  3. MQTT and batterylevel
17 Posts 6 Posters 8.4k Views 2 Watching
  • M mbj
    Maybe I did not read your code good enough but I could not see any definition of the message type sendBatteryLevel (see an example for the definition of the temperature message in your code "MyMessage msg(0,V_TEMP);" )
    gaduG
    gaduG
    gadu
    @mbj
    Like this?
     MyMessage msgvolt(1,V_VOLTAGE);
    • gaduG
      gaduG
      gadu
      Nope, I cant get this to work...
      I really would appreciate if someone could help me with an working example where batterylevel can be presented as a MQTT topic.
      Help!
        mbj
        Unfortunately I am a beginner with all this but I have been successful getting messages over to Openhab via the MQTT binding.
        I can guess that the "sendBatteryLevel" example from the API pages is tailored for a Vera controller or similar but is not at all understood by Openhab. I have come across something similar when other sensors send commands directed to the controller itself.
        So my assumption was that if you should send something across that Openhab understands you could test creating a message like your example msgvolt and then send the info with something like gw.send(msgvolt.set(batteryV)) or gw.send(msgvolt.set(batteryV,1)) and pick this up with an item in Openhab.
        The messages type V_VAR1 and onwards can be used for custom values so I think you can use one of these to send the battery level percentage. Only way to find out is to experiment :-)
        gaduG 1 Reply Last reply
        • M mbj
          gaduG
          gaduG
          gadu
          Big thanks @mbj
          I'm more of a beginner than you. Trust me. :-)
          I'll do some experiments using you pointers.
          gaduG K 2 Replies Last reply
          • gaduG gadu
            Big thanks @mbj
            gaduG
            gaduG
            gadu
            @mbj saved my day!!
            publish: MyMQTT/21/0/V_TEMP 23.5
            0;0;3;0;9;send: 0-0-21-21 s=0,c=1,t=0,pt=0,l=5,st=ok:23.5r
            0;0;3;0;9;read: 21-21-0 s=1,c=1,t=24,pt=2,l=2:87
            publish: MyMQTT/21/1/V_VAR1 87
            And you called yourself a beginner? ;-)
            • gaduG gadu
              @mbj saved my day!!
              mbj
              @gadu Glad to be of any help, your turn next :-)
              • gaduG
                gaduG
                gadu
                If anything, let me know! Dunno if I can be of any help, but i could try :-)
                Odd thing happend though, When the Mini is connected to the FTDI the serial monitor says "Check Wires", but on battery it sends everything correct?
                Well, that's another issue to look at later...
                • gaduG gadu
                  Big thanks @mbj
                  K
                  K
                  kunall
                  @gadu Can you post your working battery level send sketch for openhab? I would really appreciate it. I'm facing the same issue. Thanks!
                  • HeinzH
                    HeinzH
                    Heinz
                    ... probably gw.sendBatteryLevel(percent); helps.
                    • K kunall
                      gaduG
                      gaduG
                      gadu
                      @kunall
                      First these two rows before setup..
                      int oldBatteryPcnt = 0;
                      and in the loop i have these rows...
                      // get the battery Voltage
                      //Serial.println(sensorValue);
                      Serial.print(batteryV);
                      Serial.println(" V");
                      Serial.print(batteryPcnt);
                      Serial.println(" %");
                       // Power up radio after sleep
                       oldBatteryPcnt = batteryPcnt;
                      in OpenHab items i have this row...
                      Number node2_batt  "Battery [%.1f %%]" <energy> (node2,All)  {mqtt="<[MySensor:MyMQTT/21/1/V_VAR1:state:default]"}
                      hope this helps....
                      • gaduG gadu
                        @kunall
                        hope this helps....
                        K
                        K
                        kunall
                        Thanks alot @gadu . I will give this a try and get back to you! :+1:
                        • gaduG gadu
                          @kunall
                          hope this helps....
                          K
                          K
                          kunall
                          wrote on last edited by kunall
                          @gadu How did you implement V_Var1 ? and assign it to child ID 1 ?
                          Like this? if so, what did you use for gw.present(CHILD_ID, S_XXX) ?
                          #define CHILD_ID 1
                          myMessage msg(CHILD_ID, V_VAR1);
                          • siodS
                            siodS
                            siod
                            @gadu
                            where is the imprtoant MQTT code of your sketch? Would be so kind and share it with us?
                            Thanks in advance!!
                            still learning...
