Need a little help to alter my sketch
Hey everyone,
I have a few on the Mini Rboards working very well for control of a few light switches, using Vera 3 as my controller. What is driving me and the family a little crazy is how the manual light switches have to work so that they operate the Mini Rboard.
Here is my sketch:
// Example sketch för a "light switch" where you can control light or something // else from both vera and a local physical button (connected between digital // pin 14 and GND). // This node also works as a repeader for other nodes #include <MySensor.h> #include <SPI.h> #include <Bounce2.h> #define RELAY_PIN 4 // Arduino Digital I/O pin number for relay #define BUTTON_PIN 14 // Arduino Digital I/O pin number for button -A0 which is D14 #define CHILD_ID 1 // Id of the sensor child #define RELAY_ON 1 #define RELAY_OFF 0 Bounce debouncer = Bounce(); int oldValue=0; bool state; MySensor gw; MyMessage msg(CHILD_ID,V_LIGHT); void setup() { gw.begin(incomingMessage, AUTO, true); // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Relay & Button", "1.0"); // Setup the button pinMode(BUTTON_PIN,INPUT); // Activate internal pull-up digitalWrite(BUTTON_PIN,HIGH); // After setting up the button, setup debouncer debouncer.attach(BUTTON_PIN); debouncer.interval(5); // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID, S_LIGHT); // Make sure relays are off when starting up digitalWrite(RELAY_PIN, RELAY_OFF); // Then set relay pins in output mode pinMode(RELAY_PIN, OUTPUT); // Set relay to last known state (using eeprom storage) state = gw.loadState(CHILD_ID); digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF); } /* * Example on how to asynchronously check for new messages from gw */ void loop() { gw.process(); debouncer.update(); // Get the update value int value = debouncer.read(); if (value != oldValue && value==0) { gw.send(msg.set(state?false:true), true); // Send new state and request ack back } oldValue = value; } void incomingMessage(const MyMessage &message) { // We only expect one type of message from controller. But we better check anyway. if (message.isAck()) { Serial.println("This is an ack from gateway"); } if (message.type == V_LIGHT) { // Change relay state state = message.getBool(); digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF); // Store state in eeprom gw.saveState(CHILD_ID, state); // Write some debug info Serial.print("Incoming change for sensor:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(message.getBool()); } }So to use mu current light switches, I have to turn them on and then off, for the light to operate. If I only turn the switch on, the light will operate, but to operate it again I have to turn the switch off and then on again.
I have looked into a momentary switch, but to get the ones to fit are quite expensive...
Is there a way to alter the sketch to make it work better? IE can I have the sketch open the relay when the binary switch is connected, and then close the relay when it is disconnected?
thanks for your help :-)
@rvendrame thanks for that mate! I will give that a go.
So that I am clear on the understanding, I have it so that it is waiting for a change, and it needs to equal zero. So by removing the zero bit, it should just be waiting for a change. I suppose the reason for it to be waiting for both is to reduce the chance of it missing a change in value, which I could see happening, but it may not be a big deal, so I'll change the code and try it.
Thanks again for your help :-)
The original code is written for a Momentary switch. Press it and it closes the circuit driving a change of state, release it and again it changes back to an open circuit and the pin state changes again.
You have a toggle switch which when 'flipped' remains in its new state.
