  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 590.5k Views 69 Watching
  • YveauxY Yveaux
    @jemish yes
    J
    J
    jemish
    @Yveaux where may I can buy it?
    • J jemish
      @jemish Depends on where you live. I bought mine from Conrad, and I know Farnell and Mouser also sell it.
      Just google for some local suppliers.
      • petewillP petewill
        Does anyone know of any 120V AC to 5V DC transformers that are safe to put in a wall electrical box? I have been using old cell phone chargers for most of my projects but I was recently pondering putting something right in the wall. Since shipping can take so long I thought I'd ask now before I even start on the project.
        I did some searching and couldn't find anything so I thought I'd ask the experts here.
        Thanks in advance!
        EDIT 9/7/2016
        Watch out for Fakes! Read more here: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers/355
        If in doubt you can get them directly from the vendor here: http://www.hlktech.net/product.php?CateId=10
        EDIT 12/28/2015
        After MUCH discussion on this here are the findings of this thread (as of now):
        Here is the diagram for how things should be wired:
        These are the parts I ordered. I haven't tested any of these parts yet as this project has been put on the back burner for now :(. I am in the USA so this is spec'd for 120 VAC. If you're using 240 you will need to change the size of the Varistor but everything else should be fine for 240.
        Also, see these posts for more discussion/ideas if interested:
        http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board
        http://forum.mysensors.org/topic/2488/in-wall-pcb
        Varistor for 120VAC - http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
        73°C Thermal Fuse - http://www.ebay.com/itm/221560426284?_trksid=p2057872.m2749.l2649&var=520415979885&ssPageName=STRK%3AMEBIDX%3AIT
        250V 300mA Slow Blow Fuse - http://www.ebay.com/itm/111433875797?_trksid=p2057872.m2749.l2649&var=410420838583&ssPageName=STRK%3AMEBIDX%3AIT
        HLK-PM01 - http://www.ebay.com/itm/351418782712?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
        Pete
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @petewill @didi found a cheaper source:
        http://www.tme.eu/en/details/gs05e-usb/mains-power-supplies/mean-well/
        shipping to the US 9.90. still ridiculously expensive but not as bad as mouser
        petewillP 1 Reply Last reply
          @Moshe Livne: interesting. I didn't know that tme has it. They have nice enclosure too, like those for wall ac adapter http://www.tme.eu/en/katalog/enclosures_100431/#id_category=100628&s_field=artykul&s_order=ASC&page=1
          I live in EU. And for shipping I think they are good, regarding Rs, farnell, and mouser too. But not the same catalog unfortunately.
          • scalzS scalz
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @scalz these are new i think and beibg propagated to shops. Every time I search i get more....
            • DidiD
              DidiD
              Didi
              Powersupplies arrived :smiley:
              Moshe LivneM 2 Replies Last reply
              • DidiD Didi
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @Didi sharpening your knives and putting the plier in the fire?
                  #85
                  aaaaaaah, you are lucky, I have not received mine yet!!!
                  I am thinking about something for OVP and OTP:
                  • at my job we use MCP9509 for OTP. As OTP is for output load (and not for input I think), it could be possible to use MCP9509 and P Mosfet to cut off the load if any temp problems occurs. I think it could be sufficient like this.
                  • for OVP, why not using a varistance at the input??? And then if a problems, your fuse in your electrical service box would blow.
                  I think this module has others protection.. so maybe it could do the job. I am not sure but like this I think it couldn't burn. It is just an idea as I am not expert. But can't wait to see how it is inside!!!
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    Mine arrived too. But I don't have equipment / knowledge to test it properly. So I will go for "real-life test". The wall boxes / wires here are fire-proof (and placed into brick walls), so the risk of real fire is reduced.
                    And I'm running my Arduino-dimmers for 6 months now, all powered by really cheap phone charges, so hopefully these modules will be a bit safer ;-)
                    ESP8266 GW + mySensors 2.3.2
                    Alexa / Google Home
                    • rvendrameR rvendrame
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @rvendrame would be interested to see how you wire everything together
                      • Moshe LivneM Moshe Livne
                        petewillP
                        petewillP
                        petewill
                        Cool, thanks!
                        @Didi can't wait to hear how they work! That was fast shipping!!
                        • B
                          B
                          Bertb
                          I am new here and decided to join this forum, because of this interesting discussion.
                          Some weeks back, I was looking for a cheap AC-DC converter and ran into the Hi-Link modules. The have very nice specs, but I discovered that there are no stamps to prove it.
                          I too plan to bring an offer to the gods of AC-DC, so I will build a module into a safe box and see what happens when I start annoying it.
                          I'd like to finish for now with a remark to rvendrame, if I may:
                          It is true that stone is very difficult to ignite, but fire and heat also melts the plastic coating of the elektric wires and this can lead to high currents that are just not high enough to blow the fuse in the mains fusebox and this can ultimately lead to fire elsewhere in your house.
                          Regards,
                          Bert
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            @Bertb, thanks for the advise!
                            Alexa / Google Home
                            • A
                              Atomfire
                              I have also bought the Hi-Link modules, 10 arrived today, they seem very well built, but I have yet to try them.
                              • Q
                                Q
                                Qu3Uk
                                I got some hi-link modules a while back on a "I might need these in the future" type deal.
                                I was wondering though how to protect the connections. I got some fuses+pcb holders to add extra protection however there is going to be at least 4 points which will be exposed.
                                Can I just cover the joints with hot glue to stop them from making contact with anything? Call me paranoid but I like to be extra safe.
                                T J 2 Replies Last reply
                                • Q Qu3Uk
                                  ThinkPad
                                  @Qu3Uk For covering solder connections you can use 'heatshrink'. Kind of 'plastic' tubes that you put around a wire, apply heat (keep a lighter/match underneath (not in the flame) for example) and it shrinks around the connection.
                                  See also https://en.wikipedia.org/wiki/Heat-shrink_tubing
                                  • Q Qu3Uk
                                    J
                                    J
                                    Jan Gatzke
                                    @Qu3Uk You could protect the high voltage part of the circuit by mounting a plastic plate under the pcb using some spacers and screws. This way it would be impossible to touch the dangerous spots. I would not recommend hot glue because you never know how well it isolates. I don't think you will find electrical specs for hot glue. ;)
                                    Q 1 Reply Last reply
                                    • J Jan Gatzke
                                      Q
                                      Q
                                      Qu3Uk
                                      @Jan-Gatzke Ah yeah that's probably a neater option as well I think. Sure I can find something suitable like that.
                                      I have heatshrink but I just figured it wouldn't 100% cover the solder joints on the PCB.
                                      • rvendrameR
                                        rvendrameR
                                        rvendrame
                                        @Qu3Uk , is a small plastic box a option? Maybe some 3D-printed, with some ventilation holes on two sides, as small as the PCB + components?
                                        Alexa / Google Home
                                        • Q Qu3Uk
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @Qu3Uk there is something called liquid tape. It's expensive.... Cool stuff though
