  3. Which is better: RFM69 or NRF24L01+?
37 Posts 13 Posters 48.5k Views 7 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @rvendrame
    the new GW device that I work on, has sockets / pads for both radio versions (rfm69 and nrf24). And in theory it should have enough power to control both radio networks at the same time.
      I agree with you too. RFM is very good quality and @tbowmo GW will be sooo great! atsam is little beast and our GW will be much much powerful! Like some people I prefer not using wifi for GW (security question for me), usb is much more secure I think. And for radio, RFM is a killer!
      • rvendrameR
        rvendrameR
        rvendrame
        @tbowmo , in that case we need to adopt the gw sketch to run both radios in parallel right?
        And @Francois , by running two distinct GWs, I guess you don't have to worry about duplicate node IDs, right?
        Thank you guys!
        ESP8266 GW + mySensors 2.3.2
        Alexa / Google Home
        • FrancoisF
          FrancoisF
          Francois
          @rvendrame I give all my nodes static ID's and this is working for me in Domoticz
            If you were starting from scratch, would you still put both radio types in your system, or would you put all of one type only?
            • FrancoisF
              FrancoisF
              Francois
              @rvendrame I will only go for the RFM69. When I start playing with the Mysensor project Hek only had only support for the NRF24l01+. Once they port the library over to support the RFM69 I stop using the NRF24L01+. Luckly I don't have big installation on the NRF24 radio.
              • tbowmoT
                tbowmoT
                tbowmo
                @rvendrame
                Yes, there will be some adjustments to code here and there.. But first the prototypes needs to be build, before we can make code for it.. (Also, I don't have any rfm69 hardware at the moment..)
                • FrancoisF Francois
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @Francois darn, by now i can wire the nrf from memory. Now to learn new wiring....
                  The power consumption in idle is still something to consider
                  • Moshe LivneM Moshe Livne
                    According to JeeLabs, " The RFM69 draws 0.1 µA in sleep mode." Say, isn't that lower than for the NRF24L01+?
                    Or, by "idle," were you referring to something else?
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @NeverDie I mean in reality... people here measured 30uA compared to 3uA in similar nrf setup. could be the result of many things, might be just a kink that has to be ironed in the software.
                        I haven't measured it myself, so I'm very open to everybody's data. Hopefully more people will post results of their own measurements and a pattern will emerge suggesting what's truth.
                          shabba
                          Just curious if anyone has tested the power consumption yet? But to be honest only one of my sensors is battery powered so I'm not overly concerned :-)
                          • fetsF
                            fetsF
                            fets
                            @francois where did you get your antenna for rfm69. DIY ?
                              mrmin24
                              wrote on last edited by mrmin24
                              Anyone got the Ethernet gateway going with RFM69? I am struggling and I am not sure, but I think there are a few issues in the V1.5 for RFM69.
                              @NeverDie, a 78mm piece of wire works well for antenna.
                              *Edit - Sorry, this is assuming 915MHz. See https://www.easycalculation.com/physics/electromagnetism/antenna-wavelength.php and choose quater wavelength
                              • M mrmin24
                                Does it make any difference what the wire diameter is? I'm assuming the thicker the better?
                                  mrmin24
                                  @NeverDie Probably, but I don't think you should stress too much. The power is not "that" high.
                                  See http://ham.stackexchange.com/questions/140/good-wire-for-wire-antenna for what seems like valid response.
                                  • M mrmin24
                                    Right, I'm just not t sure how to account for the "skin effect".
                                    • FrancoisF
                                      FrancoisF
                                      Francois
                                      @fets yes ons DIY. I am using 433mhz radio and I just wound the wire around screwdriver the thickness of the wire is 5.8mm and it is working for me.
                                        #24
                                        Is it just bare copper, or does it have some kind of thin insulator on it like magnet wire has?
                                        • FrancoisF
                                          FrancoisF
                                          Francois
                                          @NeverDie it is just bare copper wire.
