  3. Distance sensor messure strange values
17 Posts 4 Posters 8.6k Views 1 Watching
  • C Offline
    C Offline
    crazy_penguin
    Hi there ,
    I have built a distance sensor to measure the level of my rainwater tank. I built it with an Arduino Nano. I use an Arduino Nano as a serial gateway as well.
    The communication between the two work well. The values in my controler (FHEM) are visible.
    The main problem is strange values, I get.
    The values jump between 0 and 400, even if the distance changes to the sensor head.
    I attache a out put from the serial console.
    Don't worry about the fail. The sensor has currently no contact to it's gateway. But this is no the reason for the stange behaviour.
    Ping: 386 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:386
    Ping: 390 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:390
    Ping: 391 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:391
    Ping: 393 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:393
    send: 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    Ping: 0 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:0
    Ping: 0 cm
    Ping: 34 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:34
    Ping: 395 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:395
    Ping: 398 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:398
    Ping: 393 cm
    Ping: 393 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 250 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:250
    Ping: 0 cm
    Ping: 0 cm
    Ping: 34 cm
    Ping: 395 cm
    Ping: 390 cm
    Ping: 395 cm
    Ping: 396 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:396
    Ping: 394 cm
    send: 100-100-0-0 s=1,c=1,t=13,pt=2,l=2,st=fail:394
    Ping: 0 cm
    • C Offline
      C Offline
      crazy_penguin
      Oh, I forgot to mention that I use a DYP-ME007Y Ultrasonic Sensor Module.
      Th
      B 1 Reply Last reply
      • C crazy_penguin
        Th
        B Offline
        B Offline
        BulldogLowell
        @crazy_penguin
        post your code... let's see what kind of hysteresis you are using and how frequently you are measuring.
        it's hard to see from the values without knowing the timing of the program you are using
        • C Offline
          C Offline
          crazy_penguin
          Hi BulldogLowell,
          sorry for the delay I was over 2 weeks on vacation. but now I am back.
          I using the code from the distance sensore example (http://www.mysensors.org/build/distance).
          #include <NewPing.h>
          #define CHILD_ID 1
          #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
          #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
          #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
          unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
          NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
          MyMessage msg(CHILD_ID, V_DISTANCE);
          int lastDist;
          boolean metric = true;
            gw.begin();
            gw.sendSketchInfo("Distance Sensor", "1.0");
            gw.present(CHILD_ID, S_DISTANCE);
            boolean metric = gw.getConfig().isMetric;
            int dist = metric?sonar.ping_cm():sonar.ping_in();
            Serial.print("Ping: ");
            Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
            Serial.println(metric?" cm":" in");
            if (dist != lastDist) {
                gw.send(msg.set(dist));
                lastDist = dist;
            gw.sleep(SLEEP_TIME);
          • C crazy_penguin
            Hi BulldogLowell,
            #define CHILD_ID 1
            int lastDist;
              gw.begin();
                  lastDist = dist;
            Moshe LivneM Offline
            Moshe Livne
            @crazy_penguin is it battery powered?
            • C Offline
              C Offline
              crazy_penguin
              No.
              It is powerd with a 5V and 2A powersupply.
              • C crazy_penguin
                No.
                Moshe Livne
                @crazy_penguin you can see all the failed transmissions. it might have to do with using the nrf and sensor at the same time? can you try it without the mysensor part? just clean arduino sketch?
                • C Offline
                  C Offline
                  crazy_penguin
                  Hi Moshe Livne,
                  I disconnect the radio device and keep the US-sensor connected and use the following code.
                  #define MAX_DISTANCE 500 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
                    Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
                    delay(500);                      // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
                    unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
                    Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance in cm and print result (0 = outside set distance range)
                    Serial.println("cm");
                  I got the following results:
                  Ping: 306cm
                  Ping: 0cm
                  Ping: 308cm
                  Ping: 0cm
                  Ping: 308cm
                  Ping: 0cm
                  Ping: 308cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  Ping: 0cm
                  Ping: 307cm
                  • C Offline
                    C Offline
                    crazy_penguin
                    wrote on last edited by crazy_penguin
                    Hi all,
                    I am really wondering whats going wrong here. I made some changes to the code and now I get this result:
                    Ping: cm
                    Ping: 0cm
                    Ping: 0cm
                    Ping: 0cm
                    Ping: 2cm
                    Ping: 0cm
                    Ping: 0cm
                    Ping: 0cm
                    Ping: 1cm
                    Ping: 0cm
                    Ping: 0cm
                    Ping: 0cm
                    Ping: 0cm
                    Ping: 0cm
                    Ping: 0cm
                    Ping: 16cm
                    Ping: 0cm
                    Ping: 0cm
                    Ping: 0cm
                    The distance between sensor and wall is about 75cm.
                    I took back any chagnes I made. Without any effect.
                    I try now use the NewPing version 1.6 library. No effect.
                    Current code:
                      delay(2000);                    // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
                      Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
                    I there any way to check I the hardware is bad or may have some defects?
                    • C crazy_penguin
                      Hi all,
                      Ping: cm
                      Ping: 0cm
                      Ping: 0cm
                      Ping: 0cm
                      Ping: 2cm
                      Ping: 0cm
                      Ping: 0cm
                      Ping: 0cm
                      Ping: 1cm
                      Ping: 0cm
                      Ping: 0cm
                      Ping: 0cm
                      Ping: 0cm
                      Ping: 0cm
                      Ping: 0cm
                      Ping: 16cm
                      Ping: 0cm
                      Ping: 0cm
                      Ping: 0cm
                      Current code:
                      Moshe Livne
                      @crazy_penguin can you please try to point the sensor straight at the wall (not down) and clear anything from the sides? you might get echoes. but this is a bit far fetched. mine is this one http://www.aliexpress.com/item/Free-shipping-1pcs-Ultrasonic-Module-HC-SR04-Distance-Measuring-Transducer-Sensor-for-Arduino-Samples-Best-prices/1967936408.html?aff_platform=aaf&aff_trace_key=34543821268212384&sk=bUBEAqbMv%3A&cpt=1435219216767
                      it works reasonably reliably
                      • C Offline
                        C Offline
                        crazy_penguin
                        @Moshe Livne I order the HC-SR04 Module as well to make sure where the problem is.
                        I also order aother Arduino Nano.
                        hekH 1 Reply Last reply
                        • C crazy_penguin
                          hekH Offline
                          hekH Offline
                          @crazy_penguin
                          Your module (on the pictures) looks really strange. What type is it?
                          • C Offline
                            C Offline
                            crazy_penguin
                            @hek DYP-ME007Y
                            • hekH Offline
                              hekH Offline
                              Check out this:
                              http://forum.arduino.cc/index.php?topic=153700.0
                              C 1 Reply Last reply
                                Check out this:
                                C Offline
                                C Offline
                                crazy_penguin
                                @hek Thanks. I will check out this and will tell you the result.
                                • C Offline
                                  C Offline
                                  crazy_penguin
                                  OK. this threat (http://forum.arduino.cc/index.php?topic=153700.0) is very usefull. I will try out some hints and tell you my result.
                                  Thank to all for now.
                                  • C Offline
                                    C Offline
                                    crazy_penguin
                                    Hi there,
                                    it's me again.
                                    I tried some things which read in the arduino froum (http://forum.arduino.cc/index.php?topic=153700.0) without any good result.
                                    I also get a new sensor and there is still no change of it's behaviour.
                                    I read in the forum that it could be a sensor that uses RX/TX to send its information.
                                    Does any one know something about that?
                                    12.2k
