  3. Custom made ethernet gateway based on atmega128
39 Posts 6 Posters 26.2k Views 2 Watching
  • axillentA axillent
    @ServiceXp sure
    M3 & M2
    http://ru.aliexpress.com/item/M3-x-10-Insert-round-nuts-Brass-Rohs-PASS-1000-pieces/745448307.html?recommendVersion=1
    http://ru.aliexpress.com/item/M2-x-3-5-x-5-Insert-round-nuts-Brass-Rohs-PASS-1000-pieces/745540578.html?recommendVersion=1
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @axillent Thanks..
    RJ_Make
    • D
      DanielD
      hey axillent,
      Could you upload the source code of your gateway?
      You use another slave that?(Type of This gateway send a RF to anther module and control de lamp?)
      If Yes could you post the schema and de souce code?
      Thx
      axillentA 1 Reply Last reply
      • D DanielD
        hey axillent,
        Thx
        axillentA
        axillentA
        axillent
        @DanielD sorry, did not get your question
        my gateways are using standard ethernet gateway sketch
        sense and drive
        • D
          DanielD
          Hmm, you use the ethernet gateway sketch:),
          Okay,I will do the question again, because it was a bit confusing.
          This getway control another things? For exemple "Smart Plug" Module?
          If yes, how you control this Plug?
          Thx
          • D DanielD
            Thx
            axillentA
            axillentA
            axillent
            @DanielD my gateways are not doing other things for now
            i have two issues with my gateways 1. it is hard to manage multi-gateway network, you need to use hardcode 2. NRF24 is not the single network I plan to integrate to mysensors
            there is an idea to redo class structure of the MS library to create a simple way of embedding drivers other than NRF24
            as soon as this will be developed we can do a new driver for RF433
            the idea on how to integrate RF433 is simple, bud without class restructuring it will be a deep hardcode
            sense and drive
            • D
              DanielD
              wrote on last edited by DanielD
              #35
              Okay, I understand
              Sorry my silliness, but what do you mean hardcore 2?
              I will do this sketch today(Ethernet Getway), but my big problem will do sync the getway to this sensor(Plug) or another sensor and control via web/cellphone
              • D
                DanielD
                • D
                  DanielD
                  @axillent
                  You modified the code base, alright?
                  Could you send me the new code?
                  Thx
                  • D DanielD
                    Okay, I understand
                    axillentA
                    axillentA
                    axillent
                    @DanielD 2 is stands for the second issue )
                    before class restructure I will recommend you to use sensor sketch as a gate between RF433 and mysensors
                    sense and drive
                    • D
                      DanielD
                      @axillent
                      Okay, I will try :)
                      The sketch of the Plug, I will see that do many challenges, but let's go.
                      I was reading the code the Ethernet getway, but i learn how i sync it with another sensor.
                      Thx for your help
