  3. BBQ Temp Controller Build
7 Posts 4 Posters 9.5k Views 5 Watching
  • T
    Tango2
    I'm in the process of building a BBQ temp controller, and was trying to figure out the best way to remotely monitor/control it. After coming across this website a month or so ago, I'm now running OpenHAB on a RPi2 and have a couple temp sensors deployed around my house.
    This project is a little more involved, and I'm sure I'm going to run into roadblocks along the way. My goal is to have a sitemap in OpenHAB that will allow me to set and monitor my desired grill temp, which will control a small fan on my BBQ using a PID algorithm, as well as display the temps of the meat probes so I can know how things are going.
    I currently have the sitemap setup in OpenHAB, and have had the code working for the thermocouple temp probes that I will be using for the grill and meat temps. Today I will start trying to get the two to work together, based on the MySensors Serial API. I'll be using the NRF24L01+ radio modules for this. I'll post my code periodically, and hopefully will have some chime in on how to make it work or improve it.
    • T
      Tango2
      Below is a very rough sketch of what I have so far. This is not working or tested even yet, but it does compile in Arduino IDE. I will breadboard the sensors I have in the next couple of days and get the basics working, then I will have to figure out how to send the temperatures over to my gateway. Next will be configuring for receiving commands from the gateway/controller to allow me to set my target temperature on the Arduino. Any recommendations are welcomed.
      This program is my attempt at creating a BBQ controller for my Big Green Egg using
      an arduino to monitor grill and meat temps as well as control a fan to
      regulate the grill temperature.
      Components used:
      - Arduino UNO
      - 10CFM Brushless DC Blower
      - Level Shifter
      - K-type Thermocouple
      - K-type Grill Probe
      - K-type Meat Probe
      Pin assignments:
      Tasks:
      - Selftest
        - Fan 0-100-0
        - Check for Probes
      - Set Grill Temp
      - Setup Display
        - Grill Temp
        - Probe 1
        - Probe 2
        - Fan Status
        - Elapsed Time
      - Measure Temperature
        - Grill
        - Probe 1
        - Probe 2
      - Analyze Temperature
        - PID Contol
      - Control Fan
        - PWM Value
        - On/Off
      //-------------------------------- Classes ------------------------
      //-------------------------------- Includes -----------------------
      #include <OneWire.h>
      #include <PID_v1.h>
      //-------------------------------- Defines ------------------------
      #define oneWirePin 9
      #define TempPrecision 9
      OneWire oneWire(oneWirePin); //Setup oneWire instance to communiate with any oneWire devices
      DallasTemperature sensors(&oneWire); //Pass our oneWire referenceto Dallas Temperature.
      DeviceAddress Probe0, Probe1, Probe2, Probe3; //Define arrays to hold device addresses.
      unsigned long SLEEP_TIME = 15000;
      int numSensors = 3;
      boolean receivedConfig = false;
      boolean metric = true;
      MyMessage msg(0,V_TEMP);
      void sketchInfo () {
        gw.begin();
        gw.sendSketchInfo("Temperature Sensor","1.0");
      void setupProbes () {
        sensors.begin();
        sensors.getAddress(Probe0, 0);
        sensors.getAddress(Probe1, 1);
        sensors.setResolution(Probe0, TempPrecision);
        sensors.setResolution(Probe1, TempPrecision);
      // Cycle fan from 0-100-0% power over 10 seconds.
      void selftestFan () {
      // Verify which probes are connected and report status for 10 seconds
      void selftestProbes () {
      void printTemperature(DeviceAddress deviceAddress)
        float tempC = sensors.getTempC(deviceAddress);
        //Display Temp in °C
        //Serial.print("Temp C: ");
        //Serial.print(tempC);
        //Display Temp in °F
        Serial.print(DallasTemperature::toFahrenheit(tempC));
        Serial.print(" F ");
      void printData(DeviceAddress deviceAddress)
        //Serial.print("Device Address: ");
        //printAddress(deviceAddress);
        //Serial.print(" ");
        printTemperature(deviceAddress);
        //Serial.println();
      void sendTemps () {
          float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) /10.;
          gw.send(msg.setSensor(i).set(temperature,1));
       gw.sleep(SLEEP_TIME);
        Serial.begin(9600);
        sketchInfo();
        setupProbes();
        //selftestFan();
        //selftestLCD();
        // put your main code here, to run repeatedly:
        printTemperature(Probe1);
        printTemperature(Probe2);
        sendTemps();
        //readTemps(Probe0);
        //readTemps(Probe1);
      • gaduG
        gaduG
        gadu
        Cool project! Following.
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          I've been watching this one, but will watch this one evolve too.
          Waiting to see if they get a web app done.
            Tango2
            @BulldogLowell
            That looks like an interesting project as well. This originally started very similar to that one, and I was planning on using a local LCD on it for the display. I quickly realized that the local LCD would not give me the "warm fuzzy" that checking this remotely would give me. When I started going towards a web interface design, I then realized that I really didn't need the local LCD at all.
            I'm not at all good with the programming piece, but I've gotten by so far. We'll see how this works out.
            • 5546dug5
              5546dug5
              5546dug
              @Tango2 Check this link, it is something I built for my Big Green Egg BBQ.
              It looks like it could be my sensors material.
              http://www.susanminor.org/forums/showthread.php?315-PID-Controller
              Maybe this may help.
              • 5546dug5 5546dug
                Tango2
                @5546dug That's an interesting build. I've come across several using a PID controller similar to that, however they have mostly been on electric smokers. My original intent was to do a PWM fan that could be speed controlled, but it was very hard (impossible) for me to find a blower type fan that was PWM-capable. My very initial testing showed that an on/off model would work as well but I haven't tried this on the Big Green Egg yet.
                My main concern is being able to feed a temp from my phone back to the arduino controlling this, and being reliable if for some reason wireless connectivity was lost from the arduino. I don't think this should be too hard, but will probably take some trial and error on my part.
