  3. sensors in boxes
sensors in boxes
57 Posts 11 Posters 44.1k Views 16 Watching
  • GuyPG GuyP
    Sure no problem.. It's the stock code for the dallas temperature sensor with the simple addition for the battery monitoring.
    oh and just as an update on that.. still haven't replaced the batteries in the sensors and they are still reporting 82%, which is a run time of over 4 months now.
    BatteryStatus.tiff
    // Example sketch showing how to send in OneWire temperature readings
    #include <OneWire.h>
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    MyMessage msgvolt(1,V_VOLTAGE);
    int BATTERY_SENSE_PIN = A0;
    int oldBatteryPcnt = 0;
      analogReference(INTERNAL);
      // Startup OneWire
      sensors.begin();
      // Startup and initialize MySensors library. Set callback for incoming messages.
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor", "1.0");
         gw.present(i, S_TEMP);
      // Process incoming messages (like config from server)
      // Battery Monitoring
      float batteryV = sensorValue * 0.003363075;
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
        gw.send(msgvolt.set(batteryPcnt,1));
        oldBatteryPcnt = batteryPcnt;
        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        if (lastTemperature[i] != temperature && temperature != -127.00) {
          gw.send(msg.setSensor(i).set(temperature,1));
      gw.sleep(SLEEP_TIME);
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @GuyP what kind of chip is the big one? Does not look like nano or pro mini. Terrific run time so must be efficient.
    • GuyPG
      GuyPG
      GuyP
      It's an ATMEGA328P, which is the Arduino processor, I buy them in bulk from China, write the boot loader and flash the code onto them using an uno board.
      Moshe LivneM H 2 Replies Last reply
      • GuyPG GuyP
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @GuyP Cool! these are really cheap and they save on cutting the LED and voltage regulator.... it looks like they are even more economical in energy then the modified (no LED no voltage reg) pro mini. Can you detail for a complete idiot the bootloader and flash thing?
        GuyPG 1 Reply Last reply
        • GuyPG GuyP
          I'm running everything at 3 volts from the 2 AAA batteries. The box is 3D printed and integrates the battery box. I'm not using any screws, just slide rails for the PCB , top and back.
          TempSensorBase.stl
          I have two board types now. One with just the single Dallas temp sensor on it, which turns out to be what I need most of.
          I also created another board which has three Connectors, JP1-3, which allows to additional Dallas Temp sensors. I have these in locations where I can run wires more easily, like my loft spaces.
          I'm etching everything myself. Very simple really. I'm using the print on to glossy paper and transfer onto copper board, using a laminator, method. Works really well. As these boards are small I tend to etch a few at a time onto a single copper board and then cut the board at the end.
          DrJeffD
          DrJeffD
          DrJeff
          @GuyP Can you post the pdf images of the boards, I want to etch some I like the use of 328P chip, The only problem the png file is scaled wrong too large.
          • GuyPG GuyP
            H
            H
            hawk_2050
            @GuyP Do you have a favourite seller for those mega328 DIP parts? Mostly when I've looked on eBay the clone Arduino Mini's come in cheaper than a DIP package mega328 IC. I also would prefer to use a design that utilises the mega328 DIP directly rather than an Arduino Mini if I could. Cost per node is very important to me to enable affordable expansion of my network. Thanks.
            • H hawk_2050
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @hawk_2050 look here
              That is much cheaper.... 1.4$/node
              • Moshe LivneM Moshe Livne
                GuyPG
                GuyPG
                GuyP
                @hawk_2050 I buy them from banggood.com where they discount for quantity so I'm usually paying about £1.66 a chip and free delivery.
                However looking at @Moshe-Livne he's found a cheaper place.. so I think I'll be using them from now on :)
                  GuyPG
                  GuyPG
                  GuyP
                  @Moshe-Livne the boot loader..
                  https://www.arduino.cc/en/Hacking/Bootloader?from=Tutorial.Bootloader
                  I use this method to write the boot loaders using an uno..
                  https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
                  works great. I use a Zero insertion socket for the chip and rattle through the chips in a seconds.
                  • DrJeffD DrJeff
                    GuyPG
                    GuyPG
                    GuyP
                    @DrJeff Sure no problem..
                    TempSensor.pdf
                    I've also now built a "Repeater Board", this board can either act as a repeater, and be powered by USB mini, or battery (Best not on battery when in repeater mode). It also has the expansion to add multiple Dallas Temperature sensors. JP1-3 sensors can be daisy chained up to around 16 in total. I have these boards in loft spaces, and garage where I want to watch temperature in lots of locations and I don't mind a few wires.
                    TempSensorRepeater.pdf
                    Let me know if those work out better...
                    DrJeffD 1 Reply Last reply
                    • GuyPG GuyP
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @GuyP That looks pretty simple... what boot loader do you write? do you really remove the processor from the uno or did you make a dedicated one? do you use the minimal breadboard version? This system also has the upside of not having to deal with the irritating counterfeit or ch340 ftdi chips, so bonus points...
                      • GuyPG GuyP
                        TempSensor.pdf
                        DrJeffD
                        DrJeffD
                        DrJeff
                        @GuyP Cool thanks, Time to etch some boards, have you used this method/setup for other nodes? Just trying to get some ideas :grinning:
                          GuyPG
                          GuyPG
                          GuyP
                          @Moshe-Livne When writing the boot loader you need to keep the uno chip in the board.
                          Once you've written all the board loaders, then you can pull the chip from uno and replace it with all the new ones to write the temperature sensor codes.
                          • DrJeffD DrJeff
                            GuyPG
                            GuyPG
                            GuyP
                            @DrJeff At the moment just temperature sensors.. however the plan is to also control my heating system around the house.
                            I will put putting controllers on all the radiators around the house, and replacing the controller in the house with simple radio buttons which feed back to openhab for manual over ride.
                            Just not had time yet! :(
                            • GuyPG GuyP
                              DrJeffD
                              DrJeffD
                              DrJeff
                              @GuyP Yes we always got to deal with real life! On the board I assume the red lines are wires due to the single sided board?
                              • DrJeffD DrJeff
                                GuyPG
                                GuyPG
                                GuyP
                                @DrJeff yes correct.. I'm just etching single sided. I couldn't solve the it completely so four links.
                                • G
                                  G
                                  gigaguy
                                  @GuyP Are you using the MYS or the Uno bootloader?
                                  • GuyPG
                                    GuyPG
                                    GuyP
                                    I'm just flashing with the uno boot loader...
                                    I have been looking at doing away with the boot loader, but really the advantages such as extra space and boot speed are not important at the moment.
                                    • GuyPG GuyP
                                      TempSensorBase.stl
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @GuyP can you please export it in brd or dxf?
                                      • GuyPG
                                        GuyPG
                                        GuyP
                                        Here's the BRD files..
                                        TempSensorRepeater.brd
                                        TempSensor.brd
                                        • GuyPG GuyP
                                          TempSensor.brd
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @GuyP Thanks!!!!
