  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 329.5k Views 52 Watching
    @petewill
    I think waiting for the I2C piggyback will be worth the time, but you can debug with the Serial connection, I have all that in there.
    I would think that retrieving the latest times for the sprinklers could be brought back to once a day even, if you are that worried about traffic.
    Just curious, but how many valves will you end up controlling?
    PS my factory is in the north, and I won't be getting to the south this trip. Shenzhen is really the epicenter of hobby electronics plus, it is never a good thing to bring a lot of small electronic components, wires and sensors in your bags through airport security!
    petewillP
    petewillP
    petewill
    Yeah, I'm thinking I can still get it partially working this weekend (hopefully) but I wish I could see the LCD. That is such a cool feature!
    I still need to think through the PLEG but I was hoping to do something like this...
    • If there has been rain in the past 5 days adjust the irrigation timing based on the amount.
    • Also, factor in the past high temperatures as well as the upcoming forecast.
    • If it is currently raining, stop the irrigation.
    I still need to think through it a little more but calculations like that would require the variables to be updated to the irrigation controller more than once a day (at least I think). That's why I was thinking it would be cool if it pulled the values before it ran each zone. It could still update every 5 hours or so though for the heartbeat. I really like that benefit!
    Currently only 5 but I will probably add 2 more in the next year or so.
    Haha, very true!
    • petewillP
      petewillP
      petewill
      @BulldogLowell is there a reason you're using pin 2 for the button/interrupt? That is normally wired up with the radio (although not currently used I believe). Is there a reason I shouldn't switch it to pin 3?
      • petewillP
        petewillP
        petewill
        Never mind. I forgot that interrupt numbers aren't pin numbers. I changed it to a 1 for pin 3 on my pro mini. What Arduino are you using?
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          I cannot recall, but think I probably used a nano.
          • petewillP
            petewillP
            petewill
            @BulldogLowell I'm getting an error when I try to compile the code (I am finally getting to the point of uploading it). There are a long string of errors but they seem to be related to this:
                IrrigationController.ino:122:34: error: invalid conversion from 'int' to 't_backlighPol' [-fpermissive]
                In file included from IrrigationController.ino:59:0:
                C:\Users\petewill\Documents\Arduino\libraries\LiquidCrystal/LiquidCrystal_I2C.h:53:4: error:   initializing argument 3 of 'LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, t_backlighPol)' [-fpermissive]
                LiquidCrystal_I2C (uint8_t lcd_Addr, uint8_t backlighPin, t_backlighPol pol);
            Here is the Arduino code:
            LiquidCrystal_I2C lcd(0x27, 16, 2);  // set the LCD I2C address to 0x27 (16 characters and 2 line display)
            I downloaded the 1.2.1 library from here: https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
            Is there something else I should be doing?
            Pete
            • petewillP petewill
              Pete
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @petewill
              9:15am here in china!
              can you post what you are trying to compile? it looks like a library issue (as you figured out) but I want to make suer I can compile exactly what you have.
              • petewillP
                petewillP
                petewill
                @BulldogLowell 9am nice! I'm ready for bed :)
                Here is the code I'm trying to compile. I think it's pretty much what you have except a couple small additions like Child ID, Sketch Name etc.
                MySprinkler for MySensors
                Arduino Multi-Zone Sprinkler Control
                November, 2014
                *** Version 2.0
                *** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve times and clock respectively
                your arduino will call to Vera once a minute and update accordingly.
                * Pushbutton activation to RUN_ALL_ZONES
                * LED status indicator
                INSTRUCTIONS:
                * Verify that each new device has a Variable1 and Variable2. Populate data accordingly with whole minutes for
                the RUN_ALL_ZONES routine and the RUN_SINGLE_ZONE routines.  The values entered may be zero.
                on the serial monitor.
                * https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
                Contributed by Jim (BulldogLowell@gmail.com) and is released to the public domain
                #include <Time.h>
                #define NUMBER_OF_VALVES 5  // Change this to set your valve count up to 16.
                #define RADIO_ID AUTO // AUTO  // Change this to fix your Radio ID or use Auto
                //*Added sketch name and version
                #define SKETCH_VERSION "2.0"
                //*Added Child ID definition
                #define CHILD_ID_SPRINKLER 0
                #define ACTIVE_LOW // comment out this line if your relays are active high
                #ifdef ACTIVE_LOW
                #define ALL_VALVES_OFF 0xFFFF
                #define ALL_VALVES_OFF 0U
                #ifdef DEBUG_ON
                typedef enum {
                 STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE}
                SprinklerStates;
                SprinklerStates lastState;
                int allZoneTime [NUMBER_OF_VALVES + 1];
                int valveSoloTime [NUMBER_OF_VALVES + 1];
                int valveNumber;
                int lastValve;
                unsigned long startMillis;
                const int ledPin = 5;
                boolean buttonPushed = false;
                boolean showTime = true;
                boolean clockUpdating = false;
                boolean recentUpdate = true;
                const char *dayOfWeek[] = {
                 "Null","Sunday ","Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "};
                time_t lastTimeRun = 0;
                //Setup Shift Register...
                const int latchPin = 8;
                const int clockPin = 4;
                const int dataPin  = 7;
                uint8_t clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // fetching time indicator
                uint8_t raindrop[8] = {0x4,0x4,0xA,0xA,0x11,0xE,0x0,}; // fetching Valve Data indicator
                MyMessage msg1valve(CHILD_ID_SPRINKLER,V_LIGHT);
                MyMessage var1valve(CHILD_ID_SPRINKLER,V_VAR1);
                MyMessage var2valve(CHILD_ID_SPRINKLER,V_VAR2);
                 //*Not needed
                 //Serial.begin(115200);
                 delay(5000);
                 lcd.init();
                 lcd.clear();
                 lcd.backlight();
                 lcd.createChar(0, clock);
                 lcd.createChar(1, raindrop);
                 pinMode(latchPin, OUTPUT);
                 pinMode(clockPin, OUTPUT);
                 pinMode(dataPin, OUTPUT);
                 pinMode(ledPin, OUTPUT);
                 //*Changed for Pin 3 on the pro mini
                 attachInterrupt(1, PushButton, CHANGE);
                 digitalWrite (ledPin, HIGH);
                 if (gw.loadState(0) == 0xFF); // EEPROM flag
                    for (int i = 0; i < 4 ; i++)
                     lastTimeRun = lastTimeRun | gw.loadState(i+1); // assemble 4 bytes into an ussigned long epoch timestamp
                 gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                    gw.present(i, S_LIGHT);
                 updateRelays(ALL_VALVES_OFF);
                 digitalWrite (ledPin, LOW);
                 DEBUG_PRINTLN(F("Ready..."));
                 lcd.setCursor(0, 0);
                 lcd.setCursor(15, 0);
                 lcd.write(0);  //lcd.print(0, BYTE);
                 lcd.setCursor(0, 1);
                 int clockCounter = 0;
                 while(timeStatus() == timeNotSet && clockCounter < 21)
                    gw.requestTime(receiveTime);
                    delay(1000);
                    lcd.print(".");
                    DEBUG_PRINT(F("."));
                    clockCounter++;
                    if (clockCounter > 16)
                     lcd.clear();
                     lcd.setCursor(0,1);
                     delay(2000);
                 lcd.clear();
                 updateClock();
                 updateDisplay();
                 goGetValveTimes();
                 if (buttonPushed)
                    if (state != RUN_ALL_ZONES);
                     state = RUN_ALL_ZONES;
                     valveNumber = 1;
                     gw.send(msg1valve.setSensor(0).set(true), false);
                     startMillis = millis();
                     for (byte i = 0; i < 5; i++)  // flash lcd backlight on button press
                        lcd.noBacklight();
                        delay(25);
                        lcd.backlight();
                     delay(50);
                     fastClear();
                     lcd.setCursor(0,0);
                     lcd.print(F("*AllZone Active*"));
                     lcd.setCursor(0,0);
                     lcd.print(F(" Cycling  Zones "));
                     delay(1000);
                     DEBUG_PRINT(F("State = "));
                     DEBUG_PRINTLN(state);
                    slowToggleLED ();
                    if (state != lastState)
                        delay(50);
                        gw.send(msg1valve.setSensor(i).set(false), false);
                     lastValve = -1;
                    if (lastValve != valveNumber)
                         gw.send(msg1valve.setSensor(i).set(true), false);
                    lastValve = valveNumber;
                    fastToggleLed();
                     valveNumber = 1;
                     valveNumber++;
                        state = CYCLE_COMPLETE;
                        lastValve = -1;
                        lastTimeRun = now();
                    fastToggleLed();
                     DEBUG_PRINT(F("Zone: "));
                     DEBUG_PRINTLN(valveNumber);
                     fastToggleLed();
                 lastState = state;
                void updateRelays(int value)
                 digitalWrite(latchPin, LOW);
                 digitalWrite(latchPin, HIGH);
                    buttonPushed = true;
                void fastToggleLed()
                    fastLedTimer = millis ();
                void slowToggleLED ()
                    slowLedTimer = millis ();
                 boolean zoneTimeUpdate = false;
                 if (message.isAck())
                 for (byte i = 0; i<= NUMBER_OF_VALVES; i++)
                    if (message.sensor == i)
                     if (message.type == V_LIGHT)
                        if (switchState == 0)
                         if (i == 0)
                            valveNumber = 1;
                            state = RUN_SINGLE_ZONE;
                            valveNumber = i;
                            DEBUG_PRINTLN(i);
                        DEBUG_PRINT(i);
                        DEBUG_PRINT(F(" = "));
                        DEBUG_PRINTLN(variable1);
                         allZoneTime[i] = variable1;
                         zoneTimeUpdate = true;
                        DEBUG_PRINT(i);
                        DEBUG_PRINTLN(variable2);
                         valveSoloTime[i] = variable2;
                 if (zoneTimeUpdate)
                     if (i != 0)
                        DEBUG_PRINT(F("Zone "));
                        DEBUG_PRINT(i);
                        DEBUG_PRINTLN(allZoneTime[i]);
                    recentUpdate = false;
                void updateDisplay()
                 static boolean displayToggle = false;
                    switch (state){
                    case STAND_BY_ALL_OFF:
                     fastClear();
                     lcd.setCursor(0,0);
                     if (displayToggle)
                        if (clockUpdating)
                         lcd.setCursor(15,0);
                         lcd.write(0);
                        lcd.setCursor(0,1);
                        lcd.print(hourFormat12());
                        lcd.print(minute());
                        lcd.print(F(" "));
                        lcd.print(month() < 10? F("0") : F(""));
                        lcd.print(month());
                        lcd.print(day() < 10? F("/0") : F("/"));
                        lcd.print(day());
                        lcd.print(F("/"));
                        lcd.print(year()%100);
                        if (clockUpdating)
                         lcd.write(0);
                        lcd.setCursor(0,1);
                        lcd.setCursor(11,1);
                        lcd.print(day(lastTimeRun));
                    case RUN_SINGLE_ZONE:
                     fastClear();
                     lcd.setCursor(0,0);
                     if (displayToggle)
                        lcd.setCursor(0,1);
                        lcd.print(F(" Zone:"));
                        lcd.print(valveNumber);
                        lcd.print(F(" Active"));
                        lcd.setCursor(0,1);
                        lcd.print("min");
                        lcd.print("sec  ");
                    case RUN_ALL_ZONES:
                     fastClear();
                     lcd.setCursor(0,0);
                     if (displayToggle)
                        lcd.setCursor(0,1);
                        lcd.print(F(" Active "));
                        lcd.setCursor(0,1);
                        lcd.print("min");
                        lcd.print("sec  ");
                    case CYCLE_COMPLETE:
                     if (displayToggle)
                        lcd.setCursor(0,0);
                        lcd.setCursor(0,1);
                        int totalTimeRan = 0;
                        lcd.setCursor(0,0);
                        lcd.setCursor(0,1);
                        lcd.print(totalTimeRan);
                        lcd.print(" Minutes   ");
                    lastUpdateTime = millis();
                 lastDisplayState = state;
                 int lastSecond = second();
                 int lastMinute = minute();
                 int lastHour = hour();
                 setTime(newTime);
                    DEBUG_PRINT(hourFormat12());
                    DEBUG_PRINT(minute());
                    DEBUG_PRINT(month());
                    DEBUG_PRINT(F("/"));
                    DEBUG_PRINT(day());
                    DEBUG_PRINTLN(year());
                    showTime = false;
                void fastClear()
                 lcd.setCursor(0,0);
                 lcd.setCursor(0,1);
                void updateClock()
                 if (millis() - lastVeraGetTime >= 60000UL) // updates clock time and gets zone times from vera once every 10 minutes
                    lcd.write(0);
                    clockUpdating = true;
                    lastVeraGetTime = millis();
                 if (gw.loadState(0) != 0xFF)
                    gw.saveState(0,0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                 for (int i = 1; i < 5; i++)
                    gw.saveState(5-i, byte(theDate >> 8 * (i-1)));// store epoch datestamp in 4 bytes of EEPROM starting in location one
                void goGetValveTimes()
                 static byte valveIndex = 1;
                 if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                    DEBUG_PRINTLN(F("Calling for Valve Times..."));
                    lcd.write(1);
                    gw.request(valveIndex, V_VAR1);
                    gw.request(valveIndex, V_VAR2);
                    valveUpdateTime = millis();
                    valveIndex++;
                    if (valveIndex > NUMBER_OF_VALVES+1)
                     valveIndex = 1;
                • BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  #26
                  @petewill
                  meanwhile I tried to compile my old code with the latest Arduino IDE and get the same errors...
                  It may take me some time, but meanwhile you can try Arduino board for I2C library for LCDs.
                  sorry!
                    On a plane to china, working on the Rain Gauge!!!
                    Awesome! I should have some time this weekend to test if you have something by then.
                    I personally don't mind at all the calls every five minutes, each call is a few milliseconds and it has the side benefit of updating the device last updated time on vera's device, so I know it's in contact with the gateway. I haven't had a traffic problem on my system yet.
                    Good to know. I have around 80 MySensors devices so I'm always thinking about keeping communication to a minimum. I may just run it as is and if I notice any issues I can look into adjusting the code.
                    I can mail you an I2C LCD if you need it, you just have to wait until I'm back from China.
                    Wow, thanks for the offer! I have already ordered a replacement so hopefully it will arrive right around the time you get back. This is my first time working with LCDs so I didn't even think to look for the I2C connectivity. I just read the description and took their word for it. That will teach me...
                    Oh yeah... that's cool you're going to China! Are you stocking up on a whole bunch of parts while you're there? :)
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    Holy cow, ~80 MySensor devices.. I'm surprised Vera handles all that traffic reliably... My Vera3 can't seem to handle my ~35 Z-Wave and ~ 15 MySensors devices reliably...
                    I'm in the starting process of moving everything over to HomeSeer. I'm really hoping this solution works better.. The little I've done so far, I'm VERY impressed. I will not miss PLEG (It's a great plug-in but difficult to build and maintain for me), as the built in event system in HS3 Pro is amazing and I've only just scratch the surface...
                    RJ_Make
                    • petewillP
                      petewillP
                      petewill
                      Depends on your definition of reliably :) I'd say 98% of the time there are no issues but the other 2% can be annoying... I am continually amazed by how well MySensors works. I just keep adding devices and it keeps performing. Henrik and team are awesome!
                      Vera can definitely be frustrating. The key for me is to limit the plugins. I am very careful what I install. I'm sure I'll have to switch from Vera one day (unless they start making more powerful hardware) but for now it works and it's cheap. What are you going to do with MySensors when you switch? I love MySensors too much!!
                      RJ_MakeR 1 Reply Last reply
                      • petewillP
                        petewillP
                        petewill
                        Jim,
                        I did some searching and modified the code a little. It will now compile but I haven't had time to figure out what the purpose of lcd.write(0) was for. I have to go to work so I won't be able to look into it until later. Here are the items of code I changed to get it to compile:
                        //LiquidCrystal_I2C lcd(0x27, 16, 2);  // set the LCD I2C address to 0x27
                        LiquidCrystal_I2C lcd(0x27);  // set the LCD I2C address to 0x27
                         //*Added
                        //*Removed
                        // lcd.init();
                        //*Removed 3 instances of:
                        // lcd.write(0);
                        Interestingly lcd.write(1); will compile. I also don't have an LCD to test with so I don't know if it will work.
                          RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          @petewill There is a MySensors plug-in for HS3, At the moment it is a bit limited, and has some bugs but the developer is working on it.
                          RJ_Make
                          petewillP 1 Reply Last reply
                          • RJ_MakeR RJ_Make
                            petewillP
                            petewillP
                            petewill
                            @ServiceXp Good to know. I'll keep that in mind. Thanks for passing that on!
                            • BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              #32
                              @petewill
                              lcd.write(0)
                              Prints the '0' special character.
                              There is a raindrop icon, which tells you times are downloading and a clock icon which designates clock updates.
                              convert the hex to binary you can see the shape (5 X 7 pixels, so disregard the first three bits):
                              00000000
                              00001110
                              00010101
                              00010111
                              00010001
                              00001110
                              00000000
                              can you see the clock face at 3:00?
                              00000100
                              00000100
                              00001010
                              00001010
                              00010001
                              00010001
                              00001110
                              00000000
                              Can you see the raindrop?
                              they are created here:
                              if you look at the video above, they appear from time to time.
                              cool right?
                              • petewillP
                                petewillP
                                petewill
                                Ok, good to know. I'll see if I can do a little searching on that. Maybe there is a different way to implement them now?? It will be hard to test without an LCD but hopefully it will come soon and I can post back :)
                                Speaking of testing I was able to control my relays last night from Vera! SO COOL!! This is one of the devices I have been wanting to add for a long time. I can't wait to be able to turn on my valves from my phone when I'm turning on my sprinkler system. It sure will beat sprinting to/from the basement...
                                Thanks again for the awesome work!
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @petewill
                                  I edited above to give more detail...
                                  • petewillP
                                    petewillP
                                    petewill
                                    Ok, thanks. I did a little research and found this from the Arduino website:
                                    When referencing custom character "0", if it is not in a variable, you need to cast it as a byte, otherwise the compiler throws an error. See the example below.
                                    http://www.arduino.cc/en/Reference/LiquidCrystalCreateChar
                                    I changed the code to this:
                                    byte clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0};
                                    and this
                                    lcd.write(byte(0));
                                    and now it's compiling. But, I don't know if it's working.
                                    I'm still working on a couple of other small things I found. I'll post the code when I get it to a point where it's ready for your review.
                                    • petewillP
                                      petewillP
                                      petewill
                                      @BulldogLowell
                                      Here is the code with some changes. I have also attached a document with the changes highlighted. The most notable thing is I added some code to update the valve times when the device is first powered on. I hope that's ok.
                                      One thing I can't figure out, but hopefully you can, is the button is always acting like it's "pressed" when the Arduino is first powered on. This could be a problem as the power seems to go off in my house a couple of times a year (I don't want my irrigation to run when it's not supposed to). Any idea how to fix it? I've tried everything I could think of (which isn't much) and nothing worked.
                                      Anyway, here is the PDF with the changes Irrigation Controller Changes.pdf
                                      And the code:
                                      November, 2014
                                      *** Version 2.0
                                      INSTRUCTIONS:
                                      #include <Time.h>
                                      #ifdef ACTIVE_LOW
                                      #ifdef DEBUG_ON
                                      typedef enum {
                                      SprinklerStates;
                                      int valveNumber;
                                      int lastValve;
                                      const int waterButtonPin = 3;
                                      byte clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // fetching time indicator
                                      byte raindrop[8] = {0x4,0x4,0xA,0xA,0x11,0xE,0x0,}; // fetching Valve Data indicator
                                        delay(5000);
                                       //*Added
                                      //*Removed
                                      // lcd.init();
                                       lcd.clear();
                                       lcd.backlight();
                                       attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                                       lcd.write(byte(0));  //lcd.print(0, BYTE);
                                          delay(1000);
                                          lcd.print(".");
                                          //DEBUG_PRINT(F("."));
                                          clockCounter++;
                                           lcd.clear();
                                           lcd.setCursor(0,1);
                                           delay(2000);
                                       lcd.clear();
                                       //Update valve times when first powered on
                                       for(byte i = 0; i <= NUMBER_OF_VALVES; i++)
                                         allZoneTime[i]=-1;
                                         valveSoloTime[i]=-1;
                                         while((valveSoloTime[i]==-1 || allZoneTime[i]==-1) && clockCounter < 10)
                                           lcd.write(byte(1)); //lcd.write(1);
                                           gw.request(i, V_VAR1);
                                           gw.request(i, V_VAR2);
                                           delay(1000);
                                           clockCounter++;
                                           if (clockCounter > 10)
                                              DEBUG_PRINTLN(F("Failed initial valve synchronization!"));
                                              lcd.clear();
                                              lcd.print(F("  Failed Valve  "));
                                              lcd.setCursor(0,1);
                                       updateClock();
                                       updateDisplay();
                                       goGetValveTimes();
                                       if (buttonPushed)
                                           valveNumber = 1;
                                              lcd.noBacklight();
                                              delay(25);
                                              lcd.backlight();
                                           delay(50);
                                           fastClear();
                                           lcd.setCursor(0,0);
                                           lcd.setCursor(0,0);
                                           delay(1000);
                                            //valveNumber = 1;
                                            gw.send(msg1valve.setSensor(0).set(false), false);
                                              lcd.noBacklight();
                                              delay(25);
                                              lcd.backlight();
                                            delay(50);
                                            fastClear();
                                            lcd.setCursor(0,0);
                                            lcd.print(F("*AllZone Off*"));
                                            lcd.setCursor(0,0);
                                            lcd.print(F(" Stopping  Zones "));
                                            delay(1000);
                                          slowToggleLED ();
                                              delay(50);
                                           lastValve = -1;
                                          fastToggleLed();
                                           valveNumber = 1;
                                           valveNumber++;
                                              lastValve = -1;
                                          fastToggleLed();
                                           fastToggleLed();
                                       lastState = state;
                                               if (i == 0)
                                                  valveNumber = 1;
                                                  valveNumber = i;
                                                  DEBUG_PRINTLN(i);
                                              DEBUG_PRINT(i);
                                              DEBUG_PRINT(i);
                                       if (zoneTimeUpdate)
                                           if (i != 0)
                                              DEBUG_PRINT(i);
                                          switch (state){
                                           fastClear();
                                           lcd.setCursor(0,0);
                                           if (displayToggle)
                                              if (clockUpdating)
                                               lcd.write(byte(0));
                                              lcd.setCursor(0,1);
                                              lcd.print(F(" "));
                                              lcd.print(month());
                                              lcd.print(day());
                                              lcd.print(F("/"));
                                              if (clockUpdating)
                                               lcd.write(byte(0));
                                              lcd.setCursor(0,1);
                                           fastClear();
                                           lcd.setCursor(0,0);
                                           if (displayToggle)
                                              lcd.setCursor(0,1);
                                              lcd.setCursor(0,1);
                                              lcd.print("min");
                                              lcd.print("sec  ");
                                          case RUN_ALL_ZONES:
                                           fastClear();
                                           lcd.setCursor(0,0);
                                           if (displayToggle)
                                              lcd.setCursor(0,1);
                                              lcd.setCursor(0,1);
                                              lcd.print("min");
                                              lcd.print("sec  ");
                                           if (displayToggle)
                                              lcd.setCursor(0,0);
                                              lcd.setCursor(0,1);
                                              lcd.setCursor(0,0);
                                              lcd.setCursor(0,1);
                                       setTime(newTime);
                                          DEBUG_PRINT(day());
                                          showTime = false;
                                      void fastClear()
                                       lcd.setCursor(0,0);
                                       lcd.setCursor(0,1);
                                      void updateClock()
                                          lcd.write(byte(0));
                                          valveIndex++;
                                           valveIndex = 1;
                                        @BulldogLowell
                                        And the code:
                                        November, 2014
                                        *** Version 2.0
                                        INSTRUCTIONS:
                                        #include <Time.h>
                                        #ifdef ACTIVE_LOW
                                        #ifdef DEBUG_ON
                                        typedef enum {
                                        SprinklerStates;
                                        int valveNumber;
                                        int lastValve;
                                          delay(5000);
                                         //*Added
                                        //*Removed
                                        // lcd.init();
                                         lcd.clear();
                                         lcd.backlight();
                                            delay(1000);
                                            lcd.print(".");
                                            clockCounter++;
                                             lcd.clear();
                                             lcd.setCursor(0,1);
                                             delay(2000);
                                         lcd.clear();
                                           allZoneTime[i]=-1;
                                             delay(1000);
                                             clockCounter++;
                                                lcd.clear();
                                                lcd.setCursor(0,1);
                                         updateClock();
                                         updateDisplay();
                                         goGetValveTimes();
                                         if (buttonPushed)
                                             valveNumber = 1;
                                                lcd.noBacklight();
                                                delay(25);
                                                lcd.backlight();
                                             delay(50);
                                             fastClear();
                                             lcd.setCursor(0,0);
                                             lcd.setCursor(0,0);
                                             delay(1000);
                                              //valveNumber = 1;
                                                lcd.noBacklight();
                                                delay(25);
                                                lcd.backlight();
                                              delay(50);
                                              fastClear();
                                              lcd.setCursor(0,0);
                                              lcd.setCursor(0,0);
                                              delay(1000);
                                            slowToggleLED ();
                                                delay(50);
                                             lastValve = -1;
                                            fastToggleLed();
                                             valveNumber = 1;
                                             valveNumber++;
                                                lastValve = -1;
                                            fastToggleLed();
                                             fastToggleLed();
                                         lastState = state;
                                                 if (i == 0)
                                                    valveNumber = 1;
                                                    valveNumber = i;
                                                    DEBUG_PRINTLN(i);
                                                DEBUG_PRINT(i);
                                                DEBUG_PRINT(i);
                                         if (zoneTimeUpdate)
                                             if (i != 0)
                                                DEBUG_PRINT(i);
                                            switch (state){
                                             fastClear();
                                             lcd.setCursor(0,0);
                                             if (displayToggle)
                                                if (clockUpdating)
                                                 lcd.write(byte(0));
                                                lcd.setCursor(0,1);
                                                lcd.print(F(" "));
                                                lcd.print(month());
                                                lcd.print(day());
                                                lcd.print(F("/"));
                                                if (clockUpdating)
                                                 lcd.write(byte(0));
                                                lcd.setCursor(0,1);
                                             fastClear();
                                             lcd.setCursor(0,0);
                                             if (displayToggle)
                                                lcd.setCursor(0,1);
                                                lcd.setCursor(0,1);
                                                lcd.print("min");
                                                lcd.print("sec  ");
                                            case RUN_ALL_ZONES:
                                             fastClear();
                                             lcd.setCursor(0,0);
                                             if (displayToggle)
                                                lcd.setCursor(0,1);
                                                lcd.setCursor(0,1);
                                                lcd.print("min");
                                                lcd.print("sec  ");
                                             if (displayToggle)
                                                lcd.setCursor(0,0);
                                                lcd.setCursor(0,1);
                                                lcd.setCursor(0,0);
                                                lcd.setCursor(0,1);
                                         setTime(newTime);
                                            DEBUG_PRINT(day());
                                            showTime = false;
                                        void fastClear()
                                         lcd.setCursor(0,0);
                                         lcd.setCursor(0,1);
                                        void updateClock()
                                            lcd.write(byte(0));
                                            valveIndex++;
                                             valveIndex = 1;
                                        BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        You could try a bigger pullup resistor, maybe the pin floats for a brief moment or it is somehow energized... I've read about others having a problem like that. Alternatively, reverse the logic and pull pull the pin down to ground. I'd expect that one or both can correct that issue.
                                        Glad to have the improvements in the code, that's great! Always better to have another set of eyes on a project.
                                        • petewillP
                                          petewillP
                                          petewill
                                          Ok, I'll do some testing with that. I don't think I'll get the chance today but I should be able to do some tomorrow. It works perfectly after the first start up so hopefully a bigger resistor will help.
