  3. How to disable debugging in a sketch
5 Posts 3 Posters 2.6k Views 3 Watching
  • bpairB
    bpairB
    bpair
    I have seen a few comments on the ethernet sketch that you need to disable debugging so that the sketch will fit on an arduino. So I am using codebender and the arduino ide 1.6.4 but I do not see anything about disabling debugging. What exactly am I missing here?
    • rvendrameR
      rvendrameR
      rvendrame
      Usually the sketch fit in a arduino (unless you write a very long "own" sensor code).
      Anyway just find our copy of MyConfig.h , and comment these lines:
       * Enable/Disable debug logging
      #define DEBUG
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      bpairB David MoraD 2 Replies Last reply
      • rvendrameR rvendrame
        #define DEBUG
        bpairB
        bpairB
        bpair
        wrote on last edited by hek
        @rvendrame Thanks. When using codebender is there an easy way to adjust the values in MyConfig.h?
        No, if you need to alter the config-file you'll probably have to download the code an use a local IDE (at least I can't modify the library code online when trying).
        • rvendrameR
          rvendrameR
          rvendrame
          I use local IDE, so I can't answer that, sorry
          Alexa / Google Home
            #define DEBUG
            David MoraD
            David MoraD
            David Mora
            @rvendrame said:
            comment th
            I know this is too old but how do you comment myconfig, tried to edit but wont let me (editing the txt file)
