OpenHab with smart door lock
What door lock?
If its zwave then I don't think OpenHab can do it as zwave locks have some encryption or similar.
Or are you wanting to use MySensors with a standard electric door strike?? In which case, have a look at one of the various "Garage Door" sketches. This should be a good base for driving a door strike... probably just change the period that the lock is disabled.
I own a door with: http://www.fuhr.de/fuhr/en/produkte/prod_tuer_881.php
According to the manual it is pretty easy to connect it to a MySensor node, but I don't think it is easy to upgrade your door with this lock and it is expensive too. ;-)
@jemish How about something like this: https://www.sparkfun.com/products/13648. It's to be used with a standard deadbolt / keys.
Al -
@jemish ,
There are thousands of locks out there which can be controlled by electricity - several examples have already been given to you.Why dont you go and research the hardware lock you think will work for you and your door and come back here with the link to it, and we can help you to control it with mySensors.
