  3. converting 12v to 5v
49 Posts 7 Posters 30.3k Views 2 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    wrote on last edited by rvendrame
    Maybe if you post the circuit, it will be easy to understand. Anyway, I think the less-invasive method is by using a optocoupler:
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    • rvendrameR rvendrame
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @rvendrame here is the page from the manual:
      my installation is the one without the batteries,
      i'll get some optocouplers and play. Thanks!
      AWIA 1 Reply Last reply
      • Moshe LivneM Moshe Livne
        AWIA
        AWIA
        AWI
        @Moshe-Livne Do you have a volt meter? Than measure between 0 and 1 while pressing the button and releasing it (or 0 and 2, depending which one is used) and than post your measurements. From the pictures I imagine that it is a DC circuit.
        Moshe LivneM 2 Replies Last reply
        • AWIA AWI
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @rvendrame Oh wow. there are zillions of kinds... As aliexpress are a bit thin on details, anyone knows when one I should get to detect 6v 6ma ?
          • AWIA AWI
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @AWI It is 6vdc, about 6ma current. i tried to tap it for powering the arduino but its not enough
              @Moshe-Livne , it should be simpler than that --- Just connect the ground of the doorbell to arduino's ground, and use a voltage divider below to divide the +12v by lets say, 3, and connect it to any arduino input pin.
              R1 = 670K and R2 = 470K should do the trick... 12V will become ~4V , and digitalRead() will read '1' when the bell rings (and zero when idle).
              AWIA
              AWIA
              AWI
              wrote on last edited by AWI
              #23
              @Moshe-Livne going back to an earlier suggestion from @rvendrame (adapted a little for the situation)
              Current is not important here as long as you do don't power the arduino from it. Just connect the ground of the doorbell to arduino's ground, and use a voltage divider below in parallel (U1) with the pushbutton. This divides the voltage of +6v by 1.5, and can be connected to any arduino input pin (Digital or Analog).
              R1 = 470K and R2 = 670K should do the trick... 6V (U1) will become ~4V (U2) , and digitalRead() will read 'low' when the bell rings (and 'high' when idle).
              • AWIA AWI
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @AWI Errrr tried something similar before and the bell was ringing continuously as if the arduino acted as a short. might be something stupid i did. I excel in these. maybe defined the pin as output. will double check tomorrow.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  #25
                  hmm.. only 6v DC?
                  why use optocouplers for that? Could also be done very simple with a resistor and one or two diodes.
                  connect gnd together, a 10-100k resistor in line with the +6V signal to the input on arduino, and a clamping diode to VCC (optionally a second clamping diode to GND for good measures).
                  See the first answer to the question here http://electronics.stackexchange.com/questions/45127/what-kind-of-diode-to-use-with-adc-inputs
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    @tbowmo , I suggested the optocoupler as an alternative to not trigger the ring as Moshe Livne had mentioned. But I agree with you, it should work without it if connected in the right way.
                    Alexa / Google Home
                    • tbowmoT tbowmo
                      hmm.. only 6v DC?
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @tbowmo SO, just re-iterating so I wont do something stupid:
                      1. I still need a bridge rectifier or some sort of ac-dc regulator/transformer to drive the arduino as the dc circuit does not have enough juice
                      2. the circuit will look something like:
                        (the simulation shows zero current so i probably did something wrong)
                      Again, thank you for your patience.
                      • tbowmoT tbowmo
                        hmm.. only 6v DC?
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @tbowmo added the door bell to the simulation and its working. you are the bestest! now to get some diodes.....
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Moshe-Livne
                          That doesn't look quite right. If you look at the link I provided, you will see that the resistor is in line with the signal from "outside" to the arduino. So 1 side goes to the doorbell, the other go to the arduino pin. Then the two diodes go from arduino pin and vcc, and arduino and gnd.
                          • tbowmoT tbowmo
                            @Moshe-Livne
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @tbowmo did I get it right now?
                            its a shame that they don't have ac power supply there so i can't simulate the rectifier. nifty site...
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @Moshe-Livne
                              Without knowing the details of the doorbell, I would think it is something like this.. That is, the doorbell get power, when the button is pressed, and makes a connection to GND. So this would be the circuit that I would create:
                              It's only the arduino part you should make, the rest is the existing doorbell.. The resistor should be high value, I've put in 56Kohm, but something in the order of 56-220K ohm, whatever you have in your parts bin :)
                              • tbowmoT tbowmo
                                @Moshe-Livne
                                Moshe LivneM
                                Moshe LivneM
                                Moshe Livne
                                @tbowmo I think its just about the same as my messy sketch. only thing is you assumes the grounds are the same, which should be ok. got a bridge rectifier as well but had to take the kids to watch minions. sigh....
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @Moshe-Livne
                                  It seems that you have the doorbell switch attached accross the supply, so you short circuit it, when you press it.
                                  You also need a common ground signal, between the door bell, and the arduino.
                                  • tbowmoT tbowmo
                                    @Moshe-Livne
                                    Moshe LivneM
                                    Moshe LivneM
                                    Moshe Livne
                                    @tbowmo oh this power supply represents the bell circuit but i see what you mean. If the kids will give me 10 min today I'll give it a try. Door bell is one of those things you can't do after they go to sleep
                                    • tbowmoT tbowmo
                                      @Moshe-Livne
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @tbowmo so, to get a common ground i just connect the "-" from the bell to the gnd on the arduino?
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @Moshe-Livne
                                        Yes, I would think so.. again, without having any knowledge to how the door bell is functioning..
                                        • tbowmoT tbowmo
                                          @Moshe-Livne
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @tbowmo Oh I wish I knew. I might just open it and look although it will be a big hard to put back. currently the power from the bridge seems to be not enough to drive the circuit which is strange. the power lights up but nothing much happens. I'll go over everything once again.
                                          12.5k
