  3. Distance sensor messure strange values
17 Posts 4 Posters 8.8k Views 1 Watching
  • C
    C
    crazy_penguin
    Hi BulldogLowell,
    sorry for the delay I was over 2 weeks on vacation. but now I am back.
    I using the code from the distance sensore example (http://www.mysensors.org/build/distance).
    #include <NewPing.h>
    #define CHILD_ID 1
    #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage msg(CHILD_ID, V_DISTANCE);
    int lastDist;
    boolean metric = true;
      gw.begin();
      gw.sendSketchInfo("Distance Sensor", "1.0");
      gw.present(CHILD_ID, S_DISTANCE);
      boolean metric = gw.getConfig().isMetric;
      int dist = metric?sonar.ping_cm():sonar.ping_in();
      Serial.print("Ping: ");
      Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      Serial.println(metric?" cm":" in");
      if (dist != lastDist) {
          gw.send(msg.set(dist));
          lastDist = dist;
      gw.sleep(SLEEP_TIME);
    • C crazy_penguin
      Hi BulldogLowell,
      #define CHILD_ID 1
      int lastDist;
        gw.begin();
            lastDist = dist;
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @crazy_penguin is it battery powered?
      • C
        C
        crazy_penguin
        No.
        It is powerd with a 5V and 2A powersupply.
        • C crazy_penguin
          No.
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @crazy_penguin you can see all the failed transmissions. it might have to do with using the nrf and sensor at the same time? can you try it without the mysensor part? just clean arduino sketch?
          • C
            C
            crazy_penguin
            Hi Moshe Livne,
            I disconnect the radio device and keep the US-sensor connected and use the following code.
            #define MAX_DISTANCE 500 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
              Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
              delay(500);                      // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
              unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
              Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance in cm and print result (0 = outside set distance range)
              Serial.println("cm");
            I got the following results:
            Ping: 306cm
            Ping: 0cm
            Ping: 308cm
            Ping: 0cm
            Ping: 308cm
            Ping: 0cm
            Ping: 308cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            Ping: 0cm
            Ping: 307cm
            • C
              C
              crazy_penguin
              wrote on last edited by crazy_penguin
              Hi all,
              I am really wondering whats going wrong here. I made some changes to the code and now I get this result:
              Ping: cm
              Ping: 0cm
              Ping: 0cm
              Ping: 0cm
              Ping: 2cm
              Ping: 0cm
              Ping: 0cm
              Ping: 0cm
              Ping: 1cm
              Ping: 0cm
              Ping: 0cm
              Ping: 0cm
              Ping: 0cm
              Ping: 0cm
              Ping: 0cm
              Ping: 16cm
              Ping: 0cm
              Ping: 0cm
              Ping: 0cm
              The distance between sensor and wall is about 75cm.
              I took back any chagnes I made. Without any effect.
              I try now use the NewPing version 1.6 library. No effect.
              Current code:
                delay(2000);                    // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
                Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
              I there any way to check I the hardware is bad or may have some defects?
              • C crazy_penguin
                Hi all,
                Ping: cm
                Ping: 0cm
                Ping: 0cm
                Ping: 0cm
                Ping: 2cm
                Ping: 0cm
                Ping: 0cm
                Ping: 0cm
                Ping: 1cm
                Ping: 0cm
                Ping: 0cm
                Ping: 0cm
                Ping: 0cm
                Ping: 0cm
                Ping: 0cm
                Ping: 16cm
                Ping: 0cm
                Ping: 0cm
                Ping: 0cm
                Current code:
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @crazy_penguin can you please try to point the sensor straight at the wall (not down) and clear anything from the sides? you might get echoes. but this is a bit far fetched. mine is this one http://www.aliexpress.com/item/Free-shipping-1pcs-Ultrasonic-Module-HC-SR04-Distance-Measuring-Transducer-Sensor-for-Arduino-Samples-Best-prices/1967936408.html?aff_platform=aaf&aff_trace_key=34543821268212384&sk=bUBEAqbMv%3A&cpt=1435219216767
                it works reasonably reliably
                • C
                  C
                  crazy_penguin
                  @Moshe Livne I order the HC-SR04 Module as well to make sure where the problem is.
                  I also order aother Arduino Nano.
                  hekH 1 Reply Last reply
                  • C crazy_penguin
                    @crazy_penguin
                    Your module (on the pictures) looks really strange. What type is it?
                    • C
                      C
                      crazy_penguin
                      @hek DYP-ME007Y
                        Check out this:
                        http://forum.arduino.cc/index.php?topic=153700.0
                        C 1 Reply Last reply
                          Check out this:
                          C
                          C
                          crazy_penguin
                          @hek Thanks. I will check out this and will tell you the result.
                          • C
                            C
                            crazy_penguin
                            OK. this threat (http://forum.arduino.cc/index.php?topic=153700.0) is very usefull. I will try out some hints and tell you my result.
                            Thank to all for now.
                            • C
                              C
                              crazy_penguin
                              Hi there,
                              it's me again.
                              I tried some things which read in the arduino froum (http://forum.arduino.cc/index.php?topic=153700.0) without any good result.
                              I also get a new sensor and there is still no change of it's behaviour.
                              I read in the forum that it could be a sensor that uses RX/TX to send its information.
                              Does any one know something about that?
                              12.5k
