  3. Newbie Problem! Get Started with NRF24L01+
55 Posts 9 Posters 27.8k Views 2 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    How are you powering your node? Your node's radio is constantly fail to transmit (st=fail).
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    hekH 1 Reply Last reply
    • rvendrameR rvendrame
      It's actually the gateway having problems transmitting acks back to node.
      F 1 Reply Last reply
        F
        F
        fakeJake
        I'm powering the nrf modules from same 3.3V supply since I haven't bought a regulator yet. I'll test it again later. I'll be going out to buy them now.
        Just to give me a heads up. What should the serial gateway get after i press the inclusion button?
        • F
          F
          fakeJake
          wrote on last edited by fakeJake
          #23
          Sorry for the late reply
          Each modules are now supplied with 5V and 3.3V.
          This is the serial gateway output:
          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=0,pt=7,l=5:30.2
          1;0;1;0;0;30.2
          0;0;3;0;9;Inclusion started by button.
          0;0;3;0;5;1
          0;0;3;0;5;0
          This is the temp output:
          sensor started, id 1
          send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
          send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
          send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor
          send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
          send: 1-1-0-0 s=0,c=0,t=6,pt=0,l=5,st=fail:1.4.1
          send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:30.2
          st keeps on failing. I checked the nrf supply and it ranges from 3.1v to 3.3 v. Is this bad? I'm using spx2815 since it's the only thing available to me. I placed 10uF capacitor in the 5v input and 3.3v output to ground
            Maybe this may cover it http://www.mysensors.org/download/serial_api_14
            F
            F
            fakeJake
            It only explains the "0;0;3;0;14;" but not the "s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor" that it sends or reads
            • rvendrameR
              rvendrameR
              rvendrame
              @fakeJake , are the node far from gateway, or any obstacle (such as a wall) in between? Another source of interference is for example a microwave.
              Alexa / Google Home
                F
                F
                fakeJake
                They are just 6 inches apart :worried:
                • rvendrameR
                  rvendrameR
                  rvendrame
                  Some people reported trouble with cheap fake radios. If you have spares nRF try replacing one of them or both.
                  You mentioned a flotation (3.1 to 3.3) in radio VCC, this can also be a reason, as these nRF are very sensible to power variations.
                  Post your sketches too, just incase...
                  Alexa / Google Home
                  • F
                    F
                    fakeJake
                    I'm using the DallasTemperatureSensor.ino on MySensors library. I just change the gw.begin(); to gw.begin(NULL, 1);
                    // Example sketch showing how to send in OneWire temperature readings
                    #include <OneWire.h>
                    int numSensors=0;
                    boolean receivedConfig = false;
                    boolean metric = true;
                    MyMessage msg(0,V_TEMP);
                      // Startup OneWire
                      sensors.begin();
                      // Startup and initialize MySensors library. Set callback for incoming messages.
                      gw.begin(NULL,1);
                      gw.sendSketchInfo("Temperature Sensor", "1.0");
                         gw.present(i, S_TEMP);
                      // Process incoming messages (like config from server)
                        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                        if (lastTemperature[i] != temperature && temperature != -127.00) {
                          gw.send(msg.setSensor(i).set(temperature,1));
                      gw.sleep(SLEEP_TIME);
                    • F
                      F
                      fakeJake
                      Good news! The gateway is now working :)
                      I changed the dallas temperature to relay actuator and, yes, it's now working!
                      Bad news is I still don't know what went wrong with my temperature sensor.
                      I'll investigate on it soon.
                      This is the gateway output:
                      0;0;3;0;9;read: 2-2-0 s=255,c=0,t=18,pt=0,l=5:1.4.1
                      2;255;0;0;18;1.4.1
                      0;0;3;0;9;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:0
                      2;255;3;0;6;0
                      0;0;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=5:Relay
                      2;255;3;0;11;Relay
                      0;0;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3:1.0
                      2;255;3;0;12;1.0
                      0;0;3;0;9;read: 2-2-0 s=1,c=0,t=3,pt=0,l=5:1.4.1
                      2;1;0;0;3;1.4.1
                      This is the relay output:
                      repeater started, id 2
                      send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                      send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                      send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
                      send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                      send: 2-2-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                      I just need to test it.
                      Since I'll be using a gsm to control the relay. Can you help me on what to send to the relay to turn it on/off?
                      • rvendrameR
                        rvendrameR
                        rvendrame
                        @fakeJake , I' m glad it worked with relay sketch.
                        Regarding the temperature, try to move the sensor to other arduino pin. Pin 2 & 3 are used by interrupts and may not play nice with gw.sleep depending on the lib used.
                        To send a message to the relay , you need a controller connected to the GW, either via USB or ethernet. You can also simulate it by entering the message on the Serial monitor.
                        The protocol is described here http://www.mysensors.org/download/serial_api_14
                        Alexa / Google Home
                        • F
                          F
                          fakeJake
                          #31
                          I tried entering message on the serial monitor of the gateway but still no luck.
                          This is the closest thing that I did to tell the relay to turn the light on.
                          Gateway output after I enter "2;0;1;1;2;1;" to the Serial monitor:
                          0;0;3;0;9;read: 2-2-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
                          2;255;0;0;17;1.4.1
                          2;255;3;0;6;0
                          2;255;3;0;11;Relay
                          2;255;3;0;12;1.0
                          2;1;0;0;3;1.4.1
                          0;0;3;0;9;send: 0-0-2-2 s=0,c=1,t=2,pt=0,l=1,st=ok:1
                          0;0;3;0;9;read: 2-2-0 s=0,c=1,t=2,pt=0,l=1:1
                          2;0;1;1;2;1
                          Relay output after "2;0;1;1;2;1;" :
                          sensor started, id 2
                          send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                          read: 0-0-2 s=0,c=1,t=2,pt=0,l=1:1
                          send: 2-2-0-0 s=0,c=1,t=2,pt=0,l=1,st=ok:1
                          Incoming change for sensor:0, New status: 1
                          Still it doesn't turn on the light
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            Maybe you can you connect the node also in a USB port, and open a serial monitor for it? You would see if it is receiving the message correctly.
                            Alexa / Google Home
                              F
                              F
                              fakeJake
                              @rvendrame Sorry I forgot to include that, I edited the post
                              • F
                                F
                                fakeJake
                                #34
                                It still doesn't open the light even if I change it to "2;255;1;1;2;1;"
                                I checked the relay using relay.ino from an instructable controlling ac light with relay and it's working.
                                • rvendrameR
                                  rvendrameR
                                  rvendrame
                                  Can we see your sensor's sketch?
                                  Alexa / Google Home
                                  • F
                                    F
                                    fakeJake
                                    #36
                                    I just changed the gw.begin();
                                    // Example sketch showing how to control physical relays.
                                    // This example will remember relay state even after power failure.
                                      gw.begin(incomingMessage, 2);
                                      gw.sendSketchInfo("Relay", "1.0");
                                      // Fetch relay status
                                        gw.present(sensor, S_LIGHT);
                                        pinMode(pin, OUTPUT);
                                        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                                      if (message.type==V_LIGHT) {
                                         // Change relay state
                                         // Store state in eeprom
                                    • rvendrameR
                                      rvendrameR
                                      rvendrame
                                      Means your are asking to activate relay 'zero'.
                                      So digital pin will be 0 - 1 + RELAY_1 = 0 - 1 + 3 = 2
                                      Conclusion: Try activating relay 1 instead 0. ;-)
                                      Alexa / Google Home
                                        F
                                        F
                                        fakeJake
                                        #38
                                        @rvendrame The light is still not turning on :sweat:
                                        I even change it to "2;257;1;1;2;1" just incase 255 is the message.sensor but it still prints "2;1;1;1;2;1" so I there's no problem there.
                                        read: 0-0-2 s=1,c=1,t=2,pt=0,l=1:1
                                        send: 2-2-0-0 s=1,c=1,t=2,pt=0,l=1,st=ok:1
                                        Incoming change for sensor:1, New status: 1
                                        • rvendrameR
                                          rvendrameR
                                          rvendrame
                                          how the relay is connected to arduino pin 3? Is there a transistor in between?
                                          Alexa / Google Home
