  3. Help!!! Binary & Relay Compilation Not Working
15 Posts 4 Posters 5.4k Views 1 Watching
  • jeylitesJ
    jeylitesJ
    jeylites
    wrote on last edited by jeylites
    REVISED!!!
    Compiles but not working
    // digitial I/O pin 3 (BUTTON_PIN below) and GND.
    #include <Time.h>        //http://playground.arduino.cc/Code/Time
    #include <TimeAlarms.h>  //http://playground.arduino.cc/Code/Time
    #define RADIO_ID 12
    #define noReeds 3
    const int BUTTON_PIN[] = {4,5,6};            // Arduino Digital I/O pin for button/reed switch, A0 - A4
    boolean reedState[] = {HIGH, HIGH, HIGH};
    Bounce debouncer[noReeds];
    MyMessage msg[noReeds];
    void setup(){
      gw.begin(NULL, RADIO_ID, true);  //stattc RADIO_ID an enable repeater
      Alarm.delay(250);
      gw.sendSketchInfo("Relay", "1.0");
      gw.sendSketchInfo("Alarm Pannel", "1.0");
      Alarm.delay(250);
      gw.requestTime(receiveTime);
      // initialize Relays with corresponding buttons
      for (int i = 0; i < noReeds; i++){
        msg[i].sensor = i;          // initialize messages
        msg[i].type = V_TRIPPED;
        debouncer[i] = Bounce();        // initialize debouncer
        debouncer[i].attach(BUTTON_PIN[i]);
        debouncer[i].interval(5);
        // Setup the button
        pinMode(BUTTON_PIN[i],INPUT);
        // Activate internal pull-up
        digitalWrite(BUTTON_PIN[i],HIGH);
        gw.present(i, S_DOOR);      // present sensor to gateway
        Serial.print("setup for switch: ");
        Serial.print(BUTTON_PIN[i]);
        Serial.println(" complete" );
        Alarm.timerRepeat(720, updateState); // update relay status every 2 hrs
        Alarm.delay(250);
       // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
        debouncer[i].update();
        // Get the update value
        if (value != reedState[i]) {
           // Send in the new value
           gw.send(msg[i].set(value==HIGH ? 1 : 0), false);
           reedState[i] = value;
           Serial.print("updating state for swicth: ");
           Serial.print(" state: ");
           Serial.println(reedState[i]);
    void updateState(){
      Serial.println("Start state info");
          Serial.print("sending update for switch: ");
          Serial.println(BUTTON_PIN[i]);
          Alarm.delay(250);
          //MyMessage msg(relayPin[pin],V_LIGHT);
          gw.send(msg[i].set(reedState[i]), false); // Send last state from eprom to GW
          Alarm.delay(250);
    void receiveTime(unsigned long time) {
      setTime(time);
    • sundberg84S
      sundberg84S
      On of the error might be the last line "}```)
      remove so its only }
      Br
      • jeylitesJ jeylites
        REVISED!!!
        #define RADIO_ID 12
        #define noReeds 3
        void setup(){
          Alarm.delay(250);
          Alarm.delay(250);
            // Setup the button
            Alarm.delay(250);
        void updateState(){
              Alarm.delay(250);
              Alarm.delay(250);
          setTime(time);
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @jeylites
        your example compiles for me.
        Consider removing TimeAlarms.h library and use gw.wait(250); instead of Alarm.delay(250);
        gw.wait() executes gw.process() over and over again during the delay time; so it is essentially non-blocking.
        • jeylitesJ
          jeylitesJ
          jeylites
          My bad. I copied the wrong sketch to this chat. I have revised the sketch and it complies but it's not working... :( Please see sketch above.
          • jeylitesJ
            jeylitesJ
            jeylites
            This is the serial message I get
            repeater started, id 12
            send: 12-12-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
            send: 12-12-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
            read: 0-0-12 s=255,c=3,t=6,pt=0,l=1:M
            send: 12-12-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
            send: 12-12-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
            send: 12-12-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Alarm Pannel
            send: 12-12-0-0 s=255,c=3,t=1,pt=0,l=3,st=ok:1.0
            send: 12-12-0-0 s=0,c=0,t=0,pt=0,l=5,st=ok:1.4.1
            setup for switch: 5 complete
            send: 12-12-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
            read: 0-0-12 s=255,c=3,t=1,pt=0,l=10:1435918408
            • BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @jeylites
              fyi, just pick one name...
              What is this supposed to be doing? it looks like:
              reporting the state of three reed switches
              actuating a relay
              Why are you using the dalays? time?
              hard to really understand what you are trying to do here...
              • jeylitesJ
                jeylitesJ
                jeylites
                @BulldogLowell
                Essentially, I will like to combine Array Binary and Relay Actuator in one sketch.
                • BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  three binary switches and a single relay?
                  • jeylitesJ
                    jeylitesJ
                    jeylites
                    yes sir !
                    • jeylitesJ
                      jeylitesJ
                      jeylites
                      @BulldogLowell
                      Any ideas how I can get this to work?
                      Moshe LivneM BulldogLowellB 2 Replies Last reply
                        @BulldogLowell
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @jeylites it looks like you are overwriting i somewhere inside the loop. can you try to add prints of the value of i at several strategic points to see when it becomes 5? I would suggest to add one (and also print BUTTON_PIN[i]) before "msg[i].sensor = i;", one after "// Setup the button" and print i with the BUTTON_PIN[i].
                        • jeylitesJ
                          jeylitesJ
                          jeylites
                          @Moshe-Livne
                          I'm going to try fix it as suggested. But the thing is it complies....
                            @Moshe-Livne
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @jeylites Alas compiling is not a guarantee against memory overwrites....as button_pin should have shown 4 and not 5 i assume that either the index (i) got corrupt or the button_pin array.
                              @BulldogLowell
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @jeylites
                              I think this is what you want. I cannot test it right now, but it does compile:
                              #define NUMBER_OF_REEDS 3
                              const int relayPin = 3;
                              const int reedPin[NUMBER_OF_REEDS] = {4, 5, 6};
                              int reedState[NUMBER_OF_REEDS];
                              Bounce debouncer[NUMBER_OF_REEDS] = Bounce();
                              MyMessage msg[NUMBER_OF_REEDS];
                                gw.sendSketchInfo("Test", "1.0a");
                                gw.present(0, S_LIGHT);
                                pinMode(relayPin, OUTPUT);
                                digitalWrite(relayPin, gw.loadState(0));
                                for (int i = 0; i < NUMBER_OF_REEDS; i++)
                                  debouncer[i].attach(reedPin[i]);
                                  pinMode(reedPin[i], INPUT_PULLUP);
                                  gw.wait(250);
                                    gw.send(msg[i+1].set(value), false); // device number mismatch here because of the array
                                    Serial.print("updating state for switch: ");
                                    Serial.print(reedPin[i]);
                                if (message.type == V_LIGHT)
                                  int newState = message.getBool();
                                  digitalWrite(relayPin, newState);
                                  gw.saveState(0, newState);
                                  Serial.print(F("Incoming change for relay, New state: "));
                                  Serial.println(newState);
                              EDIT: Updated to correct debounce class errors
                              • BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @jeylites
                                to turn relay off automatically after two minutes (and send the updated "off status" to controller... try something like this untested code:
                                unsigned long relayTimer;
                                MyMessage relayMessage(0,V_LIGHT);
                                    gw.wait(250);
                                  if (millis() - relayTimer > 2 * 60 * 1000UL && digitalRead(relayPin)) // two minute timer
                                    digitalWrite(relayPin, LOW);
                                    gw.saveState(0, false);
                                    gw.send(relayMessage.set(false), true);
                                    if (newState)
                                      relayTimer = millis();
