  3. Controlling existing relays
54 Posts 9 Posters 38.1k Views 6 Watching
  • T
    twosh
    Found some specs on my house relays: http://www.switchtec.co.uk/relay_catalog/129_LR-28.pdf
    It's the esmi nr-8251 latching relay if this helps!
    • T TimO
      I suppose the relays are impulse relays, which need a impulse to change the state (on/off). I'm using the Relay-Modules you mentioned above to control my impulse relays. My impulse relays are controlled with 230V. The relays are connected in parallel to the existing switches and use a 100ms impulse to change the state.
      Works like a charme.
      twosh
      Could you share your experience in more detail? It feels like you have accomplished what I would like to happen at this point. :)
      • T twosh
        Here's my sketch @jeylites !
        I'm using this 8 channel relay board: http://www.ebay.com/itm/181242936438?rmvSB=true
        Had to switch the GPIO HIGH/LOW values around compared to the original sketch, and added two analogue pins controlling channel 7 and 8 on the board.
        // Example sketch showing how to control physical relays.
        // This example will remember relay state even after power failure.
        #define RELAY_1A  0  // Arduino Analog I/O pin number for first relay (second on pin+1 etc)
        #define NUMBER_OF_RELAYS 6 // Total number of attached relays
        #define NUMBER_OF_ANALOG_RELAYS 2 // Total number of attached relays
          gw.sendSketchInfo("Relay", "1.0 AD");
          // Fetch relay status
            gw.present(sensor, S_LIGHT);
            pinMode(pin, OUTPUT);
            digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
          // Fetch and present the analogue relays
          int sensor=NUMBER_OF_RELAYS+1;
          gw.present(sensor++, S_LIGHT);
          pinMode(A0, OUTPUT);
          digitalWrite(A0, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
          pinMode(A1, OUTPUT);
          digitalWrite(A1, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
          if (message.type==V_LIGHT) {
            // Change relay state
             if (message.sensor <= NUMBER_OF_RELAYS)
             else if (message.sensor == NUMBER_OF_RELAYS+1) //First analogue sensor
               digitalWrite(A0, message.getBool()?RELAY_ON:RELAY_OFF);
             else //Second analogue sensor
               digitalWrite(A1, message.getBool()?RELAY_ON:RELAY_OFF);
             // Store state in eeprom
        SparkmanS
        SparkmanS
        Sparkman
        wrote on last edited by Sparkman
        #27
        @twosh Based on the spec sheet, I believe your existing latching relays need a 35ms pulse to turn them on and off.
        The standard relay sketch to control your new relays is meant to turn the relays on based on a command from the controller and then another command from the controller to turn them off. It also maintains the relay state by saving them to EEPROM, and sets them to last state on power-up, etc. You don't need most of that. All you need to do is set the relay to on, wait 35 milliseconds and then set the relay to off based on a toggle command from the controller.
        Take a crack at simplifying the sketch, post your results and I, or others, can help with the next steps.
        The one thing to note is that with this system, you won't know if the light is on or on, all you can do is toggle current status. You would have to add current sensors or something like that to be able to know the state. Are there LEDs on the existing system that are on when the light is on and off when the lights are off?
        Al
        PS Have you measured the voltage to the control side of the existing latching relay when operated by a switch?
        • T
          twosh
          Thank you all for the various ideas and input!
          I've figured out what I had done wrong (not feeding the relays with the common wire correctly). I've also changed the sketch to give a 35 ms impulse, and connected everything. Working great! Here is my sketch if anyone needs it:
          // This example will NOT remember relay state even after power failure.
          #define noRelays 8
          const int relayPin[] = {A0, A1, A2, A3, A4, A5, 3, 4};
            for (int sensor=0; sensor < noRelays; sensor++)
              gw.present(sensor+1, S_LIGHT);
              pinMode(relayPin[sensor], OUTPUT);
              //digitalWrite(relayPin[sensor], gw.loadState(sensor+1)?RELAY_ON:RELAY_OFF);
               if (message.sensor <= noRelays)
                   digitalWrite(relayPin[message.sensor-1], RELAY_ON);
                   delay(35); // 35 ms impulse used by my relays
                   digitalWrite(relayPin[message.sensor-1], RELAY_OFF);
               //gw.saveState(message.sensor, message.getBool());
          As @Sparkman says, I won't actually know if the light is on or off, since I can't register a change that would happen via the physical light switches in the house. Any suggestions on how to do this is of course welcome! The output side of the house relay is 230 VAC to the lights, and 24 VAC to the leds in the light switches. What kind of hardware would I need for sensing current and reporting it back to the Arduino? Is there any sketch I could use that lays the groundwork?
          SparkmanS 1 Reply Last reply
          • T
            twosh
            Is this what I would need? http://www.ebay.com/itm/310506962976?rmvSB=true
            How would I wire this? Should it sit between the house relay and the light switch (serial), or would I run it parallel somehow? I guess I would need 8 of these to measure my 8 relays / light switches?
            • T twosh
              #define noRelays 8
              SparkmanS
              SparkmanS
              Sparkman
              @twosh Glad to hear you have it working. You could wire something like this in: http://www.ebay.com/itm/221649135732 for each circuit that you want to monitor. They simply put out a voltage relative to the current that you can measure on an analog input. This particular type is hard wired into the 230 VAC side. There are also options that you slip over the 230 VAC. See here for a bunch of options: http://www.ebay.com/sch/i.html?_nkw=arduino+current+sensor.
              Al
              • T
                twosh
                @Sparkman I think that would work out quite nicely! But I think I would rather stay away from the 230VAC and use it on the 24VAC instead - feels safer. If I don't misunderstand how the current sensor works it shouldn't matter if I hard wire it on 230VAC or 24VAC, right?
                • T twosh
                  SparkmanS
                  SparkmanS
                  Sparkman
                  #32
                  @twosh Because the signals on the 24 VAC side are momentary 35 ms pulses and not a continuous current when the lights are on, it would be more difficult to use as there's a chance you could miss them and then you would get out of sync. It would be most accurate to connect on the 230 VAC side. You would disconnect one side of the 230 VAC from the relay, wire it to one side of the large terminal on the module and then use a new short piece of wire (rated for at least 230 VAC/20A) and connect from the other large terminal on the module to the relay. It basically needs to be inserted in the circuit so that the current would flow through it. If you're uncomfortable with that, then you can use one of the modules that slip over the wire. They tend to cost more and also may need additional components to connect it to an analog in on the Arduino. Here's one that will work without additional components: http://www.ebay.com/itm/171737837875. This one is only rated for 5A which likely is enough depending on how many and what types of light bulbs you have on the circuit.
                  Al
                  PS The added advantage is that you'll also be able to track power usage for those lights.
                  • jeylitesJ
                    jeylitesJ
                    jeylites
                    @twosh the above current sensor could be one option or you could build a voltage divider to measure the 24v side. Something like the battery monitor .... this route is cheap and effective. Thought I don't know how you are going to the programming part but will like to see where it goes :)
                    • T
                      twosh
                      Great, thanks for the clarifications @Sparkman !
                      Being able to measure power would of course be a nice bonus! I'll think about it. I have another question (of course... :) ).
                      The Nano and Pro mini have only 6 analogue inputs, I would be having need for 8... Would I need to use two arduinos or is there any other way?
                      Best,
                      Tim
                      SparkmanS P 2 Replies Last reply
                      • jeylitesJ jeylites
                        SparkmanS
                        SparkmanS
                        Sparkman
                        #35
                        It's 24 VAC, so would also need to be rectified.
                        Al
                        • T twosh
                          Best,
                          Tim
                          SparkmanS
                          SparkmanS
                          Sparkman
                          Best,
                          Tim
                          You're welcome Tim!
                          You can go with multiple Arduinos but I'd consider a Mega instead: http://www.ebay.com/itm/360790082588.
                          Al
                          • T
                            twosh
                            @jeylites - thanks for the alternate suggestion! :)
                            @Sparkman , to clarify, my light switches does glow constantly when turned on, so there is constant current on the output side of the relay going to the light switches. I've measured the voltage and it is 24VAC. So I think that, disregarding the power measurement possibility, I could use that circuit as well.
                            • T twosh
                              SparkmanS
                              SparkmanS
                              Sparkman
                              #38
                              If there's 24 VAC on the output side of the relays as well, then yes, you could use that and you have some other options to be able to measure it including options to use digital pins instead of analog.
                              Here's some examples on converting the 24 VAC to 5 VDC: http://rayshobby.net/24vac-to-5vdc-conversion/. Option 4 may be a good choice. In your case, since you would only use it to connect to a digital pin on your Arduino, power draw is very low and some of the issues he talks about don't apply to your case.
                              Al
                              • T
                                twosh
                                Thanks for the link - will read it tomorrow! :)
                                • T
                                  twosh
                                  I read the site and concluded that I will first of try with the suggested components (thanks again @Sparkman ). Ordered a bunch of them and a Mega. I'll let you know of my progress when they arrive! Thanks everybody!
                                  • T
                                    twosh
                                    My Mega arrived today so I could load it with my customized sketch that I've worked on for controlling relays as well as measuring current. I'm still waiting for the current sensors, but I've already got a problem... I keep getting "check wires" via the serial monitor, and the Mega is not detected by the gateway.
                                    Basically I think that the wiring of the radio to the Mega is wrong, but after scavenging the forum and trying a handfull of different wiring combinations I still can't get this to work.
                                    I have tried using the normal (nano, pro mini) pins, using pins 14-16, 50-52, etc. but nothing seems to work. I have NOT modified any config files yet, but based on the various threads I've read it's unclear to me if you should or shouldn't.
                                    @Sparkman , do you use a mega yourself, and have successfully wired the radio?
                                    @hek, would it be possible to add instructions for the Mega (and perhaps the Uno as well) to the general build guide for connecting the radio?
                                    • T
                                      twosh
                                      wrote on last edited by twosh
                                      #42
                                      Finally found a combination that worked with the mega as a sensor. Here is the pin mapping if it will save time for anyone:
                                      9 CE
                                      10 CSN/CS
                                      52 SCK
                                      51 MOSI
                                      50 MISO
                                      2 IRQ
                                      Doesn't require any config changes, but I am currently getting some "0;0;3;0;9;version mismatch" in serial monitor. Have 10 uF cap on the radio.
                                      • T
                                        twosh
                                        Tried powering the Mega from computers USB 5V, and two different 12V DC adapters - still getting version mismatch. Anybody knows what's going on?
                                        • T twosh
                                          SparkmanS
                                          SparkmanS
                                          Sparkman
                                          @twosh From what I've read before, the version mismatch error is often caused by power issues. Are you getting the errors with the relays connected or without? If the relays are connected, try disconnecting them. If the error goes away, it's likely a power issues. Maybe try powering the radio from a separate 3.3v source.
                                          Al
