  3. Custom made ethernet gateway based on atmega128
39 Posts 6 Posters 26.0k Views 2 Watching
  • epierreE
    epierreE
    epierre
    @axillent which is something I actually do with all deversing into domoticz (vera, mysensors, spark core, webcam), and have an uniformized access through imperihome.
    I'm very interrested about the wifi capacity if we cannot achieve some level of security within rf24.
    z-wave - Vera -> Domoticz
    AnticimexA 1 Reply Last reply
    • axillentA
      axillentA
      axillent
      I got an idea to improve my gateway by adding 433MHz receiver
      I'm succeeded by adding it into the same dimension
      As discussed with @hek it will be other version of EthernetGateway sketch able to handle both NRF24 and RF433 reciever
      Just a small change to schematic
      sense and drive
      • epierreE epierre
        AnticimexA
        AnticimexA
        Anticimex
        @epierre About security within rf24 we are close. I have implemented and verified HMAC-SHA256 signing. I just need some more time to implement support for a pure software-alternative to the ATSHA204 as well and my "offering" will be complete. Check the security thread (I will post my update there once finished).
        • epierreE
          epierreE
          epierre
          @Anticimex This is good news, that would make us a bit safer... next step will be two ways SSL encryption ;-)
          • epierreE epierre
            AnticimexA
            AnticimexA
            Anticimex
            @epierre ha! Well, whoever wants encryption, feel free to do it :) I see no need so I'm skipping that though. I am fine with somebody potentially reading the sensor values and instructions I transmit. What concerns me is if somebody could fool my system and inject their own commands. But with my signing, I challenge anybody to try ;) (and I publish full sources)
            • axillentA
              axillentA
              axillent
              I made a version with RF433 receiver, I'm able to fit it into the same size PCB & same size box
              will work on the new code to support RF433 sensors. The idea is to use ID=254 for the single node which will holds all RF433 sensors as it's children. I will need to manage a special inclusion for RF433 sensors. I have two buttons and 3 leds. This probably will be used to select & indicate sensor type during inclusion. Sensor type and child ID will be stored in gateway EEPROM. For the controller sensors will behave as regular motions / fire / door / water leakage / etc. sensors
              I have all this sensors connected to simple GSM alarm system. The advantage to connect the, to mysensors is a reuse. All sensors will be working simultaneously with alarm and mysensors
              sense and drive
              RJ_MakeR 1 Reply Last reply
              • axillentA axillent
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @axillent Were did you get those screw inserts?
                RJ_Make
                axillentA 1 Reply Last reply
                • RJ_MakeR RJ_Make
                  axillentA
                  axillentA
                  axillent
                  all were purchased on aliexpress
                  sense and drive
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @axillent Would you happen to have links?
                    RJ_Make
                    • RJ_MakeR RJ_Make
                      axillentA
                      axillentA
                      axillent
                      @ServiceXp sure
                      M3 & M2
                      http://ru.aliexpress.com/item/M3-x-10-Insert-round-nuts-Brass-Rohs-PASS-1000-pieces/745448307.html?recommendVersion=1
                      http://ru.aliexpress.com/item/M2-x-3-5-x-5-Insert-round-nuts-Brass-Rohs-PASS-1000-pieces/745540578.html?recommendVersion=1
                      sense and drive
                        @ServiceXp sure
                        M3 & M2
                        RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        @axillent Thanks..
                        RJ_Make
                        • D
                          DanielD
                          hey axillent,
                          Could you upload the source code of your gateway?
                          You use another slave that?(Type of This gateway send a RF to anther module and control de lamp?)
                          If Yes could you post the schema and de souce code?
                          Thx
                          • D DanielD
                            hey axillent,
                            Thx
                            axillentA
                            axillentA
                            axillent
                            @DanielD sorry, did not get your question
                            my gateways are using standard ethernet gateway sketch
                            sense and drive
                            • D
                              DanielD
                              Hmm, you use the ethernet gateway sketch:),
                              Okay,I will do the question again, because it was a bit confusing.
                              This getway control another things? For exemple "Smart Plug" Module?
                              If yes, how you control this Plug?
                              Thx
                              • D DanielD
                                Thx
                                axillentA
                                axillentA
                                axillent
                                @DanielD my gateways are not doing other things for now
                                i have two issues with my gateways 1. it is hard to manage multi-gateway network, you need to use hardcode 2. NRF24 is not the single network I plan to integrate to mysensors
                                there is an idea to redo class structure of the MS library to create a simple way of embedding drivers other than NRF24
                                as soon as this will be developed we can do a new driver for RF433
                                the idea on how to integrate RF433 is simple, bud without class restructuring it will be a deep hardcode
                                sense and drive
                                • D
                                  DanielD
                                  wrote on last edited by DanielD
                                  #35
                                  Okay, I understand
                                  Sorry my silliness, but what do you mean hardcore 2?
                                  I will do this sketch today(Ethernet Getway), but my big problem will do sync the getway to this sensor(Plug) or another sensor and control via web/cellphone
                                  • D
                                    DanielD
                                    • D
                                      DanielD
                                      @axillent
                                      You modified the code base, alright?
                                      Could you send me the new code?
                                      Thx
                                      • D DanielD
                                        Okay, I understand
                                        axillentA
                                        axillentA
                                        axillent
                                        @DanielD 2 is stands for the second issue )
                                        before class restructure I will recommend you to use sensor sketch as a gate between RF433 and mysensors
                                        sense and drive
                                        • D
                                          DanielD
                                          @axillent
                                          Okay, I will try :)
                                          The sketch of the Plug, I will see that do many challenges, but let's go.
                                          I was reading the code the Ethernet getway, but i learn how i sync it with another sensor.
                                          Thx for your help
