  3. Battery Sensor / Voltage Monitor
24 Posts 7 Posters 16.4k Views 3 Watching
  • SweebeeS
    SweebeeS
    Sweebee
    wrote on last edited by Sweebee
    Everything looks fine.
    this is send to the gw send: 1-1-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:102
    Maybe the controller doesn't accept higher than 100.
    Your voltage is higher than 3.363V so thats why its 102%.
    add this just after int batteryPcnt - sensorValue / 10;
    if(batteryPcnt > 100)
       batteryPcnt = 100;
    or
    batteryPcnt = min(batteryPcnt, 100);
    • jeylitesJ
      jeylitesJ
      jeylites
      @ AWI
      good to hear from you :) Yes, I will like it to show up as a sensor, I'm using Vera Edge.
      @Sweebee
      I'm going to make the change and see if it works. Will report back guys!
      • jeylitesJ
        jeylitesJ
        jeylites
        wrote on last edited by jeylites
        It actually comes up as Arduino Door... very odd. Still can't get voltage or battery level to show up.
        jeylitesJ AWIA 2 Replies Last reply
        • jeylitesJ jeylites
          jeylitesJ
          jeylitesJ
          jeylites
          After restarting the node, I do see the battery % on Arduino Node . Question is, how do you make it to show up as a sensor. It will be great to have it show voltage too.
            AWIA
            AWIA
            AWI
            wrote on last edited by AWI
            @jeylites You are presenting the sensor as V_VOLTAGE (value=38). The sensor should present itself with a S_.... message. eg S_POWER (value=13) to be recognized correctly. Have a look at the API/ Serial spec
              S_VOLTAGE has not been implemented on vera (someone needs to create the device-files).
              But I don't think you need to present anything at all. The Battery level is added to the Node-device which is automatically created.
              jeylitesJ 1 Reply Last reply
                jeylitesJ
                jeylitesJ
                jeylites
                @hek That explains why it's not working
                  Sidedote: Hmm.. the gui looks awful on UI7. Why doesn't it break the text into lines?
                    jeylitesJ
                    jeylitesJ
                    jeylites
                    @hek
                    I couldn't agree more. I saw somewhere in My Sensor someone posted a way to make that go away but I can't seem to find it.
                      You are running the UI7 branch right?
                        jeylitesJ
                        jeylitesJ
                        jeylites
                        @hek Yes sir!
                        I added all these files below into Luup Screen Shot 2015-05-12 at 12.46.27 AM.png
                          @hek Yes sir!
                          jeylitesJ
                          jeylitesJ
                          jeylites
                          @hek
                          I did not know what this does so I did not add....Screen Shot 2015-05-12 at 12.50.03 AM.png
                          hekH 1 Reply Last reply
                            @hek
                            No they should not be added.
                            If someone has the time to adjust the UI7 GUI a bit I would appreciate it. There are a lot of whitespace above the icon. I hope that space is available to use by the device. If not, is sucks.
                            • jeylitesJ
                              jeylitesJ
                              jeylites
                              @hek out of curiosity, I was checking out the sketch for Sensebender and saw that it had a Child Id for Battery Sensor and Voltage sensor. How does this work as a Child id?
                              Since Voltage is not available on Vera at this time , I'm assuming I will not be able to use this feature... correct?
                                I think it is supported in Domoticz. But we better ping @tbowmo for a better explanation. It will simply be ignored in Vera.
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @jeylites @hek
                                  That battery ChildId is a leftover, from some earlier monitoring that I did, to monitor batteryvoltage decrease. Back then I used pidome as controler.
                                  For a long time it has only reported battery percentage with the following routine
                                   * Parameters
                                    if (force) lastBattery = -1;
                                    long vcc = readVcc();
                                    if (vcc != lastBattery) {
                                      lastBattery = vcc;
                                      // Calculate percentage
                                      long percent = vcc / 14.0;
                                      gw.sendBatteryLevel(percent);
                                  There are a couple of variable references back in the code at github, for the old battery voltage childId. These where removed last night, while I did some cleanup of the code. The changes are not pushed to github yet, as I haven't tested it yet.
                                    stamag
                                    How can I present the value in Voltage (for example 3.06 V)? I don't like the "Battery monitor".
                                    I have got the multiple temperature meter (DHT + Dallas) working very well. Would be nice to have battery level in volts also.
                                    Cheers!
                                    M AWIA 2 Replies Last reply
                                    • S stamag
                                      Cheers!
                                      mikemayers
                                      @stamag That depends on the kind of controller employed.
                                      There is no plugin for Vera according to @hek .
                                      • S stamag
                                        Cheers!
                                        AWIA
                                        AWIA
                                        AWI
                                        @stamag I don't know exactly which sensors are supported in vera but you could possibly 'trick' the voltage on a custom V_VAR type.
                                          stamag
