  3. Temperature Sensor problem
15 Posts 7 Posters 8.1k Views 2 Watching
  • V
    V
    vampircik
    You need to change the cable? I am also pleased to work with you.
    tbowmoT 1 Reply Last reply
    • V vampircik
      tbowmoT
      tbowmoT
      tbowmo
      @vampircik
      Have you set the correct board type in arduino? Could look like the baudrate doesn't match..
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @vampircik
        it could also be as simple as the sketch in the library does not by default enable serial communication, nor does that sketch output any Serial data!!
        try inserting the lines I added below and make sure that your baudrate on your serial Monitor is the same (115200bps)
          Serial.begin(115200);  //<<<<<<<<<<<<<<<<<<<<<  Add This Line
          // Startup OneWire
          sensors.begin();
          // Startup and initialize MySensors library. Set callback for incoming messages.
          gw.begin();
          gw.sendSketchInfo("Temperature Sensor", "1.0");
             gw.present(i, S_TEMP);
          Serial.println("Yeah!! now it works!!");
        @Admin
        Entire library sketch:
        // Example sketch showing how to send in OneWire temperature readings
        #include <OneWire.h>
        int numSensors=0;
        boolean receivedConfig = false;
        boolean metric = true;
        MyMessage msg(0,V_TEMP);
          // Startup OneWire
          sensors.begin();
          gw.begin();
          // Process incoming messages (like config from server)
            float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
            if (lastTemperature[i] != temperature && temperature != -127.00) {
              gw.send(msg.setSensor(i).set(temperature,1));
          gw.sleep(SLEEP_TIME);
        • HeinzH
          HeinzH
          Heinz
          Yep I agree, looks like wrong baudrate.
          • V
            V
            vampircik
            Arduino: 1.6.3 (Windows 8), Плата"Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
            Изменена опция сборки, пересобираем все
            sketch_jul26d.ino:2:3: error: invalid preprocessing directive #\
            sketch_jul26d.ino:3:3: error: invalid preprocessing directive #\
            sketch_jul26d.ino:4:3: error: invalid preprocessing directive #\
            sketch_jul26d.ino:5:3: error: invalid preprocessing directive #\
            sketch_jul26d.ino:7:3: error: invalid preprocessing directive #\
            sketch_jul26d.ino:8:4: error: invalid preprocessing directive #\
            sketch_jul26d.ino:9:1: error: stray '' in program
            sketch_jul26d.ino:10:1: error: stray '' in program
            sketch_jul26d.ino:11:1: error: stray '' in program
            sketch_jul26d.ino:13:1: error: stray '' in program
            sketch_jul26d.ino:15:1: error: stray '' in program
            sketch_jul26d.ino:16:1: error: stray '' in program
            sketch_jul26d.ino:20:1: error: stray '' in program
            sketch_jul26d.ino:35:3: error: stray '' in program
            sketch_jul26d.ino:36:6: error: stray '' in program
            sketch_jul26d.ino:41:1: error: stray '' in program
            sketch_jul26d.ino:50:3: error: stray '' in program
            sketch_jul26d.ino:53:5: error: stray '' in program
            sketch_jul26d.ino:56:5: error: stray '' in program
            sketch_jul26d.ino:59:7: error: stray '' in program
            sketch_jul26d.ino:60:7: error: stray '' in program
            sketch_jul26d.ino:9:2: error: 'u0437' does not name a type
            sketch_jul26d.ino:10:1: error: 'Wire' does not name a type
            sketch_jul26d.ino:11:1: error: 'DallasTemperature' does not name a type
            sketch_jul26d.ino:12:1: error: 'MySensor' does not name a type
            sketch_jul26d.ino:13:2: error: 'u043f' does not name a type
            sketch_jul26d.ino:14:2: error: 'INT' does not name a type
            sketch_jul26d.ino:15:2: error: 'u043b' does not name a type
            sketch_jul26d.ino:16:2: error: 'u043b' does not name a type
            sketch_jul26d.ino:18:1: error: 'MyMessage' does not name a type
            sketch_jul26d.ino:20:2: error: 'u043d' does not name a type
            sketch_jul26d.ino:41:2: error: 'u043d' does not name a type
            Ошибка компиляции.
            Это сообщение будет содержать больше информации чем
            "Отображать вывод во время компиляции"
            включено в Файл > Настройки
            • V
              V
              vampircik
              • V
                V
                vampircik
                int numSensors=0;
                // Startup OneWire
                sensors.begin();
                gw.begin();
                • BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  "Check wires" error when you don't have the NRF radio connected properly.
                  • V
                    V
                    vampircik
                    I connected properly checked.
                    • sundberg84S
                      sundberg84S
                      I have seen "check wires" a 100 times and every time it is because I missed in the wiring.
                      Double and tripple check wiring in both arduino and radio side.
                      If its correct, try another radio, change wires or even try another arduino.
                      Good luck.
                        And make sure you haven't enabled SOFTSPI earlier and forgot to change it back.
                        • V
                          V
                          vinzouille
                          I had the check wires problem and this topic was helpful thanks a lot :)
                          Now I don't have this error message anymore but I don't have any message at all, so my question is am I supposed to have any message while running my temperature sensor on serial monitor ?
                          • V
                            V
                            vinzouille
                            I found the solution this was my NRF that didn't work
