  3. Newbie Problem! Get Started with NRF24L01+
55 Posts 9 Posters 28.0k Views 2 Watching
  • F
    F
    fakeJake
    wrote on last edited by fakeJake
    #23
    Sorry for the late reply
    Each modules are now supplied with 5V and 3.3V.
    This is the serial gateway output:
    0;0;3;0;9;read: 1-1-0 s=0,c=1,t=0,pt=7,l=5:30.2
    1;0;1;0;0;30.2
    0;0;3;0;9;Inclusion started by button.
    0;0;3;0;5;1
    0;0;3;0;5;0
    This is the temp output:
    sensor started, id 1
    send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
    send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor
    send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
    send: 1-1-0-0 s=0,c=0,t=6,pt=0,l=5,st=fail:1.4.1
    send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:30.2
    st keeps on failing. I checked the nrf supply and it ranges from 3.1v to 3.3 v. Is this bad? I'm using spx2815 since it's the only thing available to me. I placed 10uF capacitor in the 5v input and 3.3v output to ground
    • rvendrameR rvendrame
      Maybe this may cover it http://www.mysensors.org/download/serial_api_14
      F
      F
      fakeJake
      It only explains the "0;0;3;0;14;" but not the "s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor" that it sends or reads
      • rvendrameR
        rvendrameR
        rvendrame
        @fakeJake , are the node far from gateway, or any obstacle (such as a wall) in between? Another source of interference is for example a microwave.
        ESP8266 GW + mySensors 2.3.2
        Alexa / Google Home
        F 1 Reply Last reply
          F
          F
          fakeJake
          They are just 6 inches apart :worried:
          • rvendrameR
            rvendrameR
            rvendrame
            Some people reported trouble with cheap fake radios. If you have spares nRF try replacing one of them or both.
            You mentioned a flotation (3.1 to 3.3) in radio VCC, this can also be a reason, as these nRF are very sensible to power variations.
            Post your sketches too, just incase...
            Alexa / Google Home
            • F
              F
              fakeJake
              I'm using the DallasTemperatureSensor.ino on MySensors library. I just change the gw.begin(); to gw.begin(NULL, 1);
              // Example sketch showing how to send in OneWire temperature readings
              #include <OneWire.h>
              int numSensors=0;
              boolean receivedConfig = false;
              boolean metric = true;
              MyMessage msg(0,V_TEMP);
                // Startup OneWire
                sensors.begin();
                // Startup and initialize MySensors library. Set callback for incoming messages.
                gw.begin(NULL,1);
                gw.sendSketchInfo("Temperature Sensor", "1.0");
                   gw.present(i, S_TEMP);
                // Process incoming messages (like config from server)
                  float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                  if (lastTemperature[i] != temperature && temperature != -127.00) {
                    gw.send(msg.setSensor(i).set(temperature,1));
                gw.sleep(SLEEP_TIME);
              • F
                F
                fakeJake
                Good news! The gateway is now working :)
                I changed the dallas temperature to relay actuator and, yes, it's now working!
                Bad news is I still don't know what went wrong with my temperature sensor.
                I'll investigate on it soon.
                This is the gateway output:
                0;0;3;0;9;read: 2-2-0 s=255,c=0,t=18,pt=0,l=5:1.4.1
                2;255;0;0;18;1.4.1
                0;0;3;0;9;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:0
                2;255;3;0;6;0
                0;0;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=5:Relay
                2;255;3;0;11;Relay
                0;0;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3:1.0
                2;255;3;0;12;1.0
                0;0;3;0;9;read: 2-2-0 s=1,c=0,t=3,pt=0,l=5:1.4.1
                2;1;0;0;3;1.4.1
                This is the relay output:
                repeater started, id 2
                send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
                send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                send: 2-2-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                I just need to test it.
                Since I'll be using a gsm to control the relay. Can you help me on what to send to the relay to turn it on/off?
                • rvendrameR
                  rvendrameR
                  rvendrame
                  @fakeJake , I' m glad it worked with relay sketch.
                  Regarding the temperature, try to move the sensor to other arduino pin. Pin 2 & 3 are used by interrupts and may not play nice with gw.sleep depending on the lib used.
                  To send a message to the relay , you need a controller connected to the GW, either via USB or ethernet. You can also simulate it by entering the message on the Serial monitor.
                  The protocol is described here http://www.mysensors.org/download/serial_api_14
                  Alexa / Google Home
                  • F
                    F
                    fakeJake
                    #31
                    I tried entering message on the serial monitor of the gateway but still no luck.
                    This is the closest thing that I did to tell the relay to turn the light on.
                    Gateway output after I enter "2;0;1;1;2;1;" to the Serial monitor:
                    0;0;3;0;9;read: 2-2-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
                    2;255;0;0;17;1.4.1
                    2;255;3;0;6;0
                    2;255;3;0;11;Relay
                    2;255;3;0;12;1.0
                    2;1;0;0;3;1.4.1
                    0;0;3;0;9;send: 0-0-2-2 s=0,c=1,t=2,pt=0,l=1,st=ok:1
                    0;0;3;0;9;read: 2-2-0 s=0,c=1,t=2,pt=0,l=1:1
                    2;0;1;1;2;1
                    Relay output after "2;0;1;1;2;1;" :
                    sensor started, id 2
                    send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                    read: 0-0-2 s=0,c=1,t=2,pt=0,l=1:1
                    send: 2-2-0-0 s=0,c=1,t=2,pt=0,l=1,st=ok:1
                    Incoming change for sensor:0, New status: 1
                    Still it doesn't turn on the light
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      Maybe you can you connect the node also in a USB port, and open a serial monitor for it? You would see if it is receiving the message correctly.
                      Alexa / Google Home
                        F
                        F
                        fakeJake
                        @rvendrame Sorry I forgot to include that, I edited the post
                        • F
                          F
                          fakeJake
                          #34
                          It still doesn't open the light even if I change it to "2;255;1;1;2;1;"
                          I checked the relay using relay.ino from an instructable controlling ac light with relay and it's working.
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            Can we see your sensor's sketch?
                            Alexa / Google Home
                            • F
                              F
                              fakeJake
                              #36
                              I just changed the gw.begin();
                              // Example sketch showing how to control physical relays.
                              // This example will remember relay state even after power failure.
                                gw.begin(incomingMessage, 2);
                                gw.sendSketchInfo("Relay", "1.0");
                                // Fetch relay status
                                  gw.present(sensor, S_LIGHT);
                                  pinMode(pin, OUTPUT);
                                  digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                                if (message.type==V_LIGHT) {
                                   // Change relay state
                                   // Store state in eeprom
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                Means your are asking to activate relay 'zero'.
                                So digital pin will be 0 - 1 + RELAY_1 = 0 - 1 + 3 = 2
                                Conclusion: Try activating relay 1 instead 0. ;-)
                                Alexa / Google Home
                                  F
                                  F
                                  fakeJake
                                  #38
                                  @rvendrame The light is still not turning on :sweat:
                                  I even change it to "2;257;1;1;2;1" just incase 255 is the message.sensor but it still prints "2;1;1;1;2;1" so I there's no problem there.
                                  read: 0-0-2 s=1,c=1,t=2,pt=0,l=1:1
                                  send: 2-2-0-0 s=1,c=1,t=2,pt=0,l=1,st=ok:1
                                  Incoming change for sensor:1, New status: 1
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    how the relay is connected to arduino pin 3? Is there a transistor in between?
                                    Alexa / Google Home
                                      F
                                      F
                                      fakeJake
                                      #40
                                      @rvendrame No transistor. I just followed MySensors: Build Relay Actuator. I directly connected the 5v, gnd and signal to the arduino.
                                      • rvendrameR
                                        rvendrameR
                                        rvendrame
                                        Do you have a standalone relay, or a arduino relay board, like this picture?
                                        http://www.mysensors.org/relay/relayModule.png
                                        The board contains a transistor. Some boards also have a 'hi-low' switch, if yours have it, you may try to play with it.
                                        The arduino output is max of 40ma and will eventually burn or not operate correctly if connected directly to a relay. You must have a transistor in between.
                                        Make sure you relay board contains at least this circuit: http://www.electroschematics.com/8975/arduino-control-relay/
                                        Alexa / Google Home
                                        F 2 Replies Last reply
                                          F
                                          F
                                          fakeJake
                                          @rvendrame My relay is more like this http://www.elecdesignworks.com/images/stories/virtuemart/product/img_62112.jpg
                                          Thank you for your reference.
                                          It has a transistor. I hope it's ok to use. I have tested it by following an instructable.
