  3. Bad range
Bad range
16 Posts 6 Posters 9.9k Views 2 Watching
  • n3roN n3ro
    is it possible that my wifi router make problems with mysensors?
    andriej
    @n3ro It is possible - try changing 'channel' in RF24 Config on every node (by reflashing it).
    n3roN 1 Reply Last reply
    • A andriej
      n3roN
      n3roN
      n3ro
      @andriej this sounds interesting. what is to do to reflash it?
      pimatic + MySensors + Homeduino + z-way
      https://github.com/n3roGit/MySensors_n3ro
      A 1 Reply Last reply
      • n3roN n3ro
        andriej
        @n3ro just change the channel in config file (try to set it in higher values in example) and reprogram all sensors and gateway on your network.
        • n3roN
          n3roN
          n3ro
          ah okay. So far I have this sketch to test the distance:
          https://github.com/n3roGit/MySensors_n3ro/tree/master/test_sketch
          tomorrow I'll reflash all nodes+gw and test it again :)
          • A
            Andreas Maurer
            Have you seen this new Video
            n3roN Sander TeunissenS 2 Replies Last reply
            • A Andreas Maurer
              n3roN
              n3roN
              n3ro
              wrote on last edited by n3ro
              @Andreas-Maurer Cant play Video :(
              • A Andreas Maurer
                Sander TeunissenS
                Sander TeunissenS
                Sander Teunissen
                • A
                  Andreas Maurer
                  https://www.youtube.com/watch?v=gtM832Z0ujE
                  • n3roN
                    n3roN
                    n3ro
                    i have still a band range. next i will test a gw with a nrf antenna version. i hope this helps
                    • R
                      R
                      rickmontana83
                      If you're using the cheaper low-power variants of the nrf24l01+ on the gateway then make sure that your MyConfig.h file has RF24_PA_MAX for RF24_PA_LEVEL_GW.
                      I noticed the other day that the default value from GitHub is RF24_PA_LOW, which gave me only a couple of feet of comms. Changing the default made everything work much better. Seems like the default repos is set up for the high-power radio variants.
                      • R rickmontana83
                        n3roN
                        n3roN
                        n3ro
                        @rickmontana83 YEAH!!!!! This has fixed my problem!!
                        Now i have much better rage with my nodes :+1:
                        Big THX!
