  3. converting 12v to 5v
49 Posts 7 Posters 30.2k Views 2 Watching
  • rvendrameR rvendrame
    @Moshe-Livne , it should be simpler than that --- Just connect the ground of the doorbell to arduino's ground, and use a voltage divider below to divide the +12v by lets say, 3, and connect it to any arduino input pin.
    R1 = 670K and R2 = 470K should do the trick... 12V will become ~4V , and digitalRead() will read '1' when the bell rings (and zero when idle).
    AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    #23
    @Moshe-Livne going back to an earlier suggestion from @rvendrame (adapted a little for the situation)
    Current is not important here as long as you do don't power the arduino from it. Just connect the ground of the doorbell to arduino's ground, and use a voltage divider below in parallel (U1) with the pushbutton. This divides the voltage of +6v by 1.5, and can be connected to any arduino input pin (Digital or Analog).
    R1 = 470K and R2 = 670K should do the trick... 6V (U1) will become ~4V (U2) , and digitalRead() will read 'low' when the bell rings (and 'high' when idle).
    • AWIA AWI
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @AWI Errrr tried something similar before and the bell was ringing continuously as if the arduino acted as a short. might be something stupid i did. I excel in these. maybe defined the pin as output. will double check tomorrow.
      • tbowmoT
        tbowmoT
        tbowmo
        #25
        hmm.. only 6v DC?
        why use optocouplers for that? Could also be done very simple with a resistor and one or two diodes.
        connect gnd together, a 10-100k resistor in line with the +6V signal to the input on arduino, and a clamping diode to VCC (optionally a second clamping diode to GND for good measures).
        See the first answer to the question here http://electronics.stackexchange.com/questions/45127/what-kind-of-diode-to-use-with-adc-inputs
        Moshe LivneM 2 Replies Last reply
        • rvendrameR
          rvendrameR
          rvendrame
          @tbowmo , I suggested the optocoupler as an alternative to not trigger the ring as Moshe Livne had mentioned. But I agree with you, it should work without it if connected in the right way.
          ESP8266 GW + mySensors 2.3.2
          Alexa / Google Home
          • tbowmoT tbowmo
            hmm.. only 6v DC?
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @tbowmo SO, just re-iterating so I wont do something stupid:
            1. I still need a bridge rectifier or some sort of ac-dc regulator/transformer to drive the arduino as the dc circuit does not have enough juice
            2. the circuit will look something like:
              (the simulation shows zero current so i probably did something wrong)
            Again, thank you for your patience.
            • tbowmoT tbowmo
              hmm.. only 6v DC?
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @tbowmo added the door bell to the simulation and its working. you are the bestest! now to get some diodes.....
              • tbowmoT
                tbowmoT
                tbowmo
                @Moshe-Livne
                That doesn't look quite right. If you look at the link I provided, you will see that the resistor is in line with the signal from "outside" to the arduino. So 1 side goes to the doorbell, the other go to the arduino pin. Then the two diodes go from arduino pin and vcc, and arduino and gnd.
                • tbowmoT tbowmo
                  @Moshe-Livne
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @tbowmo did I get it right now?
                  its a shame that they don't have ac power supply there so i can't simulate the rectifier. nifty site...
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Moshe-Livne
                    Without knowing the details of the doorbell, I would think it is something like this.. That is, the doorbell get power, when the button is pressed, and makes a connection to GND. So this would be the circuit that I would create:
                    It's only the arduino part you should make, the rest is the existing doorbell.. The resistor should be high value, I've put in 56Kohm, but something in the order of 56-220K ohm, whatever you have in your parts bin :)
                    • tbowmoT tbowmo
                      @Moshe-Livne
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @tbowmo I think its just about the same as my messy sketch. only thing is you assumes the grounds are the same, which should be ok. got a bridge rectifier as well but had to take the kids to watch minions. sigh....
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Moshe-Livne
                        It seems that you have the doorbell switch attached accross the supply, so you short circuit it, when you press it.
                        You also need a common ground signal, between the door bell, and the arduino.
                        • tbowmoT tbowmo
                          @Moshe-Livne
                          Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          @tbowmo oh this power supply represents the bell circuit but i see what you mean. If the kids will give me 10 min today I'll give it a try. Door bell is one of those things you can't do after they go to sleep
                          • tbowmoT tbowmo
                            @Moshe-Livne
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @tbowmo so, to get a common ground i just connect the "-" from the bell to the gnd on the arduino?
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @Moshe-Livne
                              Yes, I would think so.. again, without having any knowledge to how the door bell is functioning..
                              • tbowmoT tbowmo
                                @Moshe-Livne
                                Moshe LivneM
                                Moshe LivneM
                                Moshe Livne
                                @tbowmo Oh I wish I knew. I might just open it and look although it will be a big hard to put back. currently the power from the bridge seems to be not enough to drive the circuit which is strange. the power lights up but nothing much happens. I'll go over everything once again.
                                • tbowmoT tbowmo
                                  @Moshe-Livne
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @tbowmo I have double checked everything, used the arduino connected to the computer so have a stable 5v power supply to the nano. connected external power supply with 6.3v and 8ma to ground and the external leg of the resistor - nothing...
                                  wouldn't it be simpler it I used npn transistor to close the circuit? I am on the verge of going the "safe" way - connecting the doorbell loop to the arduino so pressing the doorbell will short pin 3 to gnd and then activating a relay to close the doorbell circuit. this is far from being a good solution as if the sensor does not work the doorbell will not work as well, but this is stuff that I understand (to an extent :-) )
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @Moshe-Livne
                                    what is the voltage at the arduino input, when you apply the external power supply?
                                    Could you try and measure the voltage across the switch terminals in the door bell:
                                    1. when button isn't pressed
                                    2. when the button is pressed
                                    You need to simulate these two input voltages on the input of the circuit..
                                    • tbowmoT tbowmo
                                      @Moshe-Livne
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @tbowmo this is not connected to the doorbell as I hate working in the air... so, its connected to my laptop for the 5v and debug and to a variable voltage power supply that i set to 6.3v (it shows 8ma are "used")
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @Moshe-Livne
                                        Yes, but you need to simulate the doorbell, so take some measurements on the doorbell, and copy those to your circuit. That is, if the signal on the doorbell is 0V when the button is pressed, then you should be able to short the input to your signal to 0V.
                                        Also, again, when applying 6.3V via your external powersupply, what is the voltage on the input pin on the arduino?
                                        • tbowmoT tbowmo
                                          @Moshe-Livne
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @tbowmo i get 3.30v when power is off 4.7v when power is on. i think i used the wrong resistor... i am colour blind.... checking...
