  3. $8 Lamp (Outlet) "Smart Plug" Module
109 Posts 34 Posters 121.1k Views 13 Watching
  • Mohsin HassanM
    Mohsin HassanM
    Mohsin Hassan
    any possibility of including a push button to manually trigger the switch on and off as well?
    And if possible update Vera on the status change.
    This way i can make it Wife safe and not get kicked out of the house...
    I'm not good with coding but if someone can point me in the right direction please...
    petewillP 1 Reply Last reply
    • sundberg84S
      sundberg84S
      #54
      There is a scetch in mysensors lib doing this. Relayaccuatorwithbutton or something. Download the examplescetches and have a look: http://www.mysensors.org/build/relay#relaywithbuttonactuator-example @Mohsin-Hassan
      • sundberg84S
        sundberg84S
        @petewill @Moshe-Livne . Coil activates when i try with a 9v battery, so either bad/cheap relays or to weak power plug. All measures +5v but its not enough. Ill order some new relays.
        Moshe LivneM petewillP 2 Replies Last reply
        • sundberg84S sundberg84
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @sundberg84 IMHO 9v will fry the relay. max voltage is 5.5v if my failing memory serves. depends on your relay, naturally but this is the most common one. have a look at the datasheet https://www.ghielectronics.com/downloads/man/20084141716341001RelayX1.pdf
          yes it is 5.5v - nominal 5v, max current is 110%. I am sure it can sustain 6 but 9v will be really pushing it IMHO
          • sundberg84S
            sundberg84S
            It was only to test coil failure and see if it was a power issue :)
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @sundberg84 A self fulfilling prophecy :-)
              • Mohsin HassanM Mohsin Hassan
                petewillP
                petewillP
                petewill
                We are discussing this over here: http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
                You want to be careful you use the right transformer so you don't burn your house down. :) The wife probably wouldn't appreciate that.
                I really want to do this too. I'm just waiting for the experts to weigh in on which transformer is safe.
                  petewillP
                  petewillP
                  petewill
                  So strange that it's not working. What is the power rating of your 5V transformer? Do you have a picture of your set up?
                  • sundberg84S
                    sundberg84S
                    #61
                    I dont reallt wants to admit it...
                    Well, I ordered the 5v relay from ebay (i have the reciept!) and looking at petewill video it says SRD-05VDC-
                    Looking at mine it says SRD-12VDC so probalby the sent me a 12v relay...
                    New one will arive soon i hope :) Thank you for the help and sorry for clogging the thread.
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @sundberg84 that makes so much sense! And its not even your fault! :-)
                        petewillP
                        petewillP
                        petewill
                        @sundberg84 That's good news! Unfortunately you have to wait for new one but at least it's an easy fix!
                        • petewillP petewill
                          @sundberg84 said:
                          Hi @petewill!
                          I made this :) Great video :+1:
                          I think i get bad reception or something because it works the first 5-6 times and then nothing...
                          This could also be a power or a wiring issue. But, the antenna is an easy modification so it wouldn't hurt to try this first. Another test is to move the device closer to your gateway. If it still stops after 5-6 times then it probably isn't communication issues.
                          In the end you describe an cat5 wire added as antenna because of bad reception.
                          Do you remove the plastic/shielding so its just copper?
                          Im afraid to short anything out with a long uncovered antenna if thats the case...
                          No, I left the shielding on the wire. Sorry, I should have specified that.
                          and if i hear you right its 3,28 inches which should be 33,31200 millimeters on the antenna?
                          I think 3.28 inches is 83.312 millimeters (at least that's what google says it is).
                          H
                          H
                          hyla
                          @petewill
                          Just out of interest: how did You come up with the length for the antenna?
                          I remember vaguely that You can calculate the length if You know the
                          used frequency but You connect Your wire to an already existing PCB-Antenna...
                          Christoph
                          • H hyla
                            @petewill
                            Christoph
                            petewillP
                            petewillP
                            petewill
                            @hyla I actually recently did a separate video on how I do this with a little more explanation. If you're interested it's here:
                            https://youtu.be/NpMnauHeR7Y
                            In summary, I measured the length of the existing antenna on the PCB then added additional wire to get it up to the required length for the 2.4GHz range (4.92 in).
                            barduinoB 1 Reply Last reply
                            • H
                              H
                              hyla
                              Thanx :)
                              Meanwhile I did some research too. The formula (as You all know :) ) is:
                              Lambda (m) = c(m/s) / f(1/s) with
                              c= 299711000 m/s
                              f= 2.400.000.000 hz
                              which comes down to 0.1248795833333333 m or roughly 4.92 in
                              The 1.64 in that are used on the PCB are actually Lambda/3.
                              Nicely done, Pete :)
                              C.
                              • sundberg84S
                                sundberg84S
                                #67
                                @petewill
                                Now i got three working relays thanks to you, so again, great video!
                                Wanted to thank you and also show my sollution.
                                I hade some 433mhz cheap (not good working) relays with perfect case i could re-use:
                                The case had a status-led and a switch i use as well.
                                petewillP m26872M D 3 Replies Last reply
                                  @petewill
                                  petewillP
                                  petewillP
                                  petewill
                                  @sundberg84 Cool! That's nice to have a case like that.
                                    @petewill
                                    m26872M
                                    m26872M
                                    m26872
                                    wrote on last edited by m26872
                                    #69
                                    @sundberg84
                                    Nice! That one deserves its own project thread. I think we're many interested in the details.
                                    • Ivan ZI
                                      Ivan ZI
                                      Ivan Z
                                      This is may realisation
                                        barduinoB
                                        barduinoB
                                        barduino
                                        Hi @petewill
                                        I've tried this and had inconclusive results rather then a significant extended rage. Not sure what I'm doing wrong or if it's the quality of my RF module.
                                        I've used some wire (8.33 cm) I had left over but its not one solid copper wire, its has many "strings" inside. In your experiment did you use one solid copper wire and can this influence this hack?
                                        • barduinoB barduino
                                          Hi @petewill
                                          petewillP
                                          petewillP
                                          petewill
                                          @barduino I am using solid copper cat5e wire. I don't know much about antennas but it may change the behavior. Do you have any old cat5 that you can cut and test with?
