.V_PRESSURE            = 4;\nMySHelper.prototype.V_FORECAST            = 5;\nMySHelper.prototype.V_RAIN                = 6;\nMySHelper.prototype.V_RAINRATE            = 7;\nMySHelper.prototype.V_WIND                = 8;\nMySHelper.prototype.V_GUST                = 9;\nMySHelper.prototype.V_DIRECTION           = 10;\nMySHelper.prototype.V_UV                  = 11;\nMySHelper.prototype.V_WEIGHT              = 12;\nMySHelper.prototype.V_DISTANCE            = 13;\nMySHelper.prototype.V_IMPEDANCE           = 14;\nMySHelper.prototype.V_ARMED               = 15;\nMySHelper.prototype.V_TRIPPED             = 16;\nMySHelper.prototype.V_WATT                = 17;\nMySHelper.prototype.V_KWH                 = 18;\nMySHelper.prototype.V_SCENE_ON            = 19;\nMySHelper.prototype.V_SCENE_OFF           = 20;\nMySHelper.prototype.V_HEATER              = 21;\nMySHelper.prototype.V_HEATER_SW           = 22;\nMySHelper.prototype.V_LIGHT_LEVEL         = 23;\nMySHelper.prototype.V_VAR1                = 24;\nMySHelper.prototype.V_VAR2                = 25;\nMySHelper.prototype.V_VAR3                = 26;\nMySHelper.prototype.V_VAR4                = 27;\nMySHelper.prototype.V_VAR5                = 28;\nMySHelper.prototype.V_UP                  = 29;\nMySHelper.prototype.V_DOWN                = 30;\nMySHelper.prototype.V_STOP                = 31;\nMySHelper.prototype.V_IR_SEND             = 32;\nMySHelper.prototype.V_IR_RECEIVE          = 33;\nMySHelper.prototype.V_FLOW                = 34;\nMySHelper.prototype.V_VOLUME              = 35;\nMySHelper.prototype.V_LOCK_STATUS         = 36;\nMySHelper.prototype.V_LEVEL               = 37; \nMySHelper.prototype.V_VOLTAGE             = 38; \nMySHelper.prototype.V_CURRENT             = 39; \nMySHelper.prototype.V_RGB                 = 40; \nMySHelper.prototype.V_RGBW                = 41;\nMySHelper.prototype.V_ID                  = 42;\nMySHelper.prototype.V_UNIT_PREFIX         = 43;\nMySHelper.prototype.V_HVAC_SETPOINT_COOL  = 44;\nMySHelper.prototype.V_HVAC_SETPOINT_HEAT  = 45;\nMySHelper.prototype.V_HVAC_FLOW_MODE      = 46;\nMySHelper.prototype.V_TEXT                = 47;\n\nvar vtype = {\nV_TEMP:              MySHelper.prototype.V_TEMP,\nV_HUM:               MySHelper.prototype.V_HUM,\nV_LIGHT:             MySHelper.prototype.V_LIGHT,\nV_DIMMER:            MySHelper.prototype.V_DIMMER,\nV_PRESSURE:          MySHelper.prototype.V_PRESSURE,\nV_FORECAST:          MySHelper.prototype.V_FORECAST,\nV_RAIN:              MySHelper.prototype.V_RAIN,\nV_RAINRATE:          MySHelper.prototype.V_RAINRATE,\nV_WIND:              MySHelper.prototype.V_WIND,\nV_GUST:              MySHelper.prototype.V_GUST,\nV_DIRECTION:         MySHelper.prototype.V_DIRECTION,\nV_UV:                MySHelper.prototype.V_UV,\nV_WEIGHT:            MySHelper.prototype.V_WEIGHT,\nV_DISTANCE:          MySHelper.prototype.V_DISTANCE,\nV_IMPEDANCE:         MySHelper.prototype.V_IMPEDANCE,\nV_ARMED:             MySHelper.prototype.V_ARMED,\nV_TRIPPED:           MySHelper.prototype.V_TRIPPED,\nV_WATT:              MySHelper.prototype.V_WATT,\nV_KWH:               MySHelper.prototype.V_KWH,\nV_SCENE_ON:          MySHelper.prototype.V_SCENE_ON,\nV_SCENE_OFF:         MySHelper.prototype.V_SCENE_OFF,\nV_HEATER:            MySHelper.prototype.V_HEATER,\nV_HEATER_SW:         MySHelper.prototype.V_HEATER_SW,\nV_LIGHT_LEVEL:       MySHelper.prototype.V_LIGHT_LEVEL,\nV_VAR1:              MySHelper.prototype.V_VAR1,\nV_VAR2:              MySHelper.prototype.V_VAR2,\nV_VAR3:              MySHelper.prototype.V_VAR3,\nV_VAR4:              MySHelper.prototype.V_VAR4,\nV_VAR5:              MySHelper.prototype.V_VAR5,\nV_UP:                MySHelper.prototype.V_UP,\nV_DOWN:              MySHelper.prototype.V_DOWN,\nV_STOP:              MySHelper.prototype.V_STOP,\nV_IR_SEND:           MySHelper.prototype.V_IR_SEND,\nV_IR_RECEIVE:        MySHelper.prototype.V_IR_RECEIVE,\nV_FLOW:              MySHelper.prototype.V_FLOW,\nV_VOLUME:            MySHelper.prototype.V_VOLUME,\nV_LOCK_STATUS:       MySHelper.prototype.V_LOCK_STATUS,\nV_LEVEL:             MySHelper.prototype.V_LEVEL,\nV_VOLTAGE:           MySHelper.prototype.V_VOLTAGE, \nV_CURRENT:           MySHelper.prototype.V_CURRENT,\nV_RGB:               MySHelper.prototype.V_RGB,\nV_RGBW:              MySHelper.prototype.V_RGBW,\nV_ID:                MySHelper.prototype.V_ID,\nV_UNIT_PREFIX:       MySHelper.prototype.V_UNIT_PREFIX,\nV_HVAC_SETPOINT_COOL:MySHelper.prototype.V_HVAC_SETPOINT_COOL,\nV_HVAC_SETPOINT_HEAT:MySHelper.prototype.V_HVAC_SETPOINT_HEAT,\nV_HVAC_FLOW_MODE:    MySHelper.prototype.V_HVAC_FLOW_MODE,\nV_TEXT:              MySHelper.prototype.V_TEXT\n};\n\n\n\nMySHelper.prototype.VString = function(V_SUBTYPE) {\n    for (var prop in vtype ) \n    if( vtype[ prop ] === parseInt(V_SUBTYPE) )\n        return prop;\n};\n    \n\nMySHelper.prototype.S_DOOR = 0; // Door sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_MOTION = 1;  // Motion sensor; V_TRIPPED; V_ARMED \nMySHelper.prototype.S_SMOKE = 2;  // Smoke sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_LIGHT = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nMySHelper.prototype.S_BINARY = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nMySHelper.prototype.S_DIMMER = 4; // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nMySHelper.prototype.S_COVER = 5; // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nMySHelper.prototype.S_TEMP = 6; // Temperature sensor; V_TEMP\nMySHelper.prototype.S_HUM = 7; // Humidity sensor; V_HUM\nMySHelper.prototype.S_BARO = 8; // Barometer sensor; V_PRESSURE; V_FORECAST\nMySHelper.prototype.S_WIND = 9; // Wind sensor; V_WIND; V_GUST\nMySHelper.prototype.S_RAIN = 10; // Rain sensor; V_RAIN; V_RAINRATE\nMySHelper.prototype.S_UV = 11; // Uv sensor; V_UV\nMySHelper.prototype.S_WEIGHT = 12; // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nMySHelper.prototype.S_POWER = 13; // Power meter; V_WATT; V_KWH\nMySHelper.prototype.S_HEATER = 14; // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nMySHelper.prototype.S_DISTANCE = 15; // Distance sensor; V_DISTANCE\nMySHelper.prototype.S_LIGHT_LEVEL = 16; // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nMySHelper.prototype.S_ARDUINO_NODE = 17 ; // Used (internally) for presenting a non-repeating Arduino node\nMySHelper.prototype.S_ARDUINO_REPEATER_NODE = 18; // Used (internally) for presenting a repeating Arduino node \nMySHelper.prototype.S_LOCK = 19; // Lock device; V_LOCK_STATUS\nMySHelper.prototype.S_IR = 20; // Ir device; V_IR_SEND; V_IR_RECEIVE\nMySHelper.prototype.S_WATER = 21; // Water meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_AIR_QUALITY = 22; // Air quality sensor; V_LEVEL\nMySHelper.prototype.S_CUSTOM = 23; // Custom sensor \nMySHelper.prototype.S_DUST = 24; // Dust sensor; V_LEVEL\nMySHelper.prototype.S_SCENE_CONTROLLER = 25; // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nMySHelper.prototype.S_RGB_LIGHT = 26; // RGB light. Send color component data using V_RGB. Also supports V_WATT \nMySHelper.prototype.S_RGBW_LIGHT = 27; // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nMySHelper.prototype.S_COLOR_SENSOR = 28;  // Color sensor; send color information using V_RGB\nMySHelper.prototype.S_HVAC = 28; // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nMySHelper.prototype.S_MULTIMETER = 29; // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nMySHelper.prototype.S_SPRINKLER  = 30;  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nMySHelper.prototype.S_WATER_LEAK = 31; // Water leak sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_SOUND = 32; // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nMySHelper.prototype.S_VIBRATION = 33; // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nMySHelper.prototype.S_MOISTURE = 34; // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nMySHelper.prototype.S_INFO = 35; // LCD text device / Simple information device on controller; V_TEXT\nMySHelper.prototype.S_GAS = 36; // Gas meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_GPS = 37; // GPS Sensor; V_POSITION\n \nvar stype = {\nS_DOOR:                 MySHelper.prototype.S_DOOR, // Door sensor; V_TRIPPED; V_ARMED\nS_MOTION:               MySHelper.prototype.S_MOTION,  // Motion sensor; V_TRIPPED; V_ARMED \nS_SMOKE:                MySHelper.prototype.S_SMOKE,  // Smoke sensor; V_TRIPPED; V_ARMED\nS_LIGHT:                MySHelper.prototype.S_LIGHT, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nS_BINARY:               MySHelper.prototype.S_BINARY, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nS_DIMMER:               MySHelper.prototype.S_DIMMER, // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nS_COVER:                MySHelper.prototype.S_COVER, // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nS_TEMP:                 MySHelper.prototype.S_TEMP, // Temperature sensor; V_TEMP\nS_HUM:                  MySHelper.prototype.S_HUM, // Humidity sensor; V_HUM\nS_BARO:                 MySHelper.prototype.S_BARO, // Barometer sensor; V_PRESSURE; V_FORECAST\nS_WIND:                 MySHelper.prototype.S_WIND, // Wind sensor; V_WIND; V_GUST\nS_RAIN:                 MySHelper.prototype.S_RAIN, // Rain sensor; V_RAIN; V_RAINRATE\nS_UV:                   MySHelper.prototype.S_UV, // Uv sensor; V_UV\nS_WEIGHT:               MySHelper.prototype.S_WEIGHT, // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nS_POWER:                MySHelper.prototype.S_POWER, // Power meter; V_WATT; V_KWH\nS_HEATER:               MySHelper.prototype.S_HEATER, // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nS_DISTANCE:             MySHelper.prototype.S_DISTANCE, // Distance sensor; V_DISTANCE\nS_LIGHT_LEVEL:          MySHelper.prototype.S_LIGHT_LEVEL, // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nS_ARDUINO_NODE:         MySHelper.prototype.S_ARDUINO_NODE, // Used (internally) for presenting a non-repeating Arduino node\nS_ARDUINO_REPEATER_NODE:MySHelper.prototype.S_ARDUINO_REPEATER_NODE, // Used (internally) for presenting a repeating Arduino node \nS_LOCK:                 MySHelper.prototype.S_LOCK, // Lock device; V_LOCK_STATUS\nS_IR:                   MySHelper.prototype.S_IR, // Ir device; V_IR_SEND; V_IR_RECEIVE\nS_WATER:                MySHelper.prototype.S_WATER, // Water meter; V_FLOW; V_VOLUME\nS_AIR_QUALITY:          MySHelper.prototype.S_AIR_QUALITY, // Air quality sensor; V_LEVEL\nS_CUSTOM:               MySHelper.prototype.S_CUSTOM, // Custom sensor \nS_DUST:                 MySHelper.prototype.S_DUST, // Dust sensor; V_LEVEL\nS_SCENE_CONTROLLER:     MySHelper.prototype.S_SCENE_CONTROLLER, // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nS_RGB_LIGHT:            MySHelper.prototype.S_RGB_LIGHT, // RGB light. Send color component data using V_RGB. Also supports V_WATT \nS_RGBW_LIGHT:           MySHelper.prototype.S_RGBW_LIGHT, // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nS_COLOR_SENSOR:         MySHelper.prototype.S_COLOR_SENSOR,  // Color sensor; send color information using V_RGB\nS_HVAC:                 MySHelper.prototype.S_HVAC, // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nS_MULTIMETER:           MySHelper.prototype.S_MULTIMETER, // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nS_SPRINKLER:            MySHelper.prototype.S_SPRINKLER,  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nS_WATER_LEAK:           MySHelper.prototype.S_WATER_LEAK, // Water leak sensor; V_TRIPPED; V_ARMED\nS_SOUND:                MySHelper.prototype.S_SOUND, // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nS_VIBRATION:            MySHelper.prototype.S_VIBRATION, // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nS_MOISTURE:             MySHelper.prototype.S_MOISTURE, // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nS_INFO:                 MySHelper.prototype.S_INFO, // LCD text device / Simple information device on controller; V_TEXT\nS_GAS:                  MySHelper.prototype.S_GAS, // Gas meter; V_FLOW; V_VOLUME\nS_GPS:                  MySHelper.prototype.S_GPS // GPS Sensor; V_POSITION\n};\n\nMySHelper.prototype.SString = function(S_SUBTYPE) {\n    for (var prop in stype ) \n    if( stype[ prop ] === parseInt(S_SUBTYPE) )\n        return prop;\n};    \n    \n}\n\n\nvar MySHelperObj = new MySHelper();\n\ncontext.global.MYS = MySHelperObj;\n\nreturn msg;","outputs":1,"noerr":0,"x":325.25,"y":59.00000190734863,"z":"9592163f.6a6de8","wires":[[]]},{"id":"df1e322.f20e1d","type":"function","name":"Set Controller 1","func":"msg.controller = 1\n\nreturn msg;","outputs":1,"noerr":0,"x":602.0000076293945,"y":140.50000190734863,"z":"9592163f.6a6de8","wires":[["ebcef3df.14311"]]},{"id":"266b87b3.d99478","type":"switch","name":"route to controller n","property":"controller","rules":[{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"false","outputs":4,"x":94,"y":207.25000381469727,"z":"9592163f.6a6de8","wires":[["5f03c10e.a0fc4"],["c7d0d88b.382f28"],[],[]]},{"id":"c7d0d88b.382f28","type":"tcp request","server":"192.168.92.14","port":"5003","out":"char","splitc":"\\n","name":"MySWifi ESP8266 GW AES 14","x":370.5,"y":217.25000381469727,"z":"9592163f.6a6de8","wires":[["c5f14d8f.3a0eb"]]},{"id":"c5f14d8f.3a0eb","type":"function","name":"Set Controller 2","func":"msg.controller = 2\n\nreturn msg;","outputs":1,"noerr":0,"x":597.5000076293945,"y":218.750018119812,"z":"9592163f.6a6de8","wires":[["ebcef3df.14311"]]},{"id":"56b9f6ab.a94608","type":"file in","name":"read store for next ids","filename":"mysids.dump","format":"utf8","x":346,"y":97,"z":"9592163f.6a6de8","wires":[["57db23d6.a824dc"]]},{"id":"e000bd09.1fff4","type":"debug","name":"Debug","active":true,"console":"false","complete":"true","x":785,"y":470,"z":"9592163f.6a6de8","wires":[]},{"id":"57db23d6.a824dc","type":"function","name":"store to context.global.mysnextid","func":"if (msg.payload === undefined) {\n          var mysnextid = {};\n\n        obj = mysnextid;  \n}\nelse \n{\ntry{\n        obj = JSON.parse(msg.payload);\n    }\n    catch(e){\n        \n        var mysnextid = {};\n\n        obj = mysnextid;\n        \n    }\n}    \n\ncontext.global.mysnextid = obj;\n\nmsg.payload = context.global.mysnextid;\n\nreturn msg;","outputs":1,"noerr":0,"x":591,"y":96,"z":"9592163f.6a6de8","wires":[[]]},{"id":"dfba7d69.20458","type":"file","name":"dump mysids","filename":"mysids.dump","appendNewline":true,"createDir":false,"overwriteFile":"true","x":1434,"y":375,"z":"9592163f.6a6de8","wires":[]},{"id":"25efb0d3.da105","type":"inject","name":"Test Backup","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":false,"x":209,"y":456,"z":"9592163f.6a6de8","wires":[["e7d998a7.182668"]]},{"id":"e7d998a7.182668","type":"function","name":"Show context.global.mysnextid","func":"msg.payload = JSON.stringify(context.global.mysnextid);\n\nreturn msg;","outputs":1,"noerr":0,"x":427,"y":453,"z":"9592163f.6a6de8","wires":[["e000bd09.1fff4"]]},{"id":"e0e76d62.1f189","type":"function","name":"handle nextids","func":"// increase nextid, if nodeid >= nextid \n\nif (msg.nodeid < 255)\n{\n    if (context.global.mysnextid[msg.controller] === undefined) {\n        context.global.mysnextid[msg.controller] = msg.nodeid+1;\n    }\n    \n    if (msg.nodeid >= context.global.mysnextid[msg.controller]) {\n       context.global.mysnextid[msg.controller] = msg.nodeid+1; \n    }\n    \n}\n\nreturn msg;","outputs":1,"noerr":0,"x":1223,"y":368,"z":"9592163f.6a6de8","wires":[["dfba7d69.20458"]]},{"id":"a7d335f6.582cc8","type":"inject","name":"Test GetNodeId","topic":"","payload":"255;0;3;0;3;","payloadType":"string","repeat":"","crontab":"","once":false,"x":456,"y":264,"z":"9592163f.6a6de8","wires":[["c5f14d8f.3a0eb"]]}]
                                    Features:
                                    • Publish states to mqtt
                                    • handle node-ids
                                    • support multiple ethernet conrollers
                                    • should be adoptable to serial controllers
                                    Restrictions:
                                    • read only, no values can be sent to nodes
                                    • you will find others :)
                                    • FotoFieberF
                                      FotoFieberF
                                      FotoFieber
                                      • Fixed node-id handling for new nodes.
                                      • added write support (see "MQTT to MYS" convert for details)
                                      • parameters can be set in 'MYS initialize'
                                      [{"id":"ba386057.845d3","type":"mqtt-broker","broker":"192.168.92.4","port":"1883","clientid":"NodeRed"},{"id":"e6ce260d.1931d8","type":"switch","z":"9592163f.6a6de8","name":"switch message type","property":"messageType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"true","outputs":5,"x":1259.166648864746,"y":182.50001335144043,"wires":[["8c663d73.7399c"],["4a1e5f84.b5e1a"],["7753f9a2.88ac08"],["1e4aa61b.e1b55a"],["60a0dde4.9f5f24"]]},{"id":"8c663d73.7399c","type":"function","z":"9592163f.6a6de8","name":"presentation","func":"msg.subTypeString = context.global.MYS.SString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1488.916648864746,"y":45.24998474121094,"wires":[["df9e131d.2061f","4d15a037.b2ea6"]]},{"id":"7753f9a2.88ac08","type":"function","z":"9592163f.6a6de8","name":"req","func":"msg.topic = \"req\";\nreturn msg;","outputs":1,"noerr":0,"x":1484.5000228881836,"y":182.75000190734863,"wires":[["4d15a037.b2ea6"]]},{"id":"1e4aa61b.e1b55a","type":"function","z":"9592163f.6a6de8","name":"internal","func":"msg.subTypeString = context.global.MYS.IString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1488.5000228881836,"y":233.00000190734863,"wires":[["df9e131d.2061f","4d15a037.b2ea6","b5e4f17d.4a1b1"]]},{"id":"60a0dde4.9f5f24","type":"function","z":"9592163f.6a6de8","name":"stream","func":"msg.topic = \"stream\";\nreturn msg;","outputs":1,"x":1496.5000228881836,"y":328.00000190734863,"wires":[[]]},{"id":"4d15a037.b2ea6","type":"debug","z":"9592163f.6a6de8","name":"debug","active":false,"console":"false","complete":"true","x":1845.7500267028809,"y":242.00000286102295,"wires":[]},{"id":"4a1e5f84.b5e1a","type":"function","z":"9592163f.6a6de8","name":"set","func":"msg.subTypeString = context.global.MYS.VString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\n\nreturn msg;","outputs":1,"noerr":0,"x":1492.166648864746,"y":107.5,"wires":[["4d15a037.b2ea6","df9e131d.2061f"]]},{"id":"fc54bb91.03ab48","type":"debug","z":"9592163f.6a6de8","name":"","active":false,"console":"false","complete":"true","x":1218.9166259765625,"y":41.66668510437012,"wires":[]},{"id":"6aa2d9f6.955d28","type":"function","z":"9592163f.6a6de8","name":"Split GW Message","func":"\n    var tokens = msg.payload.split(\";\")\n    \n    msg.rawData = tokens;\n    if(tokens.length >= 6)\n    {\n        msg.nodeId = parseInt(tokens[0]);\n        msg.childSensorId = parseInt(tokens[1]);\n        msg.messageType = parseInt(tokens[2]);\n        msg.ack = parseInt(tokens[3]);\n        msg.subType = parseInt(tokens[4]);\n        msg.payload = tokens[5];\n        for (j=6; j<tokens.length; j++) \n            msg.payload = msg.payload + ';' + tokens[j];\n    }\n\nreturn msg;","outputs":1,"noerr":0,"x":1023.6666488647461,"y":180.66664123535156,"wires":[["e6ce260d.1931d8","fc54bb91.03ab48","e0e76d62.1f189"]]},{"id":"df9e131d.2061f","type":"mqtt out","z":"9592163f.6a6de8","name":"Publish to MQTT","topic":"","qos":"","retain":"","broker":"ba386057.845d3","x":1858.9166526794434,"y":181.16665649414062,"wires":[]},{"id":"b5e4f17d.4a1b1","type":"function","z":"9592163f.6a6de8","name":"hanlde internal messages","func":"//msg.subTypeString = \"\";\n//msg.topic = \"internal respones\";\n\nif (msg.subTypeString == 'I_TIME')\n{\n    var payload = parseInt(new Date().getTime()/1000);\n\tvar command = context.global.MYS.T_INTERNAL; \n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_TIME; // I_TIME\n\tmsg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg;\n    \n}\nelse if  (msg.subTypeString == 'I_ID_REQUEST')\n{\n    msg.topic = \"I_ID_RESPONSE\";\n    msg.subTypeString = \"I_ID_RESPONSE\";\n    // 255;255;3;0;4;8 for ID 8\n    var command = context.global.MYS.T_INTERNAL;\n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_ID_RESPONSE; // I_ID_RESPONSE\n\n\tif (context.global.mysnextid[msg.controller] === undefined) {\n\t    payload = context.global.MYS.MIN_NODEID;\n\t}    \n\telse\n\t{\n\t    payload = context.global.mysnextid[msg.controller];\n\t}\n\t\n    msg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg; \n} \nelse if  (msg.subTypeString == 'I_CONFIG')\n{\n    var payload = 'M';\n\tvar command = context.global.MYS.T_INTERNAL; \n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_CONFIG; // I_TIME\n\tmsg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg;\n}\nelse if  (msg.subTypeString == 'I_INCLUSION_MODE')\n{\n    // not yet implemented\n}\n\nreturn;\n\n\n","outputs":1,"noerr":0,"x":1694.916648864746,"y":543.4166889190674,"wires":[["4d15a037.b2ea6","266b87b3.d99478"]]},{"id":"e6d67f33.19298","type":"inject","z":"9592163f.6a6de8","name":"Startup","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":true,"x":145.25,"y":81.41665363311768,"wires":[["64617800.9b9e88","56b9f6ab.a94608","3e866f6d.c1799"]]},{"id":"ebcef3df.14311","type":"function","z":"9592163f.6a6de8","name":"ToString","func":"msg.payload = msg.payload.toString().replace(/[\\n\\r]/g, '');\n\nreturn msg;","outputs":1,"noerr":0,"x":829.1666946411133,"y":181.91668796539307,"wires":[["6aa2d9f6.955d28"]]},{"id":"31047fa6.cefb8","type":"catch","z":"9592163f.6a6de8","name":"","x":58,"y":449,"wires":[["3622f9b9.c9dd06"]]},{"id":"3622f9b9.c9dd06","type":"debug","z":"9592163f.6a6de8","name":"","active":false,"console":"false","complete":"true","x":224,"y":450,"wires":[]},{"id":"64617800.9b9e88","type":"function","z":"9592163f.6a6de8","name":"MYS Initialize","func":"function MySHelper() { \n\nMySHelper.prototype.TOPIC_PREFIX = \"MYS-NODERED\";\n\nMySHelper.prototype.MIN_NODEID = 10;\n\n\n// don't touch below :)\n    \nMySHelper.prototype.T_PRESENTATION                = 0;\nMySHelper.prototype.T_SET                         = 1;\nMySHelper.prototype.T_REQ                         = 2;\nMySHelper.prototype.T_INTERNAL                    = 3;\nMySHelper.prototype.T_STREAM                      = 4;\n\nMySHelper.prototype.I_BATTERY_LEVEL               = 0;\nMySHelper.prototype.I_TIME                        = 1;\nMySHelper.prototype.I_VERSION                     = 2;\nMySHelper.prototype.I_ID_REQUEST                  = 3;\nMySHelper.prototype.I_ID_RESPONSE                 = 4;\nMySHelper.prototype.I_INCLUSION_MODE              = 5;\nMySHelper.prototype.I_CONFIG                      = 6;\nMySHelper.prototype.I_PING                        = 7;\nMySHelper.prototype.I_PING_ACK                    = 8;\nMySHelper.prototype.I_LOG_MESSAGE                 = 9;\nMySHelper.prototype.I_CHILDREN                    = 10;\nMySHelper.prototype.I_SKETCH_NAME                 = 11;\nMySHelper.prototype.I_SKETCH_VERSION              = 12;\nMySHelper.prototype.I_REBOOT                      = 13;\nMySHelper.prototype.I_GATEWAY_READY               = 14;\nMySHelper.prototype.I_REQUEST_SIGNING             = 15;\nMySHelper.prototype.I_GET_NONCE                   = 16;\nMySHelper.prototype.I_GET_NONCE_RESPONSE          = 17;\nMySHelper.prototype.I_HEARTBEAT                   = 18;\nMySHelper.prototype.I_PRESENTATION                = 19;\n \nvar itype = {\nI_BATTERY_LEVEL:                    MySHelper.prototype.I_BATTERY_LEVEL,\nI_TIME:                             MySHelper.prototype.I_TIME,\nI_VERSION:                          MySHelper.prototype.I_VERSION,\nI_ID_REQUEST:                       MySHelper.prototype.I_ID_REQUEST,\nI_ID_RESPONSE:                      MySHelper.prototype.I_ID_RESPONSE,\nI_INCLUSION_MODE:                   MySHelper.prototype.I_INCLUSION_MODE,\nI_CONFIG:                           MySHelper.prototype.I_CONFIG,\nI_PING:                             MySHelper.prototype.I_PING,\nI_PING_ACK:                         MySHelper.prototype.I_PING_ACK,\nI_LOG_MESSAGE:                      MySHelper.prototype.I_LOG_MESSAGE,\nI_CHILDREN:                         MySHelper.prototype.I_CHILDREN,\nI_SKETCH_NAME:                      MySHelper.prototype.I_SKETCH_NAME,\nI_SKETCH_VERSION:                   MySHelper.prototype.I_SKETCH_VERSION,\nI_REBOOT:                           MySHelper.prototype.I_REBOOT,\nI_GATEWAY_READY:                    MySHelper.prototype.I_GATEWAY_READY,\nI_REQUEST_SIGNING:                  MySHelper.prototype.I_REQUEST_SIGNING,\nI_GET_NONCE:                        MySHelper.prototype.I_GET_NONCE,\nI_GET_NONCE_RESPONSE:               MySHelper.prototype.I_GET_NONCE_RESPONSE,\nI_HEARTBEAT:                        MySHelper.prototype.I_HEARTBEAT,\nI_PRESENTATION:                     MySHelper.prototype.I_PRESENTATION\n};\n\nMySHelper.prototype.IString = function(I_SUBTYPE) {\n    for (var prop in itype ) \n    if( itype[ prop ] === parseInt(I_SUBTYPE) )\n        return prop;\n};\n\nMySHelper.prototype.V_TEMP                = 0;\nMySHelper.prototype.V_HUM                 = 1;\nMySHelper.prototype.V_LIGHT               = 2;\nMySHelper.prototype.V_STATUS              = 2;\nMySHelper.prototype.V_DIMMER              = 3;\nMySHelper.prototype.V_PRESSURE            = 4;\nMySHelper.prototype.V_FORECAST            = 5;\nMySHelper.prototype.V_RAIN                = 6;\nMySHelper.prototype.V_RAINRATE            = 7;\nMySHelper.prototype.V_WIND                = 8;\nMySHelper.prototype.V_GUST                = 9;\nMySHelper.prototype.V_DIRECTION           = 10;\nMySHelper.prototype.V_UV                  = 11;\nMySHelper.prototype.V_WEIGHT              = 12;\nMySHelper.prototype.V_DISTANCE            = 13;\nMySHelper.prototype.V_IMPEDANCE           = 14;\nMySHelper.prototype.V_ARMED               = 15;\nMySHelper.prototype.V_TRIPPED             = 16;\nMySHelper.prototype.V_WATT                = 17;\nMySHelper.prototype.V_KWH                 = 18;\nMySHelper.prototype.V_SCENE_ON            = 19;\nMySHelper.prototype.V_SCENE_OFF           = 20;\nMySHelper.prototype.V_HEATER              = 21;\nMySHelper.prototype.V_HEATER_SW           = 22;\nMySHelper.prototype.V_LIGHT_LEVEL         = 23;\nMySHelper.prototype.V_VAR1                = 24;\nMySHelper.prototype.V_VAR2                = 25;\nMySHelper.prototype.V_VAR3                = 26;\nMySHelper.prototype.V_VAR4                = 27;\nMySHelper.prototype.V_VAR5                = 28;\nMySHelper.prototype.V_UP                  = 29;\nMySHelper.prototype.V_DOWN                = 30;\nMySHelper.prototype.V_STOP                = 31;\nMySHelper.prototype.V_IR_SEND             = 32;\nMySHelper.prototype.V_IR_RECEIVE          = 33;\nMySHelper.prototype.V_FLOW                = 34;\nMySHelper.prototype.V_VOLUME              = 35;\nMySHelper.prototype.V_LOCK_STATUS         = 36;\nMySHelper.prototype.V_LEVEL               = 37; \nMySHelper.prototype.V_VOLTAGE             = 38; \nMySHelper.prototype.V_CURRENT             = 39; \nMySHelper.prototype.V_RGB                 = 40; \nMySHelper.prototype.V_RGBW                = 41;\nMySHelper.prototype.V_ID                  = 42;\nMySHelper.prototype.V_UNIT_PREFIX         = 43;\nMySHelper.prototype.V_HVAC_SETPOINT_COOL  = 44;\nMySHelper.prototype.V_HVAC_SETPOINT_HEAT  = 45;\nMySHelper.prototype.V_HVAC_FLOW_MODE      = 46;\nMySHelper.prototype.V_TEXT                = 47;\n\nvar vtype = {\nV_TEMP:              MySHelper.prototype.V_TEMP,\nV_HUM:               MySHelper.prototype.V_HUM,\nV_STATUS:            MySHelper.prototype.V_STATUS,\nV_LIGHT:             MySHelper.prototype.V_LIGHT,\nV_DIMMER:            MySHelper.prototype.V_DIMMER,\nV_PRESSURE:          MySHelper.prototype.V_PRESSURE,\nV_FORECAST:          MySHelper.prototype.V_FORECAST,\nV_RAIN:              MySHelper.prototype.V_RAIN,\nV_RAINRATE:          MySHelper.prototype.V_RAINRATE,\nV_WIND:              MySHelper.prototype.V_WIND,\nV_GUST:              MySHelper.prototype.V_GUST,\nV_DIRECTION:         MySHelper.prototype.V_DIRECTION,\nV_UV:                MySHelper.prototype.V_UV,\nV_WEIGHT:            MySHelper.prototype.V_WEIGHT,\nV_DISTANCE:          MySHelper.prototype.V_DISTANCE,\nV_IMPEDANCE:         MySHelper.prototype.V_IMPEDANCE,\nV_ARMED:             MySHelper.prototype.V_ARMED,\nV_TRIPPED:           MySHelper.prototype.V_TRIPPED,\nV_WATT:              MySHelper.prototype.V_WATT,\nV_KWH:               MySHelper.prototype.V_KWH,\nV_SCENE_ON:          MySHelper.prototype.V_SCENE_ON,\nV_SCENE_OFF:         MySHelper.prototype.V_SCENE_OFF,\nV_HEATER:            MySHelper.prototype.V_HEATER,\nV_HEATER_SW:         MySHelper.prototype.V_HEATER_SW,\nV_LIGHT_LEVEL:       MySHelper.prototype.V_LIGHT_LEVEL,\nV_VAR1:              MySHelper.prototype.V_VAR1,\nV_VAR2:              MySHelper.prototype.V_VAR2,\nV_VAR3:              MySHelper.prototype.V_VAR3,\nV_VAR4:              MySHelper.prototype.V_VAR4,\nV_VAR5:              MySHelper.prototype.V_VAR5,\nV_UP:                MySHelper.prototype.V_UP,\nV_DOWN:              MySHelper.prototype.V_DOWN,\nV_STOP:              MySHelper.prototype.V_STOP,\nV_IR_SEND:           MySHelper.prototype.V_IR_SEND,\nV_IR_RECEIVE:        MySHelper.prototype.V_IR_RECEIVE,\nV_FLOW:              MySHelper.prototype.V_FLOW,\nV_VOLUME:            MySHelper.prototype.V_VOLUME,\nV_LOCK_STATUS:       MySHelper.prototype.V_LOCK_STATUS,\nV_LEVEL:             MySHelper.prototype.V_LEVEL,\nV_VOLTAGE:           MySHelper.prototype.V_VOLTAGE, \nV_CURRENT:           MySHelper.prototype.V_CURRENT,\nV_RGB:               MySHelper.prototype.V_RGB,\nV_RGBW:              MySHelper.prototype.V_RGBW,\nV_ID:                MySHelper.prototype.V_ID,\nV_UNIT_PREFIX:       MySHelper.prototype.V_UNIT_PREFIX,\nV_HVAC_SETPOINT_COOL:MySHelper.prototype.V_HVAC_SETPOINT_COOL,\nV_HVAC_SETPOINT_HEAT:MySHelper.prototype.V_HVAC_SETPOINT_HEAT,\nV_HVAC_FLOW_MODE:    MySHelper.prototype.V_HVAC_FLOW_MODE,\nV_TEXT:              MySHelper.prototype.V_TEXT\n};\n\n\n\nMySHelper.prototype.VString = function(V_SUBTYPE) {\n    for (var prop in vtype ) \n    if( vtype[ prop ] === parseInt(V_SUBTYPE) )\n        return prop;\n};\n    \nMySHelper.prototype.VNum = function(V_SUBTYPE) {\n    sRet = vtype [V_SUBTYPE];\n    if (sRet === undefined)\n        sRet = V_SUBTYPE;\n    return sRet;\n}\n\nMySHelper.prototype.S_DOOR = 0; // Door sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_MOTION = 1;  // Motion sensor; V_TRIPPED; V_ARMED \nMySHelper.prototype.S_SMOKE = 2;  // Smoke sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_LIGHT = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nMySHelper.prototype.S_BINARY = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nMySHelper.prototype.S_DIMMER = 4; // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nMySHelper.prototype.S_COVER = 5; // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nMySHelper.prototype.S_TEMP = 6; // Temperature sensor; V_TEMP\nMySHelper.prototype.S_HUM = 7; // Humidity sensor; V_HUM\nMySHelper.prototype.S_BARO = 8; // Barometer sensor; V_PRESSURE; V_FORECAST\nMySHelper.prototype.S_WIND = 9; // Wind sensor; V_WIND; V_GUST\nMySHelper.prototype.S_RAIN = 10; // Rain sensor; V_RAIN; V_RAINRATE\nMySHelper.prototype.S_UV = 11; // Uv sensor; V_UV\nMySHelper.prototype.S_WEIGHT = 12; // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nMySHelper.prototype.S_POWER = 13; // Power meter; V_WATT; V_KWH\nMySHelper.prototype.S_HEATER = 14; // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nMySHelper.prototype.S_DISTANCE = 15; // Distance sensor; V_DISTANCE\nMySHelper.prototype.S_LIGHT_LEVEL = 16; // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nMySHelper.prototype.S_ARDUINO_NODE = 17 ; // Used (internally) for presenting a non-repeating Arduino node\nMySHelper.prototype.S_ARDUINO_REPEATER_NODE = 18; // Used (internally) for presenting a repeating Arduino node \nMySHelper.prototype.S_LOCK = 19; // Lock device; V_LOCK_STATUS\nMySHelper.prototype.S_IR = 20; // Ir device; V_IR_SEND; V_IR_RECEIVE\nMySHelper.prototype.S_WATER = 21; // Water meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_AIR_QUALITY = 22; // Air quality sensor; V_LEVEL\nMySHelper.prototype.S_CUSTOM = 23; // Custom sensor \nMySHelper.prototype.S_DUST = 24; // Dust sensor; V_LEVEL\nMySHelper.prototype.S_SCENE_CONTROLLER = 25; // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nMySHelper.prototype.S_RGB_LIGHT = 26; // RGB light. Send color component data using V_RGB. Also supports V_WATT \nMySHelper.prototype.S_RGBW_LIGHT = 27; // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nMySHelper.prototype.S_COLOR_SENSOR = 28;  // Color sensor; send color information using V_RGB\nMySHelper.prototype.S_HVAC = 28; // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nMySHelper.prototype.S_MULTIMETER = 29; // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nMySHelper.prototype.S_SPRINKLER  = 30;  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nMySHelper.prototype.S_WATER_LEAK = 31; // Water leak sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_SOUND = 32; // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nMySHelper.prototype.S_VIBRATION = 33; // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nMySHelper.prototype.S_MOISTURE = 34; // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nMySHelper.prototype.S_INFO = 35; // LCD text device / Simple information device on controller; V_TEXT\nMySHelper.prototype.S_GAS = 36; // Gas meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_GPS = 37; // GPS Sensor; V_POSITION\n \nvar stype = {\nS_DOOR:                 MySHelper.prototype.S_DOOR, // Door sensor; V_TRIPPED; V_ARMED\nS_MOTION:               MySHelper.prototype.S_MOTION,  // Motion sensor; V_TRIPPED; V_ARMED \nS_SMOKE:                MySHelper.prototype.S_SMOKE,  // Smoke sensor; V_TRIPPED; V_ARMED\nS_LIGHT:                MySHelper.prototype.S_LIGHT, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nS_BINARY:               MySHelper.prototype.S_BINARY, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nS_DIMMER:               MySHelper.prototype.S_DIMMER, // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nS_COVER:                MySHelper.prototype.S_COVER, // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nS_TEMP:                 MySHelper.prototype.S_TEMP, // Temperature sensor; V_TEMP\nS_HUM:                  MySHelper.prototype.S_HUM, // Humidity sensor; V_HUM\nS_BARO:                 MySHelper.prototype.S_BARO, // Barometer sensor; V_PRESSURE; V_FORECAST\nS_WIND:                 MySHelper.prototype.S_WIND, // Wind sensor; V_WIND; V_GUST\nS_RAIN:                 MySHelper.prototype.S_RAIN, // Rain sensor; V_RAIN; V_RAINRATE\nS_UV:                   MySHelper.prototype.S_UV, // Uv sensor; V_UV\nS_WEIGHT:               MySHelper.prototype.S_WEIGHT, // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nS_POWER:                MySHelper.prototype.S_POWER, // Power meter; V_WATT; V_KWH\nS_HEATER:               MySHelper.prototype.S_HEATER, // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nS_DISTANCE:             MySHelper.prototype.S_DISTANCE, // Distance sensor; V_DISTANCE\nS_LIGHT_LEVEL:          MySHelper.prototype.S_LIGHT_LEVEL, // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nS_ARDUINO_NODE:         MySHelper.prototype.S_ARDUINO_NODE, // Used (internally) for presenting a non-repeating Arduino node\nS_ARDUINO_REPEATER_NODE:MySHelper.prototype.S_ARDUINO_REPEATER_NODE, // Used (internally) for presenting a repeating Arduino node \nS_LOCK:                 MySHelper.prototype.S_LOCK, // Lock device; V_LOCK_STATUS\nS_IR:                   MySHelper.prototype.S_IR, // Ir device; V_IR_SEND; V_IR_RECEIVE\nS_WATER:                MySHelper.prototype.S_WATER, // Water meter; V_FLOW; V_VOLUME\nS_AIR_QUALITY:          MySHelper.prototype.S_AIR_QUALITY, // Air quality sensor; V_LEVEL\nS_CUSTOM:               MySHelper.prototype.S_CUSTOM, // Custom sensor \nS_DUST:                 MySHelper.prototype.S_DUST, // Dust sensor; V_LEVEL\nS_SCENE_CONTROLLER:     MySHelper.prototype.S_SCENE_CONTROLLER, // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nS_RGB_LIGHT:            MySHelper.prototype.S_RGB_LIGHT, // RGB light. Send color component data using V_RGB. Also supports V_WATT \nS_RGBW_LIGHT:           MySHelper.prototype.S_RGBW_LIGHT, // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nS_COLOR_SENSOR:         MySHelper.prototype.S_COLOR_SENSOR,  // Color sensor; send color information using V_RGB\nS_HVAC:                 MySHelper.prototype.S_HVAC, // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nS_MULTIMETER:           MySHelper.prototype.S_MULTIMETER, // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nS_SPRINKLER:            MySHelper.prototype.S_SPRINKLER,  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nS_WATER_LEAK:           MySHelper.prototype.S_WATER_LEAK, // Water leak sensor; V_TRIPPED; V_ARMED\nS_SOUND:                MySHelper.prototype.S_SOUND, // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nS_VIBRATION:            MySHelper.prototype.S_VIBRATION, // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nS_MOISTURE:             MySHelper.prototype.S_MOISTURE, // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nS_INFO:                 MySHelper.prototype.S_INFO, // LCD text device / Simple information device on controller; V_TEXT\nS_GAS:                  MySHelper.prototype.S_GAS, // Gas meter; V_FLOW; V_VOLUME\nS_GPS:                  MySHelper.prototype.S_GPS // GPS Sensor; V_POSITION\n};\n\nMySHelper.prototype.SString = function(S_SUBTYPE) {\n    for (var prop in stype ) \n    if( stype[ prop ] === parseInt(S_SUBTYPE) )\n        return prop;\n};    \n    \n MySHelper.prototype.encode = function(destination, sensor, command, acknowledge, type, payload) {\n\tvar msg = destination.toString(10) + \";\" + sensor.toString(10) + \";\" + command.toString(10) + \";\" + acknowledge.toString(10) + \";\" + type.toString(10) + \";\";\n\tif (command == 4) {\n\t\tfor (var i = 0; i < payload.length; i++) {\n\t\t\tif (payload[i] < 16)\n\t\t\t\tmsg += \"0\";\n\t\t\tmsg += payload[i].toString(16);\n\t\t}\n\t} else {\n\t\tmsg += payload;\n\t}\n\tmsg += '\\n';\n\treturn msg.toString();\n}\n}\n\n\nvar MySHelperObj = new MySHelper();\n\ncontext.global.MYS = MySHelperObj;\n\nreturn msg;","outputs":1,"noerr":0,"x":364.25,"y":65.99999809265137,"wires":[[]]},{"id":"df1e322.f20e1d","type":"function","z":"9592163f.6a6de8","name":"Set Controller 1","func":"msg.controller = 1\n\nreturn msg;","outputs":1,"noerr":0,"x":641.0000076293945,"y":147.49999809265137,"wires":[["ebcef3df.14311"]]},{"id":"266b87b3.d99478","type":"switch","z":"9592163f.6a6de8","name":"route to controller n","property":"controller","rules":[{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"false","outputs":4,"x":133,"y":214.25,"wires":[["3e866f6d.c1799"],["c7d0d88b.382f28"],[],[]]},{"id":"c7d0d88b.382f28","type":"tcp request","z":"9592163f.6a6de8","server":"192.168.92.14","port":"5003","out":"sit","splitc":"0","name":"MySWifi ESP8266 GW AES 14","x":410.5,"y":207.24999618530273,"wires":[["c5f14d8f.3a0eb"]]},{"id":"c5f14d8f.3a0eb","type":"function","z":"9592163f.6a6de8","name":"Set Controller 2","func":"msg.controller = 2\n\nreturn msg;","outputs":1,"noerr":0,"x":653.5,"y":205.7500114440918,"wires":[["ebcef3df.14311"]]},{"id":"56b9f6ab.a94608","type":"file in","z":"9592163f.6a6de8","name":"read store for next ids","filename":"mysids.dump","format":"utf8","x":385,"y":103.99999618530273,"wires":[["57db23d6.a824dc"]]},{"id":"e000bd09.1fff4","type":"debug","z":"9592163f.6a6de8","name":"Debug","active":false,"console":"false","complete":"true","x":732,"y":361,"wires":[]},{"id":"57db23d6.a824dc","type":"function","z":"9592163f.6a6de8","name":"store to context.global.mysnextid","func":"if (msg.payload === undefined) {\n          var mysnextid = {};\n\n        obj = mysnextid;  \n}\nelse \n{\ntry{\n        obj = JSON.parse(msg.payload);\n    }\n    catch(e){\n        \n        var mysnextid = {};\n\n        obj = mysnextid;\n        \n    }\n}    \n\ncontext.global.mysnextid = obj;\n\nmsg.payload = context.global.mysnextid;\n\nreturn msg;","outputs":1,"noerr":0,"x":630,"y":102.99999618530273,"wires":[[]]},{"id":"dfba7d69.20458","type":"file","z":"9592163f.6a6de8","name":"dump mysids","filename":"mysids.dump","appendNewline":true,"createDir":false,"overwriteFile":"true","x":1473,"y":381.99999618530273,"wires":[]},{"id":"e0e76d62.1f189","type":"function","z":"9592163f.6a6de8","name":"handle nextids","func":"// increase nextid, if nodeid >= nextid \n// node.log(\"Handling next ids\");\n// node.log(\"nodeId: \" + msg.nodeId);\n\nbChanged = false;\n\nif (msg.nodeId === 0) return;\n\nif (msg.nodeId < 255)\n{\n    // node.log(\"Test if next node-id must be set\");\n    if (context.global.mysnextid[msg.controller] === undefined) {\n        node.log(\"node-id not initialized yet\");\n        context.global.mysnextid[msg.controller] = msg.nodeId+1;\n        if (context.global.mysnextid[msg.controller] < context.global.MYS.MIN_NODEID)\n            context.global.mysnextid[msg.controller] = context.global.MYS.MIN_NODEID;\n        bChanged = true;\n    }\n    \n    // node.log(\"Nexid stored \" + parseInt(context.global.mysnextid[msg.controller]));\n    \n    if (msg.nodeId >= parseInt(context.global.mysnextid[msg.controller])) {\n        node.log(\"node-id >= next -> increase\");\n        // convert to int\n        context.global.mysnextid[msg.controller] = parseInt(context.global.mysnextid[msg.controller]);\n        context.global.mysnextid[msg.controller] = msg.nodeId+1; \n        if (context.global.mysnextid[msg.controller] < context.global.MYS.MIN_NODEID)\n            context.global.mysnextid[msg.controller] = context.global.MYS.MIN_NODEID;\n        bChanged = true;\n    }\n\n    if (bChanged) {\n        node.log(\"next id must be stored\");\n        msg.payload = JSON.stringify(context.global.mysnextid);   \n        return msg;\n    }\n}\n\n\n","outputs":1,"noerr":0,"x":1262,"y":374.99999618530273,"wires":[["dfba7d69.20458","5c074c19.a3f8b4"]]},{"id":"8da09002.725f7","type":"function","z":"9592163f.6a6de8","name":"MQTT to MYS convert","func":"// topic = MYS-NODERED/set/controller/node-id/sensor-id/ack/sub-type\n// payload = payload :)\n\n    var tokens = msg.topic.split(\"/\")\n    \n    msg.rawData = tokens;\n    msg.tokens = tokens.length;\n    if(tokens.length == 7)\n    {\n        if (tokens[0] != context.global.MYS.TOPIC_PREFIX) // not for us\n            return;\n        if (tokens[1] != 'set') // not for us\n            return;\n            \n        msg.controller = parseInt(tokens[2]);\n        msg.messageType = context.global.MYS.T_SET;\n        msg.nodeId = parseInt(tokens[3]);\n        msg.childSensorId = parseInt(tokens[4]);\n        msg.ack = parseInt(tokens[5]);\n        msg.subType = context.global.MYS.VNum(tokens[6]);\n        \n        msg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, msg.messageType, msg.ack, msg.subType, msg.payload);\n    \n        return msg;        \n    }\n","outputs":1,"noerr":0,"x":490,"y":361,"wires":[["e000bd09.1fff4","266b87b3.d99478"]]},{"id":"3e866f6d.c1799","type":"tcp request","z":"9592163f.6a6de8","server":"192.168.92.13","port":"5003","out":"sit","splitc":"0","name":"MySWifi ESP8266 GW AES 13","x":407,"y":145.99999618530273,"wires":[["df1e322.f20e1d"]]},{"id":"5c074c19.a3f8b4","type":"debug","z":"9592163f.6a6de8","name":"","active":true,"console":"false","complete":"false","x":1454,"y":543.9999961853027,"wires":[]},{"id":"c75fd7f4.38a028","type":"mqtt in","z":"9592163f.6a6de8","name":"Read MQTT Stream: change Topic to your needs","topic":"MYS-NODERED/set/#","broker":"ba386057.845d3","x":183.5,"y":362,"wires":[["8da09002.725f7"]]}]```
                                      fetsF 1 Reply Last reply
                                      • FotoFieberF
                                        FotoFieberF
                                        FotoFieber
                                        Stability is not sufficient. The connection gets lost from time to time.
                                        Added a watchdog to add another connection, if no messages arrives.
                                        Seems, that this is only interesting for me. If I get no feedback I will stop spaming this thread. :smiley:
                                        [{"id":"ba386057.845d3","type":"mqtt-broker","broker":"192.168.92.4","port":"1883","clientid":"NodeRed"},{"id":"e6ce260d.1931d8","type":"switch","z":"9592163f.6a6de8","name":"switch message type","property":"messageType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"true","outputs":5,"x":1259.166648864746,"y":182.50001335144043,"wires":[["8c663d73.7399c"],["4a1e5f84.b5e1a"],["7753f9a2.88ac08"],["1e4aa61b.e1b55a"],["60a0dde4.9f5f24"]]},{"id":"8c663d73.7399c","type":"function","z":"9592163f.6a6de8","name":"presentation","func":"msg.subTypeString = context.global.MYS.SString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1488.916648864746,"y":45.24998474121094,"wires":[["df9e131d.2061f","4d15a037.b2ea6"]]},{"id":"7753f9a2.88ac08","type":"function","z":"9592163f.6a6de8","name":"req","func":"msg.topic = \"req\";\nreturn msg;","outputs":1,"noerr":0,"x":1484.5000228881836,"y":182.75000190734863,"wires":[["4d15a037.b2ea6"]]},{"id":"1e4aa61b.e1b55a","type":"function","z":"9592163f.6a6de8","name":"internal","func":"msg.subTypeString = context.global.MYS.IString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\nreturn msg;","outputs":1,"noerr":0,"x":1488.5000228881836,"y":233.00000190734863,"wires":[["df9e131d.2061f","4d15a037.b2ea6","b5e4f17d.4a1b1"]]},{"id":"60a0dde4.9f5f24","type":"function","z":"9592163f.6a6de8","name":"stream","func":"msg.topic = \"stream\";\nreturn msg;","outputs":1,"x":1496.5000228881836,"y":328.00000190734863,"wires":[[]]},{"id":"4d15a037.b2ea6","type":"debug","z":"9592163f.6a6de8","name":"debug","active":false,"console":"false","complete":"true","x":1845.7500267028809,"y":242.00000286102295,"wires":[]},{"id":"4a1e5f84.b5e1a","type":"function","z":"9592163f.6a6de8","name":"set","func":"msg.subTypeString = context.global.MYS.VString(msg.subType);\n\nmsg.topic = context.global.MYS.TOPIC_PREFIX + '/' + msg.controller + \"/\" + msg.nodeId + \"/\" + msg.childSensorId + \"/\" + msg.subTypeString;\n\n\nreturn msg;","outputs":1,"noerr":0,"x":1492.166648864746,"y":107.5,"wires":[["4d15a037.b2ea6","df9e131d.2061f"]]},{"id":"fc54bb91.03ab48","type":"debug","z":"9592163f.6a6de8","name":"","active":false,"console":"false","complete":"true","x":1218.9166259765625,"y":41.66668510437012,"wires":[]},{"id":"6aa2d9f6.955d28","type":"function","z":"9592163f.6a6de8","name":"Split GW Message","func":"\n    var tokens = msg.payload.split(\";\")\n    \n    msg.rawData = tokens;\n    if(tokens.length >= 6)\n    {\n        msg.nodeId = parseInt(tokens[0]);\n        msg.childSensorId = parseInt(tokens[1]);\n        msg.messageType = parseInt(tokens[2]);\n        msg.ack = parseInt(tokens[3]);\n        msg.subType = parseInt(tokens[4]);\n        msg.payload = tokens[5];\n        for (j=6; j<tokens.length; j++) \n            msg.payload = msg.payload + ';' + tokens[j];\n    }\n\nreturn msg;","outputs":1,"noerr":0,"x":1023.6666488647461,"y":180.66664123535156,"wires":[["e6ce260d.1931d8","fc54bb91.03ab48","e0e76d62.1f189"]]},{"id":"df9e131d.2061f","type":"mqtt out","z":"9592163f.6a6de8","name":"Publish to MQTT","topic":"","qos":"","retain":"","broker":"ba386057.845d3","x":1858.9166526794434,"y":181.16665649414062,"wires":[]},{"id":"b5e4f17d.4a1b1","type":"function","z":"9592163f.6a6de8","name":"hanlde internal messages","func":"//msg.subTypeString = \"\";\n//msg.topic = \"internal respones\";\n\nif (msg.subTypeString == 'I_TIME')\n{\n    var payload = parseInt(new Date().getTime()/1000);\n\tvar command = context.global.MYS.T_INTERNAL; \n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_TIME; // I_TIME\n\tmsg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg;\n    \n}\nelse if  (msg.subTypeString == 'I_ID_REQUEST')\n{\n    msg.topic = \"I_ID_RESPONSE\";\n    msg.subTypeString = \"I_ID_RESPONSE\";\n    // 255;255;3;0;4;8 for ID 8\n    var command = context.global.MYS.T_INTERNAL;\n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_ID_RESPONSE; // I_ID_RESPONSE\n\n\tif (context.global.mysnextid[msg.controller] === undefined) {\n\t    payload = context.global.MYS.MIN_NODEID;\n\t}    \n\telse\n\t{\n\t    payload = context.global.mysnextid[msg.controller];\n\t}\n\t\n    msg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg; \n} \nelse if  (msg.subTypeString == 'I_CONFIG')\n{\n    var payload = 'M';\n\tvar command = context.global.MYS.T_INTERNAL; \n\tvar acknowledge = 0; // no ack\n\tvar type = context.global.MYS.I_CONFIG; // I_TIME\n\tmsg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, command, acknowledge, type, payload);\n    return msg;\n}\nelse if  (msg.subTypeString == 'I_INCLUSION_MODE')\n{\n    // not yet implemented\n}\n\nreturn;\n\n\n","outputs":1,"noerr":0,"x":1694.916648864746,"y":543.4166889190674,"wires":[["4d15a037.b2ea6","266b87b3.d99478"]]},{"id":"e6d67f33.19298","type":"inject","z":"9592163f.6a6de8","name":"Startup","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":true,"x":145.25,"y":81.41665363311768,"wires":[["64617800.9b9e88","56b9f6ab.a94608","3e866f6d.c1799"]]},{"id":"ebcef3df.14311","type":"function","z":"9592163f.6a6de8","name":"ToString","func":"msg.payload = msg.payload.toString().replace(/[\\n\\r]/g, '');\n\nreturn msg;","outputs":1,"noerr":0,"x":829.1666946411133,"y":181.91668796539307,"wires":[["6aa2d9f6.955d28"]]},{"id":"31047fa6.cefb8","type":"catch","z":"9592163f.6a6de8","name":"","x":58,"y":449,"wires":[["3622f9b9.c9dd06"]]},{"id":"3622f9b9.c9dd06","type":"debug","z":"9592163f.6a6de8","name":"","active":false,"console":"false","complete":"true","x":224,"y":450,"wires":[]},{"id":"64617800.9b9e88","type":"function","z":"9592163f.6a6de8","name":"MYS Initialize","func":"function MySHelper() { \n\nMySHelper.prototype.TOPIC_PREFIX = \"MYS-NODERED\";\n\nMySHelper.prototype.MIN_NODEID = 10;\n\n\n// don't touch below :)\n    \nMySHelper.prototype.T_PRESENTATION                = 0;\nMySHelper.prototype.T_SET                         = 1;\nMySHelper.prototype.T_REQ                         = 2;\nMySHelper.prototype.T_INTERNAL                    = 3;\nMySHelper.prototype.T_STREAM                      = 4;\n\nMySHelper.prototype.I_BATTERY_LEVEL               = 0;\nMySHelper.prototype.I_TIME                        = 1;\nMySHelper.prototype.I_VERSION                     = 2;\nMySHelper.prototype.I_ID_REQUEST                  = 3;\nMySHelper.prototype.I_ID_RESPONSE                 = 4;\nMySHelper.prototype.I_INCLUSION_MODE              = 5;\nMySHelper.prototype.I_CONFIG                      = 6;\nMySHelper.prototype.I_PING                        = 7;\nMySHelper.prototype.I_PING_ACK                    = 8;\nMySHelper.prototype.I_LOG_MESSAGE                 = 9;\nMySHelper.prototype.I_CHILDREN                    = 10;\nMySHelper.prototype.I_SKETCH_NAME                 = 11;\nMySHelper.prototype.I_SKETCH_VERSION              = 12;\nMySHelper.prototype.I_REBOOT                      = 13;\nMySHelper.prototype.I_GATEWAY_READY               = 14;\nMySHelper.prototype.I_REQUEST_SIGNING             = 15;\nMySHelper.prototype.I_GET_NONCE                   = 16;\nMySHelper.prototype.I_GET_NONCE_RESPONSE          = 17;\nMySHelper.prototype.I_HEARTBEAT                   = 18;\nMySHelper.prototype.I_PRESENTATION                = 19;\n \nvar itype = {\nI_BATTERY_LEVEL:                    MySHelper.prototype.I_BATTERY_LEVEL,\nI_TIME:                             MySHelper.prototype.I_TIME,\nI_VERSION:                          MySHelper.prototype.I_VERSION,\nI_ID_REQUEST:                       MySHelper.prototype.I_ID_REQUEST,\nI_ID_RESPONSE:                      MySHelper.prototype.I_ID_RESPONSE,\nI_INCLUSION_MODE:                   MySHelper.prototype.I_INCLUSION_MODE,\nI_CONFIG:                           MySHelper.prototype.I_CONFIG,\nI_PING:                             MySHelper.prototype.I_PING,\nI_PING_ACK:                         MySHelper.prototype.I_PING_ACK,\nI_LOG_MESSAGE:                      MySHelper.prototype.I_LOG_MESSAGE,\nI_CHILDREN:                         MySHelper.prototype.I_CHILDREN,\nI_SKETCH_NAME:                      MySHelper.prototype.I_SKETCH_NAME,\nI_SKETCH_VERSION:                   MySHelper.prototype.I_SKETCH_VERSION,\nI_REBOOT:                           MySHelper.prototype.I_REBOOT,\nI_GATEWAY_READY:                    MySHelper.prototype.I_GATEWAY_READY,\nI_REQUEST_SIGNING:                  MySHelper.prototype.I_REQUEST_SIGNING,\nI_GET_NONCE:                        MySHelper.prototype.I_GET_NONCE,\nI_GET_NONCE_RESPONSE:               MySHelper.prototype.I_GET_NONCE_RESPONSE,\nI_HEARTBEAT:                        MySHelper.prototype.I_HEARTBEAT,\nI_PRESENTATION:                     MySHelper.prototype.I_PRESENTATION\n};\n\nMySHelper.prototype.IString = function(I_SUBTYPE) {\n    for (var prop in itype ) \n    if( itype[ prop ] === parseInt(I_SUBTYPE) )\n        return prop;\n};\n\nMySHelper.prototype.V_TEMP                = 0;\nMySHelper.prototype.V_HUM                 = 1;\nMySHelper.prototype.V_LIGHT               = 2;\nMySHelper.prototype.V_STATUS              = 2;\nMySHelper.prototype.V_DIMMER              = 3;\nMySHelper.prototype.V_PRESSURE            = 4;\nMySHelper.prototype.V_FORECAST            = 5;\nMySHelper.prototype.V_RAIN                = 6;\nMySHelper.prototype.V_RAINRATE            = 7;\nMySHelper.prototype.V_WIND                = 8;\nMySHelper.prototype.V_GUST                = 9;\nMySHelper.prototype.V_DIRECTION           = 10;\nMySHelper.prototype.V_UV                  = 11;\nMySHelper.prototype.V_WEIGHT              = 12;\nMySHelper.prototype.V_DISTANCE            = 13;\nMySHelper.prototype.V_IMPEDANCE           = 14;\nMySHelper.prototype.V_ARMED               = 15;\nMySHelper.prototype.V_TRIPPED             = 16;\nMySHelper.prototype.V_WATT                = 17;\nMySHelper.prototype.V_KWH                 = 18;\nMySHelper.prototype.V_SCENE_ON            = 19;\nMySHelper.prototype.V_SCENE_OFF           = 20;\nMySHelper.prototype.V_HEATER              = 21;\nMySHelper.prototype.V_HEATER_SW           = 22;\nMySHelper.prototype.V_LIGHT_LEVEL         = 23;\nMySHelper.prototype.V_VAR1                = 24;\nMySHelper.prototype.V_VAR2                = 25;\nMySHelper.prototype.V_VAR3                = 26;\nMySHelper.prototype.V_VAR4                = 27;\nMySHelper.prototype.V_VAR5                = 28;\nMySHelper.prototype.V_UP                  = 29;\nMySHelper.prototype.V_DOWN                = 30;\nMySHelper.prototype.V_STOP                = 31;\nMySHelper.prototype.V_IR_SEND             = 32;\nMySHelper.prototype.V_IR_RECEIVE          = 33;\nMySHelper.prototype.V_FLOW                = 34;\nMySHelper.prototype.V_VOLUME              = 35;\nMySHelper.prototype.V_LOCK_STATUS         = 36;\nMySHelper.prototype.V_LEVEL               = 37; \nMySHelper.prototype.V_VOLTAGE             = 38; \nMySHelper.prototype.V_CURRENT             = 39; \nMySHelper.prototype.V_RGB                 = 40; \nMySHelper.prototype.V_RGBW                = 41;\nMySHelper.prototype.V_ID                  = 42;\nMySHelper.prototype.V_UNIT_PREFIX         = 43;\nMySHelper.prototype.V_HVAC_SETPOINT_COOL  = 44;\nMySHelper.prototype.V_HVAC_SETPOINT_HEAT  = 45;\nMySHelper.prototype.V_HVAC_FLOW_MODE      = 46;\nMySHelper.prototype.V_TEXT                = 47;\n\nvar vtype = {\nV_TEMP:              MySHelper.prototype.V_TEMP,\nV_HUM:               MySHelper.prototype.V_HUM,\nV_STATUS:            MySHelper.prototype.V_STATUS,\nV_LIGHT:             MySHelper.prototype.V_LIGHT,\nV_DIMMER:            MySHelper.prototype.V_DIMMER,\nV_PRESSURE:          MySHelper.prototype.V_PRESSURE,\nV_FORECAST:          MySHelper.prototype.V_FORECAST,\nV_RAIN:              MySHelper.prototype.V_RAIN,\nV_RAINRATE:          MySHelper.prototype.V_RAINRATE,\nV_WIND:              MySHelper.prototype.V_WIND,\nV_GUST:              MySHelper.prototype.V_GUST,\nV_DIRECTION:         MySHelper.prototype.V_DIRECTION,\nV_UV:                MySHelper.prototype.V_UV,\nV_WEIGHT:            MySHelper.prototype.V_WEIGHT,\nV_DISTANCE:          MySHelper.prototype.V_DISTANCE,\nV_IMPEDANCE:         MySHelper.prototype.V_IMPEDANCE,\nV_ARMED:             MySHelper.prototype.V_ARMED,\nV_TRIPPED:           MySHelper.prototype.V_TRIPPED,\nV_WATT:              MySHelper.prototype.V_WATT,\nV_KWH:               MySHelper.prototype.V_KWH,\nV_SCENE_ON:          MySHelper.prototype.V_SCENE_ON,\nV_SCENE_OFF:         MySHelper.prototype.V_SCENE_OFF,\nV_HEATER:            MySHelper.prototype.V_HEATER,\nV_HEATER_SW:         MySHelper.prototype.V_HEATER_SW,\nV_LIGHT_LEVEL:       MySHelper.prototype.V_LIGHT_LEVEL,\nV_VAR1:              MySHelper.prototype.V_VAR1,\nV_VAR2:              MySHelper.prototype.V_VAR2,\nV_VAR3:              MySHelper.prototype.V_VAR3,\nV_VAR4:              MySHelper.prototype.V_VAR4,\nV_VAR5:              MySHelper.prototype.V_VAR5,\nV_UP:                MySHelper.prototype.V_UP,\nV_DOWN:              MySHelper.prototype.V_DOWN,\nV_STOP:              MySHelper.prototype.V_STOP,\nV_IR_SEND:           MySHelper.prototype.V_IR_SEND,\nV_IR_RECEIVE:        MySHelper.prototype.V_IR_RECEIVE,\nV_FLOW:              MySHelper.prototype.V_FLOW,\nV_VOLUME:            MySHelper.prototype.V_VOLUME,\nV_LOCK_STATUS:       MySHelper.prototype.V_LOCK_STATUS,\nV_LEVEL:             MySHelper.prototype.V_LEVEL,\nV_VOLTAGE:           MySHelper.prototype.V_VOLTAGE, \nV_CURRENT:           MySHelper.prototype.V_CURRENT,\nV_RGB:               MySHelper.prototype.V_RGB,\nV_RGBW:              MySHelper.prototype.V_RGBW,\nV_ID:                MySHelper.prototype.V_ID,\nV_UNIT_PREFIX:       MySHelper.prototype.V_UNIT_PREFIX,\nV_HVAC_SETPOINT_COOL:MySHelper.prototype.V_HVAC_SETPOINT_COOL,\nV_HVAC_SETPOINT_HEAT:MySHelper.prototype.V_HVAC_SETPOINT_HEAT,\nV_HVAC_FLOW_MODE:    MySHelper.prototype.V_HVAC_FLOW_MODE,\nV_TEXT:              MySHelper.prototype.V_TEXT\n};\n\n\n\nMySHelper.prototype.VString = function(V_SUBTYPE) {\n    for (var prop in vtype ) \n    if( vtype[ prop ] === parseInt(V_SUBTYPE) )\n        return prop;\n};\n    \nMySHelper.prototype.VNum = function(V_SUBTYPE) {\n    sRet = vtype [V_SUBTYPE];\n    if (sRet === undefined)\n        sRet = V_SUBTYPE;\n    return sRet;\n}\n\nMySHelper.prototype.S_DOOR = 0; // Door sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_MOTION = 1;  // Motion sensor; V_TRIPPED; V_ARMED \nMySHelper.prototype.S_SMOKE = 2;  // Smoke sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_LIGHT = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nMySHelper.prototype.S_BINARY = 3; // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nMySHelper.prototype.S_DIMMER = 4; // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nMySHelper.prototype.S_COVER = 5; // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nMySHelper.prototype.S_TEMP = 6; // Temperature sensor; V_TEMP\nMySHelper.prototype.S_HUM = 7; // Humidity sensor; V_HUM\nMySHelper.prototype.S_BARO = 8; // Barometer sensor; V_PRESSURE; V_FORECAST\nMySHelper.prototype.S_WIND = 9; // Wind sensor; V_WIND; V_GUST\nMySHelper.prototype.S_RAIN = 10; // Rain sensor; V_RAIN; V_RAINRATE\nMySHelper.prototype.S_UV = 11; // Uv sensor; V_UV\nMySHelper.prototype.S_WEIGHT = 12; // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nMySHelper.prototype.S_POWER = 13; // Power meter; V_WATT; V_KWH\nMySHelper.prototype.S_HEATER = 14; // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nMySHelper.prototype.S_DISTANCE = 15; // Distance sensor; V_DISTANCE\nMySHelper.prototype.S_LIGHT_LEVEL = 16; // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nMySHelper.prototype.S_ARDUINO_NODE = 17 ; // Used (internally) for presenting a non-repeating Arduino node\nMySHelper.prototype.S_ARDUINO_REPEATER_NODE = 18; // Used (internally) for presenting a repeating Arduino node \nMySHelper.prototype.S_LOCK = 19; // Lock device; V_LOCK_STATUS\nMySHelper.prototype.S_IR = 20; // Ir device; V_IR_SEND; V_IR_RECEIVE\nMySHelper.prototype.S_WATER = 21; // Water meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_AIR_QUALITY = 22; // Air quality sensor; V_LEVEL\nMySHelper.prototype.S_CUSTOM = 23; // Custom sensor \nMySHelper.prototype.S_DUST = 24; // Dust sensor; V_LEVEL\nMySHelper.prototype.S_SCENE_CONTROLLER = 25; // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nMySHelper.prototype.S_RGB_LIGHT = 26; // RGB light. Send color component data using V_RGB. Also supports V_WATT \nMySHelper.prototype.S_RGBW_LIGHT = 27; // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nMySHelper.prototype.S_COLOR_SENSOR = 28;  // Color sensor; send color information using V_RGB\nMySHelper.prototype.S_HVAC = 28; // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nMySHelper.prototype.S_MULTIMETER = 29; // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nMySHelper.prototype.S_SPRINKLER  = 30;  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nMySHelper.prototype.S_WATER_LEAK = 31; // Water leak sensor; V_TRIPPED; V_ARMED\nMySHelper.prototype.S_SOUND = 32; // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nMySHelper.prototype.S_VIBRATION = 33; // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nMySHelper.prototype.S_MOISTURE = 34; // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nMySHelper.prototype.S_INFO = 35; // LCD text device / Simple information device on controller; V_TEXT\nMySHelper.prototype.S_GAS = 36; // Gas meter; V_FLOW; V_VOLUME\nMySHelper.prototype.S_GPS = 37; // GPS Sensor; V_POSITION\n \nvar stype = {\nS_DOOR:                 MySHelper.prototype.S_DOOR, // Door sensor; V_TRIPPED; V_ARMED\nS_MOTION:               MySHelper.prototype.S_MOTION,  // Motion sensor; V_TRIPPED; V_ARMED \nS_SMOKE:                MySHelper.prototype.S_SMOKE,  // Smoke sensor; V_TRIPPED; V_ARMED\nS_LIGHT:                MySHelper.prototype.S_LIGHT, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT\nS_BINARY:               MySHelper.prototype.S_BINARY, // Binary light or relay; V_STATUS (or V_LIGHT); V_WATT (same as MySHelper.prototype.S_LIGHT)\nS_DIMMER:               MySHelper.prototype.S_DIMMER, // Dimmable light or fan device; V_STATUS (on/off); V_DIMMER (dimmer level 0-100); V_WATT\nS_COVER:                MySHelper.prototype.S_COVER, // Blinds or window cover; V_UP; V_DOWN; V_STOP; V_DIMMER (open/close to a percentage)\nS_TEMP:                 MySHelper.prototype.S_TEMP, // Temperature sensor; V_TEMP\nS_HUM:                  MySHelper.prototype.S_HUM, // Humidity sensor; V_HUM\nS_BARO:                 MySHelper.prototype.S_BARO, // Barometer sensor; V_PRESSURE; V_FORECAST\nS_WIND:                 MySHelper.prototype.S_WIND, // Wind sensor; V_WIND; V_GUST\nS_RAIN:                 MySHelper.prototype.S_RAIN, // Rain sensor; V_RAIN; V_RAINRATE\nS_UV:                   MySHelper.prototype.S_UV, // Uv sensor; V_UV\nS_WEIGHT:               MySHelper.prototype.S_WEIGHT, // Personal scale sensor; V_WEIGHT; V_IMPEDANCE\nS_POWER:                MySHelper.prototype.S_POWER, // Power meter; V_WATT; V_KWH\nS_HEATER:               MySHelper.prototype.S_HEATER, // Header device; V_HVAC_SETPOINT_HEAT; V_HVAC_FLOW_STATE; V_TEMP\nS_DISTANCE:             MySHelper.prototype.S_DISTANCE, // Distance sensor; V_DISTANCE\nS_LIGHT_LEVEL:          MySHelper.prototype.S_LIGHT_LEVEL, // Light level sensor; V_LIGHT_LEVEL (uncalibrated in percentage);  V_LEVEL (light level in lux)\nS_ARDUINO_NODE:         MySHelper.prototype.S_ARDUINO_NODE, // Used (internally) for presenting a non-repeating Arduino node\nS_ARDUINO_REPEATER_NODE:MySHelper.prototype.S_ARDUINO_REPEATER_NODE, // Used (internally) for presenting a repeating Arduino node \nS_LOCK:                 MySHelper.prototype.S_LOCK, // Lock device; V_LOCK_STATUS\nS_IR:                   MySHelper.prototype.S_IR, // Ir device; V_IR_SEND; V_IR_RECEIVE\nS_WATER:                MySHelper.prototype.S_WATER, // Water meter; V_FLOW; V_VOLUME\nS_AIR_QUALITY:          MySHelper.prototype.S_AIR_QUALITY, // Air quality sensor; V_LEVEL\nS_CUSTOM:               MySHelper.prototype.S_CUSTOM, // Custom sensor \nS_DUST:                 MySHelper.prototype.S_DUST, // Dust sensor; V_LEVEL\nS_SCENE_CONTROLLER:     MySHelper.prototype.S_SCENE_CONTROLLER, // Scene controller device; V_SCENE_ON; V_SCENE_OFF. \nS_RGB_LIGHT:            MySHelper.prototype.S_RGB_LIGHT, // RGB light. Send color component data using V_RGB. Also supports V_WATT \nS_RGBW_LIGHT:           MySHelper.prototype.S_RGBW_LIGHT, // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT\nS_COLOR_SENSOR:         MySHelper.prototype.S_COLOR_SENSOR,  // Color sensor; send color information using V_RGB\nS_HVAC:                 MySHelper.prototype.S_HVAC, // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT; V_HVAC_SETPOINT_COLD; V_HVAC_FLOW_STATE; V_HVAC_FLOW_MODE; V_TEMP\nS_MULTIMETER:           MySHelper.prototype.S_MULTIMETER, // Multimeter device; V_VOLTAGE; V_CURRENT; V_IMPEDANCE \nS_SPRINKLER:            MySHelper.prototype.S_SPRINKLER,  // Sprinkler; V_STATUS (turn on/off); V_TRIPPED (if fire detecting device)\nS_WATER_LEAK:           MySHelper.prototype.S_WATER_LEAK, // Water leak sensor; V_TRIPPED; V_ARMED\nS_SOUND:                MySHelper.prototype.S_SOUND, // Sound sensor; V_TRIPPED; V_ARMED; V_LEVEL (sound level in dB)\nS_VIBRATION:            MySHelper.prototype.S_VIBRATION, // Vibration sensor; V_TRIPPED; V_ARMED; V_LEVEL (vibration in Hz)\nS_MOISTURE:             MySHelper.prototype.S_MOISTURE, // Moisture sensor; V_TRIPPED; V_ARMED; V_LEVEL (water content or moisture in percentage?) \nS_INFO:                 MySHelper.prototype.S_INFO, // LCD text device / Simple information device on controller; V_TEXT\nS_GAS:                  MySHelper.prototype.S_GAS, // Gas meter; V_FLOW; V_VOLUME\nS_GPS:                  MySHelper.prototype.S_GPS // GPS Sensor; V_POSITION\n};\n\nMySHelper.prototype.SString = function(S_SUBTYPE) {\n    for (var prop in stype ) \n    if( stype[ prop ] === parseInt(S_SUBTYPE) )\n        return prop;\n};    \n    \n MySHelper.prototype.encode = function(destination, sensor, command, acknowledge, type, payload) {\n\tvar msg = destination.toString(10) + \";\" + sensor.toString(10) + \";\" + command.toString(10) + \";\" + acknowledge.toString(10) + \";\" + type.toString(10) + \";\";\n\tif (command == 4) {\n\t\tfor (var i = 0; i < payload.length; i++) {\n\t\t\tif (payload[i] < 16)\n\t\t\t\tmsg += \"0\";\n\t\t\tmsg += payload[i].toString(16);\n\t\t}\n\t} else {\n\t\tmsg += payload;\n\t}\n\tmsg += '\\n';\n\treturn msg.toString();\n}\n}\n\n\nvar MySHelperObj = new MySHelper();\n\ncontext.global.MYS = MySHelperObj;\n\nreturn msg;","outputs":1,"noerr":0,"x":383.25,"y":20,"wires":[[]]},{"id":"df1e322.f20e1d","type":"function","z":"9592163f.6a6de8","name":"Set Controller 1","func":"msg.controller = 1\n\nreturn msg;","outputs":1,"noerr":0,"x":641.0000076293945,"y":147.49999809265137,"wires":[["ebcef3df.14311"]]},{"id":"266b87b3.d99478","type":"switch","z":"9592163f.6a6de8","name":"route to controller n","property":"controller","rules":[{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"}],"checkall":"false","outputs":4,"x":133,"y":214.25,"wires":[["3e866f6d.c1799"],["c7d0d88b.382f28"],[],[]]},{"id":"c7d0d88b.382f28","type":"tcp request","z":"9592163f.6a6de8","server":"192.168.92.14","port":"5003","out":"sit","splitc":"0","name":"MySWifi ESP8266 GW AES 14","x":410.5,"y":207.24999618530273,"wires":[["c5f14d8f.3a0eb"]]},{"id":"c5f14d8f.3a0eb","type":"function","z":"9592163f.6a6de8","name":"Set Controller 2","func":"msg.controller = 2\n\nreturn msg;","outputs":1,"noerr":0,"x":653.5,"y":205.7500114440918,"wires":[["ebcef3df.14311"]]},{"id":"56b9f6ab.a94608","type":"file in","z":"9592163f.6a6de8","name":"read store for next ids","filename":"mysids.dump","format":"utf8","x":395,"y":65,"wires":[["57db23d6.a824dc"]]},{"id":"e000bd09.1fff4","type":"debug","z":"9592163f.6a6de8","name":"Debug","active":false,"console":"false","complete":"true","x":732,"y":361,"wires":[]},{"id":"57db23d6.a824dc","type":"function","z":"9592163f.6a6de8","name":"store to context.global.mysnextid","func":"if (msg.payload === undefined) {\n          var mysnextid = {};\n\n        obj = mysnextid;  \n}\nelse \n{\ntry{\n        obj = JSON.parse(msg.payload);\n    }\n    catch(e){\n        \n        var mysnextid = {};\n\n        obj = mysnextid;\n        \n    }\n}    \n\ncontext.global.mysnextid = obj;\n\nmsg.payload = context.global.mysnextid;\n\nreturn msg;","outputs":1,"noerr":0,"x":658,"y":53,"wires":[[]]},{"id":"dfba7d69.20458","type":"file","z":"9592163f.6a6de8","name":"dump mysids","filename":"mysids.dump","appendNewline":true,"createDir":false,"overwriteFile":"true","x":1473,"y":381.99999618530273,"wires":[]},{"id":"e0e76d62.1f189","type":"function","z":"9592163f.6a6de8","name":"handle nextids","func":"// increase nextid, if nodeid >= nextid \n// node.log(\"Handling next ids\");\n// node.log(\"nodeId: \" + msg.nodeId);\n\nbChanged = false;\n\nif (msg.nodeId === 0) return;\n\nif (msg.nodeId < 255)\n{\n    // node.log(\"Test if next node-id must be set\");\n    if (context.global.mysnextid[msg.controller] === undefined) {\n        node.log(\"node-id not initialized yet\");\n        context.global.mysnextid[msg.controller] = msg.nodeId+1;\n        if (context.global.mysnextid[msg.controller] < context.global.MYS.MIN_NODEID)\n            context.global.mysnextid[msg.controller] = context.global.MYS.MIN_NODEID;\n        bChanged = true;\n    }\n    \n    // node.log(\"Nexid stored \" + parseInt(context.global.mysnextid[msg.controller]));\n    \n    if (msg.nodeId >= parseInt(context.global.mysnextid[msg.controller])) {\n        node.log(\"node-id >= next -> increase\");\n        // convert to int\n        context.global.mysnextid[msg.controller] = parseInt(context.global.mysnextid[msg.controller]);\n        context.global.mysnextid[msg.controller] = msg.nodeId+1; \n        if (context.global.mysnextid[msg.controller] < context.global.MYS.MIN_NODEID)\n            context.global.mysnextid[msg.controller] = context.global.MYS.MIN_NODEID;\n        bChanged = true;\n    }\n\n    if (bChanged) {\n        node.log(\"next id must be stored\");\n        msg.payload = JSON.stringify(context.global.mysnextid);   \n        return msg;\n    }\n}\n\n\n","outputs":1,"noerr":0,"x":1262,"y":374.99999618530273,"wires":[["dfba7d69.20458","5c074c19.a3f8b4"]]},{"id":"8da09002.725f7","type":"function","z":"9592163f.6a6de8","name":"MQTT to MYS convert","func":"// topic = MYS-NODERED/set/controller/node-id/sensor-id/ack/sub-type\n// payload = payload :)\n\n    var tokens = msg.topic.split(\"/\");\n    \n    msg.rawData = tokens;\n    msg.tokens = tokens.length;\n    if(tokens.length == 7)\n    {\n        if (tokens[0] != context.global.MYS.TOPIC_PREFIX) // not for us\n            return;\n        if (tokens[1] != 'set') // not for us\n            return;\n            \n        msg.controller = parseInt(tokens[2]);\n        msg.messageType = context.global.MYS.T_SET;\n        msg.nodeId = parseInt(tokens[3]);\n        msg.childSensorId = parseInt(tokens[4]);\n        msg.ack = parseInt(tokens[5]);\n        msg.subType = context.global.MYS.VNum(tokens[6]);\n        \n        msg.payload = context.global.MYS.encode(msg.nodeId, msg.childSensorId, msg.messageType, msg.ack, msg.subType, msg.payload);\n    \n        return msg;        \n    }\n","outputs":1,"noerr":0,"x":490,"y":361,"wires":[["e000bd09.1fff4","266b87b3.d99478"]]},{"id":"3e866f6d.c1799","type":"tcp request","z":"9592163f.6a6de8","server":"192.168.92.13","port":"5003","out":"sit","splitc":"0","name":"MySWifi ESP8266 GW AES 13","x":407,"y":145.99999618530273,"wires":[["df1e322.f20e1d","9386fdb0.6c79"]]},{"id":"5c074c19.a3f8b4","type":"debug","z":"9592163f.6a6de8","name":"","active":true,"console":"false","complete":"false","x":1454,"y":543.9999961853027,"wires":[]},{"id":"c75fd7f4.38a028","type":"mqtt in","z":"9592163f.6a6de8","name":"Read MQTT Stream: change Topic to your needs","topic":"MYS-NODERED/set/#","broker":"ba386057.845d3","x":183.5,"y":362,"wires":[["8da09002.725f7"]]},{"id":"9386fdb0.6c79","type":"function","z":"9592163f.6a6de8","name":"Watchdog controller 1","func":"if (isNaN(context.global.controller1count))\n    context.global.controller1count=0;\n\n\ncontext.global.controller1count++;\n\n","outputs":1,"noerr":0,"x":630,"y":105,"wires":[[]]},{"id":"d465a67.f2b9a58","type":"inject","z":"9592163f.6a6de8","name":"Check health controller 1 every 5 minutes","topic":"","payload":"","payloadType":"none","repeat":"60","crontab":"","once":false,"x":173,"y":516,"wires":[["aa935a.ff556ca8"]]},{"id":"aa935a.ff556ca8","type":"function","z":"9592163f.6a6de8","name":"check health controlller 1","func":"if (isNaN(context.global.controller1count))\n    context.global.controller1count=0;\n    \nif (context.global.controller1count === 0) {\n    // make a new connection to the controller\n    msg.payload = \"\";\n    node.log(\"no message recieved on mys controller 1, try to connect\");\n    \n    return msg;\n}\nelse\n{\n    // reset counter\n    context.global.controller1count=0;\n}\n","outputs":1,"noerr":0,"x":470,"y":510,"wires":[["c8b342e9.374cc","3e866f6d.c1799"]]},{"id":"c8b342e9.374cc","type":"debug","z":"9592163f.6a6de8","name":"","active":true,"console":"false","complete":"false","x":682,"y":511,"wires":[]}]```
                                        AWIA L 2 Replies Last reply
                                        • F
                                          F
                                          Fabien
                                          It's not spam. You can share your flow !
