  3. PCB Boards for MySensors
56 Posts 24 Posters 68.8k Views 23 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @meanpenugin first post probably needs a slight update on available boards :) And ongoing projects..
      stevenwatson011
      Are thses PCB board available as stock board?
      • tbowmoT
        tbowmoT
        tbowmo
        @stevenwatson011
        Only the sensebender is available as official board (described in the thread "Minimal design thoughts")
        Some of the other boards are supplied with manufacturing details, so you can order your own pcb's and populate the boards yourself.
        • Frank HerrmannF
          Frank HerrmannF
          Frank Herrmann
          wrote on last edited by Frank Herrmann
          May you want to add my Boards?
          XAmbi mini kid pro (tested with NRF24L01+ & mysensors)
          https://oshpark.com/shared_projects/ezK4aEQd
          http://forum.mysensors.org/topic/1593/xambi-kid-mini-pro-prototype/6
          XAmbi kid mainboard (RFM12B)
          https://github.com/xpix/XAmbi/tree/master/Xambi_kids/xambikid_mainboard
          XAmbi kid sensorboard
          https://github.com/xpix/XAmbi/tree/master/Xambi_kids/xambikid_sensorboard
            smokey1300
            wrote on last edited by smokey1300
            I am trying to find a new sensor board design and I came across this one on OSH Park. Only thing is I don't who's board design or what documentation goes with it. Anyone have any ideas which one it is? Could it be Mean Penguin version?
            https://oshpark.com/shared_projects/uXIff7XO
            • C
              C
              Cory
              @smokey1300
              This is a board that I designed. I didnt think anyone would actually stumble on it. :-)
              I'm not sure about any mean penguins, but here is some extra documentation.
              https://docs.google.com/document/d/1WtImjSbQPctq8rUAT6k1CyUgJHuo2WDs6bO2HfEr8NI/edit?usp=sharing
              Let me know if you want more info. I have built 3 sensors with these boards with no issues.
              TD22057T C rborerR 3 Replies Last reply
              • C Cory
                @smokey1300
                TD22057T
                TD22057T
                TD22057
                @Cory Thanks for the docs - I was looking at your board as well because it's the closest thing to what I think I need and the extra docs help a lot. What software did you use to do the design? I'm thinking about using your design as a baseline with some small changes like:
                • slightly larger board with corner holes for easier mounting
                • support for the ATSHA204 message signing chip
                I've never done a PCB design before but it looks like a fun project...
                  smokey1300
                  Thanks for the reply Cory. I like the design only thing is I have a hard time soldering SMT components. I might order them and tough it out anyways. I appreciate the documentation as it helps a lot. Do you have the schematic too?
                  • C
                    C
                    Cory
                    I did the design in Eagle after watching some youtube videos. OSHPark has a design rules file and can accept the eagle file type without exporting.
                    This board was my very first (second rev to fix some issues). Here is a link to the files if you want to modify it.
                    https://drive.google.com/file/d/0B1btbQ_slGM4YzZQTGZHZ19NWEk/view?usp=sharing
                    Personally I think it would be better to start from scratch in order to get the learning.
                    My goal was to get the board as small as possible (to reduce cost). I have a smaller one with the radio inside the arduino footprint, but I haven't tested it or shared it yet.
                    S 1 Reply Last reply
                    • C Cory
                      smokey1300
                      @Cory Great I'll check it out. Do you power any with 3v battery? If so how long does it last? Thanks again.
                      • J
                        J
                        jemish
                        any PCB available for fan control using dimmer with rotarry switch?
                        I just know only circuit diagram. but I don't try that.
                        • C Cory
                          @smokey1300
                          C
                          C
                          chickey
                          @Cory What size SMD components are used for the caps and resistors?
                          Just ordered 9 boards to test with and ordered a lot of SMD components but then realised they do them in different sizes, SMD is very new to me. Most of what i've ordered are 603.
                          Great looking boards from OSH Park, seem great quality.
                          • GertSandersG
                            GertSandersG
                            GertSanders
                            Below you will find a link to a board I made and now use with the MySensors library and EasyIOT.
                            https://oshpark.com/shared_projects/qnkNIMZx
                            This is a version with the small nRF24L01+. I'm now working on a version using the longer board version (with SMA antenna).
                            • GertSandersG GertSanders
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @GertSanders I've now used three of these boards with Domoticz (running on a Synology NAS). Next test is running Domoticz on Raspberry Pi 2 with these sensors.
                              • FotoFieberF
                                FotoFieberF
                                FotoFieber
                                @GertSanders
                                Nice design! :+1:
                                I think I will purchase this one instead of my design next time I need some mysensor nodes...
                                • TD22057T
                                  TD22057T
                                  TD22057
                                  FYI for anyone looking to get PCB's made, here is a price comparison site that shows you various manufacturers and what they'll charge you for different sized boards. Prices are crazy cheap these days...
                                  http://pcbshopper.com/
                                  • GertSandersG
                                    GertSandersG
                                    GertSanders
                                    @hek Since the OP has not been online the past 5 months, is it possible for someone else to take over editing this post of PCB's for MySensors ? I think you were making a site to collect open source hardware, is that a possible avenue to publish design compatible with MySensors ?
                                      Yes, the idea was to have a openhardware.io as a place for publishing open hardware accompanying the mysensors site/forum.
                                      The emryo is still on my computer but I got stuck trying to visualize gerbers in 3d and doing SSO integration with the mysensors forum. Then some other projects came in the way... and summer.
                                      I've picked up the gerber viewer ideas again last week.. This time I will probably do it as a NodeBB forum plugin to get integration more seamless with the community. Where you can drop gerber files directly in post or link them from your github repository.
                                      I would also need some new mechanism and/or layout to make the open hardware- and sensor projects easier to find here on the forum.
                                      Would've been nice to do a couple of weeks fulltime on this project to get there quickly.. But still have to take care of my dayjob :sweat:
                                      Meanwhile I suggest you post your project in a separate thread and reply here with a link until I sort things out in my mind and plugins. :)
                                      • AnticimexA
                                        AnticimexA
                                        Anticimex
                                        Feel free to add my board as well:
                                        http://forum.mysensors.org/topic/1857/my-sensor-node-motherboard-mysensorsnode
                                        • GertSandersG
                                          GertSandersG
                                          GertSanders
                                          #31
                                          Visualising 3d gerbers is available on other sites. Why repeat the effort ? Access to the gerbers or board files would be sufficient, if accompanied by some explanation or wiki about what you can do with the provided files.
                                          As a designer I do not mind making some documentation, but storing it in an accessible location would be nice.
                                          Github comes to mind. Links to github and recommendations on a minimum set of documents (and "proven" compatibility with the MySensor library) would be totally acceptable for me, but I would like some guidelines.
