  3. Door Window sensor consuming more power when closed
10 Posts 2 Posters 8.4k Views 2 Watching
  • I Offline
    I Offline
    iask
    I have a Door/Window/Switch sensor setup with a reed switch and magnet assembly. When open (magnet moved away) the device consumes 0.20mA, however, when closed the device consumes 0.97mA (uA). Is this normal?
    I modified the example to include an INTERRUPT.
    // digitial I/O pin 3 (BUTTON_PIN below) and GND.
    #define CHILD_ID 3
    #define BUTTON_PIN 3  // Arduino Digital I/O pin for button/reed switch
    #define INTERRUPT BUTTON_PIN-2
    Bounce debouncer = Bounce();
    int oldValue=-1;
      gw.begin();
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         oldValue = value;
          gw.sleep(INTERRUPT,CHANGE, 0);
    A 1 Reply Last reply
    • I iask
      #define CHILD_ID 3
      int oldValue=-1;
        gw.begin();
       // Setup the button
        debouncer.update();
           oldValue = value;
      A Offline
      A Offline
      AWI
      @iask (probable cause) You are using the internal pull-up of the Arduino. This is a resistor of around 20 k ohm link. If this is pulled to ground by the reed contact. I = U/R = 5/20.000 = 250 uA = 0.250 mA..
      Also: debouncer combined with sleep is guaranteed to give trouble. Sleep does also sleep the internal clock which is used by the debouncer class/ library.
      I 1 Reply Last reply
      • I Offline
        I Offline
        iask
        wrote on last edited by iask
        @AWI thanks for responding. I will look into the internal pull-up. I did had some doubts with the debouncer. For example, putting the line gw.sleep(INTERRUPT,CHANGE, 0); outside of the IF statement caused the sensor to randomly drop messages to the GATEWAY. I did come across a post whereby someone used a delay instead of debouncing
         sensor_node.sleep(5);
        • A AWI
          I Offline
          I Offline
          iask
          @AWI You are right about that internal pull-up. It got even worse when I added an external pull-up. I placed a 10k between pin 3 and GND (for the Door, Window example) and disabled the internal pull-up. When the reed contact is open the sensor pulls only 008.5 uA which is great! When the reed is closed it pulls a whopping 00.32 mA.
          I don't know what else to try to bring down that 00.32mA whenever the reed is closed (which will be most of the time because the window will be closed).
          I will look into hardware debouncing to see if that will be a solution for the reed switch.
          #define CHILD_ID 3
          int oldValue=-1;
            gw.begin();
           // Setup the button
            // deActivate internal pull-up
            digitalWrite(BUTTON_PIN,LOW);
            debouncer.update();
               oldValue = value;
               //Sleep until interrupt comes in on motion sensor. Send update every two minute.
               //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
          • I iask
            #define CHILD_ID 3
            int oldValue=-1;
              gw.begin();
             // Setup the button
              debouncer.update();
                 oldValue = value;
            A Offline
            A Offline
            AWI
            wrote on last edited by AWI
            @iask try a 1 Mohm pull up and disable the internal. Hardware debounce is the way to go. Add 100nF to ground and 10k in series with the contact.
            • I Offline
              I Offline
              iask
              I tried that with the code below but it doesn't work at all. It registers the first 0 status with the Gateway and then goes silent.
              //#include <Bounce2.h>
              #define CHILD_ID 3
              //const byte switchPin = 3;
              byte oldSwitchState = HIGH;  // assume switch open because of pull-up resistor
                  for (byte i = 0; i <= A5; i++)
                  pinMode (i, INPUT);
                  digitalWrite (i, LOW);
                gw.begin();
               // Setup the button
                //digitalWrite(BUTTON_PIN,LOW);
                 // see if switch is open or closed
                byte switchState = digitalRead (BUTTON_PIN);
                 // has it changed since last time?
                if (switchState != oldSwitchState)
                     oldSwitchState =  switchState;  // remember for next time
                     if (switchState == LOW)
                         gw.send(msg.set(0));
                        gw.send(msg.set(1));
              • I iask
                #define CHILD_ID 3
                    pinMode (i, INPUT);
                  gw.begin();
                 // Setup the button
                A Offline
                A Offline
                AWI
                @iask Are you measuring a transition on the input? You need the external pull-up at minimum.
                I 2 Replies Last reply
                • A AWI
                  I Offline
                  I Offline
                  iask
                  @AWI right on! I had some time to go at this again. I realized that I had soldered the pullup on the wrong pin. Right after that my fine 898+ station stopped working. It just wont get hot. Going old school for the next few days.
                  • A AWI
                    I Offline
                    I Offline
                    iask
                    @AWI So here is what I got. When the sensor (Reed Switch) is open, the sensor consumes 8.5uA and when closed it consumes 11.5uA.
                    • I still have the regulator on board
                    • I removed both LEDS
                    • I am using hardware debouncing
                    • Set Analog pins LOW
                    Were you able to get lower than 11.5uA, with your NRFXXXXX connected, when in sleep mode? I am trying to find a proper benchmark to work with. My sensor is powered with a 3V CR123A battery.
                    I find that the CR123A is used in sensors by some alarm companies here in the US. See page 10 here (I've seen these things last a long time...3 years in some cases) so I am using this as my battery benchmark for all my sensors. Definitely not the cheepies from China.
                    • I iask
                      A Offline
                      A Offline
                      AWI
                      @iask I am not able to measure anything accurate that low. I use the chargeable version of cr123 in many sensors. No long term results yet, but a lot of power
                      12.2k
