  3. Multisensor PIR problem [solved]
53 Posts 7 Posters 27.4k Views 3 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    Which arduino PIN do you use to connect the PIR?
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    n3roN 1 Reply Last reply
    • rvendrameR rvendrame
      n3roN
      n3roN
      n3ro
      @n3ro said:
      #define PIR_SENSOR_DIGITAL 3
      pimatic + MySensors + Homeduino + z-way
      https://github.com/n3roGit/MySensors_n3ro
      • rvendrameR
        rvendrameR
        rvendrame
        Perfect. If it is working fine with a switch --- Maybe your PIN is triggering false positives? Or maybe the PIR output is floating a bit, and arduino is triggering it more than it should?
        Alexa / Google Home
        • SweebeeS
          SweebeeS
          Sweebee
          wrote on last edited by Sweebee
          #41
          If a switch works than the only could be the pir itself. You have enabled the pull-up resistor so an open collector should not give floats.
          You already told that a sketch with a pir only worked fine?
          Well, i can test what happens with my dht22 and a pir tomorrow (with your sketch).
          • SweebeeS Sweebee
            n3roN
            n3roN
            n3ro
            @Sweebee thy this would be very nice :)
            You find my sketch here:
            https://github.com/n3roGit/MySensors_n3ro/tree/master/MotionSensor_DHT_light_battery_mod
            • n3roN n3ro
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @n3ro
              you are sending an update on the PIR status every time the arduino wakes from a sleep, which you don't need.
              Also, and this probably isn't a problem right now, but will case a problem later, use unsigned subtraction in your millis( ) timers
              could not see where you were using the library, so I commented it out below, not having it on my computer
              I also made a few more notes in the code:
              //#include <readVcc.h> // cannot see where you are using this library yet
              #define NODE_ID 10                       // ID of node
              unsigned long SLEEP_TIME = 10000UL;        // Sleep time between reports (in milliseconds)
              #define CHILD_ID_PIR 1                   // Id of the sensor PIR
              #define CHILD_ID_HUM 2                   // Id of the sensor HUM
              #define CHILD_ID_TEMP 3                  // Id of the sensor TEMP
              #define CHILD_ID_LIGHT 4                 // Id of the sensor LIGHT
              #define PIR_SENSOR_DIGITAL 3           // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
              #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
              #define HUMIDITY_SENSOR_DIGITAL_PIN 2
              // Initialize Variables
              MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
              MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
              DHT dht;
              float lastTemp;
              float lastHum;
              boolean metric = true;
              boolean lastTripped = false;
              int oldBatteryPcnt;
              int lastLightLevel;
              unsigned long mytime;
              //int MIN_V = 2700; // empty voltage (0%)
              //int MAX_V = 3200; // full voltage (100%)
                gw.begin(NULL, NODE_ID, false);
                gw.sendSketchInfo("Motion Sensor", "1.0"); // here you call it motion sensor
                pinMode(PIR_SENSOR_DIGITAL, INPUT_PULLUP);
                gw.present(CHILD_ID_PIR, S_MOTION);
                //gw.sendSketchInfo("Humidity", "1.0"); // here you call it humidity
                //gw.sendSketchInfo("Light Sensor", "1.0");// pick a name for your sketch, it will only be one
                // why send this every time?
                boolean tripped = digitalRead(PIR_SENSOR_DIGITAL) == HIGH;
                Serial.print("---------- PIR: ");
                Serial.println(tripped);
                gw.send(msgPir.set(tripped ? "1" : "0"));
                if (tripped != lastTripped)  // only need to update controller on a change.
                  gw.send(msgPir.set(tripped? "1" : "0"));
                  Serial.println(tripped? "tripped" : " not tripped");
                  lastTripped = tripped;
                if ( millis() - mytime >= SLEEP_TIME )  //use UNSIGNED SUBRTACTION im your millis() timers to avoid rollover issues later on down the line
                  if (isnan(temperature))
                  else if (temperature != lastTemp)
                    lastTemp = temperature;
                    if (!metric)
                    Serial.print("---------- Temp: ");
                  if (isnan(humidity))
                  else if (humidity != lastHum)
                    lastHum = humidity;
                    Serial.print("---------- Humidity: ");
                    Serial.println(humidity);
                  mytime = millis();
                gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME); // Sleep until interrupt detected from motion sensor. Send update every SLEEP_TIME.
                @n3ro
                DHT dht;
                float lastTemp;
                float lastHum;
                int oldBatteryPcnt;
                int lastLightLevel;
                      if (!metric)
                      lastHum = humidity;
                    mytime = millis();
                n3roN
                n3roN
                n3ro
                @BulldogLowell
                Hey, its a good idea to send only PIR if changed!
                The unused code in the sketch is because i have reduced the used functions to the minimum to debug it better. The full sketch has LDR and battery lifetime output too.
                i have added some extra output in the modified sketch:
                DHT dht;
                float lastTemp;
                float lastHum;
                int oldBatteryPcnt;
                int lastLightLevel;
                    Serial.println(tripped ? "tripped" : " not tripped");
                      if (!metric)
                      lastHum = humidity;
                    mytime = millis();
                    Serial.println("no millis");
                  Serial.println(millis());
                  Serial.println(mytime);
                  Serial.println(SLEEP_TIME);
                send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:0
                ---------- PIR: not tripped
                no millis
                2185
                no millis
                2189
                no millis
                2193
                no millis
                2195
                no millis
                2197
                no millis
                2201
                no millis
                2203
                no millis
                2205
                no millis
                2209
                no millis
                2211
                no millis
                You can see that the "if millis" will never used .:(
                • n3roN
                  n3roN
                  n3ro
                  i think millis didnt work with sleep. the counter is not increasing when sleeping..
                  • BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    you dont need this:
                    since you are sleeping longer than the minimum sampling period
                    try like this, removing the timer, just use the sleep period t update temp/humidity (untested):
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                    int oldBatteryPcnt;
                    int lastLightLevel;
                        if (!metric)
                        lastHum = humidity;
                      you dont need this:
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                      int oldBatteryPcnt;
                      int lastLightLevel;
                          if (!metric)
                          lastHum = humidity;
                      n3roN
                      n3roN
                      n3ro
                      @BulldogLowell
                      when i use this sketch the PIR works but the DHT cant read:
                      • BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        check the connections
                          n3roN
                          n3roN
                          n3ro
                          @BulldogLowell the wires are OK.
                          In sleep the DHT cant warm-up. so the dht need 2 sec before read. when i dont use the delay i cant read it.
                          i dont understand why the interrupt didnt work with the enabled delay.
                          do you have tested on a arduino?
                          • n3roN
                            n3roN
                            n3ro
                            now its working. when i use PIN4 for DHT.:)
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              @n3ro, i'm glad you fixed it. DHT was on PIN3 before, right? Pin 2 & Pin3 are connected to the interrupts, maybe this was the problem.
                              Alexa / Google Home
                                n3roN
                                n3roN
                                n3ro
                                @rvendrame yes i think so. but now its ok =)
                                • n3roN n3ro
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  :clap:
