  3. Bad range
Bad range
16 Posts 6 Posters 9.4k Views 2 Watching
  • N Offline
    N Offline
    n3ro
    wrote on last edited by n3ro
    Hey folks,
    i have some problems with the rage of my nodes.
    the maximum is only 3-7 meters and 1 wall.
    i use 10 uA capacitors on each node and the gw.
    Is it possible to change some settings to extend the range or set something that the node resend the signal if the gw dont get the signal?
    Regards,
    n3ro
    Edit:
    Some output from the Node:
    Battery: 100
    PIR: 0
    send: 11-11-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:0
    send: 11-11-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    send: 11-11-0-0 s=2,c=1,t=1,pt=7,l=5,st=fail:51.3
    Humidity: 51.30
    Battery: 100
    PIR: 1
    send: 11-11-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:1
    send: 11-11-0-0 s=4,c=1,t=23,pt=2,l=2,st=fail:77
    Light: 77
    Battery: 100
    PIR: 0
    Battery: 100
    PIR: 1
    Battery: 100
    PIR: 0
    Battery: 100
    PIR: 1
    send: 11-11-0-0 s=3,c=1,t=0,pt=7,l=5,st=fail:21.6
    Temp: 21.60
    send: 11-11-0-0 s=2,c=1,t=1,pt=7,l=5,st=fail:51.2
    Humidity: 51.20
    Battery: 100
    PIR: 1
    send: 11-11-0-0 s=4,c=1,t=23,pt=2,l=2,st=fail:76
    Light: 76
    Battery: 100
    PIR: 0
    pimatic + MySensors + Homeduino + z-way
    https://github.com/n3roGit/MySensors_n3ro
    • A Offline
      A Offline
      andriej
      10uA? should be uF and at least 47uF caps (remember about +/-)
      You can also get te LNA+PA version with antenna...
      I have much better range anyway... maybe your modules are too much from China? ;-)
      • N Offline
        N Offline
        n3ro
        Hehe, yes :D 10uF. It's not good to write technical issues to late in the night.
        I use the nfrs from banggood.com
        Do you know better ones?
        • N Offline
          N Offline
          n3ro
          is it possible that my wifi router make problems with mysensors?
          A 1 Reply Last reply
          • J Offline
            J Offline
            Jan Gatzke
            This must be a problem with your nrf modules. 3m is nothing. The cheap version you are u sing should have a range of about 10-15 meters in normal buildings. The better version LNA+PA works for ranges >20 meters with multiple walls in between.
            • N n3ro
              A Offline
              A Offline
              andriej
              @n3ro It is possible - try changing 'channel' in RF24 Config on every node (by reflashing it).
              N 1 Reply Last reply
              • A andriej
                N Offline
                N Offline
                n3ro
                @andriej this sounds interesting. what is to do to reflash it?
                • N n3ro
                  A Offline
                  A Offline
                  andriej
                  @n3ro just change the channel in config file (try to set it in higher values in example) and reprogram all sensors and gateway on your network.
                  • N Offline
                    N Offline
                    n3ro
                    ah okay. So far I have this sketch to test the distance:
                    https://github.com/n3roGit/MySensors_n3ro/tree/master/test_sketch
                    tomorrow I'll reflash all nodes+gw and test it again :)
                    • A Offline
                      A Offline
                      Andreas Maurer
                      Have you seen this new Video
                      N Sander TeunissenS 2 Replies Last reply
                      • A Andreas Maurer
                        N Offline
                        N Offline
                        n3ro
                        @Andreas-Maurer Cant play Video :(
                        • A Andreas Maurer
                          Sander TeunissenS Offline
                          Sander Teunissen
                          • A Offline
                            A Offline
                            Andreas Maurer
                            https://www.youtube.com/watch?v=gtM832Z0ujE
                            • N Offline
                              N Offline
                              n3ro
                              i have still a band range. next i will test a gw with a nrf antenna version. i hope this helps
                              • R Offline
                                R Offline
                                rickmontana83
                                If you're using the cheaper low-power variants of the nrf24l01+ on the gateway then make sure that your MyConfig.h file has RF24_PA_MAX for RF24_PA_LEVEL_GW.
                                I noticed the other day that the default value from GitHub is RF24_PA_LOW, which gave me only a couple of feet of comms. Changing the default made everything work much better. Seems like the default repos is set up for the high-power radio variants.
                                • R rickmontana83
                                  N Offline
                                  N Offline
                                  n3ro
                                  @rickmontana83 YEAH!!!!! This has fixed my problem!!
                                  Now i have much better rage with my nodes :+1:
                                  Big THX!
                                  12.1k
