  3. PhoneyTV for Vera is Here!
34 Posts 6 Posters 31.8k Views 3 Watching
  • 5546dug5
    5546dug5
    5546dug
    Should also tell you I use ui5 in my veras case it makes a difference and I can toggle the switch off and on in my Device page but no Phoney TV changes.
    • 5546dug5 5546dug
      @BulldogLowell yes I have v3.1 So I was wrong -at least consistent!
      I have Vera controller and at the moment My Sensors serial GW is connected ,
      The vera dashboard shows node for light on and off and that is really what I want. To start the lights remotely , I think using the reset locally (d2 to gnd?) may work but only if we are there
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      then you are there...
      is it working?
      • 5546dug5
        5546dug5
        5546dug
        no it is not
        • 5546dug5
          5546dug5
          5546dug
          @BulldogLowell I see in v3.1 pin d2 is called ' button pin' and is an' input' and 'pullup'
          (understand it is for the pushbutton use but even then it is only for a few sec. in my setup.)
          Also there is d13 defined as for the relay and used with the radio could that be an issue?
          How is the controller/GW telling the Phoney TV to change states? Do I need to run a wire from d2 (?) to gnd/vcc to create an interupt?
          I don't really need the button, but I will leave it there
          • 5546dug5
            5546dug5
            5546dug
            @BulldogLowell Just noticed your post is v3.1 lib 1.4.1 and I have lib 1.4
            That might be why I can't control from Vera ....then there is that d2 interrupt connection.
            • 5546dug5 5546dug
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @5546dug
              hmmm, looking at the code I posted I see why you have a problem.
              Try this:
               * PhoneyTV v3.1.1
               * This Sketch illuminates 6 sets of LED's in a random fashion as to mimic the
               * light eminating from a television.  It is intended to make an empty home,
               * or an empty section of a home, appear to be occupied by someone watching
               * TV.  As an alternative to a real television left on, this uses less than 1%
               * of the electrical energy.
               * With the use of the MySensors plugin and gateway, PhoneyTV is intended to
               * be used with a controller (e.g. Vera or Raspberry PI).
               * Sketch does not use any delays to create the random blinking as a way to
               * assure that communication back to the gateway is as unaffected as possible.
               * You can adjust the length of the blink interval and its "twitchyness" by
               * modifying the random number generators, if you prefer more/less 'motion' in
               * in your unit.  The lines are highlighted in the code, play around to create the
               * random effect you like.
               * Sketch takes advantage of available PWM on pins 3, 5 & 6 using the white/blue LEDs
               * to allow fluctuations in the intensity of the light, enhancing the PhoneyTV's
               * realistic light effects.
               * Created 12-APR-2014
               * Free for distrubution
               * Credit should be given to MySensors.org for their base code for relay control
               * and for the radio configuration.  Thanks Guys.
               * 29-May-2014
               * Version 2:  Simplified the code, removing all redundant relay setup from original
               * code.  Added an on/off momentary pushputton option to be set up on pin 2.  Inproved
               * the dark dips for longer duration (can be configured) at intervals.
               * 6-Jun-2015
               * Version 3.1
               * Updated for MySensors V1.4.1
               * Contributed by Jim (BulldogLowell@gmail.com) Inspired by Josh >> Deltanu1142@gmail.com
              #define SKETCH_NAME "PhoneyTV"
              #define SKETCH_VERSION "3.1.1"
              #define RADIO_RESET_DELAY_TIME 20
              #define BUTTON_PIN  2  // Arduino Digital I/O pin number for button
              #define CHILD_ID 1   //
              #define RADIO_ID 5  //AUTO
              #define DEBUG_ON
              #ifdef DEBUG_ON
              byte ledPin3 =  3;      // White using PWM
              byte ledPin4 =  4;      // Red
              byte ledPin5 =  5;      // Blue using PWM
              byte ledPin6 =  6;      // Blue using PWM
              byte ledPin7 =  7;      // Green
              byte ledPin8 =  8;      // White (No PWM)
              Bounce debouncer = Bounce();
              byte oldValue = 0;
              boolean state = false;
              boolean oldState = false;
              int dipInterval = 10;
              int darkTime = 250;
              unsigned long currentDipTime;
              unsigned long dipStartTime;
              unsigned long currentMillis;
              byte ledState = LOW;
              unsigned long previousMillis = 0UL;
              byte led = 5;
              unsigned long interval = 2000UL;
              int twitch = 50;
              int dipCount = 0;
              int analogLevel = 100;
              boolean timeToDip = false;
              boolean gotAck=false;
                SERIAL_START(115200);
                pinMode(ledPin3, OUTPUT);
                pinMode(ledPin4, OUTPUT);
                pinMode(ledPin5, OUTPUT);
                pinMode(ledPin6, OUTPUT);
                pinMode(ledPin7, OUTPUT);
                pinMode(ledPin8, OUTPUT);
                pinMode(BUTTON_PIN, INPUT_PULLUP);
                debouncer.attach(BUTTON_PIN);
                debouncer.interval(50);
                gw.begin(incomingMessage, RADIO_ID, true, 0);  // configured as a repeating node!!
                gw.wait(RADIO_RESET_DELAY_TIME);
                gw.present(CHILD_ID, S_LIGHT);
                while(!gw.send(msg.set(state), false))
                debouncer.update();
                byte value = debouncer.read();
                if (value != oldValue && value == 0)
                  state = !state;
                  while(!gotAck)
                    gw.send(msg.set(state), true);
                  gotAck = false;
                  DEBUG_PRINT(F("State Changed to:"));
                  DEBUG_PRINTLN(state? F("PhoneyTV ON") : F("PhoneyTV OFF"));
                oldValue = value;
                if (state)
                  if (timeToDip == false)
                    currentMillis = millis();
                    if (currentMillis - previousMillis > interval)
                      interval = random(750, 4001); //Adjusts the interval for more/less frequent random light changes
                      twitch = random(40, 100); // Twitch provides motion effect but can be a bit much if too high
                      dipCount = dipCount++;
                    if (currentMillis - previousMillis < twitch)
                      led = random(3, 9);
                      analogLevel = random(50, 255); // set the range of the 3 pwm leds
                      ledState = !ledState;
                      switch (led) //for the three PWM pins
                        case 3:
                          pwmWrite();
                        case 5:
                          pwmWrite();
                        case 6:
                          pwmWrite();
                        default:
                          digitalWrite(led, ledState);
                      if (dipCount > dipInterval)
                        timeToDip = true;
                        dipCount = 0;
                        dipStartTime = millis();
                        darkTime = random(50, 150);
                        dipInterval = random(5, 250); // cycles of flicker
                    DEBUG_PRINTLN(F("Dip Time"));
                    currentDipTime = millis();
                    if (currentDipTime - dipStartTime < darkTime)
                      for (int i = 3; i < 9; i++)
                        digitalWrite(i, LOW);
                      timeToDip = false;
                  if (state != oldState)
                oldState = state;
              void incomingMessage(const MyMessage &message)
                if (message.isAck())
                  gotAck = true;
                if (message.type == V_LIGHT)
                  state = message.getBool();
                  DEBUG_PRINT(F("Incoming change for sensor... New State = "));
                  DEBUG_PRINTLN(state? F("ON") : F("OFF"));
              void pwmWrite()
                if (ledState == HIGH)
                  analogWrite(led, analogLevel);
                  digitalWrite(led, LOW);
              • 5546dug5
                5546dug5
                5546dug
                @BulldogLowell Thanks
                I will try. 3.1.1 when I get home
                • 5546dug5
                  5546dug5
                  5546dug
                  @BulldogLowell
                  here is screen shot of error codeArduino: 1.6.5 (Windows 8.1), Board: "Arduino Nano, ATmega328"
                  Using library MySensors in folder: C:\Users\Carolyn & Doug\Documents\Arduino\libraries\MySensors (legacy)
                  Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                  Using library Bounce2 in folder: C:\Users\Carolyn & Doug\Documents\Arduino\libraries\Bounce2 (legacy)
                  C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs -IC:\Users\Carolyn & Doug\Documents\Arduino\libraries\MySensors -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Users\Carolyn & Doug\Documents\Arduino\libraries\Bounce2 C:\Users\CAROLY~1\AppData\Local\Temp\build5063782765207672318.tmp\phoney_tv_july_20_3.1.1.cpp -o C:\Users\CAROLY~1\AppData\Local\Temp\build5063782765207672318.tmp\phoney_tv_july_20_3.1.1.cpp.o
                  phoney_tv_july_20_3.1.1.ino: In function 'void setup()':
                  phoney_tv_july_20_3.1.1.ino:111:6: error: 'class MySensor' has no member named 'wait'
                  phoney_tv_july_20_3.1.1.ino:113:6: error: 'class MySensor' has no member named 'wait'
                  phoney_tv_july_20_3.1.1.ino:116:8: error: 'class MySensor' has no member named 'wait'
                  phoney_tv_july_20_3.1.1.ino:118:6: error: 'class MySensor' has no member named 'wait'
                  phoney_tv_july_20_3.1.1.ino: In function 'void loop()':
                  phoney_tv_july_20_3.1.1.ino:133:10: error: 'class MySensor' has no member named 'wait'
                  • 5546dug5 5546dug
                    @BulldogLowell
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @5546dug
                    I think you need to update your MySensors IDE.
                    • 5546dug5
                      5546dug5
                      5546dug
                      Ok I will try that also
                      • 5546dug5
                        5546dug5
                        5546dug
                        @BulldogLowell I downloaded lib 1.4.1 and just like that your code worked 100% THANKS.
                        It is something I could not have done.
                        Just a question, when in your code 3.1.1 you have a few scattered lines through out the declaration code with only // on these lines does it mean anything in particular ?
                        I couldn't find anything wrote up like the notations of /* and */ for writing comments and paragraphs .
                        • 5546dug5 5546dug
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          Adding the "//" is only a personal preference of mine to use the comment marks rather than leaving a blank line. for me, with a certain text editor that I use, it is easier to edit and not inadvertently delete some curly brace and screw up my code!
                          happy to hear you are going now, sorry about the mixup.
