  3. Custom made ethernet gateway based on atmega128
39 Posts 6 Posters 26.0k Views 2 Watching
  • RJ_MakeR RJ_Make
    @axillent Would you happen to have links?
    axillentA
    axillentA
    axillent
    @ServiceXp sure
    M3 & M2
    http://ru.aliexpress.com/item/M3-x-10-Insert-round-nuts-Brass-Rohs-PASS-1000-pieces/745448307.html?recommendVersion=1
    http://ru.aliexpress.com/item/M2-x-3-5-x-5-Insert-round-nuts-Brass-Rohs-PASS-1000-pieces/745540578.html?recommendVersion=1
    sense and drive
    RJ_MakeR 1 Reply Last reply
    • axillentA axillent
      @ServiceXp sure
      M3 & M2
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @axillent Thanks..
      RJ_Make
      • D
        DanielD
        hey axillent,
        Could you upload the source code of your gateway?
        You use another slave that?(Type of This gateway send a RF to anther module and control de lamp?)
        If Yes could you post the schema and de souce code?
        Thx
        axillentA 1 Reply Last reply
        • D DanielD
          hey axillent,
          Thx
          axillentA
          axillentA
          axillent
          @DanielD sorry, did not get your question
          my gateways are using standard ethernet gateway sketch
          sense and drive
          • D
            DanielD
            Hmm, you use the ethernet gateway sketch:),
            Okay,I will do the question again, because it was a bit confusing.
            This getway control another things? For exemple "Smart Plug" Module?
            If yes, how you control this Plug?
            Thx
            • D DanielD
              Thx
              axillentA
              axillentA
              axillent
              @DanielD my gateways are not doing other things for now
              i have two issues with my gateways 1. it is hard to manage multi-gateway network, you need to use hardcode 2. NRF24 is not the single network I plan to integrate to mysensors
              there is an idea to redo class structure of the MS library to create a simple way of embedding drivers other than NRF24
              as soon as this will be developed we can do a new driver for RF433
              the idea on how to integrate RF433 is simple, bud without class restructuring it will be a deep hardcode
              sense and drive
              • D
                DanielD
                wrote on last edited by DanielD
                #35
                Okay, I understand
                Sorry my silliness, but what do you mean hardcore 2?
                I will do this sketch today(Ethernet Getway), but my big problem will do sync the getway to this sensor(Plug) or another sensor and control via web/cellphone
                • D
                  DanielD
                  • D
                    DanielD
                    @axillent
                    You modified the code base, alright?
                    Could you send me the new code?
                    Thx
                    • D DanielD
                      Okay, I understand
                      axillentA
                      axillentA
                      axillent
                      @DanielD 2 is stands for the second issue )
                      before class restructure I will recommend you to use sensor sketch as a gate between RF433 and mysensors
                      sense and drive
                      • D
                        DanielD
                        @axillent
                        Okay, I will try :)
                        The sketch of the Plug, I will see that do many challenges, but let's go.
                        I was reading the code the Ethernet getway, but i learn how i sync it with another sensor.
                        Thx for your help
