  3. Mailbox/Postbox Alert
31 Posts 8 Posters 22.6k Views 7 Watching
    @n3ro
    I'm guessing that your repeat() function is wearing out the battery.
    By the way you can take advantage of the return of sleep( ) here:
    gw.sleep(MAILBOX_FRONT_PIN - 2, CHANGE, MAILBOX_BACK_PIN - 2, CHANGE, 0);
    like this (untested):
    #include <readVcc.h>
    #define NODE_ID 21                      // ID of node
    #define CHILD_ID 1                      // Id of the sensor child
    #define MAILBOX_FRONT_PIN 2             // Arduino Digital I/O pin for button/reed switch
    #define MAILBOX_BACK_PIN 3              // Arduino Digital I/O pin for button/reed switch
    #define MIN_V 1900 // empty voltage (0%)
    #define MAX_V 3200 // full voltage (100%)
    boolean post = false;
    boolean lastpost = false;
    int oldBatteryPcnt;
    int repeat = 20;
    int trigger = -1;
    unsigned long goToSleepTime;
      gw.begin(NULL, NODE_ID, false);
      pinMode(MAILBOX_FRONT_PIN, INPUT);
      pinMode(MAILBOX_BACK_PIN, INPUT);
      digitalWrite(MAILBOX_FRONT_PIN, HIGH);
      digitalWrite(MAILBOX_BACK_PIN, HIGH);
      gw.sendSketchInfo("Mailbox Alert", "1.0");
      gw.present(CHILD_ID, S_MOTION);
      Serial.println("---------- set Mailbox empty");
      msg.set(0);
      if (millis() - goToSleepTime > 10UL) //debounce
        switch (trigger) {
          case 0:
            post = true;
            Serial.println("---------- New Mail");
          case 1:
            post = false;
            Serial.println("---------- Mailbox emptied");
          default:
            Serial.println("---------- I just woke up");
      trigger = -1;
      if (post != lastpost)
        Serial.print("---------- Send Mailboxstate ");
        Serial.println(post ? "full" : "empty");
        msg.set(post);
        lastpost = post;
        sendBattery();
      goToSleepTime = millis();
      trigger = gw.sleep(MAILBOX_FRONT_PIN - 2, CHANGE, MAILBOX_BACK_PIN - 2, CHANGE, 0);
    void sendBattery() // Measure battery
      int batteryPcnt = min(map(readVcc(), MIN_V, MAX_V, 0, 100), 100);
      if (batteryPcnt != oldBatteryPcnt)
        gw.sendBatteryLevel(batteryPcnt); // Send battery percentage
        oldBatteryPcnt = batteryPcnt;
      Serial.print("---------- Battery: ");
      Serial.println(batteryPcnt);
    n3roN
    n3roN
    n3ro
    @BulldogLowell could you please explain your changes? I don't understand everything of this :sweat:
    pimatic + MySensors + Homeduino + z-way
    https://github.com/n3roGit/MySensors_n3ro
    • F
      F
      f1dev
      @n3ro Ok, thanks! Then I learned something new today.. IRQ is only needed for receiving nodes then, like repeaters and gateways, right?
      Strange though that my circuit draws so much more current than yours. I have tested different setups, different arduinos and different radios from different suppliers with same result.
      Well, at least my mailbox are mysensored now! :smiley:
      • n3roN
        n3roN
        n3ro
        I think you need the irq only for the gw. I have a receive node without irq.
        Do you have changed fuses on your arduino?
        And remember. All this stuff is cheap China electronic.The devices can vary consume a lot of electricity.
        • F
          F
          f1dev
          Nope, havent done that yet. It´s a "stock" 3v3 pro mini. Still reading up on how to do that and how to change to MYS-bootloader, curious on how OTA-update works.
          Big thanks for your respons! :smile:
          n3roN 1 Reply Last reply
          • F f1dev
            n3roN
            n3roN
            n3ro
            @f1dev sweebe wrote a very good howto:
            http://forum.pimatic.org/topic/383/tips-battery-powered-sensors
            • F
              F
              f1dev
              @n3ro - Thanks, that was really helpfull!:smile:
              • n3roN n3ro
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @n3ro Brilliant! He recommends to take out the voltage regulator. it is easier (and works better) just to snip off one leg as described here http://www.mysensors.org/build/battery. I'll try his other mods.... hopefully now my nodes will last forever!!!!
                • Ashley SavageA
                  Ashley SavageA
                  Ashley Savage
                  quality project, been having a tinker with mixed results. used sketch from original post, but would it be possible to get a circuit diagram showing pull up locations??? bit of a beginner, but have had a few success with rolling out some power operated sensors , this is my first battery operated sensor...
                  • n3roN
                    n3roN
                    n3ro
                    No problem. I make one :) give me a day
                    • Ashley SavageA Ashley Savage
                      n3roN
                      n3roN
                      n3ro
                      • Ashley SavageA
                        Ashley SavageA
                        Ashley Savage
                        thanks for the diagram, much appreciated...
                          mathieu44444
                          Does this code still work?
                          Thank you
