  3. Door, Motion and Temperature Sensor
63 Posts 11 Posters 50.4k Views 4 Watching
  • R robosensor
    @CaptainZap
    http://www.mysensors.org/download/ click on Download button under "1.4 - Latest Release" section, download zip archive, extract archive and check Arduino-master\libraries\MySensors\Version.h file.
    CaptainZapC
    CaptainZapC
    CaptainZap
    wrote on last edited by CaptainZap
    @robosensor Thanks, I installed that but it's version 1.5 b1 and after using it it's giving me lots of errors :| I think there have been changes in how the code is used...
    LE: I finally found the 1.4.1 branch and downloaded it however it's still giving me the same error about wait:
    Door_Motion_Temp_rev2.ino: In function 'void getTemps()':
    Door_Motion_Temp_rev2:115: error: 'class MySensor' has no member named 'wait'
    LLE: Just checked the cpp and there is no wait, this is the library I used :
    https://github.com/mysensors/Arduino/tree/1.4.1
    Can you tell me if there will be any issue if I comment that part ?
    R 1 Reply Last reply
    • CaptainZapC CaptainZap
      R
      R
      robosensor
      @CaptainZap https://github.com/mysensors/Arduino/archive/master.zip
        @robosensor
        LOL :)
        • CaptainZapC
          CaptainZapC
          CaptainZap
          That was the version I was using when I first encountered the issues... anyways I'll remove arduino IDE with everything and reinstall it. Thanks.
          @hek I also LOL-ed :D Gotta love the helping spirit in the community you guys built.
            R
            R
            robosensor
            @CaptainZap also try to backup and clean C:\Users***\Documents\Arduino\ directory :)
              @robosensor
              LOL :)
              R
              R
              robosensor
              @hek as I said before, Dallas library is bit outdated. Is it possible to update dallas and onewire libraries? I provided links for newer versions of this libraries in this thread. I can do PR in github myself, but I don't know how to do it :) I need to read github manuals first :)
              requestTemperatures() is can be non-blocking in newer version of dallas library, so code can deep sleep (better for batteries) or process messages (better for repeaters and msg-receiving nodes) about 750 ms.
              hekH 1 Reply Last reply
              • R robosensor
                @robosensor
                Using github is quite easy (when you get a hang of it). We can use this as a "training session" if you want?
                I did a quick getting-started guide here:
                http://forum.mysensors.org/topic/330/how-to-contribute-code-to-the-mysensors-project
                Basically you need to
                • Fork the mysensors project on github
                • Clone your fork from your computer.
                • Replace the libraries that is outdated.
                • Commit as push the changes back to your fork of github.
                • Create a pull-request (see above instructions) which I'll review and merge.
                Easy peasy.. :)
                  @robosensor
                  Easy peasy.. :)
                  R
                  R
                  robosensor
                  @hek thank you, I'll read and try on dallas&onewire :)
                  • R robosensor
                    @robosensor
                    Great, just ask (or open a chat) if you run into trouble.
                      @robosensor
                      R
                      R
                      robosensor
                      @hek I have forked MySensors project, added 3 commits into master branch with updated libraries and updated dallas sensors example (lower power usage).
                      I'm using similar code in my own version of MySensors 1.5-dev in my home, but I havn't tested this committed 1.4.1 github code on real hardware, so I will make PR after test on real hardware.
                      https://github.com/mysensors/Arduino/compare/master...roboprint:master?diff=split&name=master
                        Sounds good!
                          Sounds good!
                          R
                          R
                          robosensor
                          wrote on last edited by robosensor
                          #26
                          @hek It seems that I did it. If this push request is correct, what I should patch? Development branch, master branch or both?
                            Good!
                            You can create pull request on master (and I'll merge it to development later).
                              @robosensor
                              Thanks and congrats! You've made your first contribution to the MySensors project. :)
                              • CaptainZapC
                                CaptainZapC
                                CaptainZap
                                #29
                                Guys, I had some free time tonight and tried to apply this fix... I ended up re-installing the arduino IDE + downloading the latest version, which now is 1.4.1 as opposed to the 1.4 that I used to have ?
                                Anyways I had to upgrade my ethernet gateway (ENC28J60) and it's no longer working now... any hints will be golden.
                                LE: I was too tired to check the sketch... I forgot to include the correct library and went to all debugging first, reset router config to default, but in the end I did notice the issue :) So I learned a valuable lesson, never work on this if it's late or you're tired.
                                • CaptainZapC
                                  CaptainZapC
                                  CaptainZap
                                  #30
                                  Hello guys,
                                  I really need an expert's opinion on this because I'm experiencing some trouble... I've tried to include suggestions from all you guys, except the delay part, but so far it works partially... in my original code the temperature worked, and now it doesn't. The rest works ok, sensor and motion, so I would be grateful if anyone could take a look at my code and help me with it... I kind of need to get it in place soon, as I intend to leave my house for some time.
                                  Thank you.
                                  //This sketch is for Door & Motion & Temp Sensor
                                  #include <OneWire.h>
                                  #define CLIENT_ID AUTO  // Sets MYSensors client id
                                  #define RADIO_CH 76  // Sets MYSensors to use Radio Channel
                                  #define TRIGGER	3	// used to connect motion sensor
                                  #define BUTTON_PIN  4 // used to connect door/window sensor
                                  //Temp Sensor bits
                                  #define ONE_WIRE_BUS 14 // Pin where dallas sensor is connected
                                  DallasTemperature DallasSensors(&oneWire);
                                  float lastTemperature ;
                                  #define CHILD_ID_T1 3 //CHILD ID for temp
                                  //Door/Window bits
                                  #define CHILD_ID_D1 1 //CHILD ID for door/window
                                  //Trigger Sensor Bits
                                  #define CHILD_ID_S1 2 //CHILD ID for Motion sensor
                                  boolean lastTripped = 0;
                                  Bounce debouncer = Bounce();
                                  int oldValue=-1;
                                  MyMessage msg(CHILD_ID_D1,V_TRIPPED);
                                  MyMessage triggerMsg(CHILD_ID_S1,V_TRIPPED);
                                  MyMessage tempMsg(CHILD_ID_T1,V_TEMP);
                                  	// Startup OneWire Temp Sensors
                                      DallasSensors.begin();
                                      DallasSensors.setWaitForConversion(false);
                                  	 gw.begin(NULL, AUTO, true);
                                  	gw.sendSketchInfo("Multi Sensor", "1.1");
                                  	gw.present(CHILD_ID_D1, S_DOOR);
                                  	gw.present(CHILD_ID_T1, S_TEMP);
                                  	gw.present(CHILD_ID_S1, S_MOTION);
                                  	// Setup the button
                                          pinMode(BUTTON_PIN,INPUT);
                                          // Activate internal pull-up
                                          debouncer.attach(BUTTON_PIN);
                                          debouncer.interval(5);
                                  	// Check for motion change value
                                  		boolean tripped = digitalRead(TRIGGER) == HIGH;
                                  		if (lastTripped != tripped ) {
                                  			gw.send(triggerMsg.set(tripped?"1":"0")); // Send new state and request ack back
                                  			Serial.println("Tripped");
                                  			lastTripped=tripped;
                                                  debouncer.update();
                                                // Get the update value
                                                  int value = debouncer.read();
                                                  if (value != oldValue) {
                                                      // Send in the new value
                                                       oldValue = value;
                                      DallasSensors.requestTemperatures(); // no delay here
                                      gw.wait(750); // insert another value for non-12-bit resolution
                                      float tempC = DallasSensors.getTempCByIndex(1);
                                      if (lastTemperature != tempC && tempC != -127.00) {
                                        gw.send(tempMsg.set(tempC,1));
                                        lastTemperature=tempC;
                                  • BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @CaptainZap
                                    what does the Serial output show during execution of the sketch?
                                    • CaptainZapC
                                      CaptainZapC
                                      CaptainZap
                                      @BulldogLowell Unfortunately I don't have a way to test that yet... I'm uploading the sketch using an arduino uno, and I have no idea how to do that with it. I do have an FTDI serial adapter but is not picked up by the IDE, it was at some point but no longer... probably fake :|
                                      • m26872M
                                        m26872M
                                        m26872
                                        I don't know what's the issue, but I'd still prefer a normal timing code instead of just the gw.wait(). The fetching of temperatures in every loop makes no sense to me.
                                        CaptainZapC 1 Reply Last reply
                                        • m26872M m26872
                                          CaptainZapC
                                          CaptainZapC
                                          CaptainZap
                                          @m26872 If you have time, could you please tell me how to do that, I know you've posted a link a few post back but I didn't do much with it :(
