  3. Strange behaviour - Check Wires and Version Mismatch
22 Posts 5 Posters 12.6k Views 3 Watching
    what happens if you hard-code parent to 0 in begin() while fetching id?
      marceltrapmanM
      marceltrapmanM
      marceltrapman
      wrote on last edited by marceltrapman
      Even stranger. This is what I do:
      //board.begin(msgCallback, nodeId, repeaterMode, parentNodeId, paLevel, channel, dataRate);
      board.begin(NULL, NULL, false, 0);
      This is now the result:
      NODE_ID          :0
      PARENT_NODE_ID   :2
      DISTANCE         :2
      Do you want me to write the node id and parent id direct into the eeprom?
      Fulltime Servoy Developer
        wrote on last edited by hek
        setting the parent in constructor won't update the eeprom. It just uses the specified parent and never searches for a new one.
        And you'll have to specify AUTO for id
          marceltrapmanM
          marceltrapmanM
          marceltrapman
          @hek So, how do I 'suddenly' have id = 0 then?
          I will clear the eeprom again and see what happens...
            marceltrapmanM
            marceltrapmanM
            marceltrapman
            @marceltrapman Stupid fail with that AUTO setting :blush:
            But the good news is that my sensor now has ID 4...
            So the bad news, I guess, is that the repeater seems to fail...
              As I mentioned earlier fetching id THROUGH a repeater need some additional love.
                marceltrapmanM
                marceltrapmanM
                marceltrapman
                Hmm, so I fail that love :(
                How can we get this thing going?
                The thing is don't want to walk down to my gateway each time I want to test something out.
                And, I also prefer not to use a fixed id because that would make testing the controller plugin a b****.
                • greglG
                  greglG
                  gregl
                  Hey @marceltrapman - I just upgraded one of my sketches from 1.3 to 1.4 ( im finally moving to 1.4 in "production!!)
                  Anyway, i had the same issue with version mismatch error and spewing out
                  version mismatch
                  read: 255-255-255 s=255,c=7,t=255,pt=7,l=31:NAN
                  version mismatch
                  version mismatch
                  version mismatch
                  wondering wtf was going on, i disconnected the relays board connected to VCC... the messages stopped and everything worked correctly- other than the relays actuating...
                  figured it could be a power issue, i connected proper power source as the issue occured with just a USB 5v from my PC....and reconnecting relay all worked properly..including now the relay.
                  So, check your powersupply!
                  HTH..
                  • greglG gregl
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    HTH..
                    marceltrapmanM
                    marceltrapmanM
                    marceltrapman
                    I don't see the version mismatch thing anymore luckily but it would have surprised me if it was power. Not only did I check it but I also use a power converter in this case to supply constant 3.3v (I use pro mini 3.3v).
                    Anyway, thanks for the tip :)
                      SparkAndHale
                      Same here. I had to go up to 5V to power my Arduino Pro Mini 3.3V sufficiently.
