  3. Solar Pannel and LiOn or Lipo
52 Posts 5 Posters 50.4k Views 9 Watching
  • epierreE
    epierreE
    epierre
    #21
    an idea maytbe, if I put sleep at 30 * 1000 it works, at 60 * 1000 infinite sleep... any idea ?
    (I observed that on both units). It also loas the battery ...
    Batt: 3.96V ; 0.00A
    Solar: 0.55V ; 0.00 A; charge: No
    BattPct: 65%
    send: 14-14-0-0 s=10,c=1,t=38,pt=7,l=5,st=ok:3.959
    send: 14-14-0-0 s=10,c=1,t=39,pt=7,l=5,st=ok:0.000000
    send: 14-14-0-0 s=11,c=1,t=38,pt=7,l=5,st=ok:0.545
    send: 14-14-0-0 s=11,c=1,t=39,pt=7,l=5,st=ok:0.000000
    send: 14-14-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:65
    22
    send: 14-14-0-0 s=0,c=1,t=23,pt=3,l=2,st=ok:22
    Batt: 3.97V ; 0.00A
    Solar: 0.48V ; 0.00 A; charge: No
    BattPct: 66%
    send: 14-14-0-0 s=10,c=1,t=38,pt=7,l=5,st=ok:3.966
    send: 14-14-0-0 s=11,c=1,t=38,pt=7,l=5,st=ok:0.480
    send: 14-14-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:66
    21
    send: 14-14-0-0 s=0,c=1,t=23,pt=3,l=2,st=ok:21
    z-wave - Vera -> Domoticz
    C 1 Reply Last reply
    • epierreE epierre
      Batt: 3.96V ; 0.00A
      BattPct: 65%
      22
      Batt: 3.97V ; 0.00A
      BattPct: 66%
      21
      C
      C
      ceech
      @epierre
      Solar voltage seems a bit low. Can you raise it? And see if the charging takes place?
      • epierreE
        epierreE
        epierre
        #23
        sleep is the problem, it loads at 30s never above...
        Batt: 4.06V ; 0.00A
        Solar: 2.56V ; 0.00 A; charge: No
        BattPct: 79%
        Batt: 4.05V ; 0.00A
        Solar: 3.38V ; 0.00 A; charge: No
        BattPct: 78%
        on the other:
        2015-07-05 20:32:40 14 10 1 0 38 4.024
        2015-07-05 20:32:40 14 10 1 0 39 0.001298
        2015-07-05 20:32:41 14 11 1 0 38 3.991
        2015-07-05 20:32:42 14 11 1 0 39 0.000000
        2015-07-05 20:32:42 14 255 3 0 0 74
        2015-07-05 16:24:08 14 10 1 0 38 3.953
        2015-07-05 16:24:08 14 10 1 0 39 0.001298
        2015-07-05 16:24:09 14 11 1 0 38 4.731
        2015-07-05 16:24:10 14 11 1 0 39 0.015577
        2015-07-05 16:24:10 14 255 3 0 0 64
        2015-07-05 18:55:40 14 10 1 0 38 4.050
        2015-07-05 18:55:40 14 10 1 0 39 0.061008
        2015-07-05 18:55:40 14 11 1 0 38 4.212
        2015-07-05 18:55:42 14 11 1 0 39 0.066200
        2015-07-05 18:55:42 14 255 3 0 0 78
        One one of the two units I have issues on radio:
        Batt: 4.05V ; 0.00A
        Solar: 1.80V ; 0.00 A; charge: No
        BattPct: 78%
        send: 15-15-0-0 s=10,c=1,t=38,pt=7,l=5,st=fail:4.050
        send: 15-15-0-0 s=10,c=1,t=39,pt=7,l=5,st=fail:0.001298
        send: 15-15-0-0 s=11,c=1,t=38,pt=7,l=5,st=ok:1.804
        send: 15-15-0-0 s=11,c=1,t=39,pt=7,l=5,st=fail:0.000000
        send: 15-15-0-0 s=255,c=3,t=0,pt=1,l=1,st=fail:78
        • epierreE epierre
          Batt: 4.06V ; 0.00A
          BattPct: 79%
          Batt: 4.05V ; 0.00A
          BattPct: 78%
          on the other:
          Batt: 4.05V ; 0.00A
          BattPct: 78%
          C
          C
          ceech
          @epierre I'll ask @AWI, he may help.
          • AWIA
            AWIA
            AWI
            Your circuit seems to be working correctly. I cannot figure out why the sleep time should influence the metering. I suggest you first test it with a minimal sketch to figure out this sleep issue.
            • epierreE
              epierreE
              epierre
              @AWI What should I keep as minimal ? also any idea about the radio hazard ? I've changed several antennae and it is either half wrong or "check wire"
              AWIA 1 Reply Last reply
              • epierreE epierre
                AWIA
                AWIA
                AWI
                @epierre in a minimal sketch I would remove have it only send one message and give it enough println's to debug via serial. Check the voltages with a meter and let it run with an increasing sleep time. It could be one of those 'bad radios' which are discussed here on the forum.
                For the charging part: it only charges a partly empty cell and the charge voltage should be high enough to let it happen.
                Debugging is where the fun starts (if you are able to solve it)..
                • epierreE
                  epierreE
                  epierre
                  so the same without sensor nor mysensors... 30 secs fine 40 secs dead...
                  I've removed the radio chipset, same behavior...
                  #include <Wire.h> 				// I2C
                  #define LTC4067_CHRG_PIN	A1		//analog input A1 on ATmega 328 is /CHRG signal from LTC4067
                  #define batteryVoltage_PIN	A0		//analog input A0 on ATmega328 is battery voltage ( /2)
                  #define solarVoltage_PIN	A2		//analog input A2 is solar cell voltage (/ 2)
                  #define solarCurrent_PIN	A6		//analog input A6 is input current ( I=V/Rclprog x 1000 )
                  #define batteryChargeCurrent_PIN	A7	//analog input A7 is battery charge current ( I=V/Rprog x 1000 )
                  #define LTC4067_SUSPEND_PIN	9		//digital output D9 - drive it high to put LTC4067 in SUSPEND mode
                  const float VccMin        = 1.0*3.5;  // Minimum expected Vcc level, in Volts. Example for 1 rechargeable lithium-ion.
                  const float VccMax        = 1.0*4.2;  // Maximum expected Vcc level, in Volts.
                  #define LIGHT_SENSOR_ANALOG_PIN 3   // Digital input did you attach your soil sensor.
                  #define CHILD_ID_LIGHT 0   // Id of the sensor child
                  #define BATT_CHILD_ID 10
                  #define SOLAR_CHILD_ID 11
                  // PIN Radio
                  #define RADIO_CE_PIN    7       // radio chip enable
                  #define RADIO_SS_PIN    8      // CS SS serial select
                  float lastBattVoltage;
                  float lastBattCurrent;
                  float lastSolarVoltage;
                  float lastSolarCurrent;
                  int lastBattPct = 0;
                  uint16_t lastlux;
                  float VccReference = 3.3 ;				// voltage reference for measurement, definitive init in setup
                  unsigned long SLEEP_TIME = 40*1000;  // sleep time between reads (seconds * 1000 milliseconds)
                  int lastSoilValue = -1;
                    // use VCC (3.3V) reference
                    analogReference(DEFAULT);								// default external reference = 3.3v for Ceech board
                    VccReference = 3.323 ;									// measured Vcc input (on board LDO)
                    pinMode(LTC4067_SUSPEND_PIN, OUTPUT);					// suspend of Lion charger set
                    digitalWrite(LTC4067_SUSPEND_PIN,LOW);   			//  active (non suspend) at start
                    sendVoltage();
                    // Power down the radio
                   delay(SLEEP_TIME);
                  void sendVoltage(void)
                  // battery and charging values
                  	// get Battery Voltage & charge current
                  	float batteryVoltage = ((float)analogRead(batteryVoltage_PIN)* VccReference/1024) * 2;	// actual voltage is double
                  	Serial.print("Batt: ");
                  	Serial.print(batteryVoltage);
                  	Serial.print("V ; ");
                  	float batteryChargeCurrent = ((float)analogRead(batteryChargeCurrent_PIN) * VccReference/1024)/ 2.5 ; // current(A) = V/Rprog(kohm)
                  	Serial.print(batteryChargeCurrent);
                  	Serial.println("A ");
                  	// get Solar Voltage & charge current
                  	float solarVoltage = ((float)analogRead(solarVoltage_PIN)/1024 * VccReference) * 2 ;		// actual voltage is double
                  	Serial.print("Solar: ");
                  	Serial.print(solarVoltage);
                  	// get Solar Current
                  	float solarCurrent = ((float)analogRead(solarCurrent_PIN)/1024 * VccReference)/ 2.5;		// current(A) = V/Rclprog(kohm)
                  	Serial.print(solarCurrent);
                  	Serial.print(" A; charge: ");
                  	Serial.println(digitalRead(LTC4067_CHRG_PIN)?"No":"Yes");
                  	// send battery percentage for node
                  	int battPct = 1 ;
                  	if (batteryVoltage > VccMin){
                  		battPct = 100.0*(batteryVoltage - VccMin)/(VccMax - VccMin);
                  	Serial.print("BattPct: ");
                  	Serial.print(battPct);
                  	Serial.println("% ");
                  • epierreE
                    epierreE
                    epierre
                    I've received a string of 10 radio chipset tonight and changing the component has no effect compared to the other board where radio is ok.
                    are you sure the problem is softare for what I see here is not dependant of a sophisticated library ?
                    I've learned recently of IAQ (incomming assurance quality) because Photon (formerly Sark) has been hit by a suppliers problem: https://community.particle.io/t/photon-manufacturing-shipping-update/12275
                    • epierreE epierre
                      // PIN Radio
                      uint16_t lastlux;
                        sendVoltage();
                       delay(SLEEP_TIME);
                      	int battPct = 1 ;
                      AWIA
                      AWIA
                      AWI
                      @epierre this sounds really weird. The delay() you used in this sketch does not sleep anything but just takes an active break. Can you measure the supply voltage on vcc to determine what is happening?
                      • epierreE
                        epierreE
                        epierre
                        voltage was made through the ftdi...
                        I'll check again, but an interresting result, the unit with sending problems works well when used with the amplified nrf24l !!! ??? !!!
                        I've plugged it too with a 4000mAh LiPo battery I just received. I'll try later to play with sleep or delay
                        2015-07-09 15:14:04 15 10 1 0 38 4.128
                        2015-07-09 15:14:04 15 10 1 0 39 0.001298
                        2015-07-09 15:14:05 15 11 1 0 38 4.524
                        2015-07-09 15:14:06 15 11 1 0 39 0.003894
                        2015-07-09 15:14:06 15 255 3 0 0 89
                        • epierreE epierre
                          AWIA
                          AWIA
                          AWI
                          Are you powering or measuring the unit from ftdi? You should only use the on-board power supply.
                          • epierreE
                            epierreE
                            epierre
                            #33
                            since I have 2 units, I have one on battery/solar panel and the other with issues on radio through ftdi else I couldn't see what it had to display...
                            I'm off for a week, I'll do further testing after.
                            Can you reproduce some part of the delay/speel issue ?
                            • epierreE
                              epierreE
                              epierre
                              @awi @ceech what test should I do about those units:
                              • delay test: what kind? what to watch ?
                              • sleep test: what kind? what to watch ?
                              • radio issue on one of the boards working only with amplified board, not with small one.
                              The good news it although they pollute the radio by sending infos every 30s, they are still alive alone with the sun one week after.
                              • epierreE epierre
                                C
                                C
                                ceech
                                @epierre Try comparing the two boards side by side. You'll get an idea where the problem is.
                                • epierreE
                                  epierreE
                                  epierre
                                  #36
                                  @ceech do you mean on SW or HW side ?
                                  HW:
                                  • I cannot plug the standard radio in one, only amplified works with it
                                  • same solar pannel 1W
                                  • different batteries, one is LiPo, the other is LiOn, but same behavior on delay/sleep seen on both
                                  • same lux sensor
                                  SW: they run the same software
                                  any idea ?
                                  • epierreE epierre
                                    HW:
                                    • same lux sensor
                                    any idea ?
                                    C
                                    C
                                    ceech
                                    @epierre Not enough power for the amplified radio, probably. Try adding bigger capacitor. In the hundreds of uF region.
                                    • epierreE
                                      epierreE
                                      epierre
                                      @ceech are the radio 3.3V or not ? why should I need a capacitor and between what parts ?
                                      • epierreE epierre
                                        AWIA
                                        AWIA
                                        AWI
                                        @epierre I quess what @ceech meant is that the on board power supply is not equiped to power the amplified radio. I you put a large capacitor on the power lines (near to the radio) it will handle the power better.
                                        I am still confused as to the problem you are having with the delay. I am able to reproduce your > 30second problem and it is driving me nuts. When I execute the 'original' sketch (including MySensors) it is working fine with gw.sleep() and times longer than 30 secs.
                                        i will do some additional measurements...
                                        • epierreE
                                          epierreE
                                          epierre
                                          @AWI @ceech I have tried this:
                                          -I have removed the mysensor debug mode on the sensor
                                          • I have removed the 4 x gw.send in the sendVoltage
                                          For a sleep time of 31-32 this is fine , start to fail at 33...
                                          Batt: 4.07V ; 0.00A
                                          Solar: 0.84V ; 0.00 A; charge: No
                                          BattPct: 81%
                                          @AWI the one with amplified has a 4000mAh Lipo and the radio is perfect. Anyway simple radio does not work with it.
                                          12.5k
