  3. 2 or more DHT11 - Sensors on one Arduino NANO MYSENSOR
dht11mysensors
11 Posts 4 Posters 14.2k Views 3 Watching
  • michlb1982M
    michlb1982M
    michlb1982
    Hello I'm a newby with programming and arduino but i like the things i can do with mysensors and the fhem on my raspberry... so i want to use a Humidity-MYSENSOR but i want to plut 2 or more of the DHT11 on one sensor...
    i tried to create a code based on the humidity-mysensor code but i failed...
    maybe someone can help me?
    is it possible to use more than one dht11 on one arduino???
    thanks for help
    mike
    SparkmanS 1 Reply Last reply
    • michlb1982M michlb1982
      thanks for help
      mike
      SparkmanS
      SparkmanS
      Sparkman
      @michlb1982 Hi Mike, yes it's possible. Why don't you post the code you have created so that feedback can be provided for it.
      Al
      • michlb1982M
        michlb1982M
        michlb1982
        hello
        well, i tried to do it by my self but, as i said, I'm a programming newbee...
        here my code
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        const int HUMIDITY_SENSOR_DIGITAL_PIN[] = {8, 7};
        #define NUMBER_OF_SENSORS 2
        unsigned long SLEEP_TIME = 15000; // Sleep time between reads (in milliseconds)
        DHT dht;
        float lastTemp;
        float lastHum;
        boolean metric = true;
          gw.begin();
          dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN[pin]);
          gw.sendSketchInfo("Humidity", "1.0");
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            Serial.print("T: ");
          if (isnan(humidity)) {
              lastHum = humidity;
              Serial.print("H: ");
              Serial.println(humidity);
        i found a relaycode and i thought that could work for the DHT11 too... ?!
        // Example sketch showing how to control physical relays.
        // This example will remember relay state even after power failure.
        const int RELAY[] = {A0, A1, A2, A3};// Arduio Digital I/O pin number for first relay (second on pin+1 etc)
          gw.sendSketchInfo("Relay", "1.4");
          // Fetch relay status
          for (int sensor=1, pin=0; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
            gw.present(sensor, S_LIGHT);
            pinMode(RELAY[pin], OUTPUT);
            digitalWrite(RELAY[pin], gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
           if (message.type==V_LIGHT) {
             // Change relay state
             digitalWrite(RELAY[message.sensor-1], message.getBool()?RELAY_ON:RELAY_OFF);
             // Store state in eeprom
        the problem i have, is that i don't know how to "call" one pin after the other to readout the data and send them each to the gateway....
        maybe you have an idea....
        thank you !
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @michlb1982 said:
          DHT dht;
          DHT dht;
          that line creates (constructs) an instance of the DHT object. If you want two DHT devices, you will need to construct two DHT objects in the program:
          DHT dht0;
          DHT dht1;
          then you need to do something like this:
          dht0.setup(HUMIDITY_SENSOR_DIGITAL_PIN[0]);
          dht1.setup(HUMIDITY_SENSOR_DIGITAL_PIN[1]);
          then in your program, you access each of them accordingly:
          float humidity0 = dht0.getHumidity();
          I hope that helps...
          • SparkmanS
            SparkmanS
            Sparkman
            To add to what BulldogLowell posted, you also need to duplicate the MySensors calls. The code below is untested and is not a real elegant way to do it, but should get you going in the right direction.
            #define CHILD_ID1_HUM 0
            #define CHILD_ID1_TEMP 1
            #define CHILD_ID2_HUM 2
            #define CHILD_ID2_TEMP 3
            const int HUMIDITY_SENSOR1_DIGITAL_PIN = 8;
            const int HUMIDITY_SENSOR2_DIGITAL_PIN = 9;
            DHT dht1;
            DHT dht2;
            float lastTemp1;
            float lastHum1;
            float lastTemp2;
            float lastHum2;
            MyMessage msgHum1(CHILD1_ID_HUM, V_HUM);
            MyMessage msgTemp1(CHILD1_ID_TEMP, V_TEMP);
            MyMessage msgHum2(CHILD2_ID_HUM, V_HUM);
            MyMessage msgTemp2(CHILD2_ID_TEMP, V_TEMP);
              gw.begin();
              dht1.setup(HUMIDITY_SENSOR1_DIGITAL_PIN);
              dht2.setup(HUMIDITY_SENSOR2_DIGITAL_PIN);
              gw.present(CHILD_ID1_HUM, S_HUM);
              gw.present(CHILD_ID1_TEMP, S_TEMP);
              gw.present(CHILD_ID2_HUM, S_HUM);
              gw.present(CHILD_ID2_TEMP, S_TEMP);
              delay(dht1.getMinimumSamplingPeriod());
              float temperature = dht1.getTemperature();
              } else if (temperature != lastTemp1) {
                lastTemp1 = temperature;
                if (!metric) {
                  temperature = dht1.toFahrenheit(temperature);
                gw.send(msgTemp1.set(temperature, 1));
                Serial.print("T1: ");
              float humidity = dht1.getHumidity();
              } else if (humidity != lastHum1) {
                  lastHum1 = humidity;
                  gw.send(msgHum1.set(humidity, 1));
                  Serial.print("H1: ");
              delay(dht2.getMinimumSamplingPeriod());
              float temperature = dht2.getTemperature();
              } else if (temperature != lastTemp2) {
                if (!metric) {
                  temperature = dht2.toFahrenheit(temperature);
                gw.send(msgTemp2.set(temperature, 1));
                Serial.print("T2: ");
              float humidity = dht2.getHumidity();
              } else if (humidity != lastHum2) {
                  lastHum = humidity;
                  gw.send(msgHum2.set(humidity, 1));
                  Serial.print("H2: ");
            • A
              andriej
              But still, even when you duplicate them - they won't properly work in Domoticz, unfortunately.
              • A andriej
                SparkmanS
                SparkmanS
                Sparkman
                Good thing the OP is using fhem then...
                • michlb1982M
                  michlb1982M
                  michlb1982
                  DHT dht1;
                  DHT dht2;
                  float lastTemp1;
                  float lastHum1;
                  float lastTemp2;
                  float lastHum2;
                  gw.begin();
                  if (!metric) {
                  if (!metric) {
                  lastHum = humidity;
                  thanks for the help, you messed up a little with the number and the names of the nodes but after 5 min i could compile it... now the test starts...
                    DHT dht1;
                    DHT dht2;
                    float lastTemp1;
                    float lastHum1;
                    float lastTemp2;
                    float lastHum2;
                    gw.begin();
                    if (!metric) {
                    if (!metric) {
                    lastHum = humidity;
                    SparkmanS
                    SparkmanS
                    Sparkman
                    @michlb1982 Glad you got it working. Do you mind posting the fixed code for reference?
                    Al
                    • michlb1982M
                      michlb1982M
                      michlb1982
                      well it works but not 100% and it needs a lot of time that the relay switches....
                      is there a way to speed up the time between giving the order and the switching of the relay?...
                      here the code
                      //Definition der Sensoren
                      #define CHILD_ID1_HUM 1
                      #define CHILD_ID2_TEMP 2
                      #define CHILD_ID3_HUM 3
                      #define CHILD_ID3_TEMP 3
                      const int HUMIDITY_SENSOR2_DIGITAL_PIN = 7;
                      const int HUMIDITY_SENSOR3_DIGITAL_PIN = 6;
                      //Definition der Relays
                      unsigned long SLEEP_TIME = 15*1000; // Sleep time between reads (in milliseconds)
                      DHT dht1;
                      DHT dht2;
                      DHT dht3;
                      float lastTemp1;
                      float lastHum1;
                      float lastTemp2;
                      float lastHum2;
                      float lastTemp3;
                      float lastHum3;
                      MyMessage msgHum1(CHILD_ID1_HUM, V_HUM);
                      MyMessage msgTemp1(CHILD_ID1_TEMP, V_TEMP);
                      MyMessage msgHum2(CHILD_ID2_HUM, V_HUM);
                      MyMessage msgTemp2(CHILD_ID2_TEMP, V_TEMP);
                      MyMessage msgHum3(CHILD_ID3_HUM, V_HUM);
                      MyMessage msgTemp3(CHILD_ID3_TEMP, V_TEMP);
                        gw.begin();
                        dht3.setup(HUMIDITY_SENSOR3_DIGITAL_PIN);
                        gw.present(CHILD_ID3_HUM, S_HUM);
                        gw.present(CHILD_ID3_TEMP, S_TEMP);
                          //digitalWrite(RELAY[pin], 0);  //schaltet standardmaessig aus
                      //DHT 11 Sensor 1
                        float temperature1 = dht1.getTemperature();
                        if (isnan(temperature1)) {
                        } else if (temperature1 != lastTemp1) {
                          lastTemp1 = temperature1;
                          if (!metric) {
                            temperature1 = dht1.toFahrenheit(temperature1);
                          gw.send(msgTemp1.set(temperature1, 1));
                          Serial.println(temperature1);
                        float humidity1 = dht1.getHumidity();
                        if (isnan(humidity1)) {
                        } else if (humidity1 != lastHum1) {
                            lastHum1 = humidity1;
                            gw.send(msgHum1.set(humidity1, 1));
                            Serial.println(humidity1);
                      // DHT11 Sensor 2
                        float temperature2 = dht2.getTemperature();
                        if (isnan(temperature2)) {
                        } else if (temperature2 != lastTemp2) {
                          lastTemp2 = temperature2;
                          if (!metric) {
                            temperature2 = dht2.toFahrenheit(temperature2);
                          gw.send(msgTemp2.set(temperature2, 1));
                          Serial.println(temperature2);
                        float humidity2 = dht2.getHumidity();
                        if (isnan(humidity2)) {
                        } else if (humidity2 != lastHum2) {
                            lastHum2 = humidity2;
                            gw.send(msgHum2.set(humidity2, 1));
                            Serial.println(humidity2);
                      //DHT11 Sensor 3
                        delay(dht3.getMinimumSamplingPeriod());
                        float temperature3 = dht3.getTemperature();
                        if (isnan(temperature3)) {
                        } else if (temperature3 != lastTemp3) {
                          lastTemp3 = temperature3;
                          if (!metric) {
                            temperature3 = dht3.toFahrenheit(temperature3);
                          gw.send(msgTemp3.set(temperature3, 1));
                          Serial.print("T3: ");
                          Serial.println(temperature3);
                        float humidity3 = dht3.getHumidity();
                        if (isnan(humidity3)) {
                        } else if (humidity3 != lastHum3) {
                            lastHum3 = humidity3;
                            gw.send(msgHum3.set(humidity3, 1));
                            Serial.print("H3: ");
                            Serial.println(humidity3);
                      maybe someone has an idea?
                      the next problem, when i unplug the power and replug it, the relay gets into the last status, i want the relay always off only when i give the order... in case of "off-plowering " it shall be off after replug...
                      did i explained understandable??
                      short: relay = off , order to switch on => relay on , cut off power and replug Relay => still off...
                        here the code
                        DHT dht1;
                        DHT dht2;
                        DHT dht3;
                        float lastTemp1;
                        float lastHum1;
                        float lastTemp2;
                        float lastHum2;
                        float lastTemp3;
                        float lastHum3;
                          gw.begin();
                        //DHT 11 Sensor 1
                            if (!metric) {
                        // DHT11 Sensor 2
                            if (!metric) {
                        //DHT11 Sensor 3
                            if (!metric) {
                        SparkmanS
                        SparkmanS
                        Sparkman
                        @michlb1982
                        A couple of things, you put the device to sleep so while it's asleep, it won't respond to the commands to change the relays. Since you are combining relays and sensors, you need to keep the unit awake and find a different way to send the sensor data occasionally. For the relay status, read the comments in the sketch. You are saving the relay state and then reading that on startup. You can eliminate all of that code and just set the relay to off in the setup section.
                        Al
