  3. DHT22 lib working on 1Mhz?
15 Posts 6 Posters 8.6k Views 3 Watching
  • T
    tomkxy
    Actually, I am using the same lib.
    I found a thread in the Arduino forum which explains that it can not work in principle: http://forum.arduino.cc/index.php?topic=291695.0
    Hmmm, quite interesting that it seems to work at least in certain cases.
      Stric
      how about 2 or 4MHz if 8 is too high?
      • T
        tomkxy
        Will try and report back.
        • T
          tomkxy
          I tried it. Even on 4Mhz only the first 4 transmits show readings. Then it only returns errors.
          So it only work on 8Mhz for me.
          • T
            tomkxy
            So after 2 weeks fiddling around with the different libraries at different clock frequencies, I have some conclusions I would like to share with you.
            I tested with a ProMini and two DHT22 sensors, one from Adafruits and one from China.
            As I already reported, I had problems with clock frequencies below 8MHz with all different libraries. After switching to 8MHz, I realized another problem. Temperature readings did not change. They stayed the same value, only when I reset the ProMini I had a correct reading.
            I had this behaviour with the Adafruit and the library included in the MySensors project.
            Since yesterday evening I am testing the library from Rob Tillaart (http://arduino.cc/playground/Main/DHTLib) which is working correctly giving me correct readings.
            I am presuming that this is related to sleeping the ProMini and may be the low power mode the DHT22 is going into, I don't know...(at least in Rob's lib there is a wakeup delay which seems to address that point)
            Anyway, it seems I have at least now a working solution. I will re-try to lower the clock frequency with that library.
            Apart from that I also realized that the DHT library included in MySensor will perform a sensor read for a call to readTemperature and readHumidity which means that you would need to put a delay of 2s between a readTemperature and readHumidity. Since the sensor delivers the values in a "single" read this is rather unfortunate for battery powered sensor.
              If it verifies ok you could perhaps create a pull request with the new library and update the DHT example sketch accordingly?
              • T
                tomkxy
                Ok. I'll do that. Might however take a couple of days.
                • T
                  tomkxy
                  I retried again with Rob Tillaart's DHT22 library whether I can reduce clock frequency.
                  The results:
                  • 1 MHz -> wrong readings, like -100 C
                  • 2 MHz -> "
                  • 4 MHz -> from time to time wrong reading
                  Overall, I would state that you need to run the DHT22 with the libraries I tested on 8 Mhz.
                    Ok, thanks for the update.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @tomkxy
                      Are you compiling for the different clock frequencies in arduino? Or is it compiled for 8/16Mhz target, and then you switch frequency in the sketch?
                      • T
                        tomkxy
                        I used the Sensebender sketch which switches in the sketch.
                        • T
                          tlustoch
                          Sorry for a stupid question, but how do you run at 1 Mhz?
                          See http://www.mysensors.org/hardware/micro#comment-2196823229
                          Are you able to switch to 1 Mhz at runtime?
                          • T
                            tomkxy
                            Have a look at the sensebender sketch http://www.mysensors.org/hardware/micro#example-sketch
                                highfreq = false;
                            The clock frequency is scaled down by software.
