  3. My outdoor weather-sensor (5v powered combined temp, hum, pressure, and light)
9 Posts 4 Posters 9.1k Views 5 Watching
  • S Offline
    Hello!
    My first sensor not powered with battery - a outdoor sensor.
    A old temp sensor from a weather station was remade as box.
    With some drilling everything fit good inside.
    Inside DHT22 (Temp and Hum), LM393 (Light) and BMP085 (Pressure (Temp disabled)).
    Some build pictures:build.png
    and the final result:
    Everything seems to work perfect in controller... now i can start making some relays to my window lamps so they can power up only when dark enough :)
    The code as well offcource:
    #include <Adafruit_BMP085.h>
    //Sketch/Node
    #define SketchName "Ute sensor x4"
    #define SketchVer "1.3"
    #define NodeID 5
    //Bmp
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    #define MetersAboveSeaLevel 130
    //DHT
    #define CHILD_ID_HUM 2
    #define CHILD_ID_TEMP 3
    //Light/LUX
    #define CHILD_ID_LIGHT 4
    unsigned long SLEEP_TIME = 1*60000;
    //unsigned long SLEEP_TIME = 10000; //debug
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
    DHT dht;
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    //BMP
    float lastPressure = -1;
    int lastForecast = -1;
    int heartbeatBMP = 0;
    //float pressureSamples[180];
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
    STABLE = 0,         // Stable weather
    SUNNY = 1,          // Slowly rising HP stable good weather
    CLOUDY = 2,         // Slowly falling Low Pressure System, stable rainy weather
    UNSTABLE = 3,       // Quickly rising HP, not stable weather
    THUNDERSTORM = 4,   // Quickly falling LP, Thunderstorm, not stable
    UNKNOWN = 5         // Unknown, more time needed
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    #define MULTIPLIER (65.0/1023.0)
    int minuteCount = 0;
    bool firstRound = true;
    float pressureAvg[7];
    float dP_dt;
    boolean metric;
    //DHT
    float lastTemp;
    float lastHum;
    //Light/LUX
    int lastLightLevel;
    int heartbeatLUX = 0;
      gw.begin(NULL, NodeID, false);
      //incomingMessageCallback - Callback function for incoming messages from other nodes or controller and request responses. Default is NULL.
      //nodeId - The unique id (1-254) for this sensor. Default is AUTO(255) which means sensor tries to fetch an id from controller.
      //repeaterMode - Activate repeater mode. This node will forward messages to other nodes in the radio network. Make sure to call process() regularly. Default in false
      gw.sendSketchInfo(SketchName, SketchVer);
      if (!bmp.begin()) {
        Serial.println("Could not find a valid BMP085 sensor, check wiring!");
        while (1) { }
      //Setup DHT
      // Register sensors to gw (they will be created as child devices)
      gw.present(BARO_CHILD, S_BARO);
      gw.present(TEMP_CHILD, S_TEMP);
      gw.present(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
      //-----------------------------------------------------------------------------//DHT
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    //-----------------------------------------------------------------------------//BPM
      float pressure = bmp.readSealevelPressure(MetersAboveSeaLevel)/100; // 130 meters above sealevel
      int forecast = sample(pressure);
      //Temp fetched from DHT
      Serial.print("Temperature = ");
      Serial.print(temperature);
      Serial.println(metric?" *C":" *F");
      Serial.print("Pressure = ");
      Serial.print(pressure);
      Serial.println(" Pa");
     if (isnan(pressure)) {
      Serial.println("Failed readin pressure");
       if (pressure != lastPressure) {
        gw.send(pressureMsg.set(pressure, 0));
        lastPressure = pressure;
      heartbeatBMP = 0;
        heartbeatBMP++;
        if (heartbeatBMP >= 24) {
          heartbeatBMP = 0;
      if (forecast != lastForecast) {
        gw.send(forecastMsg.set(weather[forecast]));
        lastForecast = forecast;
       DP/Dt explanation
       0 = "Stable Weather Pattern"
       1 = "Slowly rising Good Weather", "Clear/Sunny "
       2 = "Slowly falling L-Pressure ", "Cloudy/Rain "
       3 = "Quickly rising H-Press",     "Not Stable"
       4 = "Quickly falling L-Press",    "Thunderstorm"
       5 = "Unknown (More Time needed)
    //-----------------------------------------------------------------------------//LJUS
      int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.print("Light: ");
      Serial.println(lightLevel);
          gw.send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
          heartbeatLUX = 0;
        heartbeatLUX++;
        if (heartbeatLUX >= 24) {
          heartbeatLUX = 0;
    //-----------------------------------------------------------------------------//SLEEP
    float getLastPressureSamplesAverage()
    float lastPressureSamplesAverage = 0;
    for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
        lastPressureSamplesAverage += lastPressureSamples[i];
    lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
        return lastPressureSamplesAverage ;
    // Algorithm found here
    int sample(float pressure) {
    // Calculate the average of the last n minutes.
    int index = minuteCount % LAST_SAMPLES_COUNT;
    lastPressureSamples[index] = pressure;
    minuteCount++;
    if (minuteCount > 185)
        minuteCount = 6;
    if (minuteCount == 5) {
        pressureAvg[0] = getLastPressureSamplesAverage();
    else if (minuteCount == 35) {
        pressureAvg[1] = getLastPressureSamplesAverage();
        float change = (pressureAvg[1] - pressureAvg[0]);
            dP_dt = (MULTIPLIER * 2 * change); // note this is for t = 0.5hour
            dP_dt = ((MULTIPLIER * change) / 1.5); // divide by 1.5 as this is the difference in time from 0 value.
    else if (minuteCount == 65) {
        pressureAvg[2] = getLastPressureSamplesAverage();
        float change = (pressureAvg[2] - pressureAvg[0]);
            dP_dt = (MULTIPLIER * change); //note this is for t = 1 hour
            dP_dt = ((MULTIPLIER * change) / 2); //divide by 2 as this is the difference in time from 0 value
    else if (minuteCount == 95) {
        pressureAvg[3] = getLastPressureSamplesAverage();
        float change = (pressureAvg[3] - pressureAvg[0]);
            dP_dt = ((MULTIPLIER * change) / 1.5); // note this is for t = 1.5 hour
            dP_dt = ((MULTIPLIER * change) / 2.5); // divide by 2.5 as this is the difference in time from 0 value
    else if (minuteCount == 125) {
        pressureAvg[4] = getLastPressureSamplesAverage();
        float change = (pressureAvg[4] - pressureAvg[0]);
            dP_dt = ((MULTIPLIER * change) / 2); // note this is for t = 2 hour
            dP_dt = ((MULTIPLIER * change) / 3); // divide by 3 as this is the difference in time from 0 value
    else if (minuteCount == 155) {
        pressureAvg[5] = getLastPressureSamplesAverage();
        float change = (pressureAvg[5] - pressureAvg[0]);
            dP_dt = ((MULTIPLIER * change) / 2.5); // note this is for t = 2.5 hour
            dP_dt = ((MULTIPLIER * change) / 3.5); // divide by 3.5 as this is the difference in time from 0 value
    else if (minuteCount == 185) {
        pressureAvg[6] = getLastPressureSamplesAverage();
        float change = (pressureAvg[6] - pressureAvg[0]);
            dP_dt = ((MULTIPLIER * change) / 3); // note this is for t = 3 hour
            dP_dt = ((MULTIPLIER * change) / 4); // divide by 4 as this is the difference in time from 0 value
        pressureAvg[0] = pressureAvg[5]; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
    int forecast = UNKNOWN;
        forecast = UNKNOWN;
    else if (dP_dt < (-0.25))
        forecast = THUNDERSTORM;
    else if (dP_dt > 0.25)
        forecast = UNSTABLE;
        forecast = CLOUDY;
        forecast = SUNNY;
    else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
        forecast = STABLE;
        forecast = UNKNOWN; // Unknown
    return forecast;
    Edit: Updated the code for right forecast algorithm See here
    • M Offline
      M Offline
      m26872
      wrote on last edited by m26872
      @sundberg84
      Nice. But don't you miss a gw.process() call in your sketch? It looks like you wanted a repeater node. Just remove the gw.sleep(..) and replace it with gw.process() and some timing if-statement.
      • S Offline
        @m26872 Yes i did! - Thank you, good feedback.
        I will add that.
        Also i will clean upp the code some, because it send temp both from DHT and BMP now i think.
        • S Offline
          I ended up not using the process() but sleep() because with three sensors it was spamming the controller.
          I thought about some if statements or something to limit the spam but realised that i didnt needed it bad as a relay so...
          Also attaching a picture of my power supply - a Ipad plug stripped and used as a 240v -> 5v converter inside a outdoor safe box.
          Then ran a telephone wire with the 5v to the sensor.
          • M Offline
            M Offline
            m26872
            To make sure outdoor boxed equipment survive a swedish climate more than a year, I'd put some heater inside each box as well. Even a waterproof design will produce moisture from the inside air due to the temperature variations.
            A 1 Reply Last reply
            • M m26872
              A Offline
              A Offline
              AWI
              @m26872 I'm interested in what is best against moisture in outside equipment. Would just ventilation be a good idea? Traffic system controllers are not in heated or waterproof casings.. Any experience somebody?
              S 1 Reply Last reply
              • A AWI
                Sparkman
                @AWI @m26872 I've had X-10 indoor rated outlets installed outside in northern Canadian climate for 7+ years with no failures. Humidity was not so much a problem, but extreme temperatures were (-45C to +35C). Their fronts were shielded from direct contact with rain & snow and the outlet itself was in an outdoor rated outlet box, but this was not 100% waterproof nor was it heated other than from the waste heat of the electronics.
                Al
                • M Offline
                  M Offline
                  m26872
                  I started this thread to continue enclosure protection discussion without polluting this project thread to much.
                  • S Offline
                    --- New question on this old post
                    This node has started to behave strange. There is three sensors and lux is working 100% but DHT and LM393 stops working from time to time. It can suddenly stop sending these two values for 24 hours, and then they are back online again. Lux sensor works all the time.
                    Havent bothered to do a serial log yet since its outside and working most of the time - but any thoughs anyone?
