  3. set Metric on gw?
set Metric on gw?
7 Posts 3 Posters 4.0k Views 2 Watching
  • G Offline
    G Offline
    gigaguy
    Sorry, I am brand new to MySensors. I see in all the examples there is a gw.getConfig().isMetric
    I know this is a new feature. Trying to figure out how to set this, before I update all my nodes with the metric part just commented out.
    Can I push this setting out from openhab (via SerialGateway)?
    TIA.
    • hekH Offline
      hekH Offline
      The node sends an I_CONFIG request at startup. Create a rule that replies to this (with the same internal I_CONFIG). Payload should be M(etric) or I for imperial.
      http://www.mysensors.org/download/serial_api_14
      • G Offline
        G Offline
        gigaguy
        wrote on last edited by gigaguy
        Guess I should have posted this code initially. I already have that rule in place, and still no luck. (I couldnt get "gw.requestTime(receiveTime)" to work either)
        This is in the setup portion in arduino sketch
        Only posted relevant portions of the code. The rule itself works (for V_TEMP, etc), just none of the "internal commands I_*" do.
        var int I_CONFIG = 6
        //receiving msg from mysensors gateway
        rule "Arduino sends to Openhab"
            when
                Item Arduino received update
            then
                var String lineBuffer =  Arduino.state.toString.split("\n")
                for (String line : lineBuffer) {
                    var String[] message = line.split(";")
                    var Integer nodeId = new Integer(message.get(0))
                    var Integer childId = new Integer(message.get(1))
                    var Integer msgType = new Integer(message.get(2))
                    var Integer ack = new Integer(message.get(3))
                    var Integer subType = new Integer(message.get(4))
                    var String msg = message.get(5)
                   // Internal Command
                    if(msgType == 3){
                        if(subType == I_CONFIG){
                                var String unit
                                unit = "I"
                                //unit = "M"
                                sendCommand(Arduino, nodeId + ";255;3;0;6;" + unit + "\n")
                                println("Updated Sensor Units to " + unit +)
        end
        This is what openhab is getting when the arduino is reset.
        101;255;3;0;11;Humidity
        0;0;3;0;9;read: 101-101-0 s=255,c=3,t=12,pt=0,l=3:1.0
        101;255;3;0;12;1.0
        0;0;3;0;9;read: 101-101-0 s=0,c=0,t=7,pt=0,l=5:1.4.1
        101;0;0;0;7;1.4.1
        0;0;3;0;9;read: 101-101-0 s=1,c=0,t=6,pt=0,l=5:1.4.1
        101;1;0;0;6;1.4.1
        0;0;3;0;9;read: 101-101-0 s=2,c=0,t=4,pt=0,l=5:1.4.1
        101;2;0;0;4;1.4.1
        0;0;3;0;9;read: 101-101-0 s=3,c=2,t=3,pt=0,l=0:
        101;3;2;0;3;
        0;0;3;0;9;read: 101-101-0 s=1,c=1,t=0,pt=7,l=5:26.0
        101;1;1;0;0;26.0
        0;0;3;0;9;read: 101-101-0 s=0,c=1,t=1,pt=7,l=5:34.0
        101;0;1;0;1;34.0
        Shouldnt there be something like
        101;255;3;0;6;?
        • T Offline
          T Offline
          Tango2
          I was able to see the request come into the gw on mine, however I'm not sure how the reply should be structured given the sensor node is 101.
          • G Offline
            G Offline
            gigaguy
            Ok, it just started working !!!! I created a separate rul for it. So either it doesnt like being mixed in with the other stuff or it doesnt like the == I_CONFIG
            This rule below is working
            rule "Arduino config"
                when
                then
                        // Internal Command
                        if(msgType == 3){
                            if(subType == 6){
                                    var String unit
                                    unit = "I"
                                    //unit = "M"
                end
            • T Offline
              T Offline
              Tango2
              Glad you got yours working. I tried changing the code on mine to see if it would respond, but it didn't. I may have hard coded the sensors to imperial though. I believe mine is catching the I_CONFIG variable, because I would get an output on the console when the sensor started up where I had a println command. Hopefully it was just my syntax that was wrong.
              On another note, can you trigger a "sendCommand" with xxx;255;3;0;6;<I or M> at any time, or can it only be in response to the request from the sensor node?
              G 1 Reply Last reply
              • T Tango2
                G Offline
                G Offline
                gigaguy
                @Tango2 I had been doing this a different way until I noticed the GW should be able to do it. BTW, It is only working on one node, not sure why :(.
                Anyway, my alternate solution allows be to send "settings: to the nodes. For example, change the loop time or measurement unit.
                This is not the complete code, just the relevant parts (hopefully).
                gw.begin(incomingMessage, nodeID);
                  if (message.type == 97) {
                    Serial.print("Recvd Time");
                    Serial.println(time);
                    timeReceived=true;
                  if (message.type == 98) {
                    int reqsleep = atoi( message.data );
                    SLEEP_TIME = reqsleep*1000;
                    Serial.print( "Changing sleep to: " );
                    Serial.println( String(reqsleep) );
                  if (message.type == 99) {
                    int requnit = atoi( message.data );
                    Serial.print( "Changing units to: " );
                    if(requnit == M){
                      metric = true;
                      Serial.println( "metric" );
                      metric = false;
                      Serial.println( "imprerial" );
                Using this code, I can send things from openhab, or any serial command I suppose.
                My openhab rules
                Send Units:
                sendCommand(Arduino, "101;99;1;0;99;M\n")
                Send Time:
                var Number time1
                time1 = now().getMillis() / 1000
                sendCommand(Arduino, "101;97;1;0;97;" + time1 + "\n")
